KY3243LEEY
KY3243LEEY
    KEYSEMI(旷岳)
    TSSOP-28
    KY3243LEEY
KY3243LEEY 数据手册
KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE General Description Features The KY32xx series devices are EIA/TIA-232 and V.28/V.24 communication interfaces achieve 1µA supply current with KEYSEMI’s revolutionary POWERSAVE™ feature. A proprietary, high- efficiency, dual chargepumpregulated voltage converters and a low-dropout transmitter combine to deliver true RS-232 performance from a single +3.0V to +5.5V supply.  These devices can operate from input voltages ranging from +3.0V to +5.5V at the guaranteed data rate of 250k bits/sec with enhanced electrostatic discharge (ESD) protection in all RS232 I/O pins exceeding ±15kV EN61000-4-2 Air Gap Discharge and ±8kV EN61000-42 Contact Discharge. The POWERSAVE proprietary function which automatically powers down the on-chip regulated voltage converters and driver circuits when a RS-232 cable is disconnected from the host interface or when a connected peripheral device is turned off. The system turns on again when a valid level is applied to any RS232 receiver input. Absolute Maximum Ratings (All voltages referenced to GND.)     Meets EIA/TIA-232F and CCITT V.28/V.24specifications for VCC at +3.3V ±10% and +5V ±10% Low POWERSAVE Current:1μA typical, 10μA max Guaranteed Data Rate 250kbps Extended ESD Protection for RS-232 I/O Pins ±15kV HBM High Data Rate at 1000kbps Available on KY32xxF Series Applications       Battery-Powered And Hand-Held Applications Peripherals interface Portable Diagnostics Equipment Terminal Adapters and POS terminals Notebooks, Subnotebooks, and Palmtops Industrial and Embedded PCs Power Dissipation Per Package 16-pin SSOP (derate 7.20mW/°C above +70°C) …………… 584mW Supply Voltage VCC.................................................... -0.3V to +6V V+............................................................................... -0.3V to +7V V-............................................................................... -0.3V to +7V |V+| + |V-|...................................................................................+13V Input Voltages 16-pin nSOIC (derate 10.00mW/°C above +70°C)…………...720mW TxIN, PWRSAVE , SD , EN .......................... -0.3V to +6V 20-pin PDIP (derate 12.80mW/°C above +70°C).......……..... 976mW R_IN………........................................................................ ±15V Output Voltages TxOUT............................................................................ ±13.2V 20-pin SSOP (derate 8.10mW/°C above +70°C) ........…….... 647mW RxOUT, STATE ...................................... -0.3V to (VCC + 0.3V) Short-Circuit Duration TxOUT…….............................................................. Continuous Continuous Power Dissipation (TA = +70°C) 16-pin TSSOP (derate 6.80mW/°C above +70°C) ………….. 556mW 16-pin PDIP (derate 11.20mW/°C above +70°C).......……..... 896mW 18-pin PDIP (derate 12.60mW/°C above +70°C)…………..... 962mW 20-pin TSSOP (derate 7.20mW/°C above +70°C)…….……... 584mW 28-pin SSOP (derate 9.52mW/°C above +70°C)……………...762mW 28-pin TSSOP (derate 13.20mW/°C above +70°C) ........……........1W 32-pin VQFN (derate 29.4mW/°C above +70°C)…………….2352mW Operating Temperature Range ...................................... 0°C to +70°C Junction Temperature..............................................................+150°C Storage Temperature Range .....................................