ESD05V32D-LC
ESD05V32D-LC
    SOCAY(硕凯)
    SOD323
    ESD05V32D-LC
ESD05V32D-LC 数据手册
Transient Voltage Suppressors for ESD Protection Low Capacitance ESDXXV32D-LC Series Description SOD-323 The ESDXXV32D-LC is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, ultra-low capacitance values, it is very suitable for signal port and board space speed transmission is very small places, such as Ethernet, mobile phones, MP3 players, digital cameras and other portable. Feature Functional Diagram  350 Watts Peak Pulse Power per Line (tp=8/20μs)  Protects one bi-directional I/O line  Low clamping voltage  Working voltages: 3.3V, 5V, 8V, 12V, 15V, 24V  Low leakage current  RoHS compliant  IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC61000-4-5 (Lightning) 20A、17A、20A、11A 、10A、 6A(8/20μs) Applications Mechanical Characteristics  Cell Phone Handsets and Accessories  Microprocessor based equipment  Personal Digital Assistants (PDA’s)  Notebooks, Desktops, and Servers  Portable Instrumentation  Peripherals  USB Interface  SOD-323 Package  Molding Compound Flammability Rating : UL 94V-0  Weight 5.0 Milligrams (Approximate)  Quantity Per Reel : 3,000pcs  Lead Finish : Lead Free Absolute Maximum Ratings (TA=25℃,RH=45%-75%, unless otherwise noted) Parameter Symbol Value Units TSTG -55 to +150 ℃ Operating Junction Temperature Range TJ -55 to +150 ℃ Lead Soldering Temperature TL 260 (10sec.) ℃ Peak Pulse Power dissipation on 8/20μs waveform) PPP 350 W Storage Temperature Range ESD per IEC 61000-4-2 (Air) VESD ESD per IEC 61000-4-2 (Contact) SOCAY Electronics Corp., Ltd. Revision November 10, 2016 ±15 ±8 KV www.socay.com 1/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection Low Capacitance ESDXXV32D-LC Series Electrical Characteristics (TA= 25℃) Part Number VRWM (V) IR @ VR (μA) VBR@ IT=1mA Min(V) VC @1A Max(V) VC @ IPP Max(V) IPP① (A) Cj@ 0V,1MHZ Typ(pF) ESD03V32D-LC 3.3 1 4.0 7.5 19.0 20 1.2 ESD05V32D-LC 5.0 1 6.0 9.8 18.0 17 1.2 ESD08V32D-LC 8.0 1 8.5 13.5 27.0 20 1.2 ESD12V32D-LC 12.0 1 13.3 19.0 29.0 11 1.2 ESD15V32D-LC 15.0 1 16.7 24.0 40.0 10 1.5 ESD24V32D-LC 24.0 1 26.7 43.0 55.0 6 1.2 ① Surge waveform: 8/20μs Ratings and V-I Curve Characteristics Curves (TA=25℃, unless otherwise noted) Fig1. V- I Curve Characteristics Bi-directional Fig2. Pulse Waveform I IPP VC VBR VRWM R IR IT IT IR V VRWM VBR VC IPP Fig3. Pulse Derating Curve Fig4. ESD Clamping (8KV Contact) SOCAY Electronics Corp., Ltd. Revision November 10, 2016 www.socay.com 2/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection Low Capacitance ESDXXV32D-LC Series Package Mechanical Data Symbol Revision November 10, 2016 Inches Min. Max. Min. Max. A 1.60 1.80 0.063 0.071 B 0.25 0.35 0.010 0.014 C 2.50 2.70 0.098 0.106 D 0.00 1.00 0.000 0.039 E 1.20 1.40 0.047 0.055 F 0.08 0.15 0.003 0.006 L SOCAY Electronics Corp., Ltd. Millimeters 0.475REF 0.019REF L1 0.25 0.40 0.010 0.016 H 0.00 0.10 0.000 0.004 P 3.00 0.118 P1 0.80 0.031 www.socay.com 3/3 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
ESD05V32D-LC 价格&库存
很抱歉,暂时无法提供与“ESD05V32D-LC”相匹配的价格&库存,您可以联系我们找货
