MCW-0630-1R0-S1
MCW-0630-1R0-S1
    HOTLAND(合泰盟方)
    SMD
    MCW-0630-1R0-S1
MCW-0630-1R0-S1 数据手册
    方         合 Low profile:Thickness max.3.0mm 合 泰 泰 Thin type of on-board power supply module for     合 合         盟 方 泰 方 盟 泰 合 泰     方 盟 泰 合 泰 盟 ⑥ Material Type; 方 ⑤ The Material Code;   ④ Inductance Value:2R2=2.2µH; 合   方 盟 泰 合 17 S 1   ⑤ ⑥     ④ -   2R2 合 泰 合     方 盟 - ③ ③ Dimensions(unit:mm):6.0x6.0x3.0; 泰 0630   ② 合 盟 Suggested pad layout Dimensions are in mm 盟 方 盟 泰 合       ① (C)3.0±0.3 方   8,4 The rated current as listed is either the saturation current or the -         3,5   3,7 方   cooling provision all affect the part temperature.Part temperature MC W     盟 方 泰 合 合     component.PWB trace size and thickness, airflow and other should be verified in the end application.   合 (D)3.0Max 泰 合       方 盟 泰 泰 合     The part temperature (ambient + temp rise ) should not exceed 125℃ under the worst case operating conditions.Circuit design, 泰 盟 方 盟 方 泰 盟 合     方   盟 (F)1,6±0.3 Operat between temperature range -55℃ to +125℃ heating current depending on which value is lower. (E)0~0.15   (B)6,6±0.2 方         (A)6.95±0.35 Isat :DC current (A) that will cause L0 to drop approximately 20%   泰 盟 盟 DC/DC converters for laptop motherboards/CPU Idc: DC current (A) that will cause an approximate △T of 40℃ ② Mold Categories:W;   ※ Application Voltage regulator VRM for server Test Condition:100KHz,1.0Vrms ※ Regulation of Part number 方     盟 方   方 方     100% lead (Pb) free meet RoHS standards ※ Dimensions in inches (unit:mm) 方 盟 泰 合           Low loss and low resistance All test data is reference to 25℃ ambient. ① Molding Choke; 合 泰 盟   合 High performance (Isat) realizde by metal dust core. Capable of corresponding high frequency (3MHz) 盟 合 泰         泰 盟 泰 合     方   盟 方 ※Note: 方 ※ Features 方   泰 盟 方 盟 方           方 盟 www.sz-hotland.com     MCW-0630-XXX-S1 Series
MCW-0630-1R0-S1 价格&库存
很抱歉,暂时无法提供与“MCW-0630-1R0-S1”相匹配的价格&库存,您可以联系我们找货
