DF22-2RS/P-7.92
DF22-2RS/P-7.92
    HRS(广濑)
DF22-2RS/P-7.92 数据手册
7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) DF22 Series Positive Lock Completely enclosed locking system Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Protection from shorts circuits between adjacent contacts Fig.1 ■Features 1. Rated up to 30A Single position connector can carry current of 30A with 10 AWG conductor. Please refer to Table #1 for current ratings for multi-position connectors using other conductor sizes. Keying for multiple use ●R Type (Guide key : right side, Color : black) 2. Positive Locking Function Reliable interior lock protects mated connectors from accidental disconnection. (Fig.1) 3. Prevention of Incorrect Connections To prevent incorrect connection when using multiple connectors having the same Number of contacts, 3 product types having different mating configurations are available. (Fig.2) 4. Molded-in contact retention tabs Handling of terminated contacts during the crimping is easier and avoids entangling of wires, since there are no protruding metal tabs. ●Standard Type (Guide key : inside, Color : natural) 5. Prevention of incorrect board placement Built-in posts assure correct connector placement and orientation on the board. 6. Supports resin sealing Allows potting up to 10mm. 7. Prevention of Short Circuits Between Adjacent Contacts ●L Type (Guide key : left side, Color : red) Each Contact is completely surrounded by the housing wall electrically isolating it from adjacent contacts. 8. Increased Retention Force of Crimped Contacts Improved pull-out force design. 9. Full Line of Crimp Socket Contacts Hirose has released DF22C-*S-7.92C which has easy to push/release latch design. and DF22B-*S-7.92C/ DF22C-*S-7.92C which has improved electrical insulation properties. 10. In-line Connections Wire-to-wire connection is also available. Space is saved with 2-row (2×2) layout for 4 pos. *The image on the left show header (the board dip side), the image on the right show the socket (cable side). *The guide key position is indicated in position facing the mating surface of the header. Fig.2 11. UL, C-UL, and TÜV Certified. 12. Glow Wire compliance (Compliant with IEC 60695-2-11) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2020.1⑧ 1 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■Product Specifications No. of contacts 1 Current 2 rating 3 (Note 1) 4 Ratings 5 10 AWG 30A 25A 25A 22A 22A Voltage rating AC/DC 14 AWG 20A 18A 18A 15A 15A Current rating of UL Standards (Ambient temperature : 25ç) (Note 4) No. of Contacts 1 2 3 4 5 10 AWG 43A 38A 38A 33A 33A 16 AWG 15A 15A 15A 13A 13A 1000V Current Rating See table below See table above (Δt=30ç) See table above UL C-UL TÜV Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12 AWG 25A 20A 20A 18A 18A 12 AWG 38A 32A 32A 26A 26A Operating temperature range -55ç to 85ç (Note 2) Operating humidity range 20% to 80% Storage temperature range -10ç to 60ç (Note 3) Storage humidity range 40% to 70% (Note 3) UL/C-UL/TÜV File No. and Recognition No. UL : E52653 C-UL : E52653 TÜV : R9950703 Voltage Rating AC/DC 600V AC/DC 600V AC/DC 600V 14 AWG 26A 23A 23A 22A 22A 16 AWG 21A 21A 21A 19A 19A Item 1. Contact Resistance 2. Insulation Resistance 3. Withstand Voltage 4. Contact Insertion and Extraction Forces 5. Durability 6. Vibration Resistance 7. Shock Resistance 8. Moisture-Resistance 9. Temperature cycles Specifications Conditions No more than 5mø Measured at 1mA and no higher than 20mV No less than 1,000Mø Measured at DC=1000V No flashover or breakdown AC 2500 V is applied for 1 minute. 