DB207S
DB207S
    PINGWEI(平伟)
    DBS
DB207S 数据手册
DB201S thru DB207S SURFACE MOUNT REVERSE VOLTAGE - 50 to 1000Volts FORWARD CURRENT - 2.0 Amperes GLASS PASSIVATED BRIDGE RECTIFIERS DBS FEATURES ●Rating to 1000V PRV .047(1.2) .037(0.95) ●Ideal for printed circuit board ●Low forward voltage drop,high current capability ●Reliable low cost construction utilizing molded plastic - technique results in inexpensive product .335(8.5) .307(7.8) + .256(6.5) .244(6.2) ●The plastic material has UL flammability classification 94V-0 ~ ~ .406(10.3) .391(10.0) .140(0.35) .008(0.2) MECHANICAL DATA ●Polarit: As marked on Body .346(8.8) .323(8.2) ●Weight: 0.02 ounces,0.38 grams ●Mounting position: Any .104(2.65) .090(2.3) .063(1.6) .055(1.4) .205(5.2) .197(5.0) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ ambient temperature unless otherwise specified. Single phase, half wave ,60Hz, resistive or inductive load. For capacitive load, derate current by 20% CHARACTERISTICS SYMBOL DB201S DB202S DB203S DB204S DB205S DB206S DB207S Maximum Recurrent Peak Reverse Voltage VRRM Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum DC Blocking Voltage Maximum Average Forward 50 100 200 400 600 800 1000 UNIT V I(AV) 2.0 A IFSM 60 A VF 1.1 V IR 10 500 μA I2t Rating for Fusing (t
DB207S 价格&库存
很抱歉,暂时无法提供与“DB207S”相匹配的价格&库存,您可以联系我们找货
