Crimp
2.5 mm
XM CONNECTOR High box type
Disconnectable Crimp style connectors (Board)
pitch
Features
● Interchangeability
XM CONNECTOR
The housing is interchangeable with these of the XM
receptacle housing.
High box type
● Inner-housing lock
This inner-housing lock secures the plug to the receptacle
and prevents accidental disconnection. The lock is protected
and is not affected by external forces that might result from
the routing of wires.
● Retainer
Retainers enhance safety in case of partial insertion or
accidental release of the contact. Even if a contact is
inserted incompletely, the retainer guides the contact to
the proper position and securely locks it in place.
This is XM connector high box type, with
20.0 mm mounting height and with 8.9 mm
thickness. This connector exhibits the stable
electric connection to the condition such as
the vibration, the prying, the micro-current
and micro-voltage circuit.
● Header suitable for potting process
This header is tall and fully shrouded so as to prevent
the resin used to coat the PC board from coming into
contact with the mating pins.
6
JS
H
1
2
3
4
5
T
a
F
Specifications
• Current rating: 3 A AC/DC (AWG #22, #20)
• Voltage rating: 250 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 500 MΩ min.
• Withstanding voltage: 1,000 VAC/minute
• Applicable wire: AWG #28 to #20
• Applicable PC board thickness: 1.6 mm
1
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
XM CONNECTOR
High box type
Contact
Model No.
1.9
SXA-01T-P0.6
SXA-001T-P0.6
0.22 to 0.50
24 to 20
1.5 to 1.9
8,000
0.08 to 0.33
28 to 22
0.8 to 1.9
8,000
XM CONNECTOR
High box type
Material and Finish
2.9
1.3
Phosphor bronze, tin-plated (reflow treatment)
0.8
RoHS2 compliance
2.3
3.1
6.5
Applicable wire
Q’ty/
reel
Insulation O.D. (mm)
AWG #
mm2
Housing
4
B
6
7
2.5
A
5
8
9
10
11.5
XMP-02V
XMP-03V
XMP-04V
XMP-05V
XMP-06V
XMP-07V
XMP-08V
XMP-09V
XMP-10V
6.3
12
7.7
11.5
13.7
12
B
3
A
2
Dimensions (mm)
Model No.
2.5
No. of
circuits
14.6
A
B
Q’ty/
bag
2.5
8.8
1,000
5.0
9.8
1,000
7.5
12.3
1,000
10.0
14.8
500
12.5
17.3
500
15.0
19.8
500
17.5
22.3
500
20.0
24.8
500
22.5
27.3
500
Material and Finish
PA 66, UL94V-0
RoHS2 compliance
Retainer
No. of circuits
2
3
4
5
A
6
7
8
2.5
7.8
10
A
Q’ty/bag
2.5
1,000
5.0
1,000
7.5
1,000
10.0
1,000
12.5
1,000
15.0
1,000
17.5
1,000
20.0
1,000
22.5
1,000
Material and Finish
0.95
2.5
9
Model No.
XMS-02V
XMS-03V
XMS-04V
XMS-05V
XMS-06V
XMS-07V
XMS-08V
XMS-09V
XMS-10V
Glass-filled PA 66, UL94V-0
RoHS2 compliance
2
XM CONNECTOR
High box type
Header
No. of
circuits
2
B
3
8.9
4
5
6
7
18.8
8
9
10
Dimensions (mm)
Model No.
BH02B-XMSK
BH03B-XMSK
BH04B-XMSK
BH05B-XMSK
BH06B-XMSK
BH07B-XMSK
BH08B-XMSK
BH09B-XMSK
BH10B-XMSK
(3.5)
1.5
8.9
1.55 ±0.05
3.15
φ0.9
+0.1
Note: 1 . The above figure is the figure viewed from soldering side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method.
The dimensions above should serve as a guideline. Contact JST for details.
3
(20)
φ1.7 ±0.05
±0.05
±0.05
2.5
9.9
700
7.5
12.4
525
10.0
14.9
455
12.5
17.4
385
15.0
19.9
315
17.5
22.4
280
20.0
24.9
245
22.5
27.4
245
RoHS2 compliance This product displays (LF)(SN) on a label.
PC board layout and Assembly layout
±0.1
5.0
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PA 66, UL94V-0
A
A
B
8.9
Material and Finish
2.5
Q’ty/
bag
A
2.5
770
XM CONNECTOR
High box type
Model number allocation
Contact
Housing
XM P - 02 V
S XA - 001 T - P 0.6
Form: S…Strip form, B…Loose piece
Series name
Applicable wire range: 001…AWG #28 to #22
01…AWG #24 to #20
Series name
Surface finish: T…Tin-plated (reflow treatment)
Part name: Plug
Material: P…Phosphor bronze
No. of circuits: 2 to 10
Terminal size
Flammability: V…UL94V-0
Retainer
Header
XM S - 02
V
BH 02 B - XM S K
Shape of assembled product:
BH…Top entry type High-box
Series name
Part name: Header
Part name: Retainer
Series name
Color: S…Natural
Indication of clinch: K…Clinched
Crimping machine, Applicator
Contact
SXA-001T-P0.6
SXA-01T-P0.6
Crimping machine
AP-K2N
Crimp applicator
MKS-L
Dies
MK/SXA/M-001-06
MK/SXA/M-01-06
Crimp applicator with dies
APLMK SXA/M001-06
APLMK SXA/M01-06
Note: Contact JST for fully automatic crimping applicator.
4
很抱歉,暂时无法提供与“XMS-04V(N)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28653
- 100+0.22896
- 300+0.20024
- 1000+0.16546
