JY472M2FY5VS7LE
JY472M2FY5VS7LE
    JEC(智旭)
    插件,P=7.5mm
JY472M2FY5VS7LE 数据手册
东莞市佳仪电子有限公司 ISO 9001:2008 JEC Electronic CO.,LTD Certified Firm RoHS compliance 客户: Customer: 日期:2019-4-19 安规(Y1/Y2)电容器承认书 SPECIFICATION 品名: Part name: FOR APPROUAL Safety standard Recognized Ceramic Capacitor JD (Y1) / JY (Y2) 40/85/21/C User part No: JD472M2GY5VS7LE 承认章: VENDER 核 准 Approved by: CUSTOMER 审 核 制 作 台湾:智中电子股份有限公司 JYH CHUNG ELECTRONIC CO.,LTD 台中市大理区仁化里工业一路 2 号 TEL:886-4-24912990 FAX;886-4-24912993 Http://www.jecco.cn 1 Introduction This specification is applied to following safety standard recognized ceramic capacitor for electronics appliance. General Specifications : -40℃ Operating Temp. Rang Approved Monogram to +85℃ UL, SEMKO, FIMKO,NEMKO, SEV, JD (Y1) X1 400VAC Y1 400VAC DEMKO, VDE , CQC, KC JY (Y2) X1 400VAC Y2 300VAC Dielectric Rated JD (Y1) 400 VAC Test JD (Y1) 4000 VAC for 1 min. Withstanding Voltage Voltage JY (Y2) 300 VAC Voltage JY (Y2) 2600 VAC for 1 min. Y5P、Y5U TANδ≦2.5%, measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃ Y5V TANδ≦5.0%, measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃ Dissipation Factor(D.F) Capacitance( C ) Range Tolerance JD (Y1) 10pF to 4700pF.measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃ JY (Y2) 10pF to10000pF.measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃ Y5P for B ±10% Y5U for E ±10%、±20 Y5V for F ±20% % Insulation Resistance( I R ) 10,000 MΩ min, 500 VDC Type Code Cap. Change Y5P ±10 %, max. -40℃to+85℃ Y5U +22%,–56 % max. -40℃to+85℃ Y5V +30%,–80 % max. -40℃to+85℃ Temperature Characteristics Temp. Range The reference temperature: 25 ℃ Approval Standard And Recognized NO. : Safety Standard CSA ( Canada ) UL ( USA ) VDE ( Germany ) Standard NO. UL60384-14 Recognized NO. JD (Y1) JY (Y2) E187963 E187963 137027 123326 Monogram DIN EN 60384-14(VDE 0565-1-1):2014-04; EN 60384-14:2013-08 IEC 60384-14(ed.4) SEMKO ( Sweden ) EN 60384-14:2013 1610477 1610476 SEV (Switzerland ) EN 60384 -14:13 16.0273 16.0272 FIMKO ( Finland ) EN 60384-14:2013 FI 29416 FI 29417 NEMKO ( Norway ) EN 60384-14:2013 NO.P1622115 NO.P16221156 DEMKO ( Denmark ) EN 60384-14:2013 D-05288 D-05287 FIMKO CB IEC 60384-14:2013 FI 9088 FI 9090 CQC ( China ) IEC 60384-14:2005 CQC 10001046943 CQC 10001046944 