0.3N min., 5N max Measured with a steel pin of 1.6×0.8±0.002 thickness Contact resistance : no more than 10mø 30 mating cycles No electrical discontinuity of 1μs or greater Frequency 10-55 Hz, half amplitude 0.75mm, 10 times in each of the three directions No electrical discontinuity of 1μs or greater Accelerated velocity : 490 m/s2 for 11 ms, half-sine wave in 3 directions, 3 times for each direction Contact resistance : no more than 10mø Temperature : 40 ± 2ç ; humidity : 90 to 95%, left as it is for 96 hours Contact resistance : no more than 10mø (-55ç : 30 minutes➝ 5 to 35ç : 5 minutes➝ 85ç : 30 minutes➝ 5 to 35ç : 5 minutes) for 5 cycles The resin parts should withstand the Flow : 260ç, 10 sec 10. Solder heat Resistance temperature and resist melting. Hand soldering : temperature of soldering iron at 300ç for 3 seconds Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. If you split the current over multiple lines, please factor in your own safety margin. Note 2 : Includes temperature rise caused by current flow. Note 3 : The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating temperature for temporary storage such as pre-assembly and during shipping. Note 4 : Indicates the current that corresponds to the RTI value (temperature at which performance is halved) of the resin when the ambient temperature is 25ç. When referring to the rated current value of UL standard, please evaluate the product in the final set to confirm that there are no problems in use. ■Materials / Finish Product Sockets Crimp contacts Part Material Finish Insulator Polyamide Color : Natural white (Note) Contacts High conductivity copper alloy Tin-lead plated or Gold plated Insulator Polyamide (Glass reinforced) Color : Natural beige (Note) Headers Contacts High conductivity copper alloy Tin-copper plated or Gold plated Note : Standard Color, colors of the differing coupling forms are black for DF22R and red for DF22L. Remarks UL94V-0 ---------UL94V-0 ---------- ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Socket, Header ●Contacts DF22 B L - 2 S - 7.92 C (**) q w e r t u q q Series name : DF22 w Form Type r Number of contacts : 1 to 5 t Connector type Sockets Blank : Standard height, standard lock (Type I) B : Long type, standard lock (Type III) C : Long type, ergonomic lock (Type IV) In-line Plugs Blank : With panel stop A : Without panel stop e Guide key type S : Socket DS : Double-row socket P : Header EP : In-line plug DEP : Double-row in-line plug RS/P : Retainer y Contact pitch : 7.92 mm u Type of housing C : Crimp housing DSA : Straight header DS : Right-angle header No letter : Retainer Blank : Inside (Color: natural) R : Right side (Color: black) L : Left side (Color: red) 2 y DF22 A - 1416 SCF A i o !0 !1 i Applicable Cable Blank : UL1430 A : UL1015 o Applicable Conductor 1416 : 14 to 16 AWG 1012 : 10 to 12 AWG !0 Packaging SCF : Socket contacts / reel SC : Socket contacts / pack PCF : In-line plug contacts / reel PC : In-line plug contacts / pack !1 Plating specifications A : Gold plated Blank : Tin plated DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■Diagram of Connector Mating Combinations Gold-plated products are standard for this product in order to support high current. Be sure to select a gold-plated product for use in an environment with temperature changes and vibration. ●Wire-to-Board Connection Crimp socket (Note 2) DF22#-*S-7.92C Crimp contact for Socket DF22(A)-*SC(F)(A) Retainer (Note 1) DF22#-*RS/P-7.92 Straight pin header (Note 2) DF22#-*P-7.92DSA Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF22#-*RS/P-7.92 DF22#-*S-7.92C Right angle pin header (Note 2) DF22#-*P-7.92DS ●In-line or Wire-to-Wire Connection In-line plug DF22#-*EP-7.92C Crimp contact for in-line plug DF22(A)-*PC(F)(A) Retainer (Note 1) DF22B/C-*RS/P-7.92 DF22#-*EP-7.92C DF22B/C*RS/P-7.92 Note 1 : Since this product uses thick wires, a larger load is applied to the connector when inserting/extracting or routing the wires. Please use a retainer to reduce the load on the connector. Crimp socket Applicable Retainer DF22-*S-7.92C DF22-*RS/P-7.92 DF22B-*S-7.92C DF22B/C-*RS/P-7.92 DF22C-*S-7.92C In-line plug Applicable Retainer DF22-*EP-7.92C DF22B/C-*RS/P-7.92 DF22A-*EP-7.92C Note 2 : The key difference (L, R) product matches the mating connector of the same key (L, R). 3 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■Crimp Sockets (Standard Height Type) Shown with terminated and contacts installed. Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Pos. Shown with terminated and contacts installed. A 2 to 5 Pos. 8 B Type 1 Standard lock 7.7 Type 1 Standard lock 10.4 7.7 P=7.92 (11.55) No. of contacts indicator Cavity No. A (11.55) 14.5 20 14.5 20 Contact No. 1 Polarity mark 1 A Cavity No. ■ Type I Height : Standard type, Standard lock Note : The part number and HRS No. have changed to reflect the product form change of the 2 to 5 pos. types. Standard Type (Guide Key : Inside, Color : White) Unit : mm Part No. DF22-1S-7.92C(28) DF22-2S-7.92C(28) DF22-3S-7.92C(28) DF22-4S-7.92C(28) DF22-5S-7.92C(28) HRS No. 680-1012-2 28 680-1004-4 28 680-1005-7 28 680-1006-0 28 680-1007-2 28 No. of Contacts 1 2 3 4 5 A B 8.00 ----15.50 7.92 23.42 15.84 31.34 23.76 39.26 31.68 R Type (Guide Key : Right Side, Color : Black) Part No. DF22R-1S-7.92C(28) DF22R-2S-7.92C(28) DF22R-3S-7.92C(28) DF22R-4S-7.92C(28) DF22R-5S-7.92C(28) HRS No. 680-1026-7 28 680-1027-0 28 680-1028-2 28 680-1029-5 28 680-1030-4 28 No. of Contacts 1 2 3 4 5 L Type (Guide Key : Left Side, Color : Red) Part No. DF22L-1S-7.92C(28) DF22L-2S-7.92C(28) DF22L-3S-7.92C(28) DF22L-4S-7.92C(28) DF22L-5S-7.92C(28) HRS No. 680-1031-7 28 680-1032-0 28 680-1033-2 28 680-1034-5 28 680-1035-8 28 No. of Contacts 1 2 3 4 5 Unit : mm A B 8.00 ----15.50 7.92 23.42 15.84 31.34 23.76 39.26 31.68 Unit : mm A B 8.00 ----15.50 7.92 23.42 15.84 31.34 23.76 39.26 31.68 Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : Every even number position has a different locking design. 4 3 No. of contacts indicator DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■Crimp Sockets (Height, Long Type) 1 Pos. Shown with terminated and contacts installed. 2 to 5 Pos. A B Type 4 Height : Long type, Enhanced ergonomic lock Type 3 Height : Long type, Standard lock Contact No. 1 (12.75) 23 No. of contacts indicator Cavity No. (12.75) (11.55) 14.5 7.7 Type 4 Height : Long type, user-friendly operation 10.4 7.7 P=7.92 8 23 14.5 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Shown with terminated and contacts installed. Polarity mark A A 1 Cavity No. ■ Type III Height : Long type, Standard lock HRS No. 680-1097-5 680-1098-8 680-1099-0 680-1100-8 No. of Contacts 2 3 4 5 No. of contacts indicator ■ Type IV Height : Long type, Enhanced ergonomic lock Standard Type (Guide Key : Inside, Color : White) Unit : mm Part No. DF22B-2S-7.92C DF22B-3S-7.92C DF22B-4S-7.92C DF22B-5S-7.92C 3 A B 15.50 7.92 23.42 15.84 31.34 23.76 39.26 31.68 Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : Every even number position has a different locking design. Standard Type (Guide Key : Inside, Color : White) Unit : mm Part No. DF22C-1S-7.92C DF22C-2S-7.92C DF22C-3S-7.92C DF22C-4S-7.92C HRS No. 680-1101-0 680-1102-3 680-1103-6 680-1104-9 No. of Contacts A B 1 8.00 ----15.50 7.92 2 23.42 15.84 3 4 31.34 23.76 R Type (Guide Key : Right Side, Color : Black) Unit : mm Part No. DF22CR-3S-7.92C HRS No. 680-1130-9 No. of Contacts A B 3 23.42 15.84 L Type (Guide Key : Left Side, Color : Red) Part No. DF22CL-1S-7.92C DF22CL-3S-7.92C HRS No. 680-1133-7 680-1135-2 Unit : mm No. of Contacts A B 1 8.00 ----23.42 15.84 3 Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : Every even number position has a different locking design. 5 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■Straight Header 2 to 5 Pos. A 12.45 9.7 Cavity No. 12.45 1.5 4.05 9.3 A B No. of contacts indicator Cavity No. 3 10.8 A Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Pos. Contact No.1 1.4 9 0.8 3.7 2.3 3.2 3.7 18.1 18.1 Polarity mark 8.7 3.9 10.8 3.2 1 No. of contacts indicator Ø1.5 0.8 3.45 4.35 [Specification number] (06) : Gold plated, bag packaging (26) : Gold plated tray packaging (only 1 pos) (05) : Tin-copper plated bag packaging (25) : Tin-copper plated tray packaging (only 1 pos) Unit : mm B Bag Packaging Tray Packaging Gold plated Tin-copper plated ----✓ ✓ ✓ ✓ 7.92 ----✓ ✓ ✓ 15.84 ----✓ ✓ ✓ 23.76 ----✓ ✓ ✓ 31.68 ----✓ ✓ ✓ R Type (Guide Key : Right Side, Color : Black) Part