XNM50550ATS
XNM50550ATS
    XINER(芯能)
    XNM50550ATS
XNM50550ATS 数据手册
技术信息 / Technical Information Xiner XNM50550AT/ATS 智能功率模块 / IPM 描述/Description  XNM50550AT/ATS基于快恢复MOSFET技术,为小功率电机驱动应用(如风扇和水泵)提供紧凑型逆变解决方案。 XNM50550AT/ATS is an Advanced IPM Based on Fast-Recovery MOSFET Technology as a Compact Inverter Solution for Small Power Motor Drive Applications Such as Fans and Pumps.  XNM50550AT/ATS由6个MOSFET、3个HVIC、3个自举二极管和1个NTC组成,紧凑高绝缘并具有优化的热性能。 XNM50550AT/ATS Contains Six MOSFETs, Three Half-Bridge Gate Drive HVICs, Three Bootstrap Diodes and a NTC in a Compact Package Fully Isolated and Optimized for Thermal Performance.  XNM50550AT/ATS通过优化开关速度和减小寄生电感实现低电磁干扰(EMI)特性。 XNM50550AT/ATS Features Low Electromagnetic Interference (EMI) Characteristics Through Optimizing Switching Speed and Reducing Parasitic Inductance.  XNM50550AT/ATS使用MOSFET比使用IGBT更坚固耐用,具有更大的安全操作区(SOA)。 Since XNM50550AT/ATS Employs MOSFETs as Power Switches, It Provides Much More Ruggedness and Larger Safe Operating Area (SOA) than IGBT-Based Power Modules.  XNM50550AT/ATS内置于电机的应用和要求紧凑安装的场合。 XNM50550AT/ATS is the Right Solution for Compact and Reliable Inverter Designs Where the Assembly Space is Constrained. 主要特点 •内置6个500V/1.2Ω MOSFET和3个半桥栅极驱 动(HVIC) •3个独立的MOSFET源极副直流端用于变频器电 流检测的应用 Features • 500 V RDS(on)= 1.2Ω MOSFET 3-Phase Inverter Including HVICs • Three Separate Open-Source Pins from Low Side MOSFETs for Three Leg Current Sensing •HVIC实现驱动和欠压保护功能 •完全兼容3.3V和5V的MCU接口,高电平有效 •优化并采用了低电磁干扰设计 •绝缘级别1500Vrms/1min •内置负温度系数的电阻用于温度检测 •封装内置自举二极管 •符合ROHS • HVIC for Gate Driving and Undervoltage Protection • Active-High Interface, Can Work With 3.3 V / 5 V Logic • Optimized for Low Electromagnetic Interference • Isolation Voltage Rating of 1500 Vrms for 1 min. •Temperature feedback via NTC • Embedded Bootstrap Diode in the Package • ROHS Compliant 应用 •小功率电机 Applications • Small Power AC Motor IPM-DIP23 深圳芯能半导体技术有限公司 Http://www.invsemi.com IPM-SOP23 Datasheet XNM50550AT/ATS 技术信息 / Technical Information XNM50550AT/ATS Xiner 智能功率模块 / IPM 引脚描述 / Pin descriptions 引脚号/Pin Number 引脚名/Pin Name 1 COM 2 VB(U) 3 VCC(U) 4 IN(UH) 5 IN(UL) 6 N.C 7 VB(V) 8 VCC(V) 9 IN(VH) 10 IN(VL) 11 VTH 12 VB(W) 13 VCC(W) 14 IN(WH) 15 IN(WL) 16 N.C 17 P 18 U, VS(U) 19 NU 20 NV 21 V, VS(V) 22 NW 23 W, VS(W) 深圳芯能半导体技术有限公司 Http://www.invsemi.com 引脚描述/ Pin Description IC公共电源接地 IC Common Supply Ground U相高端MOSFET驱动的偏压 Bias Voltage for U Phase High Side MOSFET Driving U相IC和低端MOSFET驱动的偏压 Bias Voltage for U Phase IC and Low Side MOSFET Driving U相高端的信号输入 Signal Input for U Phase High-Side U相低端的信号输入 Signal Input for U Phase Low-Side 无连接 N.C V相高端MOSFET驱动的偏压 Bias Voltage for V Phase High Side MOSFET Driving V相IC和低端MOSFET驱动的偏压 Bias Voltage for V Phase