C0603NP0100JGT
C0603NP0100JGT
    DARFON(达方)
    C0603NP0100JGT
C0603NP0100JGT 数据手册
INTRODUCTION A Professional MLCC (Multi-Layer Ceramic Capacitor) Manufacturer In the post-PC 21st century, all information and communication technology products will be closely connected with our daily lives. In a colorful communication world, DARFON’s Multi-layer Ceramic Capacitor is significant. This product addresses the market's application needs by combining technology from materials engineering, chemical engineering, electronic engineering, and mechanical engineering. A Multi-layer Ceramic Capacitor with different functions is always the goal of DARFON’s R&D, with R&D taking the direction of multi-levels and small scale. As far as the technical aspect is concerned, the company has surpassed other domestic companies in Taiwan by being first to develop the BME process and 0201 ultra miniature MLCC. This product's ultra thin thickness is top notch. Through automated equipment with high efficient management systems, DARFON can guarantee the quality of each end product. DARFON Quality Policy “ To deliver Defect-free, Competitive Products and Services to our Customers on time. “ MLCC Introduction Multi-layer ceramic capacitors (MLCC) are manufactured by suspending ceramic powders in liquid and casting into a thin green sheet from 20 um in thickness to 5 um or thinner. Metal electrodes are sieved printed onto green sheets, which are later stacked to form a laminated structure. The metal electrodes are arranged so that the termination alternates from one edge to another of the capacitor. Upon sintering at high temperature the part becomes a monolithic block, which can provide an extremely high capacitance in small mechanical volumes. Finally, the termination electrodes are formed by composite of outer metal-glass electrode and followed by a barrier layer and pure-tin plating to permit MLCC to be soldered directly onto printed circuit board. DARFON MLCC 1 Version:C1007 CONTENT SELECTION GUIDE OF MULTILAYER CERAMIC CAPACITOR 3 ORDERING INFORMATION 6 STRUCTURE AND DIMENSIONS 7 PRODUCT RANGE AND THICKNESS 8 ELECTRICAL SPECIFICATIONS 13 16 General Purpose NP0 High Frequency Type TYPICAL CHARACTERISTICS CURVES 17 RF CHARACTERISTICS OF NPO Q series 19 PACKAGING 22 APPLICATION NOTES 26 ENVIRONMENTAL CONCERNS 34 DARFON MLCC 2 Version:C1007 SELECTION GUIDE Darfon’s series of Multilayer Ceramic Chip Capacitors are designed to meet a wide variety of needs. We offer a complete range of products for both general and specialized applications in the industry. We suggest your selection of capacitors based on consideration of the following items: 1. DIELECTRIC TYPE The choice of dielectric is usually determined by the required capacitance-temperature stability. Darfon offers four types, NP0, X7R, X5R and Y5V for your choice. The features and applications of these four types are specified as follows: Dielectric Features Applications NP0 X7R/X5R Y5V 1. Ultra-stable 2. Tight tolerance available 3. Low ESR 4. Good frequency performance 5. No aging of capacitance 1. Semi-stable and High K 1. High volumetric 2. High volumetric efficiency efficiency 2. Non-polar construction 3. Highly reliable in high 3. General purpose, High K temperature application 4. High insulation resistance 1. LC and RC tuned circuit 2. Filtering 3. Timing 1. 2. 3. 4. 5. Blocking Coupling Timing Bypassing Frequency discriminating 6. Filtering 1. Bypassing 2. De-coupling 3. Filtering 2. CAPACITANCE AND TOLERANCE Capacitance and its tolerance are determined by circuit requirement and cost consideration.  E Standard Number 1.0 E3 1.0 E6 E12 E24 2.2 1.0 1.5 1.2 1.5 4.7 2.2 1.8 2.2 3.3 2.7 3.3 4.7 3.9 4.7 6.8 5.6 6.8 8.2 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 * Non-standard capacitance is available on request. DARFON MLCC 3 Version:C1007 SELECTION GUIDE Available Tolerance  Available Tolerance T. C. Capacitance * Standard Tolerance on Request C = ± 0.25pF Cap < 5pF B = ± 0.1pF D = ± 0.5pF NP0 (C0G) 5pF ≦ Cap < 10pF Cap B = ± 0.1pF D = ± 0.5pF C = ± 0.25pF ≧ 10pF J = ± 5% F = ± 1% K = ±10% G = ± 2% K = ± 10% X5R All J = ± 5% M = ± 20% X7R All Y5V Z = -20% to +80% M = ± 20% * Non-standard capacitance or tolerance is available on request. 3. RATED VOLTAGE Rated voltage is determined by circuit requirement. 4. PACKAGING Specify the packaging of capacitors as bulk or tape and reeled. 5. PRODUCT RANGE AND SIZE  NP0 (Class I) Type T.C. Size RV 0603 (0201) 1005 (0402) 1608 (0603) 2012 (0805) 2.7nF~3.3nF 16V 3216 (1206) 12nF~39nF NP0 25V 0.20pF~100pF Class I 50V 0.20pF~18pF 0.20pF~470pF/1nF 0.20pF~2.2nF 0.50pF~10nF 1.50pF~10nF 100V 0.20pF~220pF 0.50pF~3.3nF 1.50pF~4.7nF DARFON MLCC 0.20pF~22pF 0.20pF~1nF 4 Version:C1007 SELECTION GUIDE X7R (Class II)  Type T.C. Size RV 0603 (0201) 1005 (0402) 1608 (0603) 2012 (0805) 3216 (1206) 3225 (1210) 4.7uF~10uF 6.3V X7R 10V 3.3nF/4.7nF/10nF 100pF~100nF 100pF~1uF 1uF/2.2uF/4.7uF/10uF 2.2uF Class 16V 100pF~100nF 100pF~1uF 330nF/470nF/1uF/ 2.2uF 470nF~10uF 10uF II 25V 100pF~2.2nF 100pF~22nF 100pF~1uF 1nF~1uF 220nF~4.7uF 4.7uF/10uF 50V 100pF~2.2nF 100pF~10nF 100pF~100nF 150pF~470nF 1nF~1uF 100pF~10nF 150pF~22nF 1nF~100nF 100V X5R (Class II)  Type T.C. Size RV 0603 (0201) 1005 (0402) 1608 (0603) 2012 (0805) 3216 (1206) 3225 (1210) 6.3V 2.2nF~220nF 470nF~4.7uF 2.2uF/ 4.7uF/10uF 4.7uF~22uF 22uF/47uF 47uF/100uF 10V 2.2nF~100nF 15nF~1uF 220nF~4.7uF 2.2uF~10uF 2.2uF~10uF 22uF 16V 15nF~1uF 220nF~2.2uF 1uF~10uF 2.2uF~10uF 4.7uF~22uF 25V 100nF 220nF/1uF 1uF~4.7uF 2.2uF~10uF 4.7uF/ 10uF X5R Class II  Y5V (Class II) Type T.C. Size RV 0603 (0201) 1005 (0402) 1608 (0603) 2012 (0805) 6.3V 22nF~100nF 10nF~1uF 10nF~2.2uF 10V 10nF~1uF 10nF~2.2uF 16V 10nF~220nF 10nF~2.2uF 100nF~2.2uF 25V 10nF~100nF 10nF~330nF 100nF ~2.2uF 50V 10nF~33nF 