PS10U150S&PS10U150FS
10.0AMPS. SCHOTTKY BARRIER RECTIFIERS
FEATURE
.High current capability
.Ultra low forward voltage drop
.Low power loss, high efficiency
.High surge capability
.High temperature soldering guaranteed
260°C /10seconds, 0.25"(6.35mm)from case.
TO-220AB
PS10U150S
ITO-220AB
PS10U150FS
MECHANICAL DATA
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy
.Mounting position: any
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
MAXIMUM RATINGS (TC=25℃ unless otherwise noted)
Parameter
Symbol
Units
Maximum Recurrent Peak Reverse Voltage
VRRM
VRMS
VDC
150
V
105
V
150
V
IF(AV)
10.0
A
IFSM
120.0
A
CJ
TJ, TSTG
260
pF
-55 to +150
°C
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
Total device
at TC =100°C
Peak Forward Surge Current 8.3ms single half sine-wave
superimposed on rated load (JEDEC method)
Typical Junction Capacitance (Note 1)
Operation Junction Temperature and Storage Temperature
Maximum Mounting torque, M3 or 6-32 srew
1.1N•m (10 lbf•in)
ELECTICAL CHARACTERISTICS TC=25℃ unless otherwise noted)
Parameter
Symbol
Test conditions
TJ=25℃
Forward voltage drop
VF
TJ=125℃
Reverse leakage current
IR
TJ=25℃
TJ=125℃
IF=3A
IF=5A
IF=10A
IF=3A
IF=5A
IF=10A
VR=150V
VR=150V
THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted)
Typ
Max
0.68
0.73
0.81
0.54
0.60
0.67
------0.95
------0.80
0.1
15
Units
V
mA
Parameter
Symbol
PS10U150S
PS10U150FS
Units
Typical Thermal Resistance (Note 2)
R(JC)
2.0
3.0
°C /W
Notes:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Thermal Resistance from Junction to Case
1
RATING AND CHARACTERISTIC CURVES
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10.0
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
100
5.0
Single Phase Half Wave
60Hz Resistive or
inductive Load
100
150
200
TJ=125℃
10
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
1
0.1
CASE TEMPERTURE,(℃)
0.6
0.4
0.2
0.8
1.0
INSTANEOUS FORWARD VOLTAGE,(V)
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
160
8.3ms Single Half
Sine-Wave (JEDEC
Method)
120
INSTANEOUS REVERSE
CURRENT,(mA)
PEAK FORWARD SURGE
CURRENT,(A)
100
80
40
0.1
0.01
0.001
1
10
100
NUMBER OF CYCLES AT 60Hz
2
TJ=125℃
1
TJ=25℃
60
90
120
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(V)
150
PACKAGE OUTLINE DIMENSIONS
TO-220AB
L
TO-220AB
Min
Max
A .573(14.55) .603(15.32)
B
.412(10.5)
C .103(2.62) .113(2.87)
D .140(3.56) .160(4.06)
E .510(13.0) .560(14.3)
F .027(0.68) .037(0.94)
G .148(3.74) .154(3.91)
H .230(5.84) .270(6.86)
I .175(4.44) .185(4.86)
J .100(2.54) .110(2.79)
K .014(0.35) .025(0.64)
L .045(1.14) .055(1.40)
P .095(2.41) .105(2.67)
I
C
Dim
H
G
A
PIN 1 2
3
D
E
J
F
Dimensions in inches and (millimeters)
ITO-220AB
B
L
G
I
C
H
A
PIN 1 2
D
3
E
J
F
P
ITO-220AB
Min
Max
A .571(14.5) .610(15.5)
B .383(9.72) .406(10.3)
C .110(2.80) .126(3.20)
D .133(3.38) .162(4.10)
E .512(13.0) .551(14.0)
F .028(0.70) .035(0.90)
G .114(2.90) .138(3.50)
H .268(6.80) .291(7.40)
I .162(4.10) .185(4.70)
J .102(2.60) .110(2.80)
K .018(0.45) .026(0.65)
L .097(2.46) .113(2.86)
P .890(2.25) .113(2.85)
Dim
K
3
Marking and packaging illustration
1、Marking
SYMBOL
XX
XXXXX
XXX
A
B
XXX
Explanation
A
B
C
D
Trademark
Product Name
Date Code
Product Information
C
D
2、Packaging
A
B
C
Tube
Inside Box
类别
TO-220
Tube(50EA per tube )
TO-220
Inside Box(1K per box)
TO-220
outside Box(6K per box)
Outside Box
A(mm)
B(mm)
C(mm)
530±5
7±0.8
33±1
542±5
82±2
78±1
555±5
285±5
245±5
4
很抱歉,暂时无法提供与“PS10U150FS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.72450
- 50+0.36271
- 150+0.15920
- 500+0.13155
- 2000+0.11924
- 5000+0.11184