No. DF22R-1P-7.92DSA(**) DF22R-2P-7.92DSA(**) DF22R-3P-7.92DSA(**) DF22R-4P-7.92DSA(**) DF22R-5P-7.92DSA(**) HRS No. No. of Contacts 680-1036-0 ** 1 680-1037-3 ** 2 680-1038-6 ** 3 680-1039-9 ** 4 680-1040-8 ** 5 A ----17.22 25.14 33.06 40.98 B ----7.92 15.84 23.76 31.68 Unit : mm Bag Packaging Tray Packaging Gold plated Tin-copper plated ----✓ ✓ ✓ ----✓ ✓ ✓ ----✓ ✓ ✓ ----✓ ✓ ✓ ----✓ ✓ ✓ BRecommended PCB Layout (Board thickness : 1.6±0.1) 1 Pos. 11.1±0.1 8.5 2.5 +0.1 0 2-R0.5 2 to 5 Pos. L Type (Guide Key : Left Side, Color : Red) Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : Tray packaging (150 pcs/tray). Order by number of 150. Note 3 : Every even number position has a different locking design. 6 (#)*¤%#%* % %#& Unit : mm B Bag Packaging Tray Packaging Gold plated Tin-copper plated --------✓ ✓ ✓ 7.92 ----✓ ✓ ✓ 15.84 ----✓ ✓ ✓ 23.76 ----✓ ✓ ✓ 31.68 ----✓ ✓ ✓ + &# ¢ , A ----17.22 25.14 33.06 40.98 &# HRS No. No. of Contacts 680-1041-0 ** 1 680-1042-3 ** 2 680-1043-6 ** 3 680-1044-9 ** 4 680-1045-1 ** 5  "¢ Part No. DF22L-1P-7.92DSA(**) DF22L-2P-7.92DSA(**) DF22L-3P-7.92DSA(**) DF22L-4P-7.92DSA(**) DF22L-5P-7.92DSA(**) +0.1 --0.2 3.2±0.05 A ----17.22 25.14 33.06 40.98 3.4±0.1 HRS No. No. of Contacts 680-1013-5 ** 1 680-1014-8 ** 2 680-1015-0 ** 3 680-1016-3 ** 4 680-1017-6 ** 5 E2,#.'¤%#%* 7¤%#%* )#(*¤%#%* Part No. DF22-1P-7.92DSA(**) DF22-2P-7.92DSA(**) DF22-3P-7.92DSA(**) DF22-4P-7.92DSA(**) DF22-5P-7.92DSA(**) 1+0.1 0 Standard Type (Guide Key : Inside, Color : Natural Beige) & %# % DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) A B C P=7.92 1.6 0.8 15.2 24 17.6 9 Contact No.1 Ø1.5 3.5 12.2 9.45 ■Right Angle Header A 5 Cavity No. No. of contacts indicator HRS No. No. of Contacts 680-1008-5 ** 2 680-1009-8 ** 3 680-1010-7 ** 4 680-1011-0 ** 5 A 19.80 27.72 35.64 43.56 B C Gold plated Tin-copper plated 15.00 7.92 (36) (35) 22.92 15.84 (06) (05) 30.84 23.76 (06) (05) 38.76 31.68 (06) (05) R Type (Guide Key : Right Side, Color : Black) Part No. DF22R-2P-7.92DS(**) DF22R-3P-7.92DS(**) DF22R-4P-7.92DS(**) DF22R-5P-7.92DS(**) HRS No. No. of Contacts 680-1018-9 ** 2 680-1019-1 ** 3 680-1020-0 ** 4 680-1021-3 ** 5 A 19.80 27.72 35.64 43.56 Unit : mm B C Gold plated Tin-copper plated 15.00 7.92 (06) (05) 22.92 15.84 (06) (05) 30.84 23.76 (06) (05) 38.76 31.68 (06) (05) Part No. DF22L-2P-7.92DS(**) DF22L-3P-7.92DS(**) DF22L-4P-7.92DS(**) DF22L-5P-7.92DS(**) HRS No. No. of Contacts 680-1022-6 ** 2 680-1023-9 ** 3 680-1024-1 ** 4 680-1025-4 ** 5 A 19.80 27.72 35.64 43.56 5 1.2 [specification number] (06), (36) : Gold plated (05), (35) : Tin-copper plated BRecommended PCB Layout (Board thickness : 1.6±0.1) B±0.05 2- L Type (Guide Key : Left Side, Color : Red) Unit : mm B C Gold plated Tin-copper plated 15.00 7.92 (06) (05) 22.92 15.84 (06) (05) 30.84 23.76 (06) (05) 38.76 31.68 (06) (05) 3.7 C±0.05 Ø1 .6 P=7.92±0.05 +0 0 .1 15.2±0.05 Part No. DF22-2P-7.92DS(**) DF22-3P-7.92DS(**) DF22-4P-7.92DS(**) DF22-5P-7.92DS(**) Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : Every even number position has a different locking design. 1 0. + 0 5 . Ø1 - * ■In-line Plug 1 Pos. 2, 3 Pos. A B No. of contacts indicator A 34.95 No. of contacts indicator Cavity No. Contact No.1 9.97 Shown with terminated and contacts installed. 12.72 Shown with terminated and contacts installed. 12.72 9.3 34.95 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Standard Type (Guide Key : Inside, Color : Natural Beige) Unit : mm 1 10.5 3 3 Standard Type (Guide Key : Inside, Color : Natural Beige) Part No. DF22A-1EP-7.92C DF22A-2EP-7.92C DF22A-3EP-7.92C HRS No. 680-1053-0 680-1054-2 680-1055-5 No. of Contacts 1 2 3 A 9.30 18.00 26.00 L Type (Guide Key : Left Side, Color : Red) Unit : mm B ----7.92 15.84 Cavity No. A 2 Polarity mark 1 R Type (Guide Key : Right Side, Color : Black) Part No. DF22AR-2EP-7.92C DF22AR-3EP-7.92C HRS No. 680-1069-0 680-1070-9 No. of Contacts 2 3 A 18.00 26.00 Unit : mm B 7.92 15.84 Unit : mm Part No. HRS No. No. of Contacts A B DF22AL-2EP-7.92C 680-1074-0 2 18.00 7.92 Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : Every even number position has a different locking design. 