10nF~220nF 100nF~1uF Y5V Class II : Note (1) Other size, capacitance, and voltage are available upon customer’s request. ; (2) Product range might be extended due to technology improvement or new product released for up-to-date information, please contact our sales. (3) Part of Y5V product will be phased out. DARFON MLCC 5 Version:C1007 ORDERING INFORMATION DARFON Part Number C 1005 NP0 101 J G T S PRODUCT CODE C = Capacitor SMD SIZE in mm (EIA CODE, in inch) 0402(01005) 3216 (1206) 0603(0201) 3225(1210) T. C. ℃ NP0: 0 ± 30ppm/ X7R: ±15% X5R: ±15% Y5V: +22%/-82% -55 -55 -55 -30 1005 (0402) 4520 (1808) 1608 (0603) 4532 (1812) 2012 (0805) ℃ to +125℃ ℃ to +125℃ ℃ to +85℃ ℃ to +85℃ CAPACITANCE CODE Expressed in pico-farads and identified by a three-digit number. First two digits represent significant figures. Last digit specifies the number of zeros. (Use 9 for 1.0 through 9.9pF Use 8 for 0.2 through 0.99pF) (Example: 2.2pF=229 or 0.47pF=478) ; TOLERANCE CODE A: ± 0.05pF J: ±5% B: ± 0.1pF K: ±10% C: ± 0.25pF M: ±20% D: ± 0.5pF Z: +80/-20% F: ±1% G: ±2% VOLTAGE CODE B: 4V J: 200V C: 6.3V K: 250V D: 10V L: 500V E: 16V M: 630V F: 25V P: 1KV N: 35V Q: 2KV G: 50V R: 3KV H: 100V S: 4KV PACKAGING CODE T: Paper tape reel Ø180mm (7”) N: Paper tape reel Ø250mm (10”) A: Paper tape reel Ø330mm (13”) B: Bulk, loosed in bag W: Special Packing P: Embossed tape reel Ø180mm (7”) D: Embossed tape reel Ø250mm (10”) E: Embossed tape reel Ø330mm (13”) C: Bulk cassette Product Type S: Standard Ceramic Capacitor Q: High Q/Low ESR DARFON MLCC 6 Version:C1007 STRUCTURE AND DIMENSIONS MLCC STRUCTURE Electrode Termination Dielectric DIMENSIONS W L T g A TYPICAL TOLERANCE SIZE CODE L W T g A (EIA) (Length) (Width) (Max Thickness) (Min) (Termination Min/Max) 0603 (0201) 0.6+/-0.03 (0.024+/-0.001) 0.3+/-0.03 (0.012+/-0.001) 0.33 (0.013) 0.15 (0.006) 0.10/0.20 (0.004/0.008) mm (inch) 1005 (0402) 1.0 +/- 0.05 (0.040 +/- 0.002) 0.5 +/- 0.05 (0.020 +/- 0.002) 0.55 (0.022) 0.30 (0.012) 0.10 / 0.30 (0.004 / 0.012) mm (inch) UNIT 1608 1.6 +/- 0.10 0.8 +/- 0.10 0.90 0.50 0.25 / 0.65 mm (0603) (0.063 +/- 0.004) (0.031 +/- 0.004) (0.035) (0.020) (0.010 / 0.026) (inch) 2012 (0805) 2.0 +/- 0.15 (0.079 +/- 0.006) 1.25 +/- 0.20 (0.049 +/- 0.008) 1.45 (0.057) 0.70 (0.028) 0.25 / 0.75 (0.010 / 0.030) mm (inch) 3216 (1206) 3.2 +/- 0.15 (0.126 +/- 0.006) 1.6 +/- 0.20 (0.063 +/- 0.008) 1.80 (0.069) 1.50 (0.060) 0.25 / 0.75 (0.010 / 0.030) mm (inch) 3225 (1210) 3.2 +/- 0.20 (0.126 +/- 0.008) 2.5 +/- 0.20 (0.098 +/- 0.008) 2.70 (0.106) 1.50 (0.060) 0.25 / 0.75 (0.010 / 0.030) mm (inch) SPECIAL TOLERANCE SIZE CODE L W T g A (EIA) (Length) (Width) (Max Thickness) (Min) (Termination Min/Max) UNIT 1005* 1.0 +/- 0.15 0.5 +/- 0.15 0.65 0.30 0.10 / 0.30 mm (0402) (0.040 +/- 0.006) (0.020 +/- 0.006) (0.026) (0.012) (0.004 / 0.012) (inch) 1608* 1.6 + 0.15/-0.1 0.8 + 0.15/-0.1 0.95 0.50 0.25 / 0.65 mm (0603) (0.063 +0.006/- 0.004) (0.031 +0.006/-0.004) (0.037) (0.020) (0.010 / 0.026) (inch) 2012* 2.0 +/- 0.20 1.25 +0.30/-0.20 1.55 0.70 0.25 / 0.75 mm (0805) (0.079 +/- 0.008) (0.049 +0.012/ -0.008) (0.061) (0.028) (0.010 / 0.030) (inch) 3216* 3.2 +/- 0.20 1.6 +0.30/-0.20 1.90 1.50 0.25 / 0.75 mm (1206) (0.126 +/- 0.008) (0.063 +0.012/ -0.008) (0.075) (0.060) (0.010 / 0.030) (inch) 3225* 3.2 +/- 0.30 2.5 +/- 0.30 2.80 1.50 0.25 / 0.75 mm (1210) (0.126 +/- 0.012) (0.098 +/- 0.012) (0.11) (0.060) (0.010 / 0.030) (inch) DARFON MLCC 7 Version:C1007 PRODUCT RANGE NP0  NP0 - General Purpose CLASS Class I TYPE Standard T.C. C0G (NP0) SIZE 0603 1005 1608 2012 3216 (EIA) 0201 0402 0603 0805 1206 RV 0.20 p 25V 50V 50V B 100V B 0.50 p A A B 0.75 p A A B 1.0 p A A 1.2 p A 1.5 p 50V D 100V D 50V 100V 50V 100V B D D C C B D D C C B B D D C C A B B D D C C A A B B D D C 1.8 p A A B B D D C C E E C E 2.2 p A A B B D D E C C E 2.7 p A A B B D E D C C E 3.3 p A A B B E D D C C E 3.9 p A A B E B D D C C E 4.7 p A A E B B D D C C E 5.6 p A E A B B D D C C E 6.8 p E A A B B D D C C E E 8.2 p A A B B D D C C E E 10 p A A B B D D C C E E 12 p A A B B D D C C E E 15 p A A B B D D C C E E 18 p A A B B D D C C E E 22 p A B B D D C C E E 27 p A B B D D C C E E 33 p A B B D D C C E E 39 p A B B D D C C E E 47 p A B B D D C C E E 56 p A B B D D C C E E 68 p A B B D D C C E E 82 p A B B D D C C E E 100 p A B B D D C C E E 120 p B B D D C C E E 150 p B B D D C C E E 180 p B B D D C C E E 220 p B B D D C C E E 270 p B D D C C E E 330 p B D D C C E E 390 p B D D C E E E 470 p B D D C E E E 560 p D D C E E E 680 p D D C E E E 820 p D D C E E E D D C E E E 1.0 n 16V B 16V 1.2 n D* E E E E 1.5 n D* E E E E 1.8 n D* E E E E 2.2 n D* E E E E 2.7 n D* G G E E 3.3 n D* G G E E 3.9 n G E E 4.7 n G E E 5.6 n G E 6.8 n G F 8.2 n G F 10 n G G 12 n G 15 n G 18 n G 22 n G 27 n G 33 n G 39 n L : Note Thickness might be changed due to technology improvement. DARFON MLCC 8 Version:C1007 PRODUCT RANGE NP0 NP0 – Low ESR/ High Q (Q Series) CLASS Class I TYPE Low ESR/High Q T.C. NP0(C0G) SIZE 0603 1005 1608 (EIA) 0201 0402 0603 RV 25V 50V 25V 50V 25V 50V * 0.20 p A A B B D D * 0.50 p A A B B D D * 0.75 p A A B B D D 1.0 p A A B B D D 1.2 p A A B B D D 1.5 p A A B B D D 1.8 p A A B B D D 2.2 p A A B B D D 2.7 p A A B B D D 3.3 p A A B B D D 3.9 p A A B B D D 4.7 p A A B B D D 5.6 p A A B B D D 6.8 p A A B B D D 8.2 p A A B B D D 10 p A A B B D D 12 p A A B B D D 15 p A A B B D D 18 p A A B B D D B B D D 22 p 27 p 33 p 39 p 47 p 56 p 68 p 82 p 100 p 120 p 150 p 180 p 220 p 270 p 330 p : Note Thickness might be changed due to technology improvement. Thickness Tolerance Thickness (mm) Code A B B Class 0.30+/-0.03 0.50+/-0.05 0.50+/-0.15 Thickness (mm) Code C D D Class 0.60+/-0.15 0.80+/-0.10 0.8+0.15/-0.1 Thickness (mm) Code E F G Class 0.85+/-0.15 1.15+/-0.20 1.25+/-0.20 Thickness (mm) Code G I L Class 1.25+0.3/-0.20 