MURS360
MURS360
    SMCDIODESOLUTIONS(桑德斯)
    SMC(DO-214AB)
    MURS360
MURS360 数据手册
MURS360 Technical Data Data Sheet N0241, Rev. B MURS360 ULTRAFAST RECTIFIE Features Ultra-Fast Switching High Current Capability Low Reverse Leakage Current High Surge Current Capability Plastic Material has UL Flammability Classification 94V-O This is a Pb − Free Device All SMC parts are traceable to the wafer lot         SMC Circuit Diagram Additional testing can be offered upon request Mechanical Data     Case: Low Profile Molded Plastic Terminals: Solder Plated, Solderable per MIL-STD-750, Method 2026 Polarity: Cathode Band or Cathode Notch Weight: 0.23grams(approx) Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol MURS360 VRRM VRWM VR 600 V VR(RMS) 420 V Io 3.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 150 A Forward Voltage (per element) @IF = 3.0A VFM 1.25 V Peak Reverse Current At Rated DC Blocking Voltage @TA = 25°C @TA = 125°C IRM 5.0 500 µA Maximum Reverse Recovery Time (Note 1) Trr 50 ns Typical Thermal Resistance Junction to Ambient (Note 2) RθJA 25 K/W TJ -55 to +150 °C TSTG -55 to +150 °C Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current (Note 1) @TA = 55°C Junction Temperature Storage Temperature Range Note: 1. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 2. Mount on Cu-Pad Size 16mm×16mm on P.C.B.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Unit MURS360 Technical Data Data Sheet N0241, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MURS360 Technical Data Data Sheet N0241, Rev. B Mechanical Dimensions SMC SYMBOL Ordering Information Device MURS360 Package SMC (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 5.59 6.22 0.220 0.245 B 6.60 7.11 0.260 0.280 C 2.75 3.25 0.108 0.128 D 0.152 0.305 0.006 0.012 E 7.75 8.25 0.305 0.325 F 2.00 2.95 0.079 0.116 G 0.051 0.203 0.002 0.008 H 0.76 1.60 0.030 0.063 Marking Diagram Where XXXXX is YYWWL Shipping MURS 3 60 YY WW L 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Device Type = Forward Current (3A) = Reverse Voltage (600V) = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification SMC SYMBOL A B C d E F P P0 P1 T W Millimeters Min. Max. 5.90 8.20 2.40 1.40 1.40 7.60 7.90 3.90 3.90 15.80  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  6.10 8.40 2.60 1.60 1.60 7.70 8.10 4.10 4.10 0.600 16.20 MURS360 Technical Data Data Sheet N0241, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
MURS360 价格&库存
很抱歉,暂时无法提供与“MURS360”相匹配的价格&库存,您可以联系我们找货