-65°C to +150°C Lead Temperature (soldering 10s) ...........................................+300°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. KY32xx Rev.2.0 KEYSEMI Proprietary Information Unauthorized Photocopy and Duplication Prohibited © 2017 KEYSEMI All Rights Reserved KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE Product Selection Guide PART Tx Rx KY3220E KY3221E KY3222E KY3223E KY3232E KY1385E KY3243E 1 1 2 2 2 2 3 1 1 2 2 2 2 5 Data Rate (kbps) 250 250 250 250 250 250 250 Receiver Enable SHUTDOWN Enable POWER SAVE Number of Pins Yes Yes Yes Yes No No No Yes Yes Yes Yes No Yes Yes No Yes No Yes No No Yes 16 16 20 20 16 20 28,32 Package Type SSOP, TSSOP SSOP, TSSOP SSOP, TSSOP, SSOP, TSSOP NSOIC, SSOP, TSSOP SSOP 28-SSOP, 28-TSSOP, 32-VQFN *High Data Rate at 1000kbps Available on KY32xxF Series Electrical Characteristics (VCC = +3.0V to +5.5V, C1–C4 = 0.1µF, TA = TMIN to TMAX, unless otherwise noted, Typical values apply at VCC = +3.3V or +5.0V and TA = 25°C.) Parameters Conditions typical VCC Min Typ Max Unit General InfolTypes TTL Logic Input TxIN, PWRSAVE , SD , TTL Logic Output RxOUT, STATE RS-232 Input RS-232 Output Charge Pump Pin Power Pin Charge Pump Caps VCC Voltage Range RxIN TxOUT C1P, C1N, C2P, C2N VCC, VGND, VDD, VSS C1P, C1N, C2P, C2N EN high ZIN 5.0 3.3 4.5 3 0.1 5.0 3.3 5.5 3.6 µF V V DC Characteristics Supply Current, Power_save disabled Supply Current, Power_save enabled PWRSAVE = SD = VCC, 3.3, 5.0 0.5 mA 3.3, 5.0 1 µA 3.3, 5.0 1 µA TTL I/P= VCC /GND, RS-232 I/P=float PWRSAVE =GND, SD = VCC, TTL I/P= VCC /GND, RS-232 I/P=float Supply Current, shutdown enabled PWRSAVE = VCC /GND, SD =GND, TTL I/P= VCC /GND, RS-232 I/P=float LOGIC Input Input Threshold Low Input Threshold High Input Hysteresis Input Leakage Current VIN= VCC and GND 3.3, 5.0 5.0 3.3 3.3, 5.0 3.3, 5.0 LOGIC Output Output Voltage Low Output voltage High Output Leakage Current IOUT=1.6mA IOUT =-1mA Receiver O/P disabled, VOUT= VCC or GND 3.3, 5.0 3.3, 5.0 3.3, 5.0 -15 0.8 0.6 Input Threshold High Input Hysteresis Input Resistance VIN =±25V 3.3, 5.0 5.0 3.3 3.3, 5.0 3.3, 5.0 3.3, 5.0 Transmitter Output Output Voltage Swing Output Resistance Output Short-circuit Current Output Leakage Current RL =3-7k, all loaded VCC =VDD=VSS=GND, VOUT=±2V VOUT =GND Transmitter disabled, VOUT=±12V 3.3, 5.0 0 3.3, 5.0 0, 3.3, 5.0 ±5 300 Receiver Input Input Voltage Range Input Threshold Low KY32xx Rev.2.0 KEYSEMI CORPORATION 0.8 2.4 2 0.3 ±1 VCC-0.6 0.4 V V µA +15 7 V V V V V kΩ ±60 ±25 V Ω mA µA VCC-0.1 ±0.05 1.5 1.2 2.4 0.3 3 V V V V µA 2 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE Timing Characteristics Maximum Data Rate < standard speed > < high speed > Transition-Region Slew Rate < standard speed > < high speed > Transmitter Propatation tPLH Transmitter Propatation tPHL Transmitter Skew Transmitter Output Enable Time Transmitter Output Disable Time Receiver Propagation tPLH Receiver Propagation tPHL Receiver Skew Receiver Output Enable Time Receiver Output Disable Time RL=3-7k, CL =50pF-1000pF, 1 DR/RC switching RL =3-7k, CL =50pF-1000pF, 1 DR/RC switching 3.3, 5.0 3.3, 5.0 RL =3-7k, CL =50pF-1000pF, 1 DR/RC switching RL =3-7k, CL =50pF-1000pF, 1 DR/RC switching 3k+1000pF, all loaded 3k+1000pF, all loaded tPHL - tPLH 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 3.3, 5.0 30 90 2 2 100 400 250 0.15 0.15 50 0.2 0.2 kbps kbps