RMC10K124FTH
RMC10K124FTH
    KAMAYA(釜屋电机)
    RMC10K124FTH
RMC10K124FTH 数据手册
Spec. No.: Date: RMC-1K-17N1011 2017. 11. 28 /1 Data sheet Title: FIXED RECTANGULAR TYPE Style: RMC10,16,20,32,35 Automotive Grade AEC-Q200 qualified RoHS COMPLIANCE ITEM Halogen and Antimony Free Note: ・Stock conditions Temperature: +5°C ∼ +35°C Relative humidity: 25% ∼ 75% The period of guarantee: Within 2 year from shipmen t by the company. Solderability shall be satisfied. ・Product specification contained in this data sheet are subject to change at any time without notice ・If you have any questions or a Purchasing Specification for any quality Agreement is necessary, please contact our sales staff. Hokkaido Research Center Approval by: T. Sannomiya Drawing by: M. Shibuya Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 1. Scope 1.1 This specification covers the detail requirements for fixed thick film chip resistors 35. 1/10 10, 16, 20,32, 1.2 Applicable documents JIS C 5201−1: 2011, IEC60115−1: 2008, AEC-Q200 Rev.D 1.3 For Automotive Grade - AEC-Q200 qualified (Grade 0) - Managed and manufactured under the exclusive manufacturing process for automotive. 2. Classification Type designation shall be the following form. (Example) 1) RMC 32 − 1 2 3 Style 2) RMC 32 1 2 Style 1 Fixed 2 Rated dissipation and / or dimension 3 Temperature coefficient of resistance 123 4 J 5 JP 4 TP 6 Style K −(Dash) 4 Rated resistance 123 1000 JP TP 6 ±100×10−6/ °C Standard E24 Series, 3 digit, Ex. 123--> 12kΩ, E96 Series, 4 digit, Ex. 1000-->100Ω 1022--> 10.2kΩ Chip jumper 5 Tolerance on rated resistance B ±0.1% D ±0.5% F ±1% G ±2% J ±5% 6 Packaging form 1. Scope B Bulk (loose package) TH Paper taping TP TE Embossed taping Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 2/10 3. Rating 3.1 The ratings shall be in accordance with Table−1. Table−1(1) Style RMC10 Rated dissipation (W) Temperature coefficient of resistance (10−6 / °C) K ±100 10∼1M Standard K ±200 ±100 ±200 +500∼−200 ±200 ±200 +500∼−200 1.02M∼3.3M 10∼1M 1.02M∼10M 1∼9.76 10∼10M 10∼10M 1∼9.1 ±100 10∼3.3M ±100 +500∼−200 ±200 +500∼−200 ±200 +500∼−200 10∼10M 1∼9.76 10∼10M 1.0∼9.1 10∼22M 1.0∼9.1 ±100 10∼2.2M Standard ±200 2.21M∼3.3M K ±100 ±200 +500∼−200 ±200 +500∼−200 ±200 +500∼−200 10∼2.2M 2.21M∼10M 1.0∼9.76 10∼10M 1.0∼9.1 10∼22M 1.0∼9.1 K ±100 10∼1M Standard ±200 +500∼−200 ±200 +500∼−200 ±200 +500∼−200 1.02M∼10M 1.0∼9.76 10∼10M 1.0∼9.1 10∼24M 1.0∼9.1 ±100 10∼1M ±200 +500∼−200 1.02M∼10M 1.0∼9.76 10∼1M 10∼22M 1.0∼9.1 0.1 Standard K RMC16 0.1 Standard K RMC20 Rated resistance range (Ω) 0.125 Standard Preferred number series for resistors E24, 96 0.25 K G(±2%) E24 E24, 96 0.5 Standard ±200 +500∼−200 J(±5%) B(±0.1%) D(±0.5%) F(±1%) G(±2%) E24 J(±5%) E24,96 B(±0.1%) D(±0.5%) D(±0.5%) F(±1%) G(±2%) E24 J(±5%) B(±0.1%) D(±0.5%) F(±1%) F(±1%) G(±2%) E24 J(±5%) E24,96 RMC35 B(±0.1%) D(±0.5%) D(±0.5%) F(±1%) E24,96 RMC32 