SU03069-14001A SU03069-14002A KC ( Kti ) Approved K60384-1 (2006-12) K60384-14 (2006-12) CB 2 Capacitance and dimensions : JD (Y1) SERIES PART NUMBER T.C. CAP. TOL. Dimension(mm) D max F T max d(±0.05) 7.0ф 10±0.8 <6.0 0.56 JD10KY5P Y1 10pF To To JD82KY5P Y1 82pF JD101KY5P Y1 100PF 7.0ф 10±0.8 <6.0 0.56 JD151KY5P Y1 150PF 7.0ф 10±0.8 <6.0 0.56 7.0ф 10±0.8 <6.0 0.56 JD221KY5P Y1 ±10% 220PF K ±10% JD331KY5P Y1 (Y5P) 330PF 8.0ф 10±0.8 <6.0 0.56 JD471KY5P Y1 470PF 7.0ф 10±0.8 <6.0 0.56 JD561KY5P Y1 560PF 8.5ф 10±0.8 <6.0 0.56 JD681KY5P Y1 680PF 9.5ф 10±0.8 <6.0 0.56 JD102KY5P Y1 1000PF 12.0ф 10±0.8 <6.0 0.56 JD102KY5U Y1 1000PF 9.0ф 10±0.8 <6.0 0.56 JD471MY5U Y1 470PF 7.0ф 10±0.8 <6.0 0.56 JD561MY5U Y1 560PF 7.5ф 10±0.8 <6.0 0.56 JD681MY5U Y1 680PF 7.5ф 10±0.8 <6.0 0.56 7.5ф 10±0.8 <6.0 0.56 K ±10% JD102MY5U Y1 +22~-56% 1000PF JD152MY5U Y1 (Y5U) 1500PF 9.0ф 10±0.8 <6.0 0.56 JD222MY5U Y1 2200PF 10.5ф 10±0.8 <6.0 0.56 JD332MY5U Y1 3300PF 13.0ф 10±0.8 <6.0 0.56 JD472MY5U Y1 4700PF 15.0ф 10±0.8 <6.0 0.56 JD102MY5V Y1 1000PF 7.0ф 10±0.8 <6.0 0.56 JD152MY5V Y1 1500PF 8.5ф 10±0.8 <6.0 0.56 9.0ф 10±0.8 <6.0 0.56 M ±20% JD222MY5V Y1 +30~-80% 2200PF M ±20% JD332MY5V Y1 (Y5V) 3300PF 10.5ф 10±0.8 <6.0 0.56 JD392MY5V Y1 3900PF 11.5ф 10±0.8 <6.0 0.56 JD472MY5V Y1 4700PF 12.0ф 10±0.8 <6.0 0.56 Dimensions and Tolerance : TYPE:FS B= 3.0 mm max for FS F FOR JD= 7.5 or 9.5 or12.5±0.8 mm F FOR JY= 6.35 or 7.5 or 9.5 ±0.8 mm L=3 ~ 33 mm. 3 JY (Y2) SERIES PART NUMBER T.C. CAP. TOL. Dimension(mm) D max F T max d(±0.05) 6.5ф 7.5±0.8 <5.0 0.56 JY10KY5P Y2 10pF To To JY82KY5P Y2 82pF JY101KY5P Y2 100PF 6.5ф 7.5±0.8 <5.0 0.56 JY151KY5P Y2 150PF 6.5ф 7.5±0.8 <5.0 0.56 6.5ф 7.5±0.8 <5.0 0.56 JY221KY5P Y2 ±10% 220PF JY271KY5P Y2 (Y5P) 270PF 6.5ф 7.5±0.8 <5.0 0.56 JY331KY5P Y2 330PF 6.5ф 7.5±0.8 <5.0 0.56 JY471KY5P Y2 470PF 7.5ф 7.5±0.8 <5.0 0.56 JY561KY5P Y2 560PF 7.5ф 7.5±0.8 <5.0 0.56 JY681KY5P Y2 680PF 7.5ф 7.5±0.8 <5.0 0.56 JY102KY5P Y2 1000PF 9.0ф 7.5±0.8 <5.0 0.56 JY471KY5U Y2 470PF 6.5ф 7.5±0.8 <5.0 0.56 7.5ф 7.5±0.8 <5.0 0.56 JY561KY5U Y2 K ±10% K ±10% 560PF 680PF 7.5ф 7.5±0.8 <5.0 0.56 JY102MY5U Y2 +22~-56% 1000PF 7.5ф 7.5±0.8 <5.0 0.56 JY222MY5U Y2 (Y5U) 2200PF 9.5ф 7.5±0.8 <5.0 0.56 11.0ф 7.5±0.8 <5.0 0.56 JY681KY5U Y2 M±20% JY332MY5U Y2 3300PF JY472MY5U Y2 4700PF 13.0ф 