V/µs V/µs V/µs µs µs ns ns ns µs µs ns µs µs Receiver I/P to STATE Output High 3.3, 5.0 1 µs Receiver I/P to STATE Output Low 3.3, 5.0 30 µs 3.3, 5.0 100 µs 3.3, 5.0 3.3, 5.0 3.3, 5.0 ±15 ±8 ±15 kV kV kV CL=150pF CL =150pF tPHL - tPLH 250 1000 AutoGreen Timing Power save mode to transmitter enabled ESD Tolerance ESD HBM ESD 1000-4-2 Contact ESD 1000-4-2 Air Pin Description PIN KY3220 KY3221 KY3222 KY3223 KY3232 NAME KY3243 FUNCTION 16Pins 16Pins 20Pin 20Pins 16Pins 28Pins 32Pins 1 1 1 1 — — — EN Receiver Enable Control. Drive low for normal operation. Drive high to force the receiver outputs into a high-Z state. 5 5 5 5 4 1 29 C2+ Positive terminal of inverting charge-pump capacitor 6 6 6 6 5 2 30 C2- Negative terminal of inverting charge-pump capacitor 7 7 7 7 6 3 31 V- -5.5V generated by the charge pump 8 8 9, 16 9, 16 8,13 4,5,6,7,8 1,2,3,4,5 R_IN 13 13 8, 17 8, 17 7,14 9,10,11 6,7,8 T_OUT 11 11 12, 13 12, 13 10,11 12,13,14 10,11,12 T_IN TTL/CMOS Transmitter Inputs 15,16,17, 13,14,15, 18,19 17,18 R_OUT TTL/CMOS Receiver Outputs ROUTB TTL/CMOS level, noninverting, always enabled receiver outputs. 9 9 10, 15 10, 15 9,12 — — — — — 20 19 — 10 — 11 — 21 20 16 16 20 20 — 12 — 14 4 4 4 4 14 14 18 18 KY32xx Rev.2.0 — STATE ( INVALID ) SD 22 21 23 22 3 24 23 C1- 15 25 24 GND — PWRSAVE RS-232 Receiver Inputs RS-232 Transmitter Outputs Output of the valid signal detector. Indicates if a valid RS232 level is present on receiver inputs logic “1”. Drive low to shut down transmitters and on-board power supply. This over- rides all automatic circuitry and PWRSAVE Drive high to override automatic circuitry keeping transmitters on ( SD must be high) Negative terminal of the voltage doubler charge-pump capacitor Ground KEYSEMI CORPORATION 3 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE 15 15 19 19 16 26 26 VCC +3.0V to +5.5V Supply Voltage 3 3 3 3 2 27 27 V+ +5.5V generated by the charge pump 2 2 2 2 1 28 28 C1+ Positive terminal of the voltage doubler charge-pump capacitor Truth Table Operation Status Shutdown Normal without PWRSAVE Normal with PWRSAVE PWRSAVE don’t care don’t care don’t’ care don’t’ care 1 1 1 1 0 0 0 0 SD EN 0 0 0 0 1 1 1 1 1 1 1 1 0 0 1 1 0 0 1 1 0 0 1 1 Signal at RXIN STATE present not present present not present present not present present not present present not present present not present 1 0 1 0 1 0 1 0 1 0 1 0 TXOUT RXOUT tri-state tri-state tri-state tri-state active active active active active tri-state active tri-state active active tri-state tri-state active active tri-state tri-state active active tri-state tri-state Detailed Description Charge-Pump RS-232 Receive The KY32xx’s family utilizes regulated on-chip dual charge pumps that provides output voltages of +5.5V(doubling charge pump) and -5.5V (inverting charge pump), regardless of the input voltage (VCC) over the +3.0V to +5.5V range. The charge pumps operate in a discontinuous mode: if the output voltages are less than 5.5V, the charge pumps are enabled; if the output voltages exceed 5.5V, the charge pumps are disabled. Each charge pump requires a flying capacitor (C1, C2) and a reservoir capacitor (C3, C4) to generate the V+ and V- supplies. The KY32xx’s receivers convert RS-232 signals to CMOS-logic output levels. They are contain standard inverting receivers that three-state (except for the KY3232, KY3243) via the EN or SD control lines. RS-232 Transmitters The transmitters