0.95+/-0.15 1.60+/-0.20 Thickness (mm) Code L N N Code 1.60+0.3/-0.20 2.00+/-0.20 2.00+/-0.30 Thickness (mm) Code P Q Special Length/Width Tolerance Size Code(EIA) Length(mm) Width(mm) DARFON MLCC 1005(0402) 1.0 ± 0.15 0.5 ± 0.15 1608(0603) 1.6 ± 0.15 0.8 ± 0.15 2012(0805) 2.0 ± 0.20 1.25 ± 0.30 9 3216(1206) 3.2 ± 0.20 1.6 ± 0.30 3225(1210) 3.2 ± 0.30 2.5 ± 0.30 Version:C1007 Code 2.50+/-0.20 0.45+/-0.05 PRODUCT RANGE X5R X5R – General Purpose CLAS Class II TYPE Standard X5R T.C. SIZE 0603 1005 1608 2012 3216 (EIA) 0201 0402 0603 0805 1206 RV 6.3V 10V 6.3V 10V 16V 25V 6.3V 2.2 n A A 3.3 n A A 4.7 n A A 5.6 n A A 6.8 n A A 8.2 n A A 10 n A A A A 15 n B B B B B B B B 56 n B B 68 n B B 82 n B B B B 120 n B B 150 n B B 180 n B B B B 22 n 33 n 47 n 100 n 220 n A A A A A 10V 16V D D D D D D D D 25V 6.3V 10V 16V 25V 6.3V 3225 1210 10V 16V 25V 6.3V 10V 16V 25V N N B D 270 n 330 n 390 n 470 n B B 560 n 680 n 820 n 1.0 u B B B Q D Q D Q D E G E G 1.5 u 1.8 u 2.2 u B D D B* D D D E G G L L L G G G G L L L G G G L L L 2.7 u 3.3 u 3.9 u 4.7 u 6.8 u 10 u D* 22 u G 47 u N L P N P 100 u   N L P Non-standard capacitance or thickness is available on request The thickness might be changed due to technology improvement.  * Special length/width tolerance Thickness Tolerance Thickness (mm) Code A B B Class 0.30+/-0.03 0.50+/-0.05 0.50+/-0.15 Thickness (mm) Code C D D Class 0.60+/-0.15 0.80+/-0.10 0.8+0.15/-0.1 Thickness (mm) Code E F G Class 0.85+/-0.15 1.15+/-0.20 1.25+/-0.20 Thickness (mm) Code G I L Class 1.25+0.3/-0.20 0.95+/-0.15 1.60+/-0.20 Thickness (mm) Code L N N Code 1.60+0.3/-0.20 2.00+/-0.20 2.00+/-0.30 Thickness (mm) Code P Q Special Length/Width Tolerance Size Code(EIA) Length(mm) Width(mm) DARFON MLCC 1005(0402) 1.0 ± 0.15 0.5 ± 0.15 1608(0603) 1.6 ± 0.15 0.8 ± 0.15 2012(0805) 2.0 ± 0.20 1.25 ± 0.30 10 3216(1206) 3.2 ± 0.20 1.6 ± 0.30 3225(1210) 3.2 ± 0.30 2.5 ± 0.30 Version:C1007 Code 2.50+/-0.20 0.45+/-0.05 N P PRODUCT RANGE X7R  X7R – General Purpose CLASS TYPE T.C. SIZE 0603 (EIA) 0201 RV 10V 25V 50V 100 p A A 120 p A A 150 p A A 180 p A A 220 p A A 270 p A A 330 p A A 390 p A A 470 p A A 560 p A A 680 p A A 820 p A A 1.0 n 1.2 n 1.5 n 1.8 n 2.2 n 2.7 n 3.3 n 3.9 n 4.7 n 5.6 n 6.8 n 8.2 n 10 n 12 n 15 n 18 n 22 n 27 n 33 n 39 n 47 n 56 n 68 n 82 n A A A A A A A A A A A A A 100 n 120 n 150 n 180 n 220 n 270 n 330 n 390 n 470 n 560 n 680 n 820 n Class II Standard X7R 10V B B B B B B B B B B B B 1005 0402 16V 25V B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B 50V B B B B B B B B B B B B B B B B B B B B B B B B B 1.0 u 1.2 u 1.5 u 1.8 u 2.2 u 2.7 u 3.3 u 3.9 u 4.7 u 10 u   1608 0603 10V 16V 25V D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D 2012 0805 50V 100V 6.3V 10V 16V 25V D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D* D* D* D* D* D* D D D D* D D D* D* D* D* D* D* D* D D D D D D D D D D D D D C C C C C C C C C C C C C C C C C C C C D* G G Non-standard capacitance or thickness is available on request The thickness might be changed due to technology improvement.  E E E E E E E E E E E E E E E E E E E E 3216 1206 100V 10V 16V 25V 50V 50V C C C C C C C C C C E E E E E E E E E E E E E E E E E E E E C C C C C C C C C C C C C C C C C C C C E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E G E E G E E E E E E E E E E E E E E E E E E I I G G G I G G G G G G L G G G G G G G L L L L L L G G 100V 3225 1210 16V 25V E E E E E E E E E E E E E E E E E E E E E E E L N N N * Special length/width tolerance Thickness Tolerance Thickness (mm) Code A B B Class 0.30+/-0.03 0.50+/-0.05 0.50+/-0.15 Thickness (mm) Code C D D Class 0.60+/-0.15 0.80+/-0.10 0.8+0.15/-0.1 Thickness (mm) Code E F G Class 0.85+/-0.15 1.15+/-0.20 1.25+/-0.20 Thickness (mm) Code G I L Class 1.25+0.3/-0.20 0.95+/-0.15 1.60+/-0.20 Thickness (mm) Code L N N Code 1.60+0.3/-0.20 2.00+/-0.20 2.00+/-0.30 Thickness (mm) Code P Q Special Length/Width Tolerance Size Code(EIA) Length(mm) Width(mm) DARFON MLCC 1005(0402) 1.0 ± 0.15 0.5 ± 0.15 1608(0603) 1.6 ± 0.15 0.8 ± 0.15 2012(0805) 2.0 ± 0.20 1.25 ± 0.30 11 3216(1206) 3.2 ± 0.20 1.6 ± 0.30 3225(1210) 3.2 ± 0.30 2.5 ± 0.30 Version:C1007 Code 2.50+/-0.20 0.45+/-0.05 PRODUCT RANGE Y5V Y5V – General Purpose  CLASS TYPE T.C. SIZE (EIA) RV 10 n 12 n 15 n 18 n 22 n 27 n 33 n 39 n 47 n 56 n 68 n 82 n 100 n 120 n 150 n 180 n 220 n 270 n 330 n 390 n 470 n 560 n 680 n 820 n 1.0 u 1.2 u 1.5 u 1.8 u 2.2 u 2.7 u 3.3 u 3.9 u 4.7 u 5.6 u 6.8 u 8.2 u 10 u   Class II Standard Y5V 0603 1005 0201 0402 6.3V 10V 6.3V 10V 16V 25V B B B B B B B B B B B B B B B B A A B B B B B B B B A A B B B B B B B B A A B B B B B B B B B B B B B A A B B B B B B B 50V B B B B B B B B 1608 0603 10V 16V 25V 50V D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D 6.3V D D D D D D D D D D D D D 2012 0805 16V 25V 50V C C E E E D D D D B D D D D B B D D D E E E B B D* D* D* E G G D D D E G Non-standard capacitance or thickness is available on request The thickness might be changed due to technology improvement. D C  * Special length/width tolerance  Part of Y5V product will be phased out. Thickness Tolerance Thickness (mm) Code A B B Class 0.30+/-0.03 0.50+/-0.05 0.50+/-0.15 Thickness (mm) Code C D D Class 0.60+/-0.15 0.80+/-0.10 0.8+0.15/-0.1 Thickness (mm) Code E F G Class 0.85+/-0.15 1.15+/-0.20 1.25+/-0.20 Thickness (mm) Code G I L Class 1.25+0.3/-0.20 0.95+/-0.15 1.60+/-0.20 Thickness (mm) Code L N N Code 1.60+0.3/-0.20 2.00+/-0.20 2.00+/-0.30 Thickness (mm) Code P Q Special Length/Width Tolerance Size Code(EIA) Length(mm) Width(mm) DARFON MLCC 1005(0402) 1.0 ± 0.15 0.5 ± 0.15 1608(0603) 1.6 ± 0.15 0.8 ± 0.15 2012(0805) 2.0 ± 0.20 1.25 ± 0.30 12 3216(1206) 3.2 ± 0.20 1.6 ± 0.30 3225(1210) 3.2 ± 0.30 2.5 ± 0.30 Version:C1007 Code 2.50+/-0.20 0.45+/-0.05 ELECTRICAL SPECIFICATIONS General Purpose Specification Item 1 Operating Temperature Range Temp. compensating type Test Method High dielectric constant type NP0: -55 to 125 degree C X7R: -55 to 125 degree C --- X5R: -55 to 85 degree C Y5V: -30 to 85 degree C 2 Rated Voltage 4VDC, 6.3VDC, 10VDC, 16VDC, 25VDC, 35VDC, 50VDC, 100VDC, The rated voltage is defined as the maximum voltage, which 200VDC, 250VDC, 500VDC, 630VDC, 1000VDC, 2000VDC, may be applied continuously to the capacitor. 