Tolerance on rated resistance B(±0.1%) D(±0.5%) F(±1%) F(±1%) G(±2%) E24 J(±5%) Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Style Limiting element voltage (V) Table−1(2) Isolation voltage (V) Page: 3/10 Category temperature range (°C) RMC10 50 100 RMC16 RMC20 150 −55∼+155 RMC32 500 200 RMC35 Note. Rated current of chip jumper: RMC10: 1(A), RMC16, 20, 32, 35: 2(A) Note. Resistance value of chip jumper: 50 mΩ max. 3.2 Climatic category 55/155/56 3.3 Stability class 2% Lower category temperature Upper category temperature Duration of the damp heat, steady state test − 55 °C +155 °C 56days Limits for change of resistance: −for long−term tests ±(2%+0.1Ω) Chip jumper: 50 mΩ max. −for short−term tests ±(0.5%+0.05Ω) Chip jumper: 50 mΩ max. 3.4 Derating The derated values of dissipation (or current rating in case of chip jumper) at temperature in excess of 70 °C shall be as indicated by the following curve. 100 Percentage of the rated dis sipation (Current) (%) 0 −55 Area of recommended operation 70 155 Ambient temperature (° C) Figure−1 Derating curve 3.5 Rated voltage d. c. or a. c. r. m. s. voltage calculated from the square root of the product of the rated resistance and the rated dissipation. E : Rated voltage (V) E = P · R P : Rated dissipation (W) R : Rated resistance (Ω) Limiting element voltage can only be applied to resistors when the resistance value is equal to or higher than the critical resistance value. At high value of resistance, the rated voltage may not be applicable. Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 4/10 4. Packaging form The standard packaging form shall be in accordance with Table−2. Table−2 Symbol B TH TP TE Standard packaging quantity / units 1,000 pcs. 10,000 pcs. 5,000 pcs. 4,000 pcs. Packaging form Bulk (loose package) Paper taping 8mm width, 2mm pitches Paper taping 8mm width, 4mm pitches Embossed taping 8mm width, 4mm pitches Application RMC10,16,20,32,35 RMC10 RMC16, 20, 32 RMC35 5. Dimensions 5.1 The resistor shall be of the design and physical dimensions in accordance with Figure−2 and Table−3. z W z L c d d H c Style RMC10 RMC16 RMC20 RMC32 RMC35 L 1.0±0.05 1.6±0.1 2.0±0.1 3.1±0.1 3.1±0.15 W 0.5±0.05 +0.15 0.8−0.05 1.25±0.10 1.6±0.15 2.5±0.15 Figure−2 Table−3 H 0.35±0.05 0.45±0.10 0.55±0.10 0.55±0.10 0.55±0.15 Unit : mm c 0.2±0.1 0.3±0.1 0.4±0.2 0.5±0.25 0.5±0.25 d +0.05 0.25−0.10 0.3±0.1 0.4±0.2 0.5±0.25 0.5±0.25 z --------0.05~0.3 0.05~0.3 5.2 Net weight (Reference) Style Net weight(mg) RMC10 0.6 RMC16 2 RMC20 5 RMC32 9 RMC35 16 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 5/10 6. Marking The Rated resistance of RMC 10 should not be marked. 6.1 RMC20,32,35. The nominal resistance shall be marked in 3 digits or 4 digits and marked on over coat side. • E24 series: 3 digits, E96 series: 4 digits In case of the resistance value that E96 overlaps with E24, It is marked by either. Marking example Contents Application 123 2R2 2.2 5623 12R7 12×10 3 [Ω] → 12 [kΩ] 2. 