DATA SHEET
STP-1230
BONSDA CODE
TACT SWITCH
DESCRIPTI N
SHENZHEN ZIGENG TECHNOLOGY CO. ,LTD
ADORES
O BUILDING 3TH FL口口R, ZI HENG R口AD N口 49,KENGZI STREETS,
PINGSHAN NEW DISTR l巳T,SHENZHEN, GUANGD口NG p R口VIN口E, 巳HINA
TEL
+B6 755-8451 7口B口
FAX
+B6 755-27日2363口
E-MAIL
LINSL@ZIGK.J.C口M
WEBSITE
WWW.ZIGK.J.C口M
嘻司
B口N SDA
ELECTRONICS
TACT SWITCH SPECIFICATION
Rev. 01
P:1/6
1. Description:
This specification covers the requirements for single key switches which have no
key top(Tact switches mechanical contact).
1-1 Operating Temperature Range : -40℃ ~ +70℃ (normal humidity, normal press)
1-2 Storage Temperature Range :
1-2-1 Single Condition : -40℃ ∼ +80℃
1-2-2 Taping Condition : -40℃ ~ +40℃
1-3 Test Conditions :
Tests and measurements shall be made in the following standard conditions unless
otherwise specified :
Normal temperature (temperature 5 to 35℃)
Normal humidity (relative humidity 45 to 85%)
Normal pressure (pressure 860 to 1,060 mbars)
In case any question arises from the judgment made, tests shall be conducted in the
following conditions:
Temperature
(20±2℃)
Relative humidity
(65±5%)
Pressure
(860 to 1,060 mbars)
2. Rating:
2-1 Maximum Rating : 50 mA, DC 12V
3. Type of Actuation
: Push – ON Type
4. Contact Arrangement
: 1 poles 1 throws (SPST)
Rev. 01
P:2/6
5. Electrical Characteristics
ITEM
DESCRIPTION
TEST CONDITIONS
REQUIREMENTS
There shall be no
5-1
Visual
Examination
By visual examination check without
defects that affect the
any out pressure & testing.
serviceability of the
product.
① Applying static load twice the actuating force
5-2
5-3
Contact
Resistance
Insulation
Resistance
Dielectric
5-4
withstanding
Voltage
to the center of the stem.
② Measurements shall be made with a 1kHz
100mΩ max.
shall current contact resistance meter.
100V DC, 1minute ±5seconds
250V AC(50Hz or 60Hz)shall be applied between
all the adjacent terminal and between the
terminal and the frame for 1 minute.
100 ㏁ min.
There shall be no
breakdown or
flashover.
Lightly striking the center of the stem at a rate
encountered in normal use (3 to 4 operations
per sec),
Bounce shall be tested when “ON” and “OFF”.
5-5
BOUNCE
10ms max.
Rev. 01
P:3/6
6. Mechanical Characteristics
ITEM DESCRIPTION
TEST CONDITIONS
REQUIREMENTS
Place the switch such that the direction of
switch operation is vertical and then
6-1
Operation
Force
gradually increase the load applied to the
center of the stem, the maximum load
160±50 gf•cm
required for the stem to come to a stop
shall be measured.
switch operation is vertical and then apply a
static load twice the actuating force to the
6-2
Travel
center of the stem, the travel distance for
0.25±0.1 mm
the stem to come to a stop shall be
measured.
The sample switch is installed such that the
direction of switch operation is vertical and,
upon depression of the stem in its center
6-3
Return Force
the whole travel distance, the force of the
50 gf•cm min
stem to return to its free position shall be
measured.
Placing the switch such that the direction of
6-4
Static Strength
switch operation is vertical, a static load of
There shall be no sigh of
3kgf shall be applied in the direction of stem
damage mechanically and
operation for a period of 60 seconds.
electrically.
Measurements shall be made following the
6-5
Operation
Life
test set forth below:
1)As shown in item 5-3, 5-4
1) 50mA, 12V DC resistive load
2)Contact Resistance:
2) Rate of operation: 2~3 cycles/ sec
3) Step of operation: 50,000 steps
200mΩ max
Rev. 01
P:4/6
7. Environmental Characteristics
ITEM
DESCRIPTION
TEST CONDITIONS
REQUIREMENTS
Following the test set forth below the
sample shall be left in normal temperature
and easurements. Are made :
7-1
Contact resistance :
Moisture
Resistance
200mΩ Max.
1) Temperature : 60±2℃
Insulation resistance :
100MΩ Min.
2) Relative humidity : 90 to 95%
3) Time : 96 hours
Water drops shall be removed.
Resistance
7-2
and humidity conditions for an hour before
Low
measurements are made:
Temperature
1)Temperature: -30℃±2℃
Contact resistance:
200mΩ Max.
100MΩ Min.
2)Time: 96 hours
Resistance
7-3
High
Temperature
Contact resistance:
200mΩ Max.
1)Temperature: 80℃±2℃
100MΩ Min.
2)Time: 96 hours
test set forth below :
1) Acceleration : 80G
2) Cycles of test : 3 cycles each in 6
7-4
Impact Shock
Resistance
directions, for a total of 18 cycles.
Item 5
Item 6-1, 6-2
Rev. 01
P:5/6
ITEM
DESCRIPTION
TEST CONDITIONS
REQUIREMENTS
Following ten cycles of high temperature
test. The sample shall be placed in normal
temperature and humidity conditions for one
hour before measurements are made. During
this test, water drops shall be removed.
7-5
200mΩ Max.
Change of
Temperature
100MΩ Min.
Cycling : 1 cycle
1) Range of oscillation : 10 to 55Hz
2) Amplitude, peak to peak : 1.5mm
7-6
Vibration
Resistance
3) Cycle of sweep : 10-55-10Hz in a minute.
4) Mode of sweep : Logarithmically seep or
uniform sweep.
5) Direction of oscillation :
Three mutually perpendicular direction,
including the direction of stem travel.
6) 2 hours each for a total of 6 hours.
8. This item is "RoHS" Compliant
9. Manual Soldering : Max 350℃, 3 sec.
10. Wave Soldering : Max 280℃, 5 sec.
11. Reflow Soldering Conditions: (SMD type only)
Item 5
Item 6-1, 6-2
Rev. 01
P:6/6
11-1 Condition for Soldering
Profile Feature
Average Ramp-UP Rate(Ts max to TP)
Pb-Free Assembly
3℃/second max
Preheat
- Temperature Min(Ts min)
150℃
- Temperature Max(Ts max)
200℃
- Time (ts min to ts max)
60-180seconds
Time maintained above:
- Temperature (TL)
- Time (tL)
Peak/Classification Temperature(TP)
217℃
60-150seconds
260℃ +0℃/ -5℃
Time within 5℃ of actual Peak Temperature(TP)
5~10 seconds
Ramp-Down Rate
6℃/sec max
Time 25℃ to Peak Temperature
8 minutes max
SPECIFICATION
1. RATING : DC 12V 50mA
2. TRAVEL : 0.25 ±0.1mm
3. CONTACT RESISTANCE : 100mΩ MAX.
4. BOUNCE : 10m SEC MAX.
5. LIFE CYCLE : 80,000 CYCLE
TACT
SWITCH
STP-1230
很抱歉,暂时无法提供与“STP-1230A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.02473
- 50+0.67150
- 150+0.47013
- 1000+0.39713
- 2000+0.36460
- 5000+0.34510
