T VS Diode – 5.0SMDJ Series
Features
Plastic package, excellent insulation strength.
Glass passivated chip junction in SMC package.
Excellent voltage clamping capability.
Low Zener impedance.
5000W peak pulse power capability on 10/1000s waveform.
Typical leakage current less than 1A above 13V.
Very fast response time, typically less than 1.0ps from 0 volt to
VBR minimum.
High temperature soldering guaranteed: 265°C/10 sec.
MSL: JEDEC-J-STD-020, Level 1
Applications
I/O interface, VCC bus
Telecom
Industrial and consumer electronic applications.
Relay and electromagnetic valve surge absorption.
Agency Approval
UL file no.: E474915
Mechanical and Physical Data
Case: JEDEC SMC molded plastic.
Surface mount device, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denoted cathode except bidirectional.
Maximum Ratings and Thermal Characteristics
Parameter
Symbol
Value
Unit
PPPM
Min 5000
Watt
Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3).
IPPM
See Table
Amp
Steady State Power Dissipation at TL = 75°C, Lead lengths 0.375”, (9.5mm) (Fig.5).
PM(AV)
6.5
Watt
IFSM
300
Amp
TJ, TSTG
-55~150
°C
Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1).
Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated
Load (Note 2, Fig.6).
Operating Junction and Storage Temperature Range.
Note:
1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2.
2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
Part Number Code
5.0SMDJ
□□□ C A - □□□
Packaging Code (T13: Tape with 13” Reel; T7: Tape with 7”)
VBR Voltage tolerance (A: 5%; Blank: 10%)
C: Bi-directional; Blank: Uni-directional
Reverse Stand-Off Voltage or Typical Breakdown Voltage
5.0SMDJ Series (5000W)
新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan.
TEL: +886-3-5643931 FAX: +886-3-5644624
http://www.pttc.com.tw
Page: 1 of 6
2017/12/28 Rev: C
I-V Curve Characteristics
PPPM
Peak Pulse Power Dissipation – Maximum power dissipation
VR
Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation
VBR
Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (IT)
VC
Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current)
IR
Reverse Leakage Current – Current measured at VR
VF
Forward Voltage Drop for Uni-directional
Electrical Characteristics
Part Number
Marking
Reverse
Test
Breakdown Voltage
Stand Off
Current
VBR (V) @ IT
Voltage VR
IT
Min.
Max.
(V)
(mA)
Maximum
Clamping
Voltage
VC (V) @ IPP
Maximum
Peak Pulse
Current
IPP (A)
Maximum
Reverse
Leakage
IR (A) @ VR
Uni
Bi
Uni
Bi
5.0SMDJ11A
5.0SMDJ11CA
5PEN
5BEN
11.0
12.2
13.5
10
18.2
275.0
800
5.0SMDJ12A
5.0SMDJ12CA
5PEP
5BEP
12.0
13.3
14.7
10
19.9
252.0
800
5.0SMDJ13A
5.0SMDJ13CA
5PEQ
5BEQ
13.0
14.4
15.9
10
21.5
233.0
500
5.0SMDJ14A
5.0SMDJ14CA
5PER
5BER
14.0
15.6
17.2
10
23.2
216.0
200
5.0SMDJ15A
5.0SMDJ15CA
5PES
5BES
15.0
16.7
18.5
1
24.4
205.0
100
5.0SMDJ16A
5.0SMDJ16CA
5PET
5BET
16.0
17.8
19.7
1
26.0
193.0
50
5.0SMDJ17A
5.0SMDJ17CA
5PEU
5BEU
17.0
18.9
20.9
1
27.6
181.0
5.0SMDJ18A
5.0SMDJ18CA
5PEV
5BEV
18.0
20.0
22.1
1
29.2
172.0
10
5.0SMDJ20A
5.0SMDJ20CA
5PEW
5BEW
20.0
22.2
24.5
1
32.4
155.0
5
5.0SMDJ22A
5.0SMDJ22CA
5PEX
5BEX
22.0
24.4
26.9
1
35.5
141.0
5
5.0SMDJ24A
5.0SMDJ24CA
5PEZ
5BEZ
24.0
26.7
29.5
1
38.9
129.0
5
5.0SMDJ26A
5.0SMDJ26CA
5PFE
5BFE
26.0
28.9
31.9
1
42.1
119.0
5
5.0SMDJ28A
5.0SMDJ28CA
5PFG
5BFG
28.0
31.1
34.4
1
45.4
110.0
5
5.0SMDJ30A
5.0SMDJ30CA
5PFK
5BFK
30.0
33.3
36.8
1
48.4
103.0
5
5.0SMDJ33A
5.0SMDJ33CA
5PFM
5BFM
33.0
36.7
40.6
1
53.3
93.9
5
5.0SMDJ36A
5.0SMDJ36CA
5PFP
5BFP
36.0
40.0
44.2
1
58.1
86.1
5
5.0SMDJ40A
5.0SMDJ40CA
5PFR
5BFR
40.0
44.4
49.1
1
64.5
77.6
5
Page: 2 of 6
2017/12/28 Rev: C
Part Number
Marking
Reverse
Test
Breakdown Voltage
Stand Off
Current
VBR (V) @ IT
Voltage VR
IT
Min.