3000VDC 3 Appearance No defects or abnormalities. Visual inspection 4 Dimensions Within the specified dimension. Using calipers 5 Dielectric Strength No defects or abnormalities. No failure shall be observed when 250%* of the rated voltage ( 150% for 500V, 120% for above 1KV ) is applied between the terminations for 1 to 5 seconds. The charge and discharge current is less than 50mA. 6 Insulation Resistance ( I.R.) Rated Voltage: 7 Capacitance ≧ ≧ Rated Voltage: 30pF, DF I. X5R, X7R: ≦1/(400+20C), See X5R,X7R DF table Item Frequency Voltage II. Y5V: See Y5V DF table. ≦0.1%. Item Table 1 Size 0603 1005 1608 9 Capacitance Temperature Characteristics TC X5R X5R X5R Thickness 0.3 mm 0.5 mm 0.8 mm Capacitance change RV 6.3V 4V/6.3V 4V/6.3V Frequency Voltage Cap 104 475 106 Capacitance change ℃ Class I C 1,000pF 1.0±0.2MHz 1.0±0.2Vrms 1.0±0.2kHz 1.0±0.2Vrms ClassII ( 10 uF) 1.0±0.2kHz 1.0±0.2Vrms ClassII (>10 uF) 120Hz±24Hz 0.5±0.1Vrms >1,000pF ≦ ℃ * For item in Table1 1.0±0.2kHz 0.5±0.1Vrms ℃ The capacitance value at 25 and 85 shall be measured and calculated from the formula given below. Δ T.C.=(C85-C25)/C25* T*106(PPM/ ℃) 2. High dielectric constant type: Termination Strength No removal of the terminations or marking defect. 11 Deflection (Bending Strength) No cracking or marking defects shall occur at 1mm deflection. Capacitance change: NP0: within ±5% or ± 0.5pF. (whichever is larger) Solder the capacitor to the test jig (glass epoxy boards) shown in Fig.a using a SAC305(Sn96.5Ag3.0Cu0.5) solder (then let sit for 48±4 hours for X7R X5R and Y5V). Then apply a force in the direction shown in Fig.b. The soldering shall be done with the reflow method and shall be conducted with care so that the soldering is uniform and free of defects such as heat shock. X7R, X5R:within ±12.5% Y5V: within ±20% (Unit in mm) 20 50 Pressurizing speed : 1.0mm/sec. φ 4.5 40 c a 100 t :1.6mm(0.8mm for 0603&1005 size) Fig. a. 12 Solderability of Termination ℃ The ranges of capacitance change compared with the 25 value over the temperature ranges shall be within the specified ranges. Apply a parallel force of 5N to a PCB mounted sample for 10±1sec. *2N for 0603 (EIA 0201). 10 b Size 0603 1005 1608 2012 3216 4520 4532 a 0.3 0.4 1.0 1.2 2.2 3.5 3.5 b 0.9 1.5 3.0 4.0 5.0 7.0 7.0 C 0.3 0.5 1.2 1.65 2.0 2.5 3.7 Pressurize R230 Flexure : 1mm Capacitance Meter 45 45 Fig. b. 90% of the terminations are to be soldered evenly and Immerse the test capacitor into a methanol solution containing continuously. rosin for 3 to 5 seconds, preheat it 150 to 180 for 2 to 3 minutes and immerse it into SAC305(Sn96.5Ag3.0Cu0.5) solder of 245 ± 5 for 3±1seconds. ℃ ℃ DARFON MLCC at the Class I ≦ 1. Temperature compensating type: NP0 within 0±30ppm/ under X7R/X5R within ±15% operating temperature range. Y5V: -82 to + 22% ℃ 13 Version:C1007 ELECTRICAL SPECIFICATIONS Specification Item 13 Resistance to Soldering Heat Temp. compensating type Appearance Cap. Change Q/D.F. I.R. Temperature cycle (Thermal shock) ℃ *Preheat the capacitor at 120 to 150 for 1 minute. Immerse the capacitor in a SAC305(Sn96.5Ag3.0Cu0.5) NP0 within ±2.5% or 0.25pF X7R/X5R within ±7.5% solder solution at 270±5 for 10±1 seconds. Let sit at room ( whichever is larger ) Y5V within ±20% temperature for 24±2 hours (temperature compensating type) If C 30pF, DF 1/(400+20C) To satisfy the specified initial or 48±4 hours (high dielectric constant type), then measure. spec. If C >30pF, DF 0.1% ≦ ℃ ≦ ≦ ≧ I.R. 10,000MΩ or RiCR 500Ω-F. ≧ I.R. ≧ 10,000MΩ or RiCR 500Ω-F. (whichever is smaller) 14 Test Method High dielectric constant type No marking defects ≧ * Preheat 150 to 200 ℃ for size≧3216. ℃ *High dielectric constant type: Initial measurement : perform a heat treatment at 150+0/-10 for one hour and then let sit for 48±4 hours at room temperature. Perform the initial measurement. (whichever is smaller) Appearance No marking defects Solder the capacitor to supporting jig (glass epoxy board) and Cap. Change NP0 within ±2.5% or 0.25pF X7R/X5R within ±7.5% ( whichever is larger ) Y5V within ±20% perform the five cycles according to the four heat treatments Q/D.F. I.R. ≦ ≦ ≦ listed in the following table. Let sit for 24±2hrs at room If C 30pF, DF 1/(400+20C) To satisfy the specified initial temperature, then measure. spec. Step 1: Minimum operating temperature If C >30pF, DF 0.1% Step 2: Room temperature I.R. 10,000MΩ or RiCR 10,000MΩ or RiCR I.R. Step 3: Maximum operating temperature 500Ω-F. 500Ω-F. Step 4: Room temperature (whichever is smaller) (whichever is smaller) ≧ ≧ ≧ ≧ 30±3min 2~3 min 30±3min 2~3min *High dielectric constant type: Initial measurement: perform a heat treatment at 150+/-10 for one hour and then let sit for 48±4 hours at room temp. Perform the initial measurement. ℃ 15 Humidity load ℃ Appearance No marking defects Cap. Change NP0 within ±7.5% or 0.75pF X7R/X5R within ±12.5% ( whichever is larger ) Y5V within ±30% Q/D.F. I.R. > ≦ ≦ ≦ If C 30pF, DF 0.5% Apply the rated voltage at 40±2 and 90 to 95% humidity for 500±12 hours. Remove and let sit for 24±2 hours (temperature compensating type) or 48±4 hours (high dielectric constant type) at room temperature, then measure. X7R 200% max of initial spec. The charge / discharge current is less than 50mA. If C 30pF,D 1/(100+10xC/3) Y5V 150% max of initial spec. C in pF X5R 200% max of initial