SS26BF
SS26BF
    JINGDAO(晶导微电子)
    SMBF
    SS26BF
SS26BF 数据手册
山东晶导微电子股份有限公司 SS22BF THRU SS220BF Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200V Forward Current - 2.0A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 1 2 Simplified outline SMBF and symbol MECHANICAL DATA • Case: SMBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 57 mg / 0.002oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS22BF SS24BF SS26BF SS28BF SS210BF SS212BF SS215BF SS220BF Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) 2.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 50 A Max Instantaneous Forward Voltage at 2 A VF Maximum DC Reverse Current T a = 25°C T a =100°C IR 0.5 5 0.3 3 mA Typical Junction Capacitance(1) Cj 220 110 pF Typical Thermal Resistance (2) RθJA 75 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C at Rated DC Reverse Voltage Operating Junction Temperature Range Storage Temperature Range 0.55 0.70 0.85 0.95 V (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2016.01 SMBF-S-SS22BF~SS220BF-2A200V Page 1 of 3 山东晶导微电子股份有限公司 SS22BF THRU SS220BF Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =75°C 10 2 SS22BF/SS26BF T J =25°C 10 0 0 60 80 T J =25°C 10 1.0 SS22BF/SS24BF SS26BF/SS28BF SS210BF/SS212BF SS215BF/SS220BF 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 500 200 100 20 SS22BF~SS26BF SS28BF~SS220BF 10 1.8 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance SS22BF-SS28BF SS210BF-SS220BF 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 1000 Instaneous Forward Voltage (V) 60 10 Junction Capacitance ( pF) T J =25°C 20 100 Fig.4 Typical Junction Capacitance 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) SS28BF-SS220BF 10 1 Case Temperature (°C) 100 Number of Cycles at 60Hz 2016.01 T J =100°C 10 3 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 SS22BF THRU SS220BF Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMBF ∠ALL ROUND C A ∠ALL ROUND D E A V M g Top View mil Bottom View g A C D E HE e max 1.3 0.26 4.4 3.7 5.5 2.2 min 1.1 0.18 4.2 3.5 5.1 1.9 max 51 10 173 146 216 86 min 43 7 165 138 200 75 UNIT mm g pad e E A pad HE 1.0 9° 40 Marking The recommended mounting pad size Type number 3.0(118) 1.8(71) 2.54(100) 1.8(71) Unit:mm(mil) 2016.01 ∠ XTH601154B0 Marking code SS22BF S22B SS24BF S24B SS26BF S26B SS28BF S28B SS210BF S210B SS212BF S212B SS215BF S215B SS220BF S220B Page 3 of 3
SS26BF
物料型号: - SS22BF - SS24BF - SS26BF - SS28BF - SS210BF - SS212BF - SS215BF - SS220BF
器件简介: - 这些器件是表面安装肖特基势垒整流器,具有金属硅结和多数载流子导电特性。 - 适用于表面安装应用,具有低功耗、高效率。 - 具有高正向浪涌电流能力。 - 适用于低电压、高频逆变器、自由轮流通路和极性保护应用。
引脚分配: - 引脚1:阴极 - 引脚2:阳极
参数特性: - 最大重复峰值反向电压(VRRM):20V至200V - 最大有效值电压(VRMS):14V至140V - 最大直流阻断电压(Voc):与VRRM相同 - 最大平均正向整流电流(IF(AV)):2.0A - 正向浪涌电流(IFSM):50A(对于SS26BF) - 最大瞬时正向电压在2A时(VF):0.55V至0.95V - 最大直流反向电流(IR):0.5mA至5mA - 典型结电容(C):220pF至110pF - 典型热阻(RaJA):75°C/W - 工作结温范围(T1):-55°C至+150°C - 存储温度范围(Tstg):-55°C至+150°C
功能详解: - 这些整流器在单相半波60Hz的电阻性或感性负载下工作。 - 正向电流降额曲线、典型反向特性、典型正向特性、典型结电容和最大非重复峰值正向浪涌电流等图表提供了详细的功能描述。
应用信息: - 适用于低电压、高频逆变器、自由轮流通路和极性保护等应用。
封装信息: - 封装类型:SMBF - 引脚:可焊,符合MIL-STD-750标准 - 重量:约57毫克(0.002盎司) - 推荐安装垫尺寸:1.8mm(71mil)x 3.0mm(118mil) - 标记代码:每个型号有对应的标记代码,如SS22BF对应S22B。
SS26BF 价格&库存
很抱歉,暂时无法提供与“SS26BF”相匹配的价格&库存,您可以联系我们找货