Max.
(V)
(mA)
Maximum
Clamping
Voltage
VC (V) @ IPP
Maximum
Peak Pulse
Current
IPP (A)
Maximum
Reverse
Leakage
IR (A) @ VR
Uni
Bi
Uni
Bi
5.0SMDJ43A
5.0SMDJ43CA
5PFT
5BFT
43.0
47.8
52.8
1
69.4
72.1
5
5.0SMDJ45A
5.0SMDJ45CA
5PFV
5BFV
45.0
50.0
55.3
1
72.7
68.8
5
5.0SMDJ48A
5.0SMDJ48CA
5PFX
5BFX
48.0
53.3
58.9
1
77.4
64.7
5
5.0SMDJ51A
5.0SMDJ51CA
5PFZ
5BFZ
51.0
56.7
62.7
1
82.4
60.7
5
5.0SMDJ54A
5.0SMDJ54CA
5RGE
5BGE
54.0
60.0
66.3
1
87.1
57.5
5
5.0SMDJ58A
5.0SMDJ58CA
5PGG
5BGG
58.0
64.4
71.2
1
93.6
53.5
5
5.0SMDJ60A
5.0SMDJ60CA
5PGK
5BGK
60.0
66.7
73.7
1
96.8
51.7
5
5.0SMDJ64A
5.0SMDJ64CA
5PGM
5BGM
64.0
71.1
78.6
1
103.0
48.6
5
5.0SMDJ70A
5.0SMDJ70CA
5PGP
5BGP
70.0
77.8
86.0
1
113.0
44.3
5
5.0SMDJ75A
5.0SMDJ75CA
5PGR
5BGR
75.0
83.3
92.1
1
121.0
41.4
5
5.0SMDJ78A
5.0SMDJ78CA
5PGT
5BGT
78.0
86.7
95.8
1
126.0
39.7
5
5.0SMDJ85A
5.0SMDJ85CA
5PGV
5BGV
85.0
94.4
104.0
1
137.0
36.5
5
5.0SMDJ90A
5.0SMDJ90CA
5PGX
5BGX
90.0
100.0
111.0
1
146.0
34.3
5
5.0SMDJ100A
5.0SMDJ100CA
5PGZ
5BGZ
100.0
111.0
123.0
1
162.0
30.9
5
5.0SMDJ110A
5.0SMDJ110CA
5PHE
5BHE
110.0
122.0
135.0
1
177.0
28.3
5
5.0SMDJ120A
5.0SMDJ120CA
5PHG
5BHG
120.0
133.0
147.0
1
193.0
26.0
5
5.0SMDJ130A
5.0SMDJ130CA
5PHK
5BHK
130.0
144.0
159.0
1
209.0
24.0
5
5.0SMDJ150A
5.0SMDJ150CA
5PHM
5BHM
150.0
167.0
185.0
1
243.0
20.6
5
5.0SMDJ160A
5.0SMDJ160CA
5PHP
5BHP
160.0
178.0
197.0
1
259.0
19.3
5
5.0SMDJ170A
5.0SMDJ170CA
5PHR
5BHR
170.0
189.0
209.0
1
275.0
18.2
5
5.0SMDJ180A
5.0SMDJ180CA
5PHT
5BHT
180.0
200.0
220.0
1
291.0
17.1
5
5.0SMDJ190A
5.0SMDJ190CA
5PHV
5BHV
190.0
211.0
232.0
1
307.8
16.2
5
5.0SMDJ200A
5.0SMDJ200CA
5PHW
5BHW
200.0
224.0
247.0
1
324.0
15.4
5
5.0SMDJ220A
5.0SMDJ220CA
5PHX
5BHX
220.0
246.0
272.0
1
356.0
14.0
5
5.0SMDJ250A
5.0SMDJ250CA
5PHZ
5BHZ
250.0
279.0
309.0
1
405.0
12.3
5
5.0SMDJ300A
5.0SMDJ300CA
5PJE
5BJE
300.0
335.0
371.0
1
486.0
10.3
5
5.0SMDJ350A
5.0SMDJ350CA
5PJG
5BJG
350.0
391.0
432.0
1
567.0
8.8
