PS176
PS176
    PARADE(谱瑞科技)
    QFN-48-EP(6x6)
PS176 数据手册
PARADE TECHNOLOGIES INC. Email: sales@paradetech.com FAX : 408-329-5541 Website: www.paradetech.com Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y TEL : 408-329-5540 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Datasheet Version 0.6 Pa August. 21, 2014 Notice All information provided in this document is on an “AS IS” basis without any guarantee or warranty. Information in this document is provided in relation to Parade products and is subject to change without notice. No intellectual rights or licenses are implied. Do Not Distribute Without Permission PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. KEY FEATURES  Compliant to DisplayPortTM Specification 1.2a for 1.62Gbps, 2.7Gbps and 5.4Gbps  Supports DisplayPortTM 1, 2, and 4 lanes  Supports full link training and no link training  Supports multiple color formats: - DP: RGB 6/8/10/12-bit per component (bpc) and YCbCr4:4:4, YCbCr4:2:2 bpc 8/10/12 bpc Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y - HDMI: RGB 8/10/12 bpc; YCbCr4:4:4, YCbCr4:2:2 and YCbCr4:2:0 8/10/12 bpc  Compliant to HDMI Specification 2.0, data rate up to 6Gbps  Supports TMDS scrambling for EMI/RFI reduction  Supports SCDC (Status and Control Data Channel)  Supports up to 8-channel LPCM, compressed audio (AC-3, DTS) and HBR audio formats  Supports up to 192kHz audio frame rate and up to 24-bit audio sample size  Content protection - Supports HDCP 1.4 repeater with on-chip keys - Supports HDCP 2.2 repeater On-chip microprocessor with embedded SPI ROM  ESD:  1.2V Core Power Supply & 3.3V I/O Power Supply  0°C to 70°C Ambient Operating Temperature Range  48-pin 6x6mm QFN Halogen free RoHS package Pa  TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 2 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. APPLICATIONS  Dongle Application Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y Typical Application TMDS Native DP PS176 Pa Figure1. Typical Application TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 3 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. DESCRIPTION PS176 is a DisplayPort 1.2a to HDMI 2.0 Protocol Converter which receives both video and audio streams from DisplayPort link and converts to TMDS output. The TMDS transmitter is compliant to HDMI 2.0 specification with data rate up to 6Gbps. PS176 supports HDCP 1.4 and HDCP 2.2 repeater for downstream sink with an embedded key. PS176 has integrated an on-chip microcontroller for system configuration purposes. The device can be Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y configured with an SPI Flash for customized applications. The system level block diagram of PS176 is described in Figure 2. Detailed descriptions of each functional block are given in the following sections. Pa FUNCTIONAL BLOCK DIAGRAM TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com Figure2. PS176 Functional Block Diagram For Customer Internal Use Only 4 Parade Technologies Inc. PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter DISPLAYPORTTM RECEIVER The DisplayPort™ Receiver interface implemented in PS176 is fully compliant to the VESA DisplayPort Standard, Version 1.2a. Physical Layer (PHY) The DisplayPort™ main link operates at a data rate of 1.62Gbps (Reduced Bit Rate - RBR), 2.7Gbps (High Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y Bit Rate - HBR) or 5.4Gbps (High Bit Rate 2 - HBR2). DisplayPort™ Receiver receives serial data stream, de-serializes it, and decodes it in ANSI 8B/10B format. Subsequently, the receiver unscrambles and de-skews the decoded data. The DisplayPort™ AUX channel is a half-duplex, bi-directional channel which supports bit rate at 1 Mbps. The logical sub-block of AUX channel generates and detects Start/Stop condition and locks to Sync pattern, encodes or decodes of data using Manchester-II coding. The electrical sub-block of AUX channel consists of one differential pair which operates as a half-duplex