7.5±0.8 <5.0 0.56 JY102MY5V Y2 1000PF 7.0ф 7.5±0.8 <5.0 0.56 JY152MY5V Y2 1500PF 7.0ф 7.5±0.8 <5.0 0.56 JY222MY5V Y2 2200PF 7.5ф 7.5±0.8 <5.0 0.56 JY332MY5V Y2 3300PF 9.0ф 7.5±0.8 <5.0 0.56 9.5ф 7.5±0.8 <5.0 0.56 9.5ф 7.5±0.8 <5.0 0.56 JY392MY5V Y2 3900PF JY472MY5V Y2 +30~-80% M±20% 4700PF JY562MY5V Y2 (Y5V) 5600PF 11.5ф 7.5±0.8 <5.0 0.56 JY682MY5V Y2 6800PF 11.5ф 7.5±0.8 <5.0 0.56 JY822MY5V Y2 8200PF 14.5ф 7.5±0.8 <5.0 0.56 JY103MY5V Y2 10000PF 14.5ф 7.5±0.8 <5.0 0.56 JY103MY5V Y2 10000PF 14.5ф 9.5±0.8 <5.0 0.56 MARKING: JD (Y1) JY (Y2) Trade mark Type , Capacitance and Tolerance 4 性能与试验 (Performance and Test) : 编号 项 目 性 能 试 1 外观及尺寸 参考第 2~ 3 页之图表。 1~1 2 记号标示 必须干净及清晰。 2~1 验 方 法 生产线必须做全数外观检验并分别剔除不 良品。尺寸利用微测仪或卡尺测量。 标示需能承受异丙醇擦拭。 额定电压:400 VAC for Y1。 耐 电 3 端子间 无异常。 3~1 试验电压:4000 VAC,时间一分钟。 额定电压:300 VAC for Y2。 压 试验电压:2600 VAC,时间一分钟。 ︵ 额定电压:400 VAC for Y1。 I ︶ 端子、封装间 无异常。 3~2 试验电压:4000 VAC,时间一分钟。 额定电压:300 VAC for Y2。 试验电压:2000 VAC,时间一分钟。 注意: 1.批量生产时测试时间为 2 秒钟。 2.耐压测试应为缓升或零启动。 3.工作电流按容量与电压大小限于 2~5mA。 4 5 6 7 耐电压(Ⅲ)(适用于安全 (1)纱布须不引燃。 性能符号 A2) (2)电容器须不冒烟。 耐电压(Ⅳ)(适用于安全 性能号 B2) 4~1 依 CNS 3432,11 节规定。 5~1 依 CNS3432, 12 节规定。 (3)元件与封装须不散飞。 (4)端子不能移动离开安 装位置 3mm 以上。 绝缘 端子间 10000MΩ以上。 电阻 端子、封装间 以上。 静电容量 10000MΩ 必须符合要求之容许差规格内。 6~1 测定电压为 500±50V,在一分钟内要在 规定值内。 7~1 测定温度 25±2℃。 7~2 测定电压:1Vrms 以下。 7~3 测定频率:1KHz±10%。 8~1 与第 7 项同。 散逸因子(CKS): 8 散逸因子 特性:B, E 2.5%以下。 特性:F 5.0%以下。 温度阶段 使用温度特性(CKS): 9 静电容量 温度特性 9~1 1、20±2℃→2、﹣25±2℃ →3、20±2℃→4、85±2℃ 范围内静电容量变化率。 →5、20±2℃ 特性 B 变化率±10%以内。 容量变化率:(CKS) 特性 E 变化率+22%—56%以内。 C.C(%)=(Ctx—Ct20)/Ct20*100 特性 F 变化率+30%—80%以内。 9~2 Ctx:温度阶段 1、3、5 除外,2 到 4 之间任何温度时之容量值。 Ct20:温度阶段 3 时之容量值。 导线不断裂,电容器不破损。 10~1 抗拉强度 10 端子强度 10~2 导线不致被折断,电容器不破 弯曲强度 损。 线径(mm) 负荷重 kgs 时间(秒) 0.5Φ 0.5 10 0.6Φ~0.8Φ 1 10 固定后负荷施力方向为端子引出之方向。 线径(mm) 10~3 负荷重 kgs 弯曲角度 0.5Φ 0.25 爲 90° 两 0.6Φ~0.8Φ 0.5 回以上。 5 外观 无显著异常。 耐 耐电压(I)端子间 合于编号 3 之规定。 湿 绝缘 端子间 编号 6 所规定值之 1/2 以上。 性 电阻 端子、封装间 ︵ 11 稳 静电容量变化率 状 湿度:90~95%RH。 特性 E ±20%以内。 11~3 时间:500±12 小时。 特性 F ±30%以内。 11~4 取出置常温下 1~2 小时后测之。 12~1 温度:40±2℃。 12~2 湿度:90~95%RH。 12~3 时间:500±12 小时。 特性 E ±20%以内。 12~4 电压:依交流额定电压印加之。 特性 F ±30%以内。 12~5 电流:50mA 以下。 12~6 取出置常温下 1~2 小时后测定之。 13~1 温度:85±3℃。 13~2 时间:1000±12 小时。 13~3 电压:依 200% 额定电压印加之。 13~4 电流:50mA 以下。 13~5 取出置常温下 1~2 小时后测定之。 特性 B、E 5%以下。 特性 F 7.5%以下。 外观 无显著异常。 耐电压(I)端子间 合于编号 3 之性能。 