IC and Low Side MOSFET Driving V相高端的信号输入 Signal Input for V Phase High-Side V相低端的信号输入 Signal Input for V Phase Low-Side 热敏电阻电压 NTC Voltage W相高端MOSFET驱动的偏压 Bias Voltage for W Phase High Side MOSFET Driving W相IC和低端MOSFET驱动的偏压 Bias Voltage for W Phase IC and Low Side MOSFET Driving W相高端的信号输入 Signal Input for W Phase High-Side W相低端的信号输入 Signal Input for W Phase Low-Side 无连接 N.C 直流输入正端 Positive DC–Link Input 高端MOSFET驱动的U相偏压接地输出 Output for U Phase & Bias Voltage Ground for High Side MOSFET Driving U相的直流输入负端 Negative DC–Link Input for U Phase V相的直流输入负端 Negative DC–Link Input for V Phase 高端MOSFET驱动的V相偏压接地输出 Output for V Phase & Bias Voltage Ground for High Side MOSFET Driving W相的直流输入负端 Negative DC–Link Input for W Phase 高端MOSFET驱动的W相偏压接地输出 Output for W Phase & Bias Voltage Ground for High Side MOSFET Driving Datasheet XNM50550AT/ATS 技术信息 / Technical Information XNM50550AT/ATS Xiner 智能功率模块 / IPM C1 (1) COM (2) VB(U) (3) VCC(U) R5 (4) IN(UH) (5) IN(UL) C5 (6) N.C C2 (17) P VCC VB HIN HO LIN VS COM LO (18) U,VS(U) (19) NU C3 VDC (7) VB(V) (20) NV (8) VCC(V) Micom (9) IN(VH) (10) IN(VL) (11) VTH VCC VB HIN HO LIN VS COM LO VCC VB HIN HO LIN VS COM LO M (21) V,VS(V) (12) VB(W) VDD (22) NW (13) VCC(W) (14) IN(WH) (15) IN(WL) (23) W,VS(W) (16) N.C C4 R4 15V Supply C6 R3 应用电路实例 . Example of Application Circuit 注/Note: 1. 关于引脚的位置请参阅图1。 About Pin Position, Refer to Figure 1. 2. IPM产品和MCU的每个输入端的RC耦合(R5和C5,R4和C6)和C4,能有效地防止由浪涌噪声产生的错误的输入信号。 RC Coupling (R5 and C5, R4and C6) and C4 at Each Input of IPM Mcu are Useful to Prevent Improper Input Signal Caused by Surge Noise. 3. 由于位于COM和低端MOSFET的源极端子之间,R3的压降会影响低端的开关性能和自举特性。为此稳态情况下的R3的压降应小于1V。 The voltage Drop Across R3 Affects the Low Side Switching Performance and the Bootstrap Characteristics Since it is Placed Between COM and the Source Terminal of the Low Side MOSFET. For this Reason, the Voltage Drop Across R3 Should Be Less Than 1 V in the Steady-State. 4. 为避免浪涌电压和HVIC故障,接地线和输出端子之间的接线应短且粗。 Ground Wires and Output Terminals, Should Be Thick and Short in Order to Avoid Surge Voltage and Malfunction of HVIC. 5. 所有的滤波电容器应紧密连接到IPM产品,他们应当具有能够很好的阻挡高频纹波电流的特性。 All the Filter Capacitors Should Be Connected Close to Motion SPM, and They Should Have Good Characteristics for Rejecting High-Frequency Ripple Current. 深圳芯能半导体技术有限公司 Http://www.invsemi.com Datasheet XNM50550AT/ATS 技术信息 / Technical Information XNM50550AT/ATS Xiner 智能功率模块 / IPM 轮廓封装详图 / Detailed Package Outline Drawings IPM-DIP23 深圳芯能半导体技术有限公司 Http://www.invsemi.com Datasheet XNM50550AT/ATS 技术信息 / Technical Information XNM50550AT/ATS Xiner 智能功率模块 / IPM IPM-SOP23 深圳芯能半导体技术有限公司 Http://www.invsemi.com Datasheet XNM50550AT/ATS
XNM50550ATS 价格&库存
很抱歉,暂时无法提供与“XNM50550ATS”相匹配的价格&库存,您可以联系我们找货