bi-directional channel. The AUX channel provides Link Configuration, Link maintenance and EDID access. The DisplayPort™ Hot Plug/Unplug detection is indicated by HPD signal. The HPD signal is asserted whenever the sink device is connected to its main power supply and the source (DP Tx) is detected. The pulsed HPD signal is also used as an Interrupt Request (IRQ) by sink device. The low-going pulse width within 0.5ms to 1.0ms is asserted as Interrupt Request (IRQ) from sink device to source device which shall read link status field of DisplayPort™ Configuration Data (DPCD) and take proper action. Link Layer The DisplayPort™ receiver Link Layer services reconstruct original video and audio data and timing base through isochronous transport services over main link. It also handles AUX Channel link service and device service. The main link supports 4-lane, 2-lane and 1-lane at 1.62Gbps, 2.7Gbps or 5.4Gbps data rate. The optimal lane count and data rate shall be negotiated through capability discovery and link training between source and sink devices. The isochronous transport services of Link Layer provide packing/unpacking, stuffing/un-stuffing, framing/un-framing, inter-lane skewing/de-skewing, stream clock recovery, insertion/extraction of Main Stream Attributes data and/or inserting/extracting of secondary-data Pa packet with ECC (Error Control Code) for audio stream packet & CEA861-F InfoFrame packet. PS176 DisplayPort™ receiver supports RGB444 (6/8/10/12-bit), YCbCr444 (8/10/12-bit) and YCbCr422 (8/10/12-bit) video input formats and supports up to 8 channels LPCM, compressed audio format (AC-3, DTS) and HBR audio format. It also supports audio frame rate of 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz and audio sample size of 16, 20 and 24 bits per sample. TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 5 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. HDMI TRANSMITTER The High Definition Multimedia Interface (HDMI) implemented in PS176 is fully compliant to the High-Definition Multimedia Interface Specification, Version 2.0, September 4, 2013. Compliance includes the capability to deliver audio and video content from the decoded DisplayPort™ audio and video streams onto an HDMI TMDS output. The HDMI TMDS provides support for up to 6.0Gbps data rate, allowing display up to 4kx2k at 60Hz refresh rate with 8-bit deep color and 3D video formats up to 1080p at 120Hz. Audio output support consists of up to 8 channels of LPCM at 32kHz, Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz sample rate and audio sample size of 16, 20 and 24-bits per sample, decoded by DisplayPort™ receiver. The PS176 also supports compressed audio formats (AC-3, DTS) and HBR audio format. PS176 provides support for a SCDC channel for EDID reading and exchange of point-to-point dynamic data between the Source and the Sink. PS176 also supports a monitor hot plug detect signal HPD to detect the attachment and presence of a sink device. HDCP The HDCP provides a secure audio and video content on DisplayPort™ receiver and TMDS transmitter interfaces, it also provides appropriate security measures to prevent discovery and nullification of the HDCP keys stored within the PS176. PS176 supports both HDCP version 1.4 specification and HDCP version 2.2 specification. The features of HDCP are summarized as below:  The DisplayPort™ receiver side performs upstream HDCP 1.4/2.2 function including HDCP authentication and HDCP decryption.  The TMDS transmitter side performs downstream HDCP 1.4/2.2 function including HDCP authentication and HDCP encryption.  Software will interface with both upstream and downstream HDCP authentication engine to implement the HDCP repeater functions. Pa  Integrated both HDCP receiver and transmitter Key ROMs HOT PLUG DETECTION (HPD) PS176 has two hot plug detection signals.  