are proprietary, low dropout, inverting level translators that convert TTL/CMOS inputs to EIA/TIA-232 output levels. Coupled with the on-chip 5.5V supplies, these transmitters deliver ptrue RS-232 levels over a wide range of single supply system voltages. When SD is driven to ground, or the POWERSAVE circuitry senses invalid voltage levels at all receiver inputs, the transmitters are disabled and the outputs are forced into a high- impedance state. Controlled Power-Down The KY3220, KY3221, KY3222, KY3223 and KY3243 have a low-power shutdown mode controlled by the SD pin. During shutdown the driver output and the switchcapacitor regulated voltage converter are disabled with the supply current falls to less than 1μA.The KY3221, KY3223 and KY3243 use KEYSEMI’s patent pending POWERSAVE circuitry to set/reset latches, which enable the circuit shutdown function when a RS232 cable is disconnected or when the peripheral is turned off and reduce the power supply drain to 1μA supply current. When a RS232 cable is connected or when the peripheral is enabled, the devices will automatically become active again. ESD Immunity The KY32xx series incorporates ruggedized ESD cells on all driver output and receiver input pins. KY32xx Rev.2.0 KEYSEMI CORPORATION 4 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE The ESD structure is improved for more rugged applications and environments sensitive to electro-static discharges and associated transients. The improved ESD tolerance is at least +15kV without damage nor latch-up. There are two methods within EN61000-4-2, the Air Discharge method and the Contact Discharge method. With the Air Discharge Method, an ESD voltage is applied to the equipment under test through air, which simulates an electrically charged person ready to connect a cable onto the rear of the system and the high energy potential on the person discharges through an arcing path to the rear panel of the system before he or she even touches the system. The Contact Discharge Method applies the ESD current directly to the EUT. This method was devised to reduce the unpredictability of the ESD arc. The discharge current rise time is constant since the energy is directly transferred without the air-gap arc inconsistencies. KEYSEMI's RS232 transceivers meets and exceeds the minimum criteria for EN61000-4-2 with ±15kV for Air Gap Discharge and ±8kV for Contact Discharge. KY32xx Rev.2.0 The circuit models in following Figures represent the typical ESD testing circuit. The CS is initially charged with the DC power supply when the first switch (SW1) is on. Now that the capacitor is charged, the second switch (SW2) is on while SW1 switches off. The voltage stored in the capacitor is then applied through RS, the current limiting resistor, onto the device under test (DUT). In ESD tests, the SW2 switch is pulsed so that the device under test receives a duration of voltage. For the Human Body Model, the current limiting resistor (RS) and the source capacitor (CS) are 1.5kΩ and 100pF, respectively. For IEC-61000-4-2, the current limiting resistor (RS) and the source capacitor (CS) are 330Ω and 150pF, respectively. The higher CS value and lower RS value in the IEC61000-4-2 model are more stringent than the Human Body Model. The larger storage capacitor injects a higher voltage to the test point when SW2 is switched on. The lower current limiting resistor increases the