B2P3S-VH(LF)(SN)
B2P3S-VH(LF)(SN)
    JST
    弯插,P=7.92mm
    线对板针座 1x3P(缺1P) 弯插 间距:7.92mm
B2P3S-VH(LF)(SN) 数据手册
VA CONNECTOR 7.92mm pitch/Disconnectable Crimp style connectors 2 1 Specifications ––––––––––––––––––– H JST This 7.92mm pitch large current carrying capacity connector is used with primary power supply circuits and various other circuits requiring large currents. It features an anti-misinsertion construction and a reliable locking mechanism to ensure maximum safety. • Current rating: 7A AC, DC (AWG #18) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,200V AC/minute • Applicable wire: AWG #20 to #18 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R75122 • Box contact • Secure contact and mounting • Compact connector with a large capacity PC board layout (viewed from soldering side) and Assembly layout 10.6 Side entry type 2.0 min 7.92 ±0.05 17.5 Circuit No.1 7.2 min φ 1.65+00.1 21.5 2.0 min φ1.65 +0.1  0 10.6 7.92 ± 0.05 5.0min Top entry type Circuit No.1 7.2 min Side entry type with PCB stabilizer 5.0 7.92 ±0.05 22.0 φ1.65 +0.1  0 10.6 5.7 min 1.95 min Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Circuit No.1 5.7 7.7 Contact Applicable wire AWG # mm2 Model No. SVA-41T-P1.1 0.5∼0.83 11.6 3.0 4.0 Insulation O.D. (mm) Q'ty / reel 1.9∼3.7 3,500 20∼18 Material and Finish 5.2 3.8 Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Contact SVA-41T-P1.1 Applicator Dies Crimp applicator with dies MKS-L MK/SVA-41-11 APLMK SVA41-11 −− −− −− Crimping machine Crimp applicator AP-K2N 1 VA CONNECTOR Housing Circuits 2.1 9.7 1,000 Material 6.8 3.8 10.6 Circuit No.1 Q'ty / bag Model No. VAR-2 2 PA 6, UL94V-0, natural (white) RoHS compliance 7.92 12.92 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 14.3 ex. VAR-2-oo(blank)…natural (white) K…black R…red E…blue Y…yellow M…green N…brown Locking header Top entry type With plugged up Top entry type 3.7 3.2 3.7 9.4 3.2 7.7 9.4 7.7 1.14 1.14 7.92 11.82 7.92 11.82 Side entry type 3.6 1.14 8.5 9.4 1.14 Side entry type 9.4 8.5 Circuit No.1 Circuit No.1 7.92 11.82 7.7 3.2 14.9 4.0 3.6 Circuit No.1 Circuit No.1 7.92 11.82 Circuits 7.7 3.2 14.9 4.0 Top entry type 2 Side entry type 2 Side entry type with PCB stabilizer 2 Model No. B2P3 -VH B2P3S-VH S2P3 -VH Q'ty / box Model No. *B2P-VA *B2PS-VA Q'ty / box 1,000 500 500 With plugged up Side entry type with PCB stabilizer Circuits 13.9 11.82 Top entry type 2 Side entry type 2 1,000 500 1.14 Material and Finish 3.6 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) Circuit No.1 7.92 7.7 RoHS compliance This product displays (LF)(SN) on a label. Note: *Marked products are not CSA/TÜV approved. 5.7 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 2 ex. B2P3(S)-VH-oo(blank)…natural (white) BK…black R…red BL…blue Y…yellow M…green N…brown O…orange PK…pink P…purple H…gray ex. S2P3-VH-oo(blank)…natural (white) BK…black R…red Y…yellow M…green
B2P3S-VH(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“B2P3S-VH(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
B2P3S-VH(LF)(SN)
    • 1+1.068381+0.13849
    • 300+0.91102300+0.11809
    • 500+0.81164500+0.10521
    • 1000+0.737101000+0.09555
    • 4000+0.670844000+0.08696
    • 5000+0.670845000+0.08696
    • 10000+0.6625610000+0.08588
    库存:7276
