山东晶导微电子有限公司
SS34LF
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 40V
Forward Current - 3.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS34L
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 27mg / 0.00095oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS34LF
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
28
V
Maximum DC Blocking Voltage
V DC
40
V
Maximum Average Forward Rectified Current
I F(AV)
3.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
80
A
VF
0.5
V
IR
0.3
5
mA
Cj
300
pF
RθJA
65
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
Max Instantaneous Forward Voltage at 3 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating Junction Temperature Range
Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SMAF-S-SS34LF-3A40V
Page 1 of 3
山东晶导微电子有限公司
SS34LF
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 1
T J =25°C
10 0
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
0.1
1.0
500
100
0.1
1
10
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
1000
1.5
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
100
10
Number of Cycles at 60Hz
2016.01
T J =100°C
10 3
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS34LF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
47
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
D
E
A
V M
7°
The recommended mounting pad size
Marking
Type number
2.2
(86)
1.6
(63)
SS34LF
Marking code
SS34L
1.8
(71)
1.6
(63)
mm
Unit :
(mil)
2016.01
XTH601155B5
Page 3 of 3
很抱歉,暂时无法提供与“SS34LF”相匹配的价格&库存,您可以联系我们找货