7 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■In-line Plug (Panel Lock Type) Shown with terminated and contacts installed. A 3 B No. of contacts indicator 34.95 20.7 10.5 Cavity No. A 3 20.7 A 1 Contact No.1 9.97 12.72 8.12 No. of contacts indicator Cavity No. 34.95 3 2, 3 Pos. 9.3 12.72 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Pos. Shown with terminated and contacts installed. Polarity mark 3 16.3 Part No. DF22L-1EP-7.92C DF22L-2EP-7.92C HRS No. 680-1063-3 680-1064-6 No. of Contacts A 1 9.30 17.22 2 Unit : mm B C ----- 16.30 7.92 24.22 13.02 Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : Every even number position has a different locking design. 3.5±0.1 2, 3 Pos. Panel thickness 2.0 1.6 1.2 0.8 X 0.48 0.96 1.44 1.92 (C-0.5-X) +0.1 0 (A+0.4) +0.1 0 11±0.2 3.5±0.1 L Type (Guide Key : Left Side, Color : Red) 4.16 +0.1 0 Unit : mm No. of Contacts A B C 17.22 7.92 24.22 2 25.14 15.84 32.14 3 9.6+0.1 0 +0.1 4.835 0 HRS No. 680-1059-6 680-1060-5 (15.8-X) +0.1 0 +0.1 0 Part No. DF22R-2EP-7.92C DF22R-3EP-7.92C 1 Pos. 10.27 R Type (Guide Key : Right Side, Color : Black) BPanel Cutout 13.02 +0.1 0 Unit : mm No. of Contacts A B C 9.30 ----- 16.30 1 17.22 7.92 24.22 2 25.14 15.84 32.14 3 +0.1 0 HRS No. 680-1048-0 680-1049-2 680-1050-1 1 C Standard Type (Guide Key : Inside, Color : White) Part No. DF22-1EP-7.92C DF22-2EP-7.92C DF22-3EP-7.92C 2 Note 1 : Please ensure when mating this connector that the tapered portions of the panel are facing outward towards the receptacle connector’s mating interface. 8 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■In-line Double-row Socket 20.14 17.44 15.5 7.92 23 14.5 Standard lock Shown with terminated and contacts installed. Part No. DF22B-4DS-7.92C HRS No. 680-1142-8 No. of Contacts 4 Unit : mm Lock type Standard lock (21.29) Polarity mark Contact No.1 1 3 2 4 A R Type (Guide Key : Right Side, Color : Black) Part No. DF22BR-4DS-7.92C HRS No. 680-1156-2 No. of Contacts 4 Unit : mm Lock type Standard lock Cavity No. No. of contacts indicator L Type (Guide Key : Left Side, Color : Red) Part No. DF22BL-4DS-7.92C HRS No. 680-1161-2 No. of Contacts 4 Unit : mm Lock type Standard lock Note : Bag packaging (100 pcs/pack). Order by number of packs. ■In-line Double-row Plug Panel lock type Without panel lock function 17.22 7.92 17.22 7.92 3 21.79 19.04 21.79 19.04 3 Contact No.1 Contact No.1 10.5 34.95 20.7 4 A 3 1 4 2 10.5 No. of contacts indicator Cavity No. 34.95 20.7 24.22 No. of contacts indicator Cavity No.  4 A 3 1 4 2 Shown with terminated and contacts installed. Standard Type (Guide Key : Inside, Color : White) Part No. DF22-4DEP-7.92C DF22A-4DEP-7.92C HRS No. 680-1051-4 680-1056-8 Unit : mm No. of Contacts Connector type 4 Panel lock type Without panel lock function 4 Part No. DF22R-4DEP-7.92C HRS No. 680-1170-3 No. of Contacts 4 Unit : mm Connector type Panel lock type Note : Bag packaging (100 pcs/pack). Order by number of packs. 6.3±0.1 19.76 +0.1 0 11±0.2 9.62+0.1 0 Unit : mm No. of Contacts Connector type 4 Panel lock type Without panel lock function 4 19.34 +0.1 0 HRS No. 680-1175-7 680-1189-1 Polarity mark (23.72-X) +0.1 0 L Type (Guide Key : Left Side, Color : Red) Part No. DF22L-4DEP-7.92C DF22AL-4DEP-7.92C Polarity mark BRecommended Panel Cutout (Panel mount type) R Type (Guide Key : Right Side, Color : Black) 22.09 +0.1 0 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Standard Type (Guide Key : Inside, Color : White) Panel thickness 2.0 1.6 1.2 0.8 X 0.48 0.96 1.44 1.92 17.62 +0.1 0 Note 1 : Please ensure when mating this connector that the tapered portions of the panel are facing outward towards the receptacle connector’s mating interface. 