P4SMA6.8A
P4SMA6.8A
    JINGDAO(晶导微电子)
P4SMA6.8A 数据手册
山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD P4SMA Series Surface mount transient voltage suppressor power 400 watts Stand-Off Voltage: 5.8V~468V PINNING FEATURES PIN • For surface mounted applications in order to optimize board space. DESCRIPTION 1 Cathode 2 Anode • Low profile package 2 • Glass passivated junction • Low inductance Unipolar • Plastic package has Underwriters Laboratory 1 Flammability Bipolar MECHANICAL DATA • Case: SMA Simplified outline SMA and symbol • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Parameter Peak Pulse Power Dissipation on T A =2 5°C (Note 1,2,4, Fig1) Peak Forward Surge Current (Note 3,Fig 4) Symbol Value Unit P PPM 400 W I FSM 60 A see Table 1 A (UNI) Peak Pulse Current on 10/1000 us waveform (Note 1, Fig 3) Contact Air ESD Voltage per IEC6100-4-2 I PPM V ESD1 V ESD2 Typical Thermal Resistance Junction to Ambient(Note 2) RθJA Operating Junction Temperature and Storage Temperature Range T j , T stg 30 30 kV 120 °C/W -55 ~ +150 °C NOTES: 1. Non-repetitive current pulse, per Fig.3 and derated above T A = 25°C per Fig. 2. 2. Mounted on 5mm 2 copper pads to each terminal. 3. Peak Forward Surge Current : 8.3ms single half sine-wave Superimposed on rated load (JEDEC method). 4. Peak pulse power waveform is 10/1000μS. 2017.01 SMA-TVS-P4SMA Series -400W Page 1 of 4 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD P4SMA Series Characteristics at Ta = 25°C Table 1 Reverse Stand-off Voltage Type UNI BI Breakdown Voltage V BR @ I T Reverse Leakage Max. Clamp Voltage IT I R @ V RWM V C @ I PP I PP A Test Current V RMW Min Max V V V mA μA V Package Peak Pulse Current SMA Device Marking Ccode UNI BI P4SMA6.8A P4SMA6.8CA 5.8 6.45 7.14 10 1000 10.5 39 6V8A 6V8C P4SMA7.5A P4SMA7.5CA 6.4 7.13 7.88 10 500 11.3 36.3 7V5A 7V5C P4SMA8.2A P4SMA8.2CA 7.02 7.79 8.61 10 200 12.1 33.9 8V2A 8V2C P4SMA9.1A P4SMA9.1CA 7.78 8.65 9.55 1 50 13.4 30.6 9V1A 9V1C 10C P4SMA10A P4SMA10CA 8.55 9.5 10.5 1 10 14.5 28.3 10A P4SMA11A P4SMA11CA 9.4 10.5 11.6 1 5 15.6 26.3 11A 11C P4SMA12A P4SMA12CA 10.2 11.4 12.6 1 5 16.7 24.6 12A 12C P4SMA13A P4SMA13CA 11.1 12.4 13.7 1 1 18.2 22.5 13A 13C P4SMA15A P4SMA15CA 12.8 14.3 15.8 1 1 21.2 19.3 15A 15C P4SMA16A P4SMA16CA 13.6 15.2 16.8 1 1 22.5 18.2 16A 16C P4SMA18A P4SMA18CA 15.3 17.1 18.9 1 1 25.5 16.1 18A 18C P4SMA20A P4SMA20CA 17.1 19 21 1 1 27.7 14.8 20A 20C P4SMA22A P4SMA22CA 18.8 20.9 23.1 1 1 30.6 13.4 22A 22C P4SMA24A P4SMA24CA 20.5 22.8 25.2 1 1 33.2 12.3 24A 24C P4SMA27A P4SMA27CA 23.1 25.7 28.4 1 1 37.5 10.9 27A 27C P4SMA30A P4SMA30CA 25.6 28.5 31.5 1 1 41.4 9.9 30A 30C P4SMA33A P4SMA33CA 28.2 31.4 34.7 1 1 45.7 9 33A 33C P4SMA36A P4SMA36CA 30.8 34.2 37.8 1 1 49.9 8.2 36A 36C P4SMA39A P4SMA39CA 33.3 37.1 41 1 1 53.9 7.6 39A 39C P4SMA43A P4SMA43CA 36.8 40.9 45.2 1 1 59.3 6.9 43A 