绝缘 编号 6 所规定之 1/2 以上。 电阻 端子间 端子、封装间 耐 湿 11~2 散逸因子(CKS): 散逸因子 ︶ 12 温度:40±2℃。 CKS: 特性 B ±15%以内。 定 态 11~1 CKS: 特性 B ±15%以内。 静电容量变化率 负 荷 散逸因子(CKS): 散逸因子 特性 B、E 5%以下。 特性 F 7.5%以下。 外观 无显著异常。 耐电压(I)端子间 合于编号 3 之规定。 高 绝缘 端子间 编号 6 所规定之 1/2 以上。 温 电阻 端子、封装间 负 13 荷 CKS: 特性 B ±15%以内。 静电容量变化率 ︵ 连 14 15 特性 E ±20%以内。 特性 F ±30%以内。 散逸因子 散逸因子(CKS): 续 特性 B、E ︶ 特性 F 7.5%以下。 5%以下。 焊 外观 无显著异常。 14~1 焊锡温度 350±10℃。 锡 耐电压(I)端子间 合于编号 3 之性能。 14~2 浸渍时间 3.5±0.5 秒。 耐 静电容量变化率 CKS: 特性 B ±10%以内。 14~3 在常温常湿中放置 4~24 小时后测定之。 导线之横截面积上须有圆周之 15~1 焊锡温度为 260±5℃(符合 RoHS)。 3/4 以上之面积为焊锡所付着。 15~2 浸渍时间为 2±0.5 秒。 热 特性 E±15%以内。 性 特性 F±20%以内。 焊锡之付着性 试验开始后,在第 1 次及第 2 次移开试验火 16 耐燃性 适用于安全性能符号 A2,B2。 16~1 焰后,不得燃烧 15 秒以上或不爆炸。而且 在第 3 次后,继续燃烧 1 分钟而不爆炸。 将样本完全浸渍于异丙醇溶剂 17 耐溶剂性(本体) 中 5±0.5 分后取出,观察本体 有无溶解,而后放置于常温中 17~1 试验后其电性能须符合标准。 48 小时后,量测其电气特性。 使用棉纱沾异丙醇, 以每 1 平方公分 5±0.5N 18 耐溶剂性 (标志) 18~1 之力,1 秒钟来回两次擦拭本体上的标示, 往返 5 次。标志应清晰可辨。 6 品名說明 ( Part No. Explain ) : 品名 ( Part No. ): J D 說明 ( Explain No. ): 1 2 2 2 2 3 M 2 4 G Y 5 5 U 6 S 0 7 L 8 9 E 10 TO JEC Marking firstword Rated voltage: Y-for Y2,X1 capacitance 2F-for 300V D-for Y1,X1 capacitance 2G-for 400V Rated capacitance value: 221-for 220PF 222-for 2200PF Tolerance: Material: J-for ± 5% Y5P-forY5P K-for ± 10% Y5U-forY5U M-for ± 20% Y5V-forY5V Lead form: Coating: S for F.S. Pitch: O for F.O. 5-for 5mm Length: I for F.I. 7-for 7.5mm 5 - for 5mm A for AA 9-for 9.5mm 0 - for 10mm 2 for A2 0-for 10mm L - for 25mm B-for 12.5mm T - for taping E:Epoxy G:Phenolic resin 脚型说明(Lead form) : F.I.型 F.O. 型 F.S. 型 A2. 型 AA. 型 包装说明(Packaging) : 1.inside: One bag 500PCS-1000PCS. PE bag size: 13×15×0.1mm 16×18×0.1mm 18×20×0.1mm 20×25×0.1mm 2.outsize: Use box packaging Box size: 305×215×145mm 450×325×160mm 7 Part No.: JD472M2GY5VS7LE D: 11.0 mm / MAX T: 6.0 mm / MAX F: 7.5 ± L: 25 d: 0.56 B: 3 0.8 mm MAX ± 0.05 mm mm / MAX TEST CONDITIONS 测 试 条 件 Operating Temp. Rang 温度范围 -40℃ ~ +85℃ TEST FREQ & VOL 測試頻率與電壓 1K Hz 1.0 V TEST TEMP 測試溫度 25 ℃ ± 2 ℃ RATED CAP. 公稱靜電容量 4700 PF CAP. TOL. 靜電容量容許差 ± 20 % TEMP. CHARACT 溫度特性 Y5V INITIAL DF δ 初期損耗角 δ 2.5% INSULATION RESISTANCE INITIAL 初期絕緣電阻 10000 MΩMIN CURRENT 工作电流 ≦5mA BETWEEN TERMINALS 端子間 AC4000V RATED VOLTAGE 額定電壓 X1 400VAC , Y1 400VAC MAX FOR 60 SEC 材质温度曲线图: 8
JY472M2FY5VS7LE 价格&库存
很抱歉,暂时无法提供与“JY472M2FY5VS7LE”相匹配的价格&库存,您可以联系我们找货
