CRYSTAL UNIT
32.768KHZ
YSX2012SK
Applications
‧RTC.
Small Size
Features
‧Dimensions:2.00 x 1.20 x 0.60 mm.
‧Ultra-thin thickness 0.6mm.
‧Standard Frequency: 32.768KHz
‧Reflow is possible.
Specifications
Standard Frequency
32.768 KHz
Frequency Tolerance (at 25 )
7pF, 9pF,12.5pF,or specify
±10ppm,±20ppm,or specify
Parabolic Coefficient
( - 0.03 ± 0.01 ) * 10-6 / ℃2
Load Capacitance
Operating Temperature
-40~+85℃,or specify
Storage Temperature
-55~+125℃
Shunt Capacitance
1.3 pF Max.
Motional Capacitance
7.5fF
Level of Drive
0.1μWMax
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
YSX2012SK
90KΩMax.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
www.yxc.hk
第1页共2页
CRYSTAL UNIT
32.768KHZ
YSX2012SK
Small Size
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability Terminal.
Tp2
In case of Resistance to soldering heat Surface.
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-2012
180±2.0
8.0±0.3
2.30±0.1
1.45±0.1
4.0±0.1
0.80±0.1
61.0±1.0
8.0±1.0
5000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X201232768KLD2SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.95090
- 10+2.36050
- 30+2.10630
- 100+1.79930
- 500+1.65110
- 1000+1.52410
- 国内价格
- 1+2.72440
- 10+2.18540
- 30+1.95020
- 国内价格
- 10+6.26530
- 100+3.73750
- 800+2.61620
- 3000+1.86870
- 6000+1.77540
- 30000+1.64450
- 国内价格
- 1+2.00540
- 100+1.59760
- 750+1.43900
- 1500+1.35960
- 3000+1.28030
- 国内价格
- 1+3.00240
- 10+2.40840
- 30+2.14920
- 100+1.83600
- 500+1.68480
- 1000+1.55520