HDMI_HPD: downstream port hot plug detection input  DP_HPD: upstream port hot plug detection output HDMI_HPD HDMI_HPD is an input signal. A HIGH on this signal indicates that a sink is connected. It is the hardware that is responsible for detecting the state change on this pin. Firmware will interpret the signal and take TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 6 Parade Technologies Inc. PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter actions after the HDMI_HPD state change. HDMI_HPD state changes are mainly used in the PS176 operation and power state machine maintained by PS176 firmware. DP_HPD DP_HPD is an output signal. A HIGH on this signal indicates that PS176 is ready to take DisplayPort™ input. Firmware will control this signal according to PS176 operation and power state machine. After power on, DP_HPD signal will stay at low. Once PS176 is ready to take DisplayPort™ input, this Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y signal will be asserted HIGH. In addition to hot plug detection, DP_HPD signal is also used for the following:  DisplayPort™ IRQ, including Link Status change, AUTOMATED_TEST_REQUEST and CP_IRQ. In these events, hardware will generate short low-going pulse (0.5ms ~ 1ms) on DP_HPD pin  DisplayPort™ MCCS_IRQ and SINK_SPECIFIC_IRQ. Firmware will generate short low-going pulse (0.5ms ~ 1ms) in the two events AUX TO I2C BRIDGE AUX to I2C bridge acts as a bidirectional repeater function from DisplayPort™ AUX CH interface to HDMI DDC interface. It monitors DisplayPort™ AUX CH traffic and converts only those I2C-over-AUX CH transactions targeted to the HDMI sink device, as described below, into HDMI DDC interface.  EDID access: I2C slave address of 60h, 61h, A0h and A1h  MCCS communication: I2C slave address of 6Eh and 6Fh  VESA DisplayID standard (proposed and legacy): I2C slave address of A0h through A7h All other I2C-over-AUX transactions are blocked and assumed to be accessing functions within the PS176. The AUX to I2C bridge provides an interface for PS176 firmware to interface AUX CH directly. This is to provide hardware support for firmware to handle all possible native AUX transactions and I2C-over-AUX transactions, including those targeted to the HDMI sink device. The AUX to I2C bridge also provides an interface for PS176 to directly access HDMI DDC port. This Pa function will be used when firmware needs to read EDID from downstream device, or to read downstream HDCP port directly. TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 7 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. ON-CHIP MICROPROCESSOR (MPU) PS176 integrates a micro-processor unit (MPU). The MPU core is an 8-bit processor which executes 8031/8051 type instructions. The instructions are stored in an internal flash ROM with Serial Peripheral Interface (SPI) and can be accessed through the internal ROM bus. 512 bytes internal RAM and 128 bytes SFR (special function register) provide the temporal data storage space. The MPU accesses the internal registers through a memory bus. Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y There is total 512K bytes SPI ROM space available for the MPU in PS176. PS176 firmware is stored in this ROM. There are two ways to update the SPI ROM. One is through PS176 control I2C port and another one is through AUX CH. EDID EDID Relay: EDID can be relayed from DDC bus in HDMI transmitter interface to AUX/DDC channel of upstream Dual-Mode DP source. When relaying the EDID from HDMI to upstream DP source, PS176 does not do any modifications. GENERIC I/O INTERFACES There are 4 dedicated General Purpose Input/Output pin (GPIO) in PS176. CONTROL I2C SLAVE Control I2C slave is the programming interface for external device to access internal registers, including Pa DPCD registers. This bus is used to configure, control or debug PS176 internal functions. TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 8 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. DISPLAY RESOLUTIONS FOR TMDS OUTPUT Following tables provide the popular video modes that PS176 may support. PS176 will also support other