SL34F
SL34F
    MDD(辰达半导体)
    SMAF(DO-214AD)
    肖特基二极管 电压:40V 电流:3A SMAF(DO-214AD)
SL34F 数据手册
SL32F THRU SL310F Reverse Voltage - 20 to 100 Volts Forward Current - 3.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER DIODES Features SMAF  7KHSODVWLFSDFNDJHFDUULHV8QGHUZULWHUV/DERUDWRU\ )ODPPDELOLW\&ODVVLILFDWLRQ95R+6FRPSOLDQW 0.106(2.70) 0.094(2.40) 0.063 (1.60) 0.051 (1.30)  , GHDIRUSULQWHGFLUFXLWERDUG  2SHQ-XQFWLRQFKLS  /RZUHYHUVHOHDNDJH +LJKIRUZDUGVXUJHFXUUHQW 0.146(3.70) 0.130(3.30)  FDSDELOLW\ +LJKWHPSHUDWXUHVROGHULQJJXDUDQWHHG  ℃VHFRQGVDWWHUPLQDOV 0.047(1.20) 0.035(0.90) Mechanical Data 0.008(0.20) 0.005(0.12) 0.047(1.20) 0.031(0.80) 0.193(4.90) 0.173(4.40) Case: 60$) molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.0014 ounce, 0.038 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter MDD SL32F MDD SL34F MDD SL36F MDD SL38F MDD SL310F VRRM 20 40 60 80 100 VRMS VDC 14 28 42 56 70 20 40 60 80 100 SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage UNITS V V Maximum average forward rectified current at TL(see fig.1) I(AV) 3.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 70 A Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=125℃ VF CJ RθJA Operating junction temperature range TJ TSTG 0.5 500 mA -55 to +150 ℃/W ℃ 300 88.0 -55 to +125 -55 to +150 V 0.7 0.2 5.0 0.5 10.0 IR Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Storage temperature range 0.45 pF ℃ Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 SL32F THRU SL310F Reverse Voltage - 20 to 100 Volts Forward Current - 3.0 Ampere FIG. 1- FORWARD CURRENT DERATING CURVE 3.0 P.C.B mounted on 0.2*0.2"(5.0*5.0mm) copper pad areas 2.4 Single Phase Half Wave 60Hz Resistive or inductive Load 1.8 1.2 SL32F-SL36F SL38F-SL310F 0.6 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Typical Characterisitics FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 70 56 42 28 14 175 0 8.3ms SINGLE HALF SINE-WAVE 1 10 LEAD TEMPERATURE, C INSTANTANEOUS FORWARD CURRENT,AMPERES TJ=25 C 10.0 1 SL32F-SL34F SL36F SL38F-SL310F FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 50 0.1 100 10 TJ=100 C 1 TJ=75 C 0.1 0.01 TJ=25 C 0.001 0.01 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 100 NUMBER OF CYCLES AT 60 Hz 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 0.9 JUNCTION CAPACITANCE, pF FIG. 5-TYPICAL JUNCTION CAPACITANCE 2000 1000 TJ=25 C 100 SL32F-SL34F SL36F-SL310F TRANSIENT THERMAL IMPEDANCE, C/W INSTANTANEOUS FORWARD VOLEAGE, VOLTS FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 SL32F THRU SL310F Reverse Voltage - 20 to 100 Volts Forward Current - 3.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SMAF D1 E Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width F B W W1 A P D2 T C D 2.80 4.75 1.42 1.50 178.00 54.40 13.00 1.75 5.05 4.00 4.00 2.00 0.30 8.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMAF REEL SIZE 7" REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) 3,000 4.0 6,000 210*208*203 178 400*265*400 120,000 10.0 Suggested Pad Layout Symbol http://www.microdiode.com Unit (mm) Unit (inch) A 1.8 0.071 B 0.063 C 1.6 3.8 D 2.2 0.087 E 5.4 0.213 0.150 Rev:2024A2 Page :3
SL34F 价格&库存
很抱歉,暂时无法提供与“SL34F”相匹配的价格&库存,您可以联系我们找货
SL34F
  • 20+0.69790
  • 100+0.41630
  • 800+0.29140
  • 3000+0.20810
  • 6000+0.19780
  • 30000+0.18320
库存:2745
SL34F
  • 500+0.22995
  • 1000+0.21131
库存:1870