43C P4SMA47A P4SMA47CA 40.2 44.7 49.4 1 1 64.8 6.3 47A 47C P4SMA51A P4SMA51CA 43.6 48.5 53.6 1 1 70.1 5.8 51A 51C P4SMA56A P4SMA56CA 47.8 53.2 58.8 1 1 77 5.3 56A 56C P4SMA62A P4SMA62CA 53 58.9 65.1 1 1 85 4.8 62A 62C P4SMA68A P4SMA68CA 58.1 64.6 71.4 1 1 92 4.5 68A 68C P4SMA75A P4SMA75CA 64.1 71.3 78.8 1 1 103 4 75A 75C P4SMA82A P4SMA82CA 70.1 77.9 86.1 1 1 113 3.6 82A 82C P4SMA91A P4SMA91CA 77.8 86.5 95.5 1 1 125 3.3 91A 91C P4SMA100A P4SMA100CA 85.5 95 105 1 1 137 3 100A 100C P4SMA110A P4SMA110CA 94 105 116 1 1 152 2.7 110A 110C P4SMA120A P4SMA120CA 102 114 126 1 1 165 2.5 120A 120C P4SMA130A P4SMA130CA 111 124 137 1 1 179 2.3 130A 130C P4SMA150A P4SMA150CA 128 143 158 1 1 207 2 150A 150C P4SMA160A P4SMA160CA 136 152 168 1 1 219 1.9 160A 160C P4SMA170A P4SMA170CA 145 162 179 1 1 234 1.8 170A 170C P4SMA180A P4SMA180CA 154 171 189 1 1 246 1.7 180A 180C P4SMA200A P4SMA200CA 171 190 210 1 1 274 1.5 200A 200C P4SMA220A P4SMA220CA 185 209 231 1 1 328 1.3 220A 220C P4SMA250A P4SMA250CA 214 237 263 1 1 344 1.2 250A 250C P4SMA300A P4SMA300CA 256 285 315 1 1 414 1 300A 300C P4SMA350A P4SMA350CA 300 332 368 1 1 482 0.9 350A 350C P4SMA400A P4SMA400CA 342 380 420 1 1 548 0.8 400A 400C P4SMA440A P4SMA440CA 376 418 462 1 1 602 0.7 440A 440C P4SMA480A P4SMA480CA 408 456 504 1 1 658 0.6 480A 480C P4SMA510A P4SMA510CA 434 485 535 1 1 698 0.6 510A 510C P4SMA530A P4SMA530CA 451 503.5 556.5 1 1 725 0.6 530A 530C P4SMA540A P4SMA540CA 460 513 567 1 1 740 0.5 540A 540C P4SMA550A P4SMA550CA 468 522.5 577.5 1 1 760 0.5 550A 550C 2017.01 www.sdjingdao.com Page 2 of 4 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD P4SMA Series Fig.2 Forward Current Derating Curve 100 Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C 10 1.0 Mounted on 5.0mm Copper Land Areas 0.1 0.1 1 10 100 1000 10000 PEAK PULSE POWER(P PP)OR CURRENT(I PP) DERATINGIN PERCENTAGE% P PPM,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 100 80 60 40 20 0 25 I ppm ,Peak Pulse Current (%) Peak Value Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp I ppm 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 3.0 4.0 I FSM,PEAK FORWARD SURGE CURRENT, AMPERES T A =25°C 100 125 150 175 60 50 40 30 20 10 T,TIME,ms 2017.01 100 Fig.4 Maximum Non-Repetitive Peak Forward Surge Current Fig.3 Pulse Waveform t f =10usec 75 T A,AMBIENT TEMPERATURE,°C t d,PULSE WIDTH ,us 120 50 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz www.sdjingdao.com Page 3 of 4 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD P4SMA Series PACKAGE OUTLINE Plastic surface mounted package; 2 leads A A SMA c a VM e A HE g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil g e A D a 0.3 12 The recommended mounting pad size 2.4 (94) 1.8 (71) 1.8 (71) 1.8 (71) mm Unit : (mil) 2017.01 JD 80404 6B0/7B2 Page 4 of 4
P4SMA6.8A 价格&库存
很抱歉,暂时无法提供与“P4SMA6.8A”相匹配的价格&库存,您可以联系我们找货
