AVL/AVLC 0402 Series
Multilayer Chip Varistor
Overview
Features
ESD Varistor is a component which acts as a non-
· Meets IEC 61000-4-2 (ESD)
conductor on the circuit in normal circumstances.
· Level 4 & IEC 61000-4-4 (EFT), Level 4 requirements
When over-voltage is loaded, it becomes a con-
· ESD Protection > 25 KV
ductor which diverts over-current from circuits to
· Low capacitance for high frequency data line protection
ground at critical voltage level.
· Fast response time < 1ns
· Available in tape and reel for automatic pick and place
Surge Voltage (V)
Applications
· Mobile Phone & PDA
Surge current (I)
Max. permiable
Operating Voltage
· Cellular Phone
Protection
Level
· PCMCIA / Compact Flash Card
· RS-232 & RS-423 Data Lines
· USB Data Lines
Fig 1 V-I Characteristic Curve
· MCM Boards
· LCD Module
Model Description
AVLC
(1)
(1)
5
(2)
S
(3)
02
(4)
050
(5)
Series name : “AVL” – General Type
“AVLC” – Low capacitance type varistor
(2)
Maximum continuous working voltage (Vdc) : “5”- 5.5V, “14”- 14V, “18”- 18V
(3)
Breakdown voltage tolerance : “S” - special order, M: 20 % Vn tolerance
(4)
Chip size : 02 - 0402(1.0x0.5mm), 03 - 0603(1.6x0.8mm)
(5)
Peak current (AVL) : 200 - 20 A
Capacitance (AVLC) : 003-3pF, 015-15pF, 050-50pF, 100-100pF, 200-200pF
07/05/22 (Rev. 01)
Amotech Corporation (www.amotech.co.kr)
1
Electrical characteristics
Varistor
Vdc
Leakage
voltage
(1)
Clamping
Peak
(@ 1kHz,
Voltage
Current
Vrms=0.5V)
(VC)
(Imax)
Current
(Vn)
Part No.
Insulation
Cp
Resistance
(IL)
(IR)
@1mA DC
@Vdc
@3.6V
(V)
(V)
(pF)
(V)
(A)
AVL 5M 02 200
5.5
6.4-9.6
20 max
480(336-624)
15.5
10 min
AVL 14K 02 200
14
16.2-19.8
20 max
160(112-208)
35
10 min
AVLC 5S 02 050
5.5
10-14
20 max
50 (35-65)
25
10
10 min
AVLC 5S 02 100
5.5
10-14
20 max
100 (70-130)
25
10 min
AVLC 5S 02 200
5.5
10-14
20 max
200 (140-260)
25
10 min
AVLC 14S 02 050
14
18-24
20 max
50 (35-65)
40
10
10 min
AVLC 14S 02 100
14
18-24
20 max
100 (70-130)
40
10 min
AVLC 18S 02 015
18
24-32
20 max
15 (7.5-22.5)
45
5
10 min
20 max
3.0 (2.1-3.9)
AVLC 18S 02 003
18
90-160
300
1
10 min
at 1MHz
(1) Maximum continuous DC working voltage
(2) Cp measuring frequency of AVLC 18S 02 003 is 1 MHz
2 Zener Diodes
Output
Input
A Capacitance content
Fig.2 Equivalent Circuit
Appearance
L
T
W
M
07/05/22 (Rev. 01)
Symbol
L
W
T
Size (mm)
1.0 ± 0.10
0.5 ± 0.10
Max. 0.6
M
0.2 ± 0.10
2
Recommended Land pattern (Typical Dimensions)
b
a
c
a
Symbol
a
b
c
Size (mm)
0.61
0.51
0.51
Recommended Soldering Profile
- Pb Free Solder Paste : Sn / Ag / Cu ( 96.5 / 3.0 / 0.5)
07/05/22 (Rev. 01)
3
很抱歉,暂时无法提供与“AVLC5S02100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.02776
- 1000+0.02193
- 3000+0.01869
- 10000+0.01674
- 50000+0.01502
- 100000+0.01404
