FH35C-41S-0.3SHW(50)
    HRS(广濑)
    SMD,P=0.3mm,卧贴
    FPC/FFC连接器 间距:0.30mm 41Pin 翻盖式 卧贴
FH35C-41S-0.3SHW(50) 数据手册
0.3 mm pitch, 0.9 mm height, back flip type dual-sided FPC connector FH35C Series %#.bb ●3.2 mm in depth &'#& Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. bb (*e ^c b (#'b ■Features 1.0.3 mm pitch, Dual-sided connector This connector utilizes both a top and bottom contact and provides design flexibility. ●At Time of FPC Insertion 2.Improved FPC retention force achieved through the use of our proprietary contact structure and a back flip actuator. FPC retention force (in the horizontal direction) is about 2.5 times greater than similar products produced by other companies. 3.Supports high speed transmissions By utilizing its excellent impedance characteristics, it is capable of supporting high speed transmissions. (Differential pairs of identical contacts allows for better transmission characteristics and eDP (ver1.3) and compatibility to MIPI(D−PHY) specifications.) 4.Delivered with actuator open ●Lock Completion State To reduce installation time and costs, the actuator is delivered in the open position and eliminates the need to open the actuator before FPC insertion. 5.Easy FPC Insertion Equipped with tapered guides at the FPC insertions point, they help to create a smoother FPC insertion operation. 6.Compatible with 0.2mm thick FPC The FH35C was designed to be used with 0.2 mm FPC. (Using the appropriate FPC will prevent deformation and problems that may occur during the insertion and mating processes.) 7.Bottom side protection The bottom surface is over-molded and provides added protection to the contacts (no exposure). This allows the PCB space under the connector to be used for additional patterning. FH35C Differential Impedance 130ps rise time (20-80%) 8.Halogen Free Chlorine and bromine levels do not exceed the standard values as defined by IEC 61249-2-21. (Br: 900 ppm or less, Cl : 900 ppm or less, Br + Cl : 1,500 ppm or less) 9.Compatible with Automatic Mounting Tape-and-reel packaging is available for use with pick-andplace machines. Connectors are available on 5000 or 500 piece reels. (The outer diameter of an embossed reel is Ø180mm) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2013.11② 1 FH35C Series●0.3 mm pitch, 0.9 mm height, back flip type dual-sided FPC connector ■Product Specifications Operating temperature Range: –55 to +85°C (Note 2) Operating temperature Range: 90% or less of relative humidity (No dew condensation is allowed) Current rating: 0.2 A (Note 1) Voltage rating: AC 30 Vrms Ratings With specifications compatible with FPC contacts Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Storage temperature Range: -10 to +50°C (Note 3) Storage temperature Range: 90% or less of relative humidity (No dew condensation is allowed) t = 0.2 ± 0.03 gold plating Specifications Conditions 1.Insulation Resistance No less than 50 Mø Measured at 100 V DC 2.Withstand Voltage No flashover or breakdown Conduct 90 V AC for one minute 3.Contact Resistance 100 mø MAX. * Including FPC conductor resistance AC 20 mV MAX (1 KHz), 1 mA 4.Mating Cycles Contact resistance: no more than 100 mø No breakage, cracks, or loosened parts 10 times 5.Vibration Resistance No electric outage of 1 µs or greater Contact resistance: no more than 100 mø No breakage, cracks, or loosened parts At the frequency of 