ESD3.3V52D-C
ESD3.3V52D-C
    SOCAY(硕凯)
    SOD523
    ESD3.3V52D-C
ESD3.3V52D-C 数据手册
Transient Voltage Suppressors for ESD Protection ESDXXV52D-C Series Description SOD-523 The ESDXXV52D-C is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Feature Functional Diagram u 100 Watts Peak Pulse Power per Line (tp=8/20μs) u Protects one I/O line u Low clamping voltage u Working voltages : 3.3V, 8V u Low leakage current u IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact) u IEC61000-4-4 (EFT) 40A (5/50ns) Applications Mechanical Characteristics u Cell Phone Handsets and Accessories u SOD-523 Package u Microprocessor based equipment u Molding Compound Flammability Rating : UL 94V-0 u Personal Digital Assistants (PDA's) u Weight 2 Milligrams (Approximate) u Notebooks, Desktops, and Servers u Quantity Per Reel : 3,000pcs u Portable Instrumentation u Reel Size : 7 inch u Peripherals u Lead Finish : Lead Free u Pagers Mechanical Characteristics Symbol Parameter Value Units 100 W PPP Peak Pulse Power (tp=8/20μs waveform) TL Lead Soldering Temperature 260 (10sec) ℃ TSTG Storage Temperature Range -55 to +150 ℃ TOP Operating Temperature Range -55 to +150 ℃ IEC61000-4-2 (ESD) Air Discharge ±30 Contact Discharge ±30 IEC61000-4-4 (EFT) 40 SSOCAY Electronics Corp., Ltd. Revision May 06, 2016 KV A www.socay.com 1/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection ESDXXV52D-C Series I-V Curve Characteristics Symbol Parameter Bi-directional IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM I IPP Working Peak Reverse Voltage IR Maximum Reverse leakage Current IT Test Current VB Breakdown Voltage @ IT VC @ VRWM IT VB VRWM R V IR IT IR VRWM VB VC IPP Electrical Characteristics (@ 25℃ Unless Otherwise Specified ) Device Marking VRWM (V) (Max.) VB (V) (Min.) IT (mA) VC @1A (Max.) (Max.) ESD3.3V52D-C CT 3.3 4 1 7 ESD08V52D-C GT 8 8.5 1 17.5 Part Number (@A) IR (μA) (Max.) C (pF) (Typ.) 12 8 1 10 25 3 1 7 VC Characteristic Curves Fig1. 8/20μs Pulse Waveform Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) tr 100 Peak Value IPP 80 100% TEST WAVEFORM PARAMETERS tr=8μs td=20μs Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time (μs) SSOCAY Electronics Corp., Ltd. Revision May 06, 2016 90% www.socay.com 2/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection ESDXXV52D-C Series Characteristic Curves Fig3. ESD Clamping (+8KV Contac per IEC61000-4-2) Fig4. ESD Clamping (-8KV Contac per IEC61000-4-2) SOD-523 Package Outline & Dimensions Millimeters Inches Symbol Soldering Footprint Min. Nom. Max. Min. Nom. Max. A 1.10 1.20 1.30 0.043 0.047 0.051 B 0.70 0.80 0.90 0.028 0.032 0.035 C 0.50 0.60 0.70 0.020 0.024 0.028 D 0.25 0.30 0.35 0.010 0.012 0.014 J 0.07 0.14 0.20 0.0028 0.0055 0.0079 K 0.15 0.20 0.25 0.006 0.008 0.010 L 1.50 1.60 1.70 0.059 0.063 0.067 Symbol Millimeters Inches E 1.40 0.0547 F 0.40 0.0157 G 0.40 0.0157 SSOCAY Electronics Corp., Ltd. Revision May 06, 2016 www.socay.com 3/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
ESD3.3V52D-C
物料型号:ESDXXV52D-C系列
器件简介:ESDXXV52D-C系列瞬态电压抑制器设计用于保护电压敏感元件免受ESD(静电放电)和瞬态电压事件的影响。这些部件具有出色的钳位能力、低漏电流和快速响应时间,非常适合在板空间有限的设计中进行ESD保护。
引脚分配:文档中未明确提供引脚分配信息,但提到了SOD-523封装。
参数特性: - 峰值脉冲功率:每线100瓦特(tp=8/20μs) - 工作电压:3.3V和8V - 低漏电流 - 符合IEC61000-4-2(ESD)标准,空气放电±30kV,接触放电±30kV - 符合IEC61000-4-4(EFT)标准,40A(5/50ns)
功能详解: - 双向钳位 - 电气特性表提供了不同工作电压下的参数,如最大反向峰值脉冲电流、钳位电压、工作峰值反向电压、最大反向漏电流等。
应用信息: - 手机及其配件 - 基于微处理器的设备 - 个人数字助理(PDA) - 笔记本电脑、台式机和服务器 - 便携式仪器 - 外围设备 - 寻呼机
封装信息: - SOD-523封装 - 重量约为2毫克 - 每卷数量:3000片 - 卷径:7英寸 - 引脚表面处理:无铅 - 机械特性表提供了详细的尺寸信息,包括最小值、标称值和最大值。
ESD3.3V52D-C 价格&库存
很抱歉,暂时无法提供与“ESD3.3V52D-C”相匹配的价格&库存,您可以联系我们找货
