RS3MAF
RS3MAF
    BLUEROCKET(蓝箭电子)
    SMAF(DO-214AD)
    快恢复二极管,反向电压:1000V,正向电流:3.0A,薄型SMAF封装。
RS3MAF 数据手册
RS3MAF Rev. F Aug.-2018  描述 / DATA SHEET Descriptions 快恢复二极管,反向电压:1000V,正向电流:3.0A,薄型 SMAF 封装。 Surface Mount Fast Recovery Rectifiers, Reverse Voltage:1000V, Forward Current:3.0A ,SMAF thin package. 特征 / Features 玻璃钝化芯片,反向恢复时间快,无铅符合欧盟 RoHS 指令 2011/65/EU,适用表面贴装。无卤产品。 Glass Passivated Chip Junction, Fast reverse recovery time, Lead free in comply with EU RoHS 2011/65/EU directives, For surface mounted applications. Halogen free product.  用途 / Applications 一般用途. General purpose. 内部等效电路 / Equivalent Circuit 引脚排列 / Pinning 印章代码 / Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1 / 7 RS3MAF Rev. F Aug.-2018 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Maximum Repetitive Peak Reverse Voltage VRRM 1000 V Maximum RMS voltage VRMS 700 V Maximum DC Blocking Voltage VDC 1000 V IF(AV) 3.0 A IFSM 80 A Cj 60 pF RθJA 50 ℃/W Tj,Tstg -55~+150 ℃ Maximum Average Forward Rectified Current at Tc = 100℃ Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) Typical Junction Capacitance at1) Typical Thermal Resistance 2) Operating and Storage Temperature Range Note: 1)Measured at 1MHz and applied reverse voltage of 4V D.C. 2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas. 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Maximum Instantaneous Forward Voltage 符号 Symbol VF Maximum DC Reverse Current at Rated DC Blocking Voltage IR Maximum Reverse Recovery Time trr http://www.fsbrec.com 测试条件 Test Conditions 数值 Rating 单位 Unit IF=3.0A 1.3 V Ta=25℃ 5.0 μA Ta=125℃ 150 μA 200 ns IF=0.5A Irr=0.25A IR=1.0A 2 / 7 RS3MAF Rev. F Aug.-2018 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3 / 7 RS3MAF Rev. F Aug.-2018 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4 / 7 RS3MAF Rev. F Aug.-2018 印章说明 / DATA SHEET Marking Instructions http://www.fsbrec.com 5 / 7 RS3MAF Rev. F Aug.-2018 印章说明 / DATA SHEET Marking Instructions R3MA-1 **** 说明 R3MA-1:   为型号代码 **** :    为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码  Note: R3MA-1: Product Type Code ****:        Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No Code http://www.fsbrec.com 6 / 7 RS3MAF Rev. F Aug.-2018 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 150~180℃,时间 60~90sec; 1.Preheating:150~180℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 包装规格 Time:10±1 sec / REEL Package Type 封装形式 使用说明 Temp.:260±5℃ / Packaging SPEC. 卷盘包装 SMAF 时间:10±1 sec. Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Reel Inner Box 盒 Outer Box 箱 3000 5 15000 5 75000 7〞×11 185X180X105 390X385X205 / Notices http://www.fsbrec.com 7 / 7
RS3MAF
物料型号:RS3MAF
器件简介:快恢复二极管,反向电压1000V,正向电流3.0A,薄型SMAF封装。
引脚分配:1号引脚为阴极(Cathode),2号引脚为阳极(Anode)。
参数特性:包括最大重复峰值反向电压(VRRM)为1000V,最大有效值电压(VRMS)为700V,最大直流阻断电压(Voc)为1000V,最大平均正向整流电流(IF(AV))为3.0A等。
功能详解:文档提供了电性能参数表和电参数曲线图,展示了器件在不同条件下的性能表现。
应用信息:适用于一般用途。
封装信息:提供了外形尺寸图和尺寸数据,以及回流焊温度曲线图和耐焊接热试验条件。封装形式为SMAF,包装规格包括卷盘包装,每卷3000只。
RS3MAF 价格&库存
很抱歉,暂时无法提供与“RS3MAF”相匹配的价格&库存,您可以联系我们找货