10-55 Hz, half amplitude 0.75 mm, and 10 cycles in each of three axial directions 6.Shock Resistance No electric outage of 1 µs or greater Contact resistance: no more than 100 mø No breakage, cracks, or loosened parts Acceleration: 981 m/s Duration: 6 ms, sine half-wave, 3 cycles in each of the 3 axis each in both directions 7.Humidity Resistance (Steady State) Contact resistance: no more than 100 mø Insulation Resistance: 50 Mø or more No breakage, cracks, or loosened parts Left to stand for 96 hours at the temperature of 40°C and the humidity of 90% to 95% 8.Temperature Cycles Contact resistance: no more than 100 mø Insulation Resistance: 50 Mø or more No breakage, cracks, or loosened parts 9.Solder Heat Resistance No deformation in appearance or marked instability of contacts 2 Temperature:-55➝ +15 to+35➝ +85➝ +15 to +35°C Time: 30➝ 2 to 3 ➝ 30➝ 2 to 3 minutes 5 cycles with the above conditions Reflow: According to the Recommended Temperature Profile Manual soldering: 350± 10°C for 5± 1 sec. (Note 1) Use at 70% of the current rating when all pins are energized with the stated current rating. (Note 2) Temperature rise at the time of electrification is included. (Note 3) The term “storage” refers to the long-term storage condition of unused products before mounting on the PCB. The operating temperature and humidity ranges apply to non-energized state after PCB mounting. (Note 4) The above specifications are representative of this series. Please refer to “drawing for approval” for official individual agreement. ■Materials Part Materials Treatment LCP Gray Polyamide resin Black Contact Phosphor bronze Nickel barrier Gold plating Metal fitting Phosphor bronze Pure tin reflow plating Insulator UL Regulation UL94V-0 ------ ■Product Number Structure Refer to the chart below when searching for the part number nomenclature. Please select connectors listed in this catalog when placing orders. The characteristics and specifications of the products described in this catalog are for reference only. Please make sure to check the latest delivery specifications before the time of purchase. FH 35 C − 35S − 0.3 SHW (50) ❶ ❷ ❸ ❹ ❶ Series Name: FH ❷ Series No.: 35 ❸ C: dual-sided, halogen-free product ❹ Number of contacts : 9 to 51 ❺ Contact Pitch: 0.3 mm 2 ❺ ❻ ❼ ❻ Contact Form SHW: SMT horizontal staggered array mount type ❼ Specifications: (50): standard product (5000 connectors per reel) (99): 500 connectors per reel FH35C Series●0.3 mm pitch, 0.9 mm height, back flip type dual-sided FPC connector ■Connector Dimensions 6¤%#&* 7¤%#& %#&' &#+ %#+¤%#& (#(* %#(¤%#& %#&' %#+¤%#& 8¤%#& 9^heaVnd[i]Z cjbWZgd[XdgZh 9^heaVnZY =GHbVg` 8Vk^inCd# EdaVg^inbVg` %#&* %#+ 9 ( :¤%#& )#' %#(* %#.¤%#& ;E8/%#'  %é &#)* &#&* %#** %#)¤%#& %#%*¤%#&* (¤%#&* &#- V9ZiV^aYgVl^c\ . Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. V %#((¤%#& %#&*¤%#&* Note 1: The lead coplanarity of contact and reinforcing metal fitting is a MAX of 0.1 mm. 2: This product packaged on tape-and-reel. See the package specification diagram for details. 3: Dimensions may be changed for sink mark prevention due to improvement, etc. In addition, black dots, etc., may occur in the mold resin but they have no effect on quality. 