spec. *High dielectric constant type: Initial measurement: perform a for one hour and then let sit for I.R. 500MΩ or RiCR 25Ω-F. I.R. 500MΩ or RiCR 25Ω-F. heat treatment at 150+/-10 48±4hours at room temperature. Perform the initial (whichever is smaller) (whichever is smaller) measurement. ≧ ≧ ≧ ℃ ≧ ≧ * some of the parts are RiCr 12.5Ω-F,please refer to table 2 16 High temperature load life test Appearance No marking defects Cap. Change NP0 within ±7.5% or 0.75pF X7R/X5R within ±12.5% ( whichever is larger ) Y5V within ±30% Q/D.F. > ≦ If C 30pF, DF 0.3% ≦ If 10pF 10 nF 1005 (EIA 0402): C > 0.1 uF 1608 (EIA 0603): C 1.0 uF 2012 (EIA 0805): C 2.2 uF 3216 (EIA 1206): C 10 uF ≧ ≧ ≧ 3225 (EIA 1210): C ≧ 22 uF 1005 (EIA 0402): C > 0.47 uF 1608 (EIA 0603): C > 1.0 uF 2012 (EIA 0805): C > 4.7 uF 3216 (EIA 1206): C > 10 uF 3225 (EIA 1210): C > 22 uF DARFON MLCC 14 Version:C1007 ELECTRICAL SPECIFICATIONS ■ X5R/X7R DF (tan δ) Table Rated Voltage Size 4V All All All All 0603/3216/3225 0603 6.3V 1005 10V 1608 2012 3216 3225 0603/3216/3225 1005 1608 16V 2012 3216 3225 All 1608 25V 3216 3225 All 3216/3225 50V ≧ ■ D.F Max. Capacitance X5R All cap ≦1.0uF 1.0uF< cap <4.7uF 4.7uF≦ cap ≦100uF All 100nF≦ cap cap ≦100nF 100nF< cap <330nF 330nF≦ cap cap ≦1.0uF 1.0uF< cap <2.2uF 2.2uF≦ cap cap <2.2uF 2.2uF≦ cap 10uF 10uF< cap ≦22uF All cap ≦100nF 100nF< cap ≦220nF cap ≦470nF 470nF< cap <1.0uF 1.0uF≦ cap cap ≦2.2uF 2.2uF< cap ≦4.7uF 4.7uF< cap ≦10uF 4.7uF< cap cap ≦22uF 10uF< All 1.0uF≦ cap 470nF 1.0uF< cap ≦4.7u 4.7uF< cap 4.7uF< cap ≦10u All but below cap ≦1.0uF X7R 15.0% 10.0% 10.0% 15.0% 7.5% 10.0% 7.5% 7.5% 10.0% 7.5% 7.5% 10.0% 7.5% 10.0% 10.0% 10.0% 5.0% 5.0% 7.5% 5.0% 7.5% 10.0% 5.0% 7.5% 10.0% 10.0% 15.0% 5.0% 10.0% 7.5% 10.0% 15.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 10.0% 5.0% 10.0% 3.5% 10.0% 5.0% 5.0% 10.0% 10.0% 2.5% 3.5% 3.0% 3.5% Y5V DF (tan δ) Table T.C Rated Voltage 4V 6.3V 10V Size Capacitance D.F Max 0603 1005 0603 ALL ALL ALL cap cap ALL ALL ALL cap cap 10uF cap cap cap cap cap cap cap cap cap 100nF cap cap 330nF cap 16.0% 20.0% 16.0% 12.5% 16.0% 12.5% 16.0% 12.5% 16.0% 12.5% 20.0% 9.0% 12.5% 7.0% 9.0% 12.5% 9.0% 12.5% 9.0% 5.0% 7.0% 9.0% 5.0% 7.0% 9.0% 1005 1608 2012 1005/1608 1005 220nF < 220nF < 2012 1005 Y5V 16V 1608 2012 < 100nF< 220nF< 2.2uF≦ 220nF 1005 1608 25V/50V 100nF< 2012 330nF< DARFON MLCC 15 ≦220nF <10uF ≦220nF 100nF ≦ ≦220nF <2.2uF 100nF 100nF ≦ < 330nF < Version:C1007 ELECTRICAL SPECIFICATIONS NP0 High Frequency Type (Q Series) Item Specification Test Method 1 Operating Temperature Range NP0: -55 to 125 degree C 2 Rated Voltage 16VDC, 25VDC, and 50VDC 3 Appearance No defects or abnormalities. Visual inspection 4 Dimensions Within the specified dimension. Using calipers 5 Dielectric Strength (Flash) No defects or abnormalities. No failure shall be observed when 250% of the rated voltage is applied between the terminations for 1 to 5 seconds. The charge and discharge current is less than 50mA. 6 Insulation Resistance ( I.R.) I.R. 7 Capacitance Within the specified tolerance 8 Quality Factor ( Q ) 30pF min.: Q --The rated voltage is defined as the maximum voltage, which may be applied continuously to the capacitor. ≧10GΩ The insulation resistance shall be measured with a DC voltage not exceeding the rated voltage at 25 and 75%RH max, and within 1 minute of charging. ℃ The capacitance / D.F. shall be measured at 25 frequency and voltage shown in the tables. ≧1000 ≧400+20C 30pF max.: Q C: Nominal Capacitance (pF) ℃ under operating Frequency 1.0±0.2MHz Voltage 1.0±0.2Vrms ℃ ℃ at the ℃ 9 Capacitance Temperature Characteristics Capacitance change within 0±30ppm/ temperature range. 10 Termination Strength No removal of the terminations or marking defect. 11 Deflection (Bending Strength) Appearance: No cracking or marking defects shall occur at Solder the capacitor to the test jig (glass epoxy boards) shown 1mm deflection. in Fig.a. Using a SAC305(Sn96.5Ag3.0Cu0.5) solder. The capacitance value at 25 and 85 shall be measured and calculated from the formula given below. Δ T.C.=(C85-C25)/C25* T*106(PPM/ ℃) Apply a parallel force of 5N to a PCB mounted sample for 10±1sec. *2N for 0603 (EIA 0201). Capacitance change: within ±2.5% or ± 0.25pF. (whichever is Then apply a force in the direction shown in Fig.b. larger) The soldering shall be done with the reflow method and shall be conducted with care so that the soldering is uniform and free of defects such as heat shock. φ 4.5 b 40 c a Size a b C 0603 0.3 0.9 0.3 1005 0.4 1.5 0.5 1608 1.0 3.0 1.2 20 50 Pressurizing speed : 1.0mm/sec. Pressurize R230 Flexure : 1mm 100 t :1.6mm(0.8mm for 0603&1005 size) Capacitance Meter 45 Fig. a. 12 Solderability of Termination Fig. b. 90% of the terminations are to be soldered evenly and Immerse the test capacitor into a methanol solution containing continuously. rosin for 3 to 5 seconds, preheat it 150 to 180 for 2 to 3 minutes and immerse it into SAC305(Sn96.5Ag3.0Cu0.5) solder of 245 ± 5 for 3±1seconds. Immerse the capacitor in a SAC305(Sn96.5Ag3.0Cu0.5) No marking defects solder solution at 270±5 for 10±1 seconds. Let sit at room temperature for 24±2 hours, then measure. NP0 within ±2.5% or ±0.25pF ( whichever is larger ) ℃ 13 Resistance to Soldering Heat Appearance Cap. Change 14 15 Temperature cycle (Thermal shock) Humidity load Q Initial spec. I.R. Initial spec. No marking defects Solder the capacitor to supporting jig (glass epoxy board) and NP0 within ±2.5% or 0.25pF ( whichever is larger ) perform the five cycles according to the four heat treatments Q Initial spec. listed in the following table. Let sit for 24±2hrs at room I.R. Initial spec. temperature, then measure. Appearance No marking defects Cap. Change NP0 within ±5% or ±0.5pF ( whichever is larger ) No marking defects NP0 within ±5% or ±0.5pF ( whichever is larger ) Q 350 min. I.R. Step 1: Minimum operating temperature 30±3min Step 2: Room temperature 2~3 min Step 3: Maximum operating temperature 30±3min Step 4: Room temperature 2~3min ℃ Apply the rated voltage at 40±2 and 90 to 95% humidity for 500±12 hours. Remove and let sit for 24±2 hours at room temperature, then measure. The charge / discharge current is less than 50mA. ≧500MΩ Appearance I.R. RF Characteristics 200 min. I.R. Cap. Change Q 17 ℃ Appearance Q High temperature load life test ℃ Cap. Change I.R. 16 45 ≧1GΩ Apply 200% of the rated voltage for 1000±12 hours at the maximum operating temperature ± 3 . Let sit for 24± 2 hours at room temperature, then measure. ℃ The charge/discharge current is less than 50mA. See RF Characteristics of NP0 Q series P:19~21 Measurements performed on a HP4287A with fixture 16196 and represent the typical capacitor performance. ESR DARFON MLCC 16 Version:C1007 TYPICAL CHARACTERISTICS CURVES TEMPERATURE COEFFICIENT Class 1 (Temperature Compensation series) Capacitance Change, ÷ C/C (%)  Temperature Coefficient of Temperature Compensation Series HP 4278A at 1MHz, 1Vrms 0.40 0.30 0.20 0.10 0.00 NP0 -0.10 -0.20 -0.30 -0.40 -80 -60 -40 -20 0 20 40 60 80 100 120 140 Temperature ( ℃ )  Class 2 (High Dielectric Constant Series) Temperature Coefficient of High Dielectric Constant Series HP 4278A at 1KHz, 1Vrms 40 Capacitance Change, ∆ C/C (%) 20 0 X7R X5R -20 -40 -60 Y5V -80 -100 -80 -60 -40 -20 0 20 40 Temperature ( DARFON MLCC 17 60 80 100 120 140 ℃) Version:C1007 TYPICAL CHARACTERISTICS CURVES DC VOLTAGE COEFFICIENT Capacitance Change,  C/C (%) Capacitance Change vs. DC Bias HP 4284A, 1MHz for NP0 HP 4284A, 1KHz for X5R , X 7R , Y5V 20% NP0 0% X7R / X5R -20% -40% -60% Y5V -80% -100% 0 2 4 6 8 10 12 14 16 18 20 DC Bias (Volt) AGING RATE The capacitance and dissipation factor of class 2 capacitors decreases with time. It is known as ‘aging’ that follows a logarithmic low and expressed in terms of an aging constant. Aging is caused by a gradual re-alignment of the crystalline structure of the ceramic. The aging constant is defined as the percentage loss of capacitance at a ‘time decade’. The law of capacitance aging is expressed as following equation: Typical Curve of Aging Rate of Different Dielectric Material 10.0 Ct2 = Ct1 x (1 – k x log10(t2/t1)) Capacitance Change Percent (%) 5.0 NP0 Ct1: Capacitance after t1 hours of start aging. 0.0 X7R / X5R -5.0 Ct2: Capacitance after t2 hours of start aging. -10.0 Y5V k: aging constant (capacitance decrease per decade) -15.0 -20.0 t1, t2: time in hours from start of aging. -25.0 -30.0 1 10 100 1000 10000 Time (Hours) 100000 A typical curve of aging rate is shown in following figure. When heating the capacitors above Curie temperature (130℃~150℃) the capacitance can be re-new. So capacitance of class 2 capacitors will be complete de-aged by soldering process; subsequently a new aging process begins. Because of aging, it is specified an age for measurement to meet the prescribed tolerance for class 2 capacitors. Normally, 1000 hours (t2=1000 hrs) is defined. DARFON MLCC 18 Version:C1007 RF CHARACTERISTICS OF NPO Q series  Typical RF Characteristics for High Frequency NP0 (C0G) 0603 (EIA 0201) at 1GHz. Maximun ESR @ 1GHz 0603 size 1000 900 800 ESR (mΩ ) 700 600 500 400 300 200 100 0 0.5 1 1.5 2 2.4 3 3.6 4.7 5.6 6.8 8.2 10 Capacitance ( pF) Minimun Q Factor @ 1GHz 0603 size 400 350 300 Q 250 200 150 100 50 0 0.5 1 1.5 2 2.4 3 3.6 4.7 5.6 6.8 8.2 10 Capacitance (pF) Measurements performed on a HP4287A with fixture 16196C and represent the typical capacitor performance. DARFON MLCC 19 Version:C1007 RF CHARACTERISTICS OF NPO Q series  Typical RF Characteristics for High Frequency NP0 (C0G) 1005 (EIA 0402) at 1GHz. Maximun ESR @ 1GHz 1005 size 1000 900 800 ESR (mΩ) 700 600 500 400 300 200 100 0 0.5 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 Capacitance (pF) Minimun Q Factor @ 1GHz 1005 size 350 300 250 Q 200 150 100 50 0 0.5 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 Capacitance (pF) Measurements performed on a HP4287A with fixture 16196B and represent the typical capacitor performance. DARFON MLCC 20 Version:C1007 RF CHARACTERISTICS OF NPO Q series Typical RF Characteristics for High Frequency NP0 (C0G) 1608 (EIA 0603) at 1GHz.  Maximun ESR @ 1GHz 1608 size 1400 1200 ESR (mΩ) 1000 800 600 400 200 0 0.5 1 1.5 2 2.4 3 3.6 4.7 5.6 6.8 8.2 10 Capacitance (pF) Minimun Q Factor @ 1GHz 1608 size 300 250 Q 200 150 100 50 0 0.5 1 1.5 2 2.4 3 3.6 4.7 5.6 6.8 8.2 10 Capacitance (pF) Measurements performed on a HP4287A with fixture 16196A and represent the typical capacitor performance. DARFON MLCC 21 Version:C1007 PACKAGING  Packing  Tape and reel packaging Tape and reel packaging is currently the most promising system for high-speed production. A typical 180mm (7 inch) diameter reel contains 1,500 to 15,000 capacitors, 250mm (10 inch) contains 10,000 capacitors, and 330mm(13 inch) contains 10,000 to 50,000 capacitors. Three standard sizes are available in taped and reeled package either with paper carrier tapes or embossed tapes.  