XNI CONNECTOR
2.5mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
This connector is 2.5mm pitch wire-to-board
connector that has a mechanism to prevent
an incomplete mating by utilizing the inertial
force when mating connector.
In all circuits of connector, controlled key for
preventing mismatching of mating is added,
and two type connectors can be used in the
same model. (See table below.)
• Current rating: 3A AC, DC (AWG#22)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10mΩ max.
After environmental testing/20mΩ max.
• Insulation resistance: 1,000MΩ min.
• Withstanding voltage: 1,000V AC/minute
• Applicable wire: AWG #30 to #22
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
• Inertial lock structure
• Finger-friendly design
• Secure locking structure
Recognized E 60389
1 Certified LR20812
2 J50148340
PC board layout (viewed from component side) and Assembly layout
List of combinations
(7.95)
A
±0.05
1.7
±0.05
Natural
Red
Polarizing key pattern A
Polarizing key pattern B
Housing Model No.
Header Model No.
XNIRP-( )V-A-S
B( )B-XNI S K-A-1
XNIRP-( )V-B-R
B( )B-XNI R K-B-2
±0.05
(12.6)
2.6
±0.05
2.5
Resin color
(Header/Housing)
Key pattern
φ0.9
φ1.3
+0.1
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimensions differ according to the kind of PC board and
piercing method.
The dimensions above should serve as a guideline.
Contact
Applicable wire
AWG#
mm2
Model No.
SXNI-001T-P0.6
SXNI-003T-P0.6
0.13 ∼ 0.33
26 ∼ 22
1.0 ∼ 1.7
7,000
0.05 ∼ 0.08
30 ∼ 28
0.65∼ 0.9
10,000
8.4
Material and Finish
2
Phosphor bronze, tin-plated (reflow treatment)
1.6
RoHS compliance
1.7
2.9
Q’ty /
reel
Insulation O.D.
(mm)
Contact
SXNI-001T-P0.6
SXNI-003T-P0.6
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SXNI-001-06
APLMK SXNI001-06
MKS-L
MK/SXNI-003-06
APLMK SXNI003-06
Crimping
machine Crimp applicator
AP-K2N
AP-K2N
1
XNI CONNECTOR
Housing
B
A
2.5
(4 to 11 circuits)
Dimensions (mm)
A
B
Q’ty /
bag
XNIRP-02V-A-S
2.5
7.5
1,000
XNIRP-03V-A-S
5.0
10.0
1,000
4
XNIRP-04V-A-S
7.5
12.5
1,000
5
XNIRP-05V-A-S
10.0
15.0
1,000
6
XNIRP-06V-A-S
12.5
17.5
1,000
7
XNIRP-07V-A-S
15.0
20.0
1,000
8
XNIRP-08V-A-S
17.5
22.5
1,000
9
XNIRP-09V-A-S
20.0
25.0
1,000
10
XNIRP-10V-A-S
22.5
27.5
1,000
11
XNIRP-11V-A-S
25.0
30.0
500
15
XNIRP-15V-A-S
35.0
40.0
500
Circuits
Model No.
2
3
7.75
10.1
(2, 3 circuits)
B
A
7.75
10.1
2.5
Material
(15 circuits)
B
A
Glass-filled PBT, UL94V-0, natural (white)
7.75
2.5
10.1
RoHS compliance
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
XNIRP-02V-A-S
S...natural (white)
R...red
Shrouded header
(2 to 11 circuits)
B
A
6.8
3.4
10.6
2.5
1.7
(15 circuits)
2.6
B
A
2
B02B-XNISK-A-1
2.5
7.5
500
3
B03B-XNISK-A-1
5.0
10.0
500
4
B04B-XNISK-A-1
7.5
12.5
250
5
B05B-XNISK-A-1
10.0
15.0
250
6
B06B-XNISK-A-1
12.5
17.5
250
7
B07B-XNISK-A-1
15.0
20.0
200
8
B08B-XNISK-A-1
17.5
22.5
200
9
B09B-XNISK-A-1
20.0
25.0
200
10
B10B-XNISK-A-1
22.5
27.5
150
11
B11B-XNISK-A-1
25.0
30.0
150
15
B15B-XNISK-A-1
35.0
40.0
100
Material and Finish
10.6
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PA 66, UL94V-0, natural (ivory)
3.4
RoHS compliance
1.7
2.6
This product displays (LF)(SN) on a label.
ex.
B02B-XNISK-A-1
S...natural (ivory)
2
Q’ty /
box
Model No.
6.8
2.5
Dimensions (mm)
A
B
Circuits
R...red
很抱歉,暂时无法提供与“XNIRP-04V-A-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68170
- 50+0.59960
- 150+0.55860
- 1000+0.48810
- 2000+0.46340
- 国内价格
- 5+0.60848
- 50+0.53514
- 150+0.49853
- 1000+0.43568
- 2000+0.41364
- 国内价格 香港价格
- 1+1.207981+0.15707
- 10+1.1123810+0.14464
- 50+0.7560750+0.09831
- 100+0.67786100+0.08814
- 500+0.62572500+0.08136
- 1000+0.599651000+0.07797
- 2000+0.590962000+0.07684