4: This product is halogen-free. (Br content: 900 ppm or less; CI content: 900 ppm or less; Br + CL total content: 1,500 ppm or less) ■Connector Dimension Table Product No. FH35C-9S-0.3SHW(50) FH35C-11S-0.3SHW(50) FH35C-13S-0.3SHW(50) FH35C-15S-0.3SHW(50) FH35C-17S-0.3SHW(50) FH35C-19S-0.3SHW(50) FH35C-21S-0.3SHW(50) FH35C-23S-0.3SHW(50) FH35C-25S-0.3SHW(50) FH35C-27S-0.3SHW(50) FH35C-31S-0.3SHW(50) FH35C-33S-0.3SHW(50) FH35C-35S-0.3SHW(50) FH35C-37S-0.3SHW(50) FH35C-39S-0.3SHW(50) FH35C-41S-0.3SHW(50) FH35C-45S-0.3SHW(50) FH35C-49S-0.3SHW(50) FH35C-51S-0.3SHW(50) HRS No. CL580-2910-5-50 CL580-2917-4-50 CL580-2925-2-50 CL580-2919-0-50 CL580-2916-1-50 CL580-2921-1-50 CL580-2922-4-50 CL580-2911-8-50 CL580-2912-0-50 CL580-2918-7-50 CL580-2923-7-50 CL580-2913-3-50 CL580-2926-5-50 CL580-2914-6-50 CL580-2915-9-50 CL580-2924-0-50 CL580-2909-6-50 ––––––– CL580-2920-9-50 Unit: mm The number of contacts 9 11 13 15 17 19 21 23 25 27 31 33 35 37 39 41 45 49 51 A 4.3 4.9 5.5 6.1 6.7 7.3 7.9 8.5 9.1 9.7 10.9 11.5 12.1 12.7 13.3 13.9 15.1 16.3 16.9 B 1.8 2.4 3 3.6 4.2 4.8 5.4 6 6.6 7.2 8.4 9 9.6 10.2 10.8 11.4 12.6 13.8 14.4 C 2.4 3 3.6 4.2 4.8 5.4 6 6.6 7.2 7.8 9 9.6 10.2 10.8 11.4 12 13.2 14.4 15 D 3.03 3.63 4.23 4.83 5.43 6.03 6.63 7.23 7.83 8.43 9.63 10.23 10.83 11.43 12.03 12.63 13.83 15.03 15.63 E 3.73 4.33 4.93 5.53 6.13 6.73 7.33 7.93 8.53 9.13 10.33 10.93 11.53 12.13 12.73 13.33 14.53 15.73 16.33 The products with no HRS No. are currently under planning. Please contact our sales representative for questions concerning the number of contacts. 3 FH35C Series●0.3 mm pitch, 0.9 mm height, back flip type dual-sided FPC connector %#(¤%#%' c"&$' %#%' M 8dccZXidg^bV\Z¬BdjciZYhjg[VXZ c &$' %#%' M %#(¤%#%' %#+ %#)¤%#%( %#*¤%#%( 8 M %#'¤%#%( %#.*¤%#%( %#(* %#' %#-¤%#%( (#+ 7 %#+ '#&*¤%#%( %#+*¤%#%( ■Recommended Land Dimensions GZXdbbZcYZYBZiVaBVh`I]^X`cZhh/i2%#& %#**¤%#%' Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Recommended Land and Metal Mask Dimensions 7 %#+ %#'(¤%#%' c"&$' %#%' N c &$' %#'(¤%#%' %#+ N 8 %#%' %#(¤%#%' %#.¤%#%' N %#'¤%#%' %#,¤%#%' %#+*¤%#%' (#+ '#)¤%#%' AVcYeViiZgc^bV\Z Note 5: 'n' represents the number of contacts. ■Recommended Land and Metal Mask Dimensions Product No. FH35C-9S-0.3SHW(50) FH35C-11S-0.3SHW(50) FH35C-13S-0.3SHW(50) FH35C-15S-0.3SHW(50) FH35C-17S-0.3SHW(50) FH35C-19S-0.3SHW(50) FH35C-21S-0.3SHW(50) FH35C-23S-0.3SHW(50) FH35C-25S-0.3SHW(50) FH35C-27S-0.3SHW(50) FH35C-31S-0.3SHW(50) FH35C-33S-0.3SHW(50) FH35C-35S-0.3SHW(50) FH35C-37S-0.3SHW(50) FH35C-39S-0.3SHW(50) FH35C-41S-0.3SHW(50) FH35C-45S-0.3SHW(50) FH35C-49S-0.3SHW(50) FH35C-51S-0.3SHW(50) 4 HRS No. CL580-2910-5-50 CL580-2917-4-50 CL580-2925-2-50 CL580-2919-0-50 CL580-2916-1-50 CL580-2921-1-50 CL580-2922-4-50 CL580-2911-8-50 CL580-2912-0-50 CL580-2918-7-50 CL580-2923-7-50 CL580-2913-3-50 CL580-2926-5-50 CL580-2914-6-50 CL580-2915-9-50 CL580-2924-0-50 CL580-2909-6-50 ––––––– CL580-2920-9-50 No. of Contacts 9 11 13 15 17 19 21 23 25 27 31 33 35 37 39 41 45 49 51 Unit: mm B 1.8 2.4 3 3.6 4.2 4.8 5.4 6 6.6 7.2 8.4 9 9.6 10.2 10.8 11.4 12.6 13.8 14.4 C 2.4 3 3.6 4.2 4.8 5.4 6 6.6 7.2 7.8 9 9.6 10.2 10.8 11.4 12 13.2 14.4 15 FH35C Series●0.3 mm pitch, 0.9 mm height, back flip type dual-sided FPC connector ■Recommended FPC Dimensions ;¤%#%* %#'¤%#%( 8 O %#(¤%#%, c &$' G %# W &#,*¤%#( GZ[ZgZcXZ\ZdbZign B^hVa^\cbZciX]ZX`bVg` C Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. %#* &#'* ' '#&¤%#& 6M %#'¤%#& B O %#,*¤%#& %#-*¤%#& %#%' %#( '#-*¤%#(Hi^[[ZcZg[^ab %#%) %#( "%#%( %#+ '#'*¤%#& %#(¤%#%, %#&¤%#%' %#%, %#( %#' c"&$' %#%) "%#%( %#%' 