2 [Ω] 2. 2 [Ω] 562×10 3 [Ω] → 562[kΩ] 12.7 [Ω] RMC20,32,35 Less than 10Ω of RMC32,35 Less than 10Ω of RMC20 RMC20,32,35 RMC20,32,35 6.2 RMC16 The nominal resistance shall be marked in 3 digits and marked on over coat side. No marking in the E96 series. Marking example Contents Application 123 E24 12×10 3 [Ω] → 12 [kΩ] E24 2R2 2. 2 [Ω] 2 No marking E96 102×10 [Ω] → 10.2 [kΩ] No marking E96 332×10−1 [Ω] → 33.2 [Ω] 6.3 Marking example of Jumper Chip Marking example Contents or 000 JP 000 Application RMC16 RMC20,32 RMC35 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 6/10 7. Performance 7.1 The standard condition for tests shall be in accordance with Sub−clause 4.2, JIS C 5201−1: 1998. 7.2 The performance shall be satisfied in Table−4. Table−4(1) Test items Condition of test Performance requirements No. 1 High temperature exposure MIL-STD-202 Method 108 Resistor: ∆R/R: Within ±(2%+0.1Ω) AEC Q200 - No.3 Ambient temperature:155±2°C, Chip jumper: 50mΩ max. Condition: Without load, No visible damage Duration: 1000 +480 h Interval measurements: 250 h and 500 h 2 Temperature cycling JESD22 Method JA-104 Resistor: ∆R/R: Within ±(1%+0.05Ω) AEC Q200 - No.4 Temperature: -55±3°C / 125±2°C, Chip jumper: 50mΩ max. Dwell time: 30min maximum at each temp. No visible damage Transition time: 1 min. max. Number of cycles: 1000 cycles. Interval measurements: 250 cy and 500 cy 3 Bias humidity MIL-STD-202 Method 103 Resistor: ∆R/R: Within ±(2%+0.1Ω) AEC Q200 – No.7 Condition: 85°C & 85% R.H. Chip jumper: 50mΩ max. Test power: 10% of rated power shall be No visible damage applied for continuously. Duration: 1,000 +480 h Interval measurements: 250 h and 500 h 4 Operational life MIL-STD-202 Method 108 Resistor: ∆R/R: Within ±(2%+0.1Ω) AEC Q200 – No.8 Ambient temperature: 125±2ºC Chip jumper: 50mΩ max. The applied voltage shall be the voltage to be No visible damage calculated at 35% of rated dissipation or the limiting element voltage whichever is the smaller. Condition: The voltage shall be applied for continuously. +48 Duration: 1000 h 0 Interval measurements: 250 h and 500 h 5 Dimensions JESD22 Method JB-100 As in Table−3 AEC Q200 – No.10 6 Resistance to Solvents MIL-STD-202 Method 215 Resistor: ∆R/R: Within ±(1%+0.05Ω) AEC Q200 – No.12 Solvent: 2−propanol at 25℃ Chip jumper: 50mΩ max. Immersion time: 3 min No visible damage Brush: 10 times brushing Immersion and brush cycle: 3cycle 7 Mechanical Shock MIL-STD-202 Method 213 Resistor: ∆R/R: Within ±(0.5%+0.05Ω) AEC Q200 – No.13 Waveform: half sine, Chip jumper: 50mΩ max. Peak value100G, No visible damage Normal duration 6ms Condition: XX'YY'ZZ', 10times each Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade No 8 Test items Vibration AEC Q200 – No.14 9 Resistance to soldering heat AEC Q200 - No.15 10 ESD