AZ5725-01F
Transient Voltage Suppressing Device
Tiny Pacakge for ESD/Transient Protection
Features
ESD Protect for 1 Line with Bi-directional
Provide ESD protection for the protected line to
IEC 61000-4-2 (ESD) ±15kV (air/contact)
proprietary clamping cell in a single package.
During transient conditions, the proprietary
clamping cell prevents over-voltage on the power
line or control/data lines, protecting any
downstream components.
IEC 61000-4-4 (EFT) 50A (5/50ns)
Cable Discharge Event (CDE)
0402 small DFN package saves board space
Protect one I/O line or one power line
Fast turn-on and Low clamping voltage
For low operating voltage applications: 5V
maximum
Solid-state silicon-avalanche and active circuit
triggering technology
Green Part
AZ5725-01F may be used to meet the ESD
immunity requirements of IEC 61000-4-2, Level 4
(±15kV air, ±8kV contact discharge)
Circuit Diagram /
Pin Configuration
Applications
Mobile Phones
Hand Held Portable Applications
Computer Interfaces Protection
Microprocessors Protection
Serial and Parallel Ports Protection
Control Signal Lines Protection
Power lines on PCB Protection
Latchup Protection
1
2
DFN1006P2X (Bottom View)
(1.0mm x 0.6mm x 0.45mm)
Description
AZ5725-01F is a design which includes one
Bi-directional ESD rated clamping cell to protect
one power line, or one control line, or one low
speed data line in an electronic systems. The
AZ5725-01F has been specifically designed to
protect sensitive components which are
connected to power and control lines from
over-voltage damage and latch-up caused by
Electrostatic Discharging (ESD), Electrical Fast
Transients (EFT), and Cable Discharge Event
(CDE).
AZ5725-01F is a unique design which includes
Revision 2012/01/18
©2011-2012 Amazing Micro.
1
www.amazingIC.com
AZ5725-01F
SPECIFICATIONS
ABSOLUTE MAXIMUM RATINGS
PARAMETER
PARAMETER
RATING
UNITS
Operating Supply Voltage
VDC
±5.5
V
ESD per IEC 61000-4-2 (Air)
VESD
±15
kV
±15
ESD per IEC 61000-4-2 (Contact)
Lead Soldering Temperature
TSOL
260 (10 sec.)
o
C
Operating Temperature
TOP
-55 to +85
o
Storage Temperature
TSTO
-55 to +150
o
C
C
ELECTRICAL CHARACTERISTICS
PARAMETER
SYMBOL
CONDITIONS
T=25 oC.
Stand-Off Voltage
VRWM
Leakage Current
ILeak
VRWM = ±5V, T=25 oC.
Breakdown
Voltage
VBV
IBV = 1mA, T=25 oC, abs(pin-1 to pin-2)
ESD Clamping
Voltage
VESD_CL
CIN
Revision 2012/01/18
TYP
-5
IEC 61000-4-2 +6kV, T=25 oC, Contact
mode.
Channel Input
Capacitance
MINI
VR= 0V, f = 1MHz, T=25 oC.
5.8
UNITS
5
V
1
µA
9.0
V
10
8
2
MAX
V
10
pF
www.amazingIC.com
AZ5725-01F
Typical Characteristics
Typical Variation of CIN vs. VIN
10
Input Capacitance (pF)
9
8
7
Pin-1 to Pin-2
6
5
4
3
2
f = 1MHz, T=25 oC,
1
-4
-3
-2
-1
2
3
4
5
Transmission Line Pulsing (TLP) Current (A)
Input Voltage (V)
Transmission Line Pulsing (TLP) Measurement
18
16
14
12
10
8
6
4
2
-4
-6
-8
-10
-12
-14
-16
-18
V_pulse
Pulse from a
transmission line
TLP_I
100ns
TLP_V
DUT
Pin-1 to Pin-2
-10
-8
-6
-4
-2
4
6
8
10
Transmission Line Pulsing (TLP) Voltage (V)
Revision 2012/01/18
3
www.amazingIC.com
AZ5725-01F
Applications Information
The AZ5725-01F is designed to protect one line
against
System
In order to obtain enough suppression of
ESD/EFT/Cable-Discharge
ESD induced transient, good circuit board is
pulses by clamping it to an acceptable reference.
critical. Thus, the following guidelines are
It provides bi-directional protection.
recommended:
The usage of the AZ5725-01F is shown in Fig. 1.
Protected line, such as data line, control line, or
Minimize the path length between the
protected lines and the AZ5725-01F.
Place the AZ5725-01F near the input
power line, is connected at pin 1. The pin 2 is
terminals or connectors to restrict transient
connected to a ground plane on the board. Since
coupling.
AZ5725-01F is b-directional, these connections
can be reversed (protected line to pin 2, ground
The ESD current return path to ground
should be kept as short as possible.
to pin 1). In order to minimize parasitic
Use ground planes whenever possible.
inductance in the board traces, all path lengths
NEVER route critical signals near board
connected to the pins of AZ5725-01F should be
edges and near the lines which the ESD
transient easily injects to.
Input
Output
VBR
Transient
Voltage
-VBR
VCL
gnd
gnd
-VCL
VBR
Normal
Operation
-VBR
gnd
gnd
1
2
2
AZ5725-01F
1
AZ5725-01F
Protected
Devices
Fig. 1
Revision 2012/01/18
4
www.amazingIC.com
AZ5725-01F
Fig. 2 shows another simplified example of using
data line, and power line from ESD transient
AZ5725-01F to protect the control line, low speed
stress.
VDD
Control Line
2
2
AZ5725-01F
2
1
1
AZ5725-01F
Chip-C
1
Chip-A
Low Speed
Data Line
AZ5725-01F
Chip-B
GND
Fig. 2
Revision 2012/01/18
5
www.amazingIC.com
AZ5725-01F
Mechanical Details
LAND LAYOUT
0.30
DFN1006P2X
PACKAGE DIAGRAMS
0.55
A
0.60
B
1.40
TOP VIEW
(Unit: mm)
Notes:
C
SIDE VIEW
D
This LAND LAYOUT is for reference
purposes only. Please consult your
manufacturing partners to ensure your
company’s PCB design guidelines are met.
E
F
MARKING CODE
45O
8
0.05
0.125
BOTTOM VIEW
Symbol
Millimeters
Inches
min
max
min
max
A
0.95
1.05
0.037
0.041
B
0.55
0.65
0.022
0.026
C
0.41
0.50
0.016
0.020
D
0.45
Part Number
Marking Code
AZ5725-01F
8
0.018
E
0.20
0.30
0.008
0.012
F
0.45
0.55
0.018
0.022
Revision 2012/01/18
Top View
6
www.amazingIC.com
AZ5725-01F
Ordering Information
PN#
Material
Type
Reel size
MOQ
MOQ/internal box
MOQ/carton
AZ5725-01F.R7G
Green
T/R
7 inch
12,000/reel
4 reel= 48,000/box
6 box =288,000/carton
Revision History
Revision
Modification Description
Revision 2011/10/27
Formal Release.
Revision 2012/01/18
Add the Ordering Information.
Revision 2012/01/18
7
www.amazingIC.com
很抱歉,暂时无法提供与“AZ5725-01F.R7G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.41840
- 10+0.35860
- 50+0.31380
- 100+0.25100
- 500+0.20920
- 1000+0.17930
- 3000+0.16730