7 %#+¤%#%, O %#+¤%#%, Note 6: FPC should be designed so that the dimension of N is 0.5 mm or more. ■Recommended FPC Dimensions Product No. FH35C-9S-0.3SHW(50) FH35C-11S-0.3SHW(50) FH35C-13S-0.3SHW(50) FH35C-15S-0.3SHW(50) FH35C-17S-0.3SHW(50) FH35C-19S-0.3SHW(50) FH35C-21S-0.3SHW(50) FH35C-23S-0.3SHW(50) FH35C-25S-0.3SHW(50) FH35C-27S-0.3SHW(50) FH35C-31S-0.3SHW(50) FH35C-33S-0.3SHW(50) FH35C-35S-0.3SHW(50) FH35C-37S-0.3SHW(50) FH35C-39S-0.3SHW(50) FH35C-41S-0.3SHW(50) FH35C-45S-0.3SHW(50) FH35C-49S-0.3SHW(50) FH35C-51S-0.3SHW(50) HRS No. CL580-2910-5-50 CL580-2917-4-50 CL580-2925-2-50 CL580-2919-0-50 CL580-2916-1-50 CL580-2921-1-50 CL580-2922-4-50 CL580-2911-8-50 CL580-2912-0-50 CL580-2918-7-50 CL580-2923-7-50 CL580-2913-3-50 CL580-2926-5-50 CL580-2914-6-50 CL580-2915-9-50 CL580-2924-0-50 CL580-2909-6-50 ––––––– CL580-2920-9-50 Unit: mm No. of Contacts 9 11 13 15 17 19 21 23 25 27 31 33 35 37 39 41 45 49 51 B 1.8 2.4 3 3.6 4.2 4.8 5.4 6 6.6 7.2 8.4 9 9.6 10.2 10.8 11.4 12.6 13.8 14.4 C 2.4 3 3.6 4.2 4.8 5.4 6 6.6 7.2 7.8 9 9.6 10.2 10.8 11.4 12 13.2 14.4 15 F 3 3.6 4.2 4.8 5.4 6 6.6 7.2 7.8 8.4 9.6 10.2 10.8 11.4 12 12.6 13.8 15 15.6 5 FH35C Series●0.3 mm pitch, 0.9 mm height, back flip type dual-sided FPC connector BFPC material composition (Recommended specifications) 1.Single-Sided FPC Name of material Cover lay film Material property Polyimide 1 mil (25) (25) Cover adhesive Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Thickness (µm) Surface treatment Nickel undercoat 1 to 5µm+ Gold plating 0.2µm Copper foil Cu Base adhesive Heat hardened adhesive 25 Base film Polyimide 25 Reinforcement material adhesive Heat hardened adhesive 40 Stiffener film Polyimide 75 3 35 1 oz 1 mil 3 mil 203 Total 2.Double-Sided FPC Name of material Cover lay film Material property Polyimide 1 mil (25) (25) Cover adhesive Surface treatment Thickness (µm) Nickel undercoat 1 to 5 µm+ Gold plating 0.2 µm 3 Through-hole copper plating Cu 15 18 Copper foil Cu ½ oz Base adhesive Thermoset adhesive 18 Base film Polyimide 25 Base adhesive Thermoset adhesive Copper foil Cu Cover adhesive Thermoset adhesive 25 Cover lay film Polyimide 25 Reinforcement material adhesive Thermoset adhesive Stiffener film Polyimide 1 mil ½ oz 18 (18) 1 mil 1 mil Total 25 25 197 *When using Double-Sided FPC, the copper foil on the back side of the FPC should be eliminated. This is to prevent any unintentional unlocking due to bent or deformed FPC. 3.Additional notes on FPC 1. The FPC material composition is to be used as a reference example. Please make sure that the thickness of the FPC mating area is 0.2± 0.03 mm as previously referred to in the product specification section. 2. Please contact the FPC manufacturer for the details on its material composition. 6 FH35C Series●0.3 mm pitch, 0.9 mm height, back flip type dual-sided FPC connector BPackaging Specifications ●Emboss Carrier Tape Dimensions (with tape width of 32 mm or more) &#,*¤%#& % % #& )¤%#& ' ?¤%#& =¤%#&
FH35C-41S-0.3SHW(50) 价格&库存
很抱歉,暂时无法提供与“FH35C-41S-0.3SHW(50)”相匹配的价格&库存,您可以联系我们找货
  • 1+2.52450
  • 10+1.99980
  • 1000+1.22265
  • 2000+1.21042
  • 5000+1.18621
库存:4700
  • 1+2.75400
  • 10+2.18160
  • 30+1.93320
  • 100+1.53900
  • 500+1.41588
  • 1000+1.33380
库存:1780
    • 1+3.08550
    • 10+2.44420
    • 30+2.16590
    • 100+1.72430
    • 500+1.58630
    • 1000+1.49440
    库存:1847