test AEC Q200 – No.17 11 Solderability AEC Q200 – No.18 12 Electrical Characterization AEC Q200 - No.19 13 Bending strength AEC Q200 – No.21 14 Adhesion AEC Q200 – No.22 Page: 7/10 Table−4(2) Condition of test MIL-STD-202 Method 204 Performance requirements Resistor: ∆R/R: Within ±(0.5%+0.05Ω) Peak acceleration and Sweep time: 5 g's for 20 Chip jumper: 50mΩ max. min , Frequency 10Hz to 2000Hz, No visible damage Condition: 12 cycles each of 3 orientations MIL-STD-202 Method 210 Resistor: ∆R/R: Within ±(0.5%+0.05Ω) Solder bath temp: 260±5ºC Chip jumper: 50mΩ max. Immersed time: 10±1s No visible damage AEC-Q200-002 Resistor: ∆R/R: Within ±(5%+0.1Ω) Human body model, 2 Kohm, 150 pF, No visible damage Test voltage: RMC16,1/10.1/8,1/4 2000V RMC10 800V J-STD-002 The surface of terminal immersed shall a) Bake the sample for 155 ºC dwell time 4h / be min. of 95% covered with a new solder dipping 235ºC/ 5s. coating of solder. Solder: Sn96.5-Ag3-Cu0.5 b) Category 3, Solder dipping 215ºC/ 5s. Solder: Sn63Pb37 c) Category 3, Solder dipping 260ºC/ 7s. 1. D.C. Resistance 1. The resistance value shall 2. Temperature Coefficient of Resistance correspond with the rated resistance -55 °C / +20°C taking into account the specified +20 °C / +155°C tolerance. 2. As in Table−1 AEC-Q200-005 Resistor: ∆R/R: Within ±(0.5%+0.05Ω) Bending value2mm Chip jumper: 50mΩ max. Holding time: 60sec. No visible damage AEC-Q200-006 Resistor: ∆R/R: Within ±(0.5%+0.05Ω) Pressurizing force: Chip jumper: 50mΩ max. RMC20,32,35 17.7N No visible damage RMC10,16 10N Test time: 60±1s. Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 8/10 9. Taping 9.1 Applicable documents JIS C 0806−3: 2014, EIAJ ET−7200C: 2010 9.2 Taping dimensions 9.2.1 Paper taping (8mm width, 2mm pitches) Taping dimensions shall be in accordance with Figure−3 and Table−5. 4±0.1 t1 Sprocket hole φ1.5 Unit: mm 0 .1 +0 0 1.75±0.1 B 8±0.2 A t2 2±0.05 Carrier cavity 3.5±0.05 Direction of unreeling Style RMC10 A 0.65+0.05 −0.10 Figure−3 Table−5 B 1.15 −+0.05 0.10 t1 0.4 ± 0.05 Unit: mm t2 0.5max. 9.2.2 Paper taping (8mm width, 4mm pitches) Taping dimensions shall be in accordance with Figure−4 and Table−6. Unit: mm 4±0.1 t 1 φ1.5 Sprocket hole +0.1 0 2±0.05 1.75±0.1 B 8±0.2 A t Carrier cavity 2 4±0.1 3.5±0.05 Direction of unreeling Style RMC16 RMC20 RMC32 Figure−4 Table−6 A B 1.15±0.15 1.9±0.2 1.65±0.15 2.5±0.2 2.00±0.15 3.6±0.2 t1 0.6±0.1 Unit: mm t2 0.8max. 0.8±0.1 1.0max. Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 9/10 9.2.3 Embossed taping dimensions shall be in accordance with Figure−5 and Table−7. Unit: mm 0.3 max. 2±0.05 Sprocket hole φ1.5+0.1 0 1.75±0.1 4±0.1 W B E A Carrier cavity t1 Style RMC35 Direction of unreeling 4±0.1 Figure−5 Table−7 B W 3.5±0.2 8.0±0.3 A 2.85±0.20 E 3.5±0.05 Unit: mm t1 1.0±0.2 1). The cover tapes shall not cover the sprocket holes. 2). Tapes in adjacent layers shall not stick together in the packing. 