5
5.0SMDJ400A
5.0SMDJ400CA
5PJK
5BJK
400.0
447.0
494.0
1
648.0
7.7
5
5.0SMDJ440A
5.0SMDJ440CA
5PJM
5BJM
440.0
492.0
543.0
1
713.0
7.0
5
Note:
1. For bi-directional type having VR of 10 volts and less, the IR limit is double.
Page: 3 of 6
2017/12/28 Rev: C
Ratings and Characteristic Curves
Fig 1 - Peak Pulse Power Rating Curve
Fig 2 - Pulse Derating Curve
Fig 3 - Pulse Waveform
Fig 4 – Typical Junction Capacitance Uni-directional
Fig 5 – Steady State Power Dissipation Derating Curve
Fig 6 – Maximum Non-Repetitive Forward Surge Current
(Uni-directional Only)
Page: 4 of 6
2017/12/28 Rev: C
Marking Definitions
PolyTrans Trade mark
Lot No
Marking Code
Cathode Band
(For Uni-directional product only)
Physical Dimensions
Dimension
A
B
C
D
E
F
G
H
I
J
K
L
Millimeters
Inches
Min
Max
Min
Max
2.90
6.60
5.59
2.20
0.76
7.75
0.15
3.30
2.40
2.40
3.20
7.11
6.22
2.80
1.52
0.20
8.13
0.31
4.20
0.114
0.260
0.220
0.087
0.030
0.305
0.006
0.129
0.094
0.094
0.126
0.280
0.245
0.110
0.060
0.008
0.320
0.012
0.165
Lead Free Reflow Soldering Recommendations
Preheat
- Temperature Min (Ts_min)
- Temperature Max (Ts_max)
- Time (Ts_min to Ts_max)
- Average Ramp-Up Rate
150ºC
200ºC
60-180 seconds
1~3ºC/second
Peak Temperature
260ºC max.
Time within 5ºC of actual Peak
Temperature (tp)
40 seconds max.
Ramp-Down Rate
6 ºC /second max.
Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements.
Page: 5 of 6
2017/12/28 Rev: C
Packaging Information
Part Number
Packaging
Code
Component
Package
Quantity
5.0SMDJ Series
5.0SMDJ Series
T13
T7
DO-214AB
DO-214AB
3000
500
Packaging Option
Tape & Reel – 16mm tape/13” reel
Tape & Reel – 16mm tape/7” reel
Packaging
Specification
EIA STD RS-481
EIA STD RS-481
Tape and Reel Specifications
Page: 6 of 6
2017/12/28 Rev: C
很抱歉,暂时无法提供与“5.0SMDJ36CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.88160
- 10+3.98520
- 30+3.54240
- 100+3.09960
- 500+2.53800
- 1000+2.40840