9 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■Retainer Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For Standard height, standard lock (Type I) For Long type, standard lock (Type III) Long type, enhanced ergonomic lock (Type IV) A B A B 2 8.6 3.2 3.2 Cavity No. Cavity No. A5 Part No. DF22-1RS/P-7.92 DF22-2RS/P-7.92 DF22-3RS/P-7.92 DF22-4RS/P-7.92 DF22-5RS/P-7.92 Applicable Socket 7.92 11.6 2 7.92 4 3 2 1 No. of contacts indicator HRS No. No. of Contacts 680-1213-4 1 680-1209-7 2 680-1210-6 3 4 680-1211-9 5 680-1212-1 Unit : mm A B 7.04 ----15.50 7.92 23.42 15.84 31.34 23.76 39.26 31.68 A5 Part No. DF22B/C-1RS/P-7.92 DF22B/C-2RS/P-7.92 DF22B/C-3RS/P-7.92 DF22B/C-4RS/P-7.92 DF22B/C-5RS/P-7.92 DF22-*S-7.92C For Standard height, standard lock (Type I) * indicates number of contacts. Note : Bag packaging (100 pcs/pack). Order by number of packs. Applicable Socket 4 HRS No. 680-1214-0 680-1200-2 680-1201-5 680-1202-8 680-1203-0 3 2 1 No. of contacts indicator No. of Contacts 1 2 3 4 5 Unit : mm A B 7.04 ----15.50 7.92 23.42 15.84 31.34 23.76 39.26 31.68 DF22B-*S-7.92C For Long type, standard lock (Type III) DF22C-*S-7.92C Long type, enhanced ergonomic lock (Type IV) DF22-*EP-7.92C DF22A-*EP-7.92C * indicates number of contacts. Note 1 : Bag packaging (100 pcs/pack). Order by number of packs. Note 2 : When connecting retainer into the plug housing, please note the cavity numbers will line up numerieally, but the retainer cavity numbers will be upside down compared to the plug cavity numbers. 10 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) ■Crimp Contact for Socket BReel Contact ※Applicable Tool : Applicator For 14 to 16 AWG Part No. 4.7 2.8 3.8 DF22-1416SCFA 680-1085-6 DF22-1416SCF 680-1000-3 3 0.8 1.6 1.5 2.7 1.4 20.8 17 DF22A-1416SCFA 680-1087-1 DF22A-1416SCF 680-1002-9 Ø1 .5 DF22A-1012SCFA 680-1106-4 P=15.5 t=0.3 DF22A-1012SCF Part No. 4.7 2.8 4 0.8 1.6 1.3 2.9 1.4 21.8 17 3.8 Ø2 680-1089-7 UL Wire style size 14 AWG Gold plated 1430 16 AWG 14 AWG Tin plated 1430 16 AWG 14 AWG Gold plated 1015 16 AWG 14 AWG Tin plated 1015 16 AWG 10 AWG Gold plated 1015 12 AWG 10 AWG Tin plated 1015 12 AWG Applicable cable Wire Sectional Construction area 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 104cores./0.26mm 5.52mm2 65cores./0.26mm 3.45mm2 104cores./0.26mm 5.52mm2 65cores./0.26mm 3.45mm2 Jacket Quantity diameter 2.4 to 3.0mm 2500 2.4 to 3.0mm 2500 3.0 to 3.8mm 2000 3.0 to 3.8mm 2000 3.6 to 4.9mm 2000 3.6 to 4.9mm 2000 BBulk Contact (100/pack) ※Applicable Tool : Manual ID tool For 10 to 12 AWG t=0.4 P=16.5 HRS No. Finish DF22-1416SCA DF22-1416SC UL style 680-1190-0 Gold plated 1430 680-1001-6 Tin plated 1430 DF22A-1416SCA 680-1191-0 Gold plated 1015 DF22A-1416SC 680-1003-1 Tin plated 1015 DF22A-1012SCA 680-1107-7 Gold plated 1015 DF22A-1012SC 680-1090-6 Tin plated 1015 Wire size 16 AWG 16 AWG 14 AWG 16 AWG 14 AWG 16 AWG 10 AWG 12 AWG 10 AWG 12 AWG Applicable cable Wire Sectional Construction area 26cores./0.254mm 1.32mm2 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 104cores./0.26mm 5.52mm2 65cores./0.26mm 3.45mm2 104cores./0.26mm 5.52mm2 65cores./0.26mm 3.45mm2 Jacket diameter 2.6mm 2.6mm 3.7mm 3.2mm 3.7mm 3.2mm 4.69mm 4.04mm 4.69mm 4.04mm Note 1 : The conductor of applicable wire is tin plated annealed copper. Note 2 : When using other than the applicable wire, contact your nearest Hirose representative. ●Strip length 3.5 to 4.5mm ■Crimp Contact for In-line Plug BReel Contact ※Applicable 4.7 2.8 1.6 Part No. DF22-1416PCFA 680-2002-4 DF22-1416PCF 680-1078-0 1.4 DF22A-1416PCFA 680-1194-0 1416 1.5 2.7 DF22A-1416PCF ●Strip length 3.5 to 4.5mm 680-1079-3 UL Wire style size 14 AWG Gold plated 1430 16 AWG 14 AWG Tin plated 1430 16 AWG 14 AWG Gold plated 1015 16 AWG 14 AWG Tin plated 1015 16 AWG Applicable cable Wire Sectional Construction area 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 2.18mm2 41cores./0.26mm 26cores./0.254mm 1.32mm2 Jacket Quantity diameter 2.4 to 3.0mm 2500 2.4 to 3.0mm 2500 3.0 to 3.8mm 2000 3.0 to 3.8mm 2000 BBulk Contact (100/pack) ※Applicable Tool : Manual ID tool 1.6 .5 Ø1 P=15.5 Tool : Applicator HRS No. Finish 0.8 29 25.2 3.8 3 0.8 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. Finish t=0.3 Part No. DF22-1416PCA DF22-1416PC DF22A-1416PCA DF22A-1416PC HRS No. Finish UL style 680-1192-0 Gold plated 1430 680-1080-2 Tin plated 1430 Wire size 16 AWG 16 AWG 14 AWG 680-1193-0 Gold plated 1015 16 AWG 14 AWG 680-1081-5 Tin plated 1015 16 AWG Applicable cable Wire Sectional Jacket Construction area diameter 26cores./0.254mm 1.32mm2 2.6mm 26cores./0.254mm 1.32mm2 2.6mm 41cores./0.26mm 2.18mm2 3.7mm 26cores./0.254mm 1.32mm2 3.2mm 2.18mm2 3.7mm 41cores./0.26mm 26cores./0.254mm 1.32mm2 3.2mm Note 1 : The conductor of applicable wire is tin plated annealed copper. Note 2 : When using other than the applicable wire, contact your nearest Hirose representative. 