Paper tape specifications 2mm and 4mm pitch tape 4.0+/-0.1 φ1.5 +0.1 P 1.1 max. 2.0+/-0.05 - 0.0 1.75+/-0.1 A F W B Cardboard Direction of feed PRODUCT SIZE CODE SYMBOL UNIT 0603(0201) 1005(0402) 1608(0603) 2012(0805) 3216(1206) SIZE TOL. SIZE TOL. SIZE TOL. SIZE TOL. SIZE TOL. A 0.38 +/- 0.04 0.60 +/- 0.04 1.0 +/- 0.2 1.5 +/- 0.2 1.9 +/- 0.2 mm B 0.68 +/- 0.04 1.12 +/- 0.04 1.8 +/- 0.2 2.3 +/- 0.2 3.6 +/- 0.2 mm F 3.50 +/- 0.05 3.50 +/- 0.05 3.5 +/- 0.05 3.5 +/- 0.05 3.5 +/- 0.05 mm P 2.00 +/- 0.10 2.00 +/- 0.10 4.0 +/- 0.1 4.0 +/- 0.1 4.0 +/- 0.1 mm W 8.00 +/- 0.20 8.00 +/- 0.20 8.0 +/- 0.2 8.0 +/- 0.2 8.0 +/- 0.2 mm DARFON MLCC 22 Version:C1007 PACKAGING  Embossed tape specifications 4mm and 8mm pitch tape P0 D0 P1 P0 D0 P1 P2 E P2 K0 T E K0 T A0 F B0 W W F A0 B0 D1 T1 D1 Direction of feed Top tape T2 Direction of feed Top tape T1 T2 ko: so chosen that the orientation of the component cannot change. For W= 8mm: T2=2.5mm max. For W= 12mm: T2= 4.5mm PRODUCT SIZE CODE DIMENSION (mm) 4 mm tape 8 mm tape TOLERANCE (mm) 2012 (0805) 3216 (1206) 3225 (1210) 4520 (1808) 4532 (1812) P1 4 4 4 8 8 +/- 0.10 PO 4 4 4 4 4 +/- 0.10 P2 2 2 2 2 2 +/- 0.05 A0 nominal clearance* 0.2 0.3 0.3 0.4 0.4 - B0 nominal clearance* 0.2 0.3 0.3 0.4 0.4 - K0 minimum clearance* 0.05 0.05 0.05 0.05 0.05 - W 8.0 8.0 8.0 12.0 12.0 +/- 0.20 E 1.75 1.75 1.75 1.75 1.75 +/- 0.10 F 3.5 3.5 3.5 5.5 5.5 +/- 0.05 D0 1.5 1.5 1.5 1.5 1.5 +0.1/-0.0 D1 1 min 1 min 1 min 1.5 min 1.5 min +0.1/-0.0 T 0.25 0.25 0.25 0.25 0.25 +/- 0.10 T1 0.05 0.05 0.05 0.05 0.05 +/- 0.01 T2 2.5 max. 2.5 max. 2.5 max. 4.5 4.5 - * Typical capacitors displace in pocket. DARFON MLCC 23 Version:C1007 PACKAGING  Reel specifications T φ13.0+/-0.5 D 50 min. 2.0+/-0.5 φ21.0+/-0.8 G 10.0+/-1.5 for 8mm wide tape 14.0+/-1.5 for 12mm wide tape TAPE WIDTH (mm) G (mm) T max. (mm) D (mm) 8 10.0 +/- 1.5 14.5 180 8 10.0 +/- 1.5 14.5 250 8 10.0 +/- 1.5 14.5 330 12 14.0 +/- 1.5 18.5 180 DARFON MLCC 24 Version:C1007 PACKAGING  Thickness and Packing Amount Thickness Code A B B Q Spec 0.30+/-0.03 0.50+/-0.05 0.50+/-0.15 0.45+/-0.05 C 0.60+/-0.15 Q D D 0.45+/-0.05 0.80+/-0.10 0.80+0.15/ -0.10 E 0.85+/-0.15 I 0.95+/-0.15 F 1.15+/-0.20 G 1.25 +/-0.20 G 1.25+0.3/-0.2 L 1.60+/-0.20 L 1.60+0.30/-0.20 N 2.00+/-0.20 N P P 2.00+/-0.30 2.50+/-0.20 2.50+/-0.30 DARFON MLCC Size(EIA) 0603 (0201) 1005 (0402) 1005 (0402) 1005 (0402) 2012 (0805) 3216(1206) 1608(0603) 1608(0603) 1608 (0603) 2012 (0805) 3216 (1206) 3225 (1210) 4532 (1812) 2012(0805) 3216(1206) 3216 (1206) 4520 (1808) 2012 (0805) 3216 (1206) 3225 (1210) 4520(1808) 4532(1812) 2012(0805) 3216(1206) 3225(1210) 3216(1206) 3225(1210) 4520(1808) 4532(1812) 3216(1206) 3225(1210) 4520(1808) 45321812) 3216 (1206) 3225 (1210) 4520 (1808) 4532(1812) 3225 (1210) 3225(1210) 3225(1210) 180 mm (7”) Paper Embossed 15K 10K 10K 10K 4K 4K 4K 4K 4K 4K 4K 3K 1K 3K 3K 3K 3K 2K/3K 3K 3K 3K 1K 2K/3K 3K 3K 2K 2K 2K 1K 2K 2K 2K 1K 2K/3K 2K 1K 1K 2K 500pcs/1K 500pcs/1K 25 Amount per reel 250 mm (10”) Paper Embossed 10K 10K 10K 10K 10K 10K 10K 330 mm (13”) Paper Embossed 50K 50K 50K 15K 15K 15K 15K 15K 15K 15K 10K 10K 10K 10K 10K 10K Version:C1007 APPLICATION NOTES Storage 1. The chip capacitors shall be packaged in carrier tapes or bulk cases. 2. Keep storage place temperatures from +5℃ to +35℃, humidity from 45 to 70% RH. 3. The storage atmosphere must be free of gas containing sulfur and chlorine. Also, avoid exposing the product to saline moisture. If the product is exposed to such atmospheres, the terminations will oxidize and solderability will be affected. 4. The solderability is assured for 12 months from our final inspection date if the above storage condition is followed. Circuit Design 1. Once application and assembly environments have been checked, the capacitor may be used in conformance with the rating and performance, which are provided in both the catalog and the specifications. Exceeding the specifications listed may result in inferior performance. It may also cause a short, open, smoking, or flaming to occur, etc. 2. Please use the capacitors in conformance with the operating temperature provided in both the catalog and the specifications. Be especially cautious not to exceed the maximum temperature. In the situation the maximum temperature set forth in both the catalog and specifications is exceeded, the capacitor’s insulation resistance may deteriorate, power may suddenly surge and short-circuit may occur. The loss of capacitance will occur, and may self-heat due to equivalent series resistance when alternating electric current is passed through. As this effect becomes critical in high frequency circuits, please exercise with caution. When using the capacitor in a (self-heating) circuit, please make sure the surface of the capacitor remains under the maximum temperature for usage. Also, please make certain temperature rise remain below 20℃. 3. Please keep voltage under the rated voltage, which is applied to the capacitor. Also, please make certain the peak voltage remains below the rated voltage when AC voltage is super-imposed to the DC voltage. In the situation where AC or pulse voltage is employed, ensure average peak voltage does not exceed the rated voltage. Exceeding the rated voltage provided in both catalog and specifications may lead to defective withstanding voltage or, in worse case situations, may cause the capacitor to burn out. 4. It’s is a common phenomenon of high-dielectric products to have a deteriorated amount of static electricity due to the application of DC voltage. DARFON MLCC 26 Version:C1007 APPLICATION NOTES Handling Chip capacitors should be handled with care to avoid contamination or damage. The use of vacuum pick-up or plastic tweezers is recommended for manual placement. Tape and reeled packages are suitable for automatic pick and placement machine. Flux 1. An excessive amount of flux or too rapid temperature rise can causes solvent burst, solder can generate a large quantity of gas. The gas can spreads small solder particles to cause solder balling effect or bridging problem. 2. Flux containing too high of a percentage of halide may cause corrosion of termination unless sufficient cleaning is applied. 3. Use rosin-type flux. Highly acidic flux (halide content less than 0.2wt%) is not recommended. 