3). Components shall not stick to the carrier tape or to the cover tape. 4). Pitch tolerance over any 10 pitches ±0.2mm. 5). The peel strength of the top cover tape shall be with in 0.1N to 0.5N on the test method as shown in the following RMC10, 16, 20, 32: Figure−6, RMC35: Figure−7. 6). When the tape is bent with the minimum radius for 25 mm, the tape shall not be damaged and the components shall maintain their position and orientation in the tape. 7). In no case shall there be two or more consecutive components missing. The maximum number of missing components shall be one or 0.1%, whichever is greater. 8). The resistors shall be faced to upward at the over coating side in the carrier cavity. Top cover tape Carrier tape Peel−off ( About 300mm/ min) 165°to180° Direction of unreeling Figure−6 Top cover tape Carrier tape 165°to180° Peel−off (About 300mm/ min) Direction of unreeling Figure−7 Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28 Drawing No: RMC−1K−17N1011 /1 Title: RMC10,16,20,32,35 Automotive Grade Page: 10/10 9.3 Reel dimension Reel dimensions shall be in accordance with the following Figure−8 and Table−8. Plastic reel (Based on EIAJ ET−7200C) Unit: mm 0     +1 φ60      0 φ13±0.2 2±0.5 φ180 −1.5 Marking A φ21±0.8 Marking B A B Figure−8 Table−8 A Unit: mm B Note Injection molding 11.4±1.0 RMC 10, 16, 20, 32, 35 9 +1.0 0 13±1.0 Vacuum forming Note: Marking label shall be marked on a place of Marking A or two place of marking A and B. Style 9.4 Leader and trailer tape. (Example) 400mm min. 100mm min. 160mm min. End Start Trailer Leader Direction of unreeling Figure−9 10. Marking on package The label of a minimum package shall be legibly marked with follows. 10.1 Marking A (1) Classification (Style, Temperature coefficient of resistance, Rated resistance, Tolerance on rated resistance, Packaging form) (2) Quantity (3) Lot number (4) Manufacturer’s name or trade mark 10.2 Marking B (KAMAYA Control label) (5) Others Product specification contained in this data sheet are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.11.28
RMC10K124FTH
物料型号:KAMAYA OHM的固定厚膜芯片电阻,型号包括RMC10, 16, 20, 32, 35。
器件简介:这些电阻是符合汽车级AEC-Q200标准的厚膜芯片电阻,具有RoHS合规性,无卤素和锑。
引脚分配:文档中没有明确提到引脚分配,但通常这类电阻的引脚分配是简单的两端引脚。
参数特性: - 额定耗散功率和尺寸/温度系数:例如,RMC10的额定耗散功率为0.1W,温度系数为±100ppm/°C。 - 额定电阻值范围:10Ω至1MΩ,提供E24和E96系列的优选数。 - 公差等级:包括B(±0.1%)、D(±0.5%)、F(±1%)、G(+2%)、J(+5%)。
功能详解: - 电阻器符合JIS C 5201−1: 2011, IEC60115−1: 2008等标准。 - 为汽车级产品,符合AEC-Q200 Rev.D标准。 - 提供了详细的电气性能测试要求,如高温暴露、温度循环、偏置湿度、操作寿命、尺寸、耐溶剂性、机械冲击、振动、耐焊接热、静电放电、可焊性、电气特性、弯曲强度和粘附性测试。
应用信息:适用于汽车电子领域。
封装信息: - 提供了详细的封装尺寸,如长度(L)、宽度(W)、高度(H)等。 - 净重:例如,RMC10的净重为0.6mg。 - 标记方式:根据电阻值的不同,标记方式也有所不同,包括3位或4位数字标记。
其他信息: - 产品规格可能会随时更改,如有疑问或需要采购规格书,请联系销售团队。 - 文档由KAMAYA ELECTRIC CO., LTD. Hokkaido Research Center发布,最后更新日期为2017年11月28日。
RMC10K124FTH 价格&库存
很抱歉,暂时无法提供与“RMC10K124FTH”相匹配的价格&库存,您可以联系我们找货
