RS821S, RS822S
RS821, RS822, RS824
14MHz, Rail-to-Rail I/O
CMOS Operational Amplifier
FEATURES
DESCRIPTION
HIGH GAIN BANDWIDTH:14MHz
RAIL-TO-RAIL INPUT AND OUTPUT
0.6mV Typical Vos
INPUT VOLTAGE RANGE: -0.1V to +5.6V
with Vs = 5.5V
SUPPLY RANGE: +2.5V to +5.5V
SHUTDOWN: RS821S/RS822S
SPECIFIED UP TO +125°C
MicroSIZE PACKAGES: SOT23-5, SOT23-6
The RS82X families of products offer low voltage
operation and rail-to-rail input and output, as well as
excellent speed/power consumption ratio, providing
an excellent bandwidth (14MHz) and slew rate of
10V/us. The op-amps are unity gain stable and
feature an ultra-low input bias current.
The devices are ideal for sensor interfaces, active
filters and portable applications. The RS821S,
RS822S include a shutdown mode. Under logic
control, the amplifiers can be switched from normal
operation to a standby current that is less than
1uA.The RS82X families of operational amplifiers
are specified at the full temperature range of −40°C
to +125°C under single or dual power supplies of
2.5V to 5.5V.
APPLICATIONS
SENSORS
PHOTODIODE AMPLIFICATION
ACTIVE FILTERS
TEST EQUIPMENT
DRIVING A/D CONVERTERS
PIN CONFIGURATIONS
2
3
4
-IN
OUT
1
V-
2
+IN
3
6
V+
NC
1
5
EN
-IN
2
4
+IN
-IN
V-
3
8
NC
7
V+
6
5
4
OUT
1
-IN A
2
+IN A
3
V-
4
En A
5
NC
SOT23-6
SOT23-5
OUT A
+IN
V+
V+
9
OUT B
8
-IN B
7
+IN B
6
En B
14
OUT D
13
-IN D
A
B
10
V-
5
1
RS821
OUT
RS822S
RS821S
RS821
SOIC-8(SOP8),MSOP-8
MSOP-10
RS821B
- IN
3
5
-IN
2
OUT +IN
3
V-
4
V+
4
EN
7
V+
2
8
1
V-
1
+ IN
RS822
RS821S
NC
6
OUT
5
NC
OUT A
-IN A
1
8
V+
OUT A
1
2
7
OUTB
-IN A
2
6
-IN B
+IN A
3
12
+IN D
5
+IN B
V+
4
11
V-
+IN B
5
10
+IN C
-IN B
6
9
-IN C
OUT B
7
8
OUT C
+IN A
3
V-
4
SOT23-5
RS824
A
B+
SOIC-8(SOP8)
SOIC-8(SOP8),MSOP-8
Note: NC indicates no internal connection
A
B
D
+ C
SOIC-14(SOP14),TSSOP-14
REV B.3
1
www.run-ic.com
RS821S, RS822S
RS821, RS822, RS824
ABSOLUTE MAXIMUM RATINGS (1)
Supply Voltage, V+ to V-...............................................7.0V
Input Terminals, Voltage (2) …………... – 0.5 to (V+) + 0.5V
Current (2)…………………....…..... ±10mA
Storage Temperature ……….…………… −65°C to +150°C
Operating Temperature ……….………… −40°C to +125°C
Junction Temperature................................................150°C
Package Thermal Resistance @ TA = +25°C
SOT23-5, SOT23-6………………….………………200°C/W
MSOP-10, SOIC-8 …………………….…………... 150°C/W
SOIC-14, TSSOP-14……….….….….…..…………100°C/W
Lead Temperature (Soldering, 10s) ……………........260°C
ESD Susceptibility
HBM …......................................................................5000V
MM ……………………….........………………...……….400V
ESD SENSITIVITY CAUTION
ESD damage can range from subtle performance
degradation to complete device failure. Precision
integrated circuits may be more susceptible to
damage because very small parametric changes
could cause the device not to meet its published
specifications.
(1) Stresses above these ratings may cause permanent damage. Exposure
to absolute maximum conditions for extended periods may degrade
device reliability. These are stress ratings only, and functional
operation of the device at these or any other conditions beyond those
specified is not implied.
(2) Input terminals are diode-clamped to the power-supply rails. Input
signals that can swing more than 0.5V beyond the supply rails should
be current-limited to 10mA or less.
PACKAGE/ORDERING INFORMATION
2
www.run-ic.com
RS821S, RS822S
RS821, RS822, RS824
ELECTRICAL CHARACTERISTICS
(At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.)
PARAMETER
CONDITIONS
TJ
RS821S, RS822S,
RS821, RS822, RS824
MIN
TYP
MAX
UNIT
5.5
V
1.9
88
2.5
mA
0.6
2.5
POWER SUPPLY
Vs
Operating Voltage Range
IQ
Quiescent Current/Amplifier
PSRR
Power-Supply Rejection Ratio
Vs=2.5V to 5.5V,
Vcm=(V-)+0.5V
25C
2.5
25C
25C
-40C to 125C
75
65
dB
INPUT
Vos
IB
Input Offset Voltage
Input Offset Voltage Average
Drift
Input Bias Current
Ios
Input Offset Current
Vos TC
Vcm
CMRR
Common-Mode Voltage Range
25C
1.6
-40C to 125C
1
10
pA
25C
1
10
pA
5.6
V
25C
-0.1
Vs= 5.5V, Vcm
=-0.1V to 4V
25C
75
-40C to 125C
67
25C
61
-40C to 125C
58
25C
-40C to 125C
25C
-40C to 125C
91
78
89
75
Vs= 5.5V, Vcm
=-0.1V to 5.6V
uV/C
25C
Vs= 5.5V
Common-Mode Rejection Ratio
mV
88
dB
75
OUTPUT
AOL
Open-Loop Voltage Gain
RL=10KΩ, Vo=
0.05V to 4.95V
RL=2KΩ
RL=10KΩ
100
dB
98
25C
mV
25C
110
mA
Slew Rate
25C
10
V/us
Gain-Bandwidth Product
25C
14
MHz
Phase Margin
25C
Output Swing From Rail
Iout
RL=2KΩ, Vo=
0.15V to 4.85V
Output Short-Circuit Current
FREQUENCY RESPONSE
SR
GBP
PM
ts
Setting Time,0.1%
Overload Recovery Time
VIN·Gain≥VS
58
0.2
us
0.3
us
NOISE
en
Input Voltage Noise Density
f = 1KHz
25C
8.5
nV/√Hz
f = 10KHz
25C
5.5
nV/√Hz
ENABLE/SHUTDOWN(RS821S,RS822S)
IQ(OFF)
25C
很抱歉,暂时无法提供与“RS821XF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.95920
- 50+2.27880
- 150+1.98720