4. The water soluble flux causes deteriorated insulation resistance between outer terminations unless sufficiently cleaned. Component Spacing For wave soldering components, the spacing must be sufficient far apart to prevent bridging or shadowing. This is not so important for reflow process but enough space for rework should be considered. The suggested spacing for reflow soldering and wave soldering is 0.5mm and 1.0mm, respectively. Solder Fillet Too much solder amount may increase solder stress and cause crack risk. Insufficient solder amount may reduce adhesive strength and cause parts falling off PCB. When soldering, confirm that the solder is placed over 0.2mm of the surface of the terminations. Max. buildup Joint Land Min. buildup Resist 0.20mm Min. PCB Adhesive DARFON MLCC 27 Version:C1007 APPLICATION NOTES Recommended Land Pattern Dimensions When mounting the capacitor to substrate, it’s important to consider that the amount of solder (size of fillet) used has a direct effect upon the capacitor once it’s mounted. 1. The greater the amount of solder, the greater the stress to the elements, as this may cause the substrate to break or crack. 2. In the situation where two or more devices are mounted onto a common land, separate the device into exclusive pads by using soldering resist. 3. Land width equal to or less than component. It is permissible to reduce land width to 80% of component width. Soldering resist Land Pattern SMD capacitor c b a Size mm (EIA) L x W (mm) a (mm) b (mm) c (mm) 0603 (0201) 0.6*0.3 0.15 to 0.35 0.2 to 0.3 0.25 to 0.3 1005 (0402) 1.0*0.5 0.3 to 0.5 0.35 to 0.45 0.4 to 0.5 1608 (0603) 1.6*0.8 0.7 to 1.0 0.6 to 0.8 0.7 to 0.8 2012 (0805) 2.0*1.25 1.0 to 1.3 0.7 to 0.9 1.0 to 1.2 3216 (1206) 3.2*1.6 2.1 to 2.5 1.0 to 1.2 1.3 to 1.6 3225 (1210) 3.2*2.5 2.1 to 2.5 1.0 to 1.2 2.0 to 2.5 4520 (1808) 4.5*2.0 3.2 to 3.8 1.2 to 1.4 1.7 to 2.0 4532 (1812) 4.5*3.2 3.2 to 3.8 1.2 to 1.4 2.7 to 3.2 DARFON MLCC 28 Version:C1007 APPLICATION NOTES Resin Mold If a large amount of resin is used for molding the chip, cracks may occur due to contraction stress during curing. To avoid such cracks, use a low shrinkage resin. The insulation resistance of the chip will degrade due to moisture absorption. Use a low moisture absorption resin. Check carefully that the resin does not generate a decomposition gas or reaction gas during the curing process or during normal storage. Such gases may crack the chip capacitor or damage the device itself. Soldering Profile for SMT Process with SnPb Solder Paste  Reflow Soldering Soldering 220 to 230 Within 10 sec. ℃ 300 250 Temperature ( ) ℃200 Gradual Natural Cooling ℃ 200 ∆T ℃ Preheating 0 60 sec. min. Within 40 sec. Time (sec.) 120 sec. max. The difference between solder and chip surface should be controlled as following table. The rate of preheat should not exceed 4℃/sec and a target of 2℃/sec is preferred. Chip Size 3216 and smaller Preheating DARFON MLCC ∆T≤150 29 ℃ 3225 and above ∆T≤130 ℃ Version:C1007 APPLICATION NOTES  Wave Soldering 300 Soldering 230 to 260 ℃ 250 ℃ Gradual Natural Cooling Temperature ( ) ∆T ℃ Preheating 0 Time (sec.) 60 sec. ~ 120 sec. Chip Size 3216 and smaller Preheating  5 sec. max. ∆T≤150 3225 and above ℃ - Soldering Iron 1. Soldering iron wattage 20W maximum. 2. Iron-tip diameter ϕ 3.0mm maximum. Soldering 270 to 300 ℃ 300 ℃ 270 Gradual Natural Cooling ∆T Temperature ( ) ℃ Preheating 0 Time (sec.) 60 sec. ~ 120 sec. Chip Size Preheating DARFON MLCC 3 sec. max. 3216 and smaller ∆T≤190 30 ℃ 3225 and above ∆T≤130 ℃ Version:C1007 APPLICATION NOTES Soldering  Reflow Soldering for Lead free Termination Soldering 240 to 260 Within 10 sec. ℃ 300 ℃ 250 Temperature ( ) ℃ Gradual Natural Cooling ∆T 200 Preheating 0 60 sec. min. 120 sec. max. ℃ Time (sec.) Over 200 Within 90 sec. The difference between solder and chip surface should be controlled as following table. The rate of preheat should not exceed 4℃/sec and a target of 2℃/sec is preferred. Chip Size 3216 and smaller Preheating DARFON MLCC ∆T≤150 31 ℃ 3225 and above ∆T≤130 ℃ Version:C1007 APPLICATION NOTES  Flow Soldering for Lead free Termination 300 Soldering 240 to 260 ℃ 250 Temperature ( ) ℃ ℃ Gradual Natural Cooling ∆T 200 Preheating 0 Time (sec.) 60 sec. ~ 120 sec. Chip Size 3216 and smaller Preheating  3 ~ 5 sec. ∆T≤150 3225 and above ℃ - Soldering Iron 1. Soldering iron wattage 20W maximum. 2. Iron-tip diameter 3.0mm maximum. 300 Soldering 270 to 300 ℃ ℃ 270 Gradual Natural Cooling ∆T Temperature ( ) ℃ Preheating 0 Time (sec.) 60 sec. ~ 120 sec. Chip Size 3216 and smaller Preheating DARFON MLCC 3 sec. max. ∆T≤190 32 ℃ 3225 and above ∆T≤130 ℃ Version:C1007 APPLICATION NOTES Chip Layout and Breaking PCB 1. To layout the SMD capacitors for reducing bend stress from board deflection of PCB. The following are examples of good and bad layout. Recommended Not Recommended 2. When breaking PCB, the layout should be noted that the mechanical stresses are depending on the position of capacitors. The following example shows recommendation for better design. E D C Perforation A A Slit B Magnitude of stresses A > B = C > D > E Peeling Off Force Peeling off force: 0.1N to 1.0N in the direction shown below. The peeling speed: 300+/-10 mm/min 165 ° to 180° Peeling force Top tape Base tape 1. The taped tape on reel is wound clockwise. The sprocket holes are to the right as the tape is pulled toward the user. 2. There are minimum 150 mm as the leader and minimum 40 mm empty tape as the tail is attached to the end of the tape. DARFON MLCC 33 Version:C1007 ENVIRONMENTAL CONCERNS DARFON ENVIRONMENTAL POLICY     KEEP ENVIRONMENTAL REGULATION ALL MEMBER MUST JOIN THE ENVIRONMENTAL PROTECTION KEEP PREVENTION AND TREATMENT PROTECT THE NATURAL RESOURCES DARFON MLCC 34 Version:C1007 ENVIRONMENTAL CONCERNS DARFON MLCC 35 Version:C1007 ENVIRONMENTAL CONCERNS DARFON MLCC 36 Version:C1007
C0603NP0100JGT 价格&库存
很抱歉,暂时无法提供与“C0603NP0100JGT”相匹配的价格&库存,您可以联系我们找货