11 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) BMated Dimensions ●Socket to Straight Header Connection ●Socket to Right Angle Header Connection 1 Pos. DF22B/C--1RS/P--7.92 DF22#--1P--7.92DSA(**) DF22#--*S--7.92C(28) DF22#--*P--7.92DS(**) (26.7) (28.7) (23.7) (25.7) DF22#--1S--7.92C(28) (31.6) (29.6) (13.5) DF22--/1RS/P--7.92 DF22B#--1S--7.92C DF22C#--1S--7.92C (12.25) (12.45) DF22--*RS/P--7.92 (34.6) (32.6) DF22#--1P--7.92DSA(**) DF22B#--*S--7.92C DF22C#--*S--7.92C (13.3) DF22#--*P--7.92DS(**) DF22B/C--*RS/P--7.92 (12.45) DF22--*RS/P--7.92 (13.5) DF22B/C--*RS/P--7.92 DF22B#--*S--7.92C DF22C#--*S--7.92C (23.7) (25.7) DF22#--*S--7.92C(28) (26.7) (28.7) DF22#--*P--7.92DSA(**) DF22#--*P--7.92DSA(**) (13.0) DF22#--*EP--7.92C DF22#--*S--7.92C(28) DF22--*RS/P--7.92C DF22B/C---*RS/P--7.92 (47.55) (43.55) DF22B/C--*RS/P--7.92 DF22B/C--*RS/P--7.92 ●In-line Double-row socket to In-line Double-row Plug (Panel lock type) Connection DF22B#--4DS--7.92C (47.55) (43.55) DF22A#--*EP--7.92C DF22B/C--*RS/P--7.92 DF22B/C--*RS/P--7.92 ●In-line Double-row socket to In-line Double-row Plug Connection (43.55) 12 DF22B#--4DS--7.92C (43.55) DF22C#--4DS--7.92C (23.3) DF22C#--4DS--7.92C (23.3) DF22#--4DEP--7.92C DF22B#--*S--7.92C DF22C#--*S--7.92C DF22A#--4DEP--7.92C DF22#--4DEP--7.92C (43.55) DF22#--*S--7.92C(28) DF22--RS/P--7.92 DF22B/C--*RS/P--7.92 (22.1) (43.55) DF22A#--*EP--7.92C DF22B#--*S--7.92C DF22C#--*S--7.92C (14.2) DF22#--*EP--7.92C (44.55) (40.55) (14.2) (44.55) (40.55) ●Socket to In-line Plug Connection (13.0) ●Socket to In-line Plug (Panel lock type) Connection (22.1) Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 to 5 Pos. DF22A#--4DEP--7.92C DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) BTools Type Hirose Press Unit Applicators Used in Hirose Press Unit CM-105C Part No. HRS No. 901-0001-0 AP105-DF22-1416 901-4576-7 UL1430 DF22-1416SCF/PCF/SCFA/PCFA AP105-DF22A-1416 901-4578-2 UL1015 DF22A-1416SCF/PCF/SCFA/PCFA 901-4579-5 UL1430 DF22-1416SCF/PCF/SCFA/PCFA 901-4580-4 901-4582-0 550-0285-0 550-0286-2 550-0288-8 UL1015 UL1015 UL1430 UL1015 UL1015 16 AWG : UL1430 16, 14 AWG : UL1015 10, 12 AWG : UL1015 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Applicators Used in Press AP109A-DF22-1416 Units of Other Japanese AP109A-DF22A-1416 Companies (Note 2) AP109A-DF22A-1012 Applicator Manufactured by CHS893800H-UP Japan Automatic Machine CHS893900H-UP (Note 3) QHS895800H-UP HT104/DF22-1416 Crimping Tools HT104/DF22A-1416 HT103/DF22A-1012 Applicable Wire (Note 7) Applicable Contact (Note 6) DF22/DF22A-1416SCF/PCF/SCFA/PCFA DF22A-1416SCF/PCF/SCFA/PCFA DF22A-1012SCF/SCFA(Note 1) DF22-1416SCF/PCF/SCFA/PCFA DF22A-1416SCF/PCF/SCFA/PCFA DF22A-1012SCF/SCFA(Note 1) DF22-1416SC/PC/SCA/PCA DF22A-1416SC/PC/SCA/PCA DF22A-1012SC/SCA Note 1 : When crimping DF22A-1012SCF/SCFA use a press of at least 3.5 tons. Note 2 : Applicators compatible with other Japanese companies (AP109A Applicator) cannot be used with the Hirose Press Unit CM-105C. An attachment is required when using the applicator. Please contact the press unit manufacturer for inquiries on attachments. Note 3 : Please contact Japan Automatic Machine (J.A.M.) via their homepage regarding inquiries on the applicator or crimping defects. (URL: http://www.jam-net.co.jp) Note 4 : Problems caused by tools other than those specified are not covered by the warranty. Note 5 : Crimping should be carried out based on the "Crimping Quality