BL-HB336G-AV-TRB
BL-HB336G-AV-TRB
    BRTLED(佰鸿)
    发光二极管/LED 蓝色 0603 SMT
BL-HB336G-AV-TRB 数据手册
BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB Specification for Approval ● SAMPLES  ATTACHED AREA  DEVICE NUMBER: BL-HB336G-AV-TRB PAGE DATE 2015.09.02 1 2 3 4 5 1.0 1.0 1.0 1.0 1.0 6 7 8 CONTENTS 1.0 1.0 1.0 Initial Released FOR CUSTOMER’S APPROVAL STAMP OR SIGNATURE APPROVED PURCHASE 佰鴻工業股份有限公司 MANUFACTURE ISSUED QUALITY ENGINEERING APPROVED PREPARED BRIGHT LED ELECTRONICS CORP. 新北市板橋區和平路 19 號 3 樓 3F., No.19, He Ping Road, Ban Qiao Dist., New Taipei City, Taiwan Tel: +886-2-29591090 張 占 任 2015.09.02 2015.09.02 2015.09.02 孝 嚴 旭 穎 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ● Features: ●Package Dimensions: 1. Emitted Color : Super Blue 2. Lens Appearance : Water Clear 1.6 0.8 3. Mono-color type. 4. 1.6x0.8x0.4mm(0603) standard package 5. Suitable for all SMT assembly methods. 6. Compatible with infrared and vapor phase reflow solder process. 7. Compatible with automatic placement equipment. 8. This product doesn’t contain restriction Substance, comply ROHS standard. NOTES: 1.All dimensions are in millimeters (inches). 2.Tolerance is ± 0.10mm (0.004”) unless otherwise specified. 3.Specifications are subject to change without notice. ● Applications: 1. Automotive : Dashboards, stop lamps, turn signals. 2. Backlighting : LCDs, Key pads advertising. 3. Status indicators : Comsumer & industrial electronics. 4. General use. ● Absolute Maximum Ratings(Ta=25℃) Parameter Symbol Rating Unit Power Dissipation Pd 70 mW Forward Current IF 5 mA Peak Forward Current *1 IFP 100 mA Reverse Voltage VR 5 V Operating Temperature Topr -40℃~85℃ - Storage Temperature Tstg -40℃~85℃ - Soldering Temperature Tsol See Page 6 - * 1 Condition for IFp is pulse of 1/10 duty and 0.1msec width. Ver.1.0 Page 1 of 8 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ● Electrical and optical characteristics(Ta=25℃) Parameter Symbol Condition Min. Typ. Max. Unit Forward Voltage Vf IF=5mA - 2.8 3.2 Luminous Intensity Iv IF=5mA 12.3 25 - mcd Reverse Current IR VR=5V - - 1 µA Peak Wave Length λp IF=5mA - 460 - nm Dominant Wave Length λd IF=5mA 460 - 475 nm Spectral Line Half-width Δλ IF=5mA - 30 - nm Viewing Angle 2θ1/2 IF=5mA - 120 - deg V ● Typical Electro-Optical Characteristics Curves Fig.2 Forward current derating curve vs. ambient temperature Fig.1 Relative intensity vs. wavelength 50 40 Forward current (mA) Relative radiant intensity 1.0 0.5 30 20 10 0 410 460 0 510 Wavelength (nm) 50 80 100 2.5 20 (Normalized @20mA) Relative Luminous intensity 30 10 2.0 1.5 1.0 0.5 1 2 3 4 0 -40 5 -20 Forward voltage(V) 0 20 40 60 Ambient temperature Ta( C) Fig.5 Relative luminous intensity vs. forward current Fig.6 Radiation diagram 0 2.0 10 20 30 1.5 Relative radiant intensity Relative luminous intensity (@20mA) 60 3.0 40 Forward current (mA) 40 Fig.4 Relative luminous intensity vs. ambient temperature Fig.3 Forward current vs. forward voltage 0 20 Ambient temperature Ta( C) 1.0 0.5 1.0 40 0.9 50 0.8 60 70 0.7 80 90 0 10 20 30 40 50 0.5 0.3 0.1 0.2 0.4 0.6 Forward current (mA) Ver.1.0 Page 2 of8 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ● Tapping and packaging specifications(Units: mm) Quantity:1000-5000PCS END 8.0±0.3 START 13.0±0.5 CATHODE ANODE USER DIRECTION OF FEED ●Package Method:(unit:mm) Vacuum 12 bag/box 5000 pcs/reel 200 Bar Code Label 245 220 220 Aluminum Foil Bag 185 645 6 box/carton 210 470 Ver.1.0 Page 3 of 8 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ● Bin Limits I n t e n s i t y B i n L i m i ts ( A t 5 m A ) BIN CODE Min. (mcd) Max. (mcd) K 12.3 18.5 L 18.5 28 M 28 42 N 42 63 To l e r a n c e f o r e a c h B i n l i m i t i s ± 1 5 % . C o l o r B i n L i m i ts ( A t 5 m A ) BIN CODE Min. (nm) Max. (nm) 4-1 460 465 4-2 465 470 4-3 470 475 To l e r a n c e f o r e a c h B i n l i m i t i s ± 1 n m . V F B i n L i m i ts ( A t 5 m A ) BIN CODE Min.(v) Max.(v) E 2.4 2.6 F 2.6 2.8 G 2.8 3.0 H 3.0 3.2 To l e r a n c e f o r e a c h B i n l i m i t i s ± 0 . 