CESD323NC5VB-M
CESD323NC5VB-M
    CREATEKMICRO(达晶微)
    SOD-323
CESD323NC5VB-M 数据手册
CESD323NC5VB-M CREATEK Microelectronics ESD Protection Diode in SOD-323 Features ■ 350Watts peak pulse power (tp = 8/20μs) ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±15kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 20A (8/20μs Applications Mechanical Data ■ Microprocessor based equipment ■ SOD323 package ■ Personal Digital Assistants (PDA’s) ■ Molding compound flammability rating: UL 94V-0 ■ Notebooks, Desktops, and Servers ■ Packaging: Tape and Reel ■ Portable Instrumentation ■ RoHS/WEEE Compliant ■ Pagers Peripherals Schematic & PIN Configuration SOD-323 Rev. 1.0, 23-May-2012 www.crea-tek.com 1 CESD323NC5VB-M CREATEK Microelectronics Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 350 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 20 A VESD 30 15 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM Max Units 5.0 V VBR IT=1mA 6.0 V Reverse Leakage Current IR VRWM=5V,T=25℃ 1 uA Clamping Voltage VC IPP=20A,tp=8/20μs 21 V Junction Capacitance Cj VR = 0V, f = 1MHz 20 pF Electrical Parameters (TA = 25°C unless otherwise noted) Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I Parameter IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT VC VBR VRWM V IR VF IT Test Current IPP Note:. 8/20μs pulse waveform. Rev. 1.0, 23-May-2012 www.crea-tek.com 2 CESD323NC5VB-M CREATEK Microelectronics Typical Characteristics Figure 2: Power Derating Curve 10k 110 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(W) Figure 1: Peak Pulse Power vs. Pulse Time 350w 8/20µs aveform 1000 100 10 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration - µs Figure3: Pulse Waveform 110 125 150 Test Waveform Paramters tr=8µs td=20µs Clamping Voltage–VC (V) 40 80 Ipp 100 45 Waveform Paramters tr=8µs td=20µs 90 Percent 75 Figure 4: Clamping Voltage vs.Ipp 100 70 e-1 60 50 Ambient Temperature - TA (℃) 50 40 30 td=Ipp/2 20 35 30 25 20 15 10 5 10 0 0 5 10 15 Time (µs) Rev. 1.0, 23-May-2012 20 25 30 0 5 10 15 20 25 Peak Pulse Current–IPP (A) www.crea-tek.com 3 CESD323NC5VB-M CREATEK Microelectronics Outline Drawing – SOD323 C A DIMENSIONS SYMBOL E B 1 2 MILLIMETER A MIN 1.600 MAX 1.800 MIN 0.063 MAX 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 0.106 D D H L L1 1.000 0.039 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 L F INCHES 0.475 REF 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 Marking 1 05B 2 Pin Style: 1. Cathode 2. Anode Ordering information Order code CESD323NC5VB-M Rev. 1.0, 23-May-2012 Package SOD323 Base qty 3000 Delivery mode Tape and reel www.crea-tek.com 4 CESD323NC5VB-M CREATEK Microelectronics CAUTION / WARNING Information in this document is believed to be accurate and reliable. However, CREATEK does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Users should independently evaluate the suitability of and test each product selected for their own applications, and CREATEK assumes no liability whatsoever relating to the choice, selection or use of the CREATEK products and services described herein. CREATEK reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. Information in this document supersedes and replaces all information previously supplied. Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an CREATEK product can reasonably be expected to result in personal injury, death or severe property or environmental damage. CREATEK accepts no liability for inclusion and/or use of CREATEK products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Resale of CREATEK products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by CREATEK for the CREATEK product or service described herein and shall not create or extend in any manner whatsoever, any liability of CREATEK. CREATEK expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. CREATEK only obligations are those in the CREATEK Standard Terms and Conditions of Sale and in no case will CREATEK be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2009,CREATEK Microelectronics t ® is a registered trademark of CREATEK Microelectronics All rights reserved Rev. 1.0, 23-May-2012 www.crea-tek.com 5
CESD323NC5VB-M 价格&库存
很抱歉,暂时无法提供与“CESD323NC5VB-M”相匹配的价格&库存,您可以联系我们找货