Standards" and "Crimping Conditions Table." Note 6 : Applicable contacts are limited to those listed in the table. Note 7 : Applicable cables are limited to those listed in the table. BContact Extraction ■ Contact extraction tool : Flat-bladed screwdriver, 1.4mm blade width ■ Intended crimp Contacts : DF22-1416SC(F), DF22-1416SC(F)A, DF22A-1416SC(F), DF22A-1416SC(F)A, DF22A-1012SC(F), DF22A-1012SC(F)A, DF22-1416PC(F), DF22-1416PC(F)A, DF22A-1416PC(F), and DF22A-1416PC(F)A ■ Work Method (Housing CrossSectional Diagram) (1) Flat-bladed screwdriver (2) Molded-in lance 1. Refer to the drawing No. 1. Insert correct size screwdriver in the housing against the molded-in lance. Push down the lance as shown. 2. Assure that the lance is deflected to release the contact and pull-out wire with the crimped contact. Note : Please do not reuse the reparred housing. Replace it to new one. Caution There are parts on the crimp contact that can cause injuries, please use caution when unmating the contacts. 13 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) BPrecautions 1. Gold-plated products are standard for this product in order to support high current. Be sure to select a gold-plated product for use in an environment with temperature changes and vibration. 2. If this product is used outside the specifications, evaluate it in the final set to confirm that there are no problems in use. 3. No outdoor use. 4. Notification for harness assembly 1) When inserting the crimping terminal to the crimping socket, please do not tilt the crimping terminal or twist the cable. Insertion at tilted angles or twisting the cable may cause deformation of the crimping terminal or crimping socket. Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2) After inserting the crimping terminal to the crimping socket, please make sure that the lance has been hooked with pulling the cable lightly. When checking the hook, please avoid bending the cable for preventing terminal drop-off. Load Load 3) Bundle cables/Cabtyre Cables Recommend bundle and strip position of cables are 100mm or more. Bundling close to the connectors may cause terminal drop-off, breaking cables and unstable connection. More than 100mm 5. Notification for Insertion Extraction 1) Please insert(extract) the crimping socket straight to the mating connector. Insertion(extraction) at tilted angles applies load concentration to the connector end and may cause deformation (at connection area, socket and header case, etc). There is firing risk using this kind of deformed connector. Insertion Extraction 2) When it is hard to extract, please lightly insert the connector beforehand and then pull it with releasing the lock. Forced extraction has a risk of connector breakage. 6. Notification of wiring 1) When using a thick cable, short cable length and bending close to the connector end, these load concentration may cause deformation. Please note that there is firing risk using deformed connector. When installing, please refrain from stress concentration such as cable bending close to the connector end or cable twisting. Stress concentration; Cable bending close to connector BCurrent Ratings The current rating listed in the catalog indicates the allowable current per contact. However, in applications requiring current transmission through all the contacts, about one-third of the listed rating should be applied. When the current rating for the connector is 3A, and the allowable current of the conductor being used is 1A, then rating of 1A will be used for the entire assembly. The connectors should not be mating / unmating when the electrical current is being applied. Hot swap should not be performed. 14 DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 15 Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF22 Series●7.92mm Contact Pitch High-Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 01/2020. Contents are subject to change without notice for the purpose of improvements.
DF22-2RS/P-7.92 价格&库存
很抱歉,暂时无法提供与“DF22-2RS/P-7.92”相匹配的价格&库存,您可以联系我们找货