0 5 V. ● B IN: x x x VF BIN CODE Color BIN CODE Intensity BIN CODE Ver.1.0 Page 4 of 8 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ● Reliability Test Classification Endurance Test Environmental Test Test Item Reference Standard MIL-STD-750D:1026 Operation Life MIL-STD-883D:1005 JIS-C-7021 :B-1 High Temperature MIL-STD-202F:103B High Humidity JIS-C-7021 :B-11 Storage High MIL-STD-883:1008 Temperature JIS-C-7021 :B-10 Storage Low Temperature JIS-C-7021 :B-11 Storage MIL-STD-202F:107D Temperature MIL-STD-750D:1051 Cycling MIL-STD-883D:1010 JIS-C-7021 :A-2 MIL-STD-202F:107D(1980) Thermal Shock MIL-STD-750D:1051(1995) MIL-STD-883D:1011(1991) Test Conditions Result Ta: Under room temperature Test time:1,000hrs IF=Product Recommended IF Ta:85±5℃ RH:90%-95% Test time:240hrs Ta:100±5℃ Test time:1,000hrs 0/32 0/32 0/32 Ta: -40±5℃ Test time=1,000hrs 0/32 Ta:-35±5℃~25±5℃~85±5℃~25±5℃ 30min 5min 30min 5min 0/32 Ta:-40±5℃ ~+85±5℃ 10min 10 min Time: 20min/cycle 10cycle 0/32 Wetting balance MIL-STD-883:2003 MIL-STD-202F:208D MIL-STD-883D:2003 Ta:230±5℃ Time:5±0.5s 0/32 Solder Resistance MIL-STD-202F:210A MIL-STD-883D:1011 JIS-C-7021 :A-1 Ta:260±10℃ Time:10±1s 0/32 ● Judgment criteria of failure for the reliability Measuring items Forward voltage Reverse current Luminous intensity Note: Symbol VF ( V) IR(uA) Iv ( mcd ) Measuring conditions IF=5mA VR=5V IF=5mA Judgement criteria for failure Initial Level*1.1 Over U*2 Initial Level*0.7 1.U means the upper limit of specified characteristics. 2.Measurment shall be taken between 2 hours and after the test pieces have been returned to normal ambient conditions after completion of each test. Ver.1.0 Page 5 of 8 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ●IR-Reflow Soldering 260℃ Max. 10sec.Max. Above255℃ 30sec.Max. 3℃/sec.Max. 6℃/sec.Max. Above 217℃ 60~150sec. Pre-heating 150~200℃ 60~120sec. 1. Avoid any external stress applied to the resin while the LEDs are at high temperature, especially during soldering . 2. Avoid rapid cooling or any excess vibration during temperature ramp-down process 3. Although the soldering condition is recommended above, soldering at the lowest possible temperature is feasible for the LEDs Ver.1.0 Page 6 of 8 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ● Dip Soldering TEMPERATURE( °C) 300 Max:260℃,5sec. Suggest:2~3sec. 250 200 150 100 Fluxing 50 30 Preheat 10 20 30 40 50 60 70 80 90 100 110 120 TIME(sec.) 1. Please avoid any external stress applied to the lead-frames and epoxy while the LEDs are at high temperature,especially during soldering 2. DIP soldering and hand soldering should not be done more than one time. 3. After soldering, avoid the epoxy lens from mechanical shock or vibration until the LEDs are back to room temerature. 4. Avoid rapid cooling during temperature ramp-down process 5. Although the soldering condition is recommended above, soldering at the lowest possible temperature is feasible for the LEDs ● IRON Soldering 300℃ Within 3 sec.,One time only. Ver.1.0 Page 7 of 8 BRIGHT LED ELECTRONICS CORP. BL-HB336G-AV-TRB ● Notes for designing: Care must be taken to provide the current limiting resistor in the circuit so as to drive the BRIGHT LEDs within the rated figures. Also, caution should be taken not to overload BRIGHT LEDs with instantaneous voltage at the turning ON and OFF of the circuit. When using the pulse drive care must be taken to keep the average current within the rated figures. Also, the circuit should be designed so as be subjected to reverse voltage when turning off the BRIGHT LEDs. ● Storage: In order to avoid the absorption of moisture, it is recommended to solder BRIGHT LEDs as soon as possible after unpacking the sealed envelope. If the envelope is still packed, to store it in the environment as following: (1) Temperature : 5℃-30℃(41℉)Humidity : RH 60﹪Max. (2) After this bag is opened, devices that will be applied to infrared reflow, vapor-phase reflow, or equivalent soldering process must be: a. Completed within 168 hours. b. Stored at less than 30% RH. (3) Devices require baking before mounting, if: (2) a or (2) b is not met. (4) If baking is required, devices must be baked under below conditions: 48 hours at 60℃±3℃. ● Package and Label of Products: (1) Package: Products are packed in one bag of 5000 pcs (one taping reel) and a label is attached on each bag. (2) Label: B Part No Quantity BIN. Sealing Date x xx xx xx x xx xx Year Month xx Year Month Day Manufacture Location Ver.1.0 Page8 of 8
BL-HB336G-AV-TRB 价格&库存
很抱歉,暂时无法提供与“BL-HB336G-AV-TRB”相匹配的价格&库存,您可以联系我们找货