current charge onto the test point. KEYSEMI CORPORATION 5 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY32xx Rev.2.0 KEYSEMI CORPORATION 6 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE Typical Application Circuits and Pin Configuration KY3220 C3(OPTIONAL CONNECTION,NOTE) KY3220(SSOP,TSSOP) TOP VIEW KY3221 C3(OPTIONAL CONNECTION,NOTE) KY3221(SSOP,TSSOP) TOP VIEW KY32xx Rev.2.0 KEYSEMI CORPORATION 7 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY3222 C3(OPTIONAL CONNECTION,NOTE) KY3222(SSOP,TSSOP) TOP VIEW KY3223 C3(OPTIONAL CONNECTION,NOTE) KY3223(SSOP,TSSOP) TOP VIEW KY32xx Rev.2.0 KEYSEMI CORPORATION 8 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY3232 C3(OPTIONAL CONNECTION,NOTE) KY3232(nSOIC,SSOP,TSSOP) TOP VIEW KY3243 KY3243(SSOP,TSSOP) TOP VIEW KY32xx Rev.2.0 KEYSEMI CORPORATION 9 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY3243(VQFN) KY3243(32Pin VQFN) Typical Test Circuits Maximum Data Rate Test Circuit Notes: A. B. TEST CIRCUIT KY32xx Rev.2.0 C. RL=3kΩ, CL = 1000pF,TA = 25°C, One Driver Switching. The pulse generator had the following characteristics: PRR = 250 kbps, Zo = 50Ω, 50% duty cycle, Tr & Tf ≤ 10ns. SD = VCC when applicable. KEYSEMI CORPORATION 10 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY32xx TxIN to TxOut (no load) at 250kbps waveform KY32xx TxIN to TxOut to RxOut (loopback to Rx with 1000pF load) at 250kbps waveform Driver Transition-Region Slew Rate Test Circuit Notes: A. RL=3k~7kΩ,CL= 150~1000pF,TA = 25°C One Driver Switching, Measured from +3V to -3V or -3V to +3V. B. The pulse generator had the following characteristics: PRR = 250 kbps, Zo = 50Ω, 50% duty cycle, Tr & Tf ≤ 10ns. C. SD = VCC when applicable. Driver Propagation (tPHL & tPLH) Test Circuit Notes: A. All drivers loaded with RL=3kΩ,CL= 1000pF. B. The pulse generator had the following characteristics: PRR = 250 kbps, Zo = 50Ω, 50% duty cycle, Tr & Tf ≤ 10ns. C. SD = VCC when applicable. Receiver Propagation Delay Times Test Circuit Notes: A. CL= 150pF, including probe and jig capacitance. B. The pulse generator had the following characteristics: PRR = 250 kbps, Zo = 50Ω, 50% duty cycle, Tr & Tf ≤ 10ns. C. SD = VCC when applicable. KY32xx Rev.2.0 KEYSEMI CORPORATION 11 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE Package Information KY32xx Rev.2.0 KEYSEMI CORPORATION 12 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY32xx Rev.2.0 KEYSEMI CORPORATION 13 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY32xx Rev.2.0 KEYSEMI CORPORATION 14 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE KY32xx Rev.2.0 KEYSEMI CORPORATION 15 KY32xx +3V to +5.5V RS-232 Transceivers with POWERSAVE Ordering Information Part Number KY3220LEEA KY3220LEEY KY3221LEEA KY3221LEEY KY3222LEEA KY3222LEEY KY3223LEEA KY3223LEEY KY3232LEEA KY3232LEEN KY3232LEEY KY1385LEEA KY3243LEEA KY3243LEEY KY3243LEEQ Temperature Range -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C -40°C to +85°C Package Type 16-pin SSOP 16-pin TSSOP 16-pin SSOP 16-pin TSSOP 20-pin SSOP 20-pin TSSOP 20-pin SSOP 20-pin TSSOP 16-pin SSOP 16-pin nSOIC 16-pin TSSOP 20-pin SSOP 28-pin SSOP 28-pin TSSOP 32-pin VQFN *High Data Rate at 1000kbps Available on KY32xxF Series Please contact the factory for pricing, availability on Tape-and-Reel, and Green Package options. KY32xx Rev.2.0 KEYSEMI CORPORATION 16
KY3243LEEY 价格&库存
很抱歉,暂时无法提供与“KY3243LEEY”相匹配的价格&库存,您可以联系我们找货