video modes as long as they are within available DisplayPortTM bandwidth, TMDS clock frequency range of 25MHz to 340MHz (HDMI Specification 1.4b) and TMDS character rate (1/4 of TMDS clock frequency) range of 85MHz to 150MHz (HDMI Specification 2.0). Table 1. Video clock table for monitors Refresh Rate Horizontal Frequency Pixel Frequency Standard Type Original Document Date 640 x 350 85 Hz 37.9 kHz 31.500 MHz VESA Standard VDMTPROP 3/1/96 640 x 400 85 Hz 37.9 kHz 31.500 MHz VESA Standard VDMTPROP 3/1/96 720 x 400 85 Hz 37.9 kHz 35.500 MHz VESA Standard VDMTPROP 3/1/96 640 x 480 60 Hz 31.5 kHz 25.175 MHz Industry Standard n/a n/a 72 Hz 37.9 kHz 31.500 MHz VESA Standard VS901101 12/2/92 75 Hz 37.5 kHz 31.500 MHz VESA Standard VDMT75HZ 10/4/93 Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y Resolution 800 x 600 85 Hz 43.3 kHz 36.000 MHz VESA Standard VDMTPROP 3/1/96 56 Hz 35.1 kHz 36.000 MHz VESA Guidelines VG900601 8/6/90 60 Hz 37.9 kHz 40.000 MHz VESA Guidelines VG900602 8/6/90 72 Hz 48.1 kHz 50.000 MHz VESA Standard VS900603A 8/6/90 75 Hz 46.9 kHz 49.500 MHz VESA Standard VDMT75HZ 10/4/93 85 Hz 53.7 kHz 56.250 MHz VESA Standard VDMTPROP 3/1/96 848 x 480 60 Hz 31.0 kHz 33.750 MHz VESA Standard AddDMT 3/4/03 1024 x 768 43 Hz 35.5 kHz 44.900 MHz Industry Standard n/a n/a 60 Hz 48.4 kHz 65.000 MHz VESA Guidelines VG901101A 9/10/91 70 Hz 56.5 kHz 75.000 MHz VESA Standard VS910801-2 8/9/91 75 Hz 60.0 kHz 78.750 MHz VESA Standard VDMT75HZ 10/4/93 85 Hz 68.7 kHz 94.500 MHz VESA Standard VDMTPROP 3/1/96 1152 x 864 75 Hz 67.5 kHz 108.000 MHz VESA Standard VDMTPROP 3/1/96 1280 x 768 60 Hz 47.4 kHz 68.250 MHz CVT Red. Blanking AddDMT 3/4/03 60 Hz 47.8 kHz 79.500 MHz CVT AddDMT 3/4/03 75 Hz 60.3 kHz 102.250 MHz CVT AddDMT 3/4/03 Interlaced Pa 1280 x 960 1280 x 1024 85 Hz 68.6 kHz 117.500 MHz CVT AddDMT 3/4/03 60 Hz 60.0 kHz 108.000 MHz VESA Standard VDMTPROP 3/1/96 85 Hz 85.9 kHz 148.500 MHz VESA Standard VDMTPROP 3/1/96 60 Hz 64.0 kHz 108.000 MHz VESA Standard VDMTREV 12/18/96 10/4/93 75 Hz 80.0 kHz 135.000 MHz VESA Standard VDMT75HZ 85 Hz 91.1 kHz 157.500 MHz VESA Standard VDMTPROP 3/1/96 1360 x 768 60 Hz 47.7 kHz 85.500 MHz VESA Standard AddDMT 3/4/03 1400 x 1050 60 Hz 64.7 kHz 101.000 MHz CVT Red. Blanking AddDMT 5/13/03 60 Hz 65.3 kHz 121.750 MHz CVT AddDMT 3/4/03 75 Hz 82.3 kHz 156.000 MHz CVT AddDMT 3/4/03 85 Hz 85.0 kHz 179.500 MHz CVT AddDMT 3/4/03 1440 x 900 60 Hz 55.5 kHz 88.750 MHz CVT Red. Blanking CVT 1.30MA 7/14/04 60 Hz 59.9 kHz 106.500 MHz CVT CVT 1.30MA 7/14/04 75 Hz 75.0 kHz 136.750 MHz CVT CVT 1.30MA 7/14/04 TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 9 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. 1600 x 1200 84.8 kHz 157.000 MHz CVT CVT 1.30MA 7/14/04 60 Hz 75.0 kHz 162.000 MHz VESA Standard VDMTREV 12/18/96 65 Hz 81.3 kHz 175.500 MHz VESA Standard VDMTREV 12/18/96 70 Hz 87.5 kHz 189.000 MHz VESA Standard VDMTREV 12/18/96 75 Hz 93.8 kHz 202.500 MHz VESA Standard VDMTREV 12/18/96 85 Hz 106.3 kHz 229.500 MHz VESA Standard VDMTREV 12/18/96 60 Hz 64.7 kHz 119.000 MHz CVT Red. Blanking CVT 1.76MA 7/14/04 60 Hz 65.3 kHz 146.250 MHz CVT CVT 1.76MA 7/14/04 75 Hz 74.9 kHz 187.000 MHz CVT CVT 1.76MA 7/14/04 85 Hz 93.9 kHz 214.75 MHz CVT CVT 1.76MA 7/14/04 Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y 1680 x 1050 85 Hz 1792 x 1344 60 Hz 83.64 kHz 1856 x 1392 60 Hz 86.33 kHz 1920 x 1200 60 Hz 74.0 kHz 60 Hz 74.6 kHz 75 Hz 60 Hz 1920 x 1440 204.750 MHz VESA Standard VDMTREV 9/17/98 218.250 MHz VESA Standard VDMTREV 9/17/98 154.000 MHz CVT Red. Blanking AddDMT 3/4/03 193.250 MHz CVT AddDMT 3/4/03 94.0 kHz 245.250 MHz CVT AddDMT 3/4/03 90.000 kHz 234.000 MHz VESA Standard VDMTREV 9/17/98 Table 2. Video clock table for TV devices Field Rate Pa Low 50Hz VIC Hactive Vactive I/P Htotal Hblank Vtotal Vblank H Freq (kHz) V Freq (Hz) Pixel Freq (MHz) 60,65 1280 720 Prog 3300 2020 750 30 18.000 24.000 59.400 61,66 1280 720 Prog 3960 2680 750 30 18.750 25.000 74.250 62,67 1280 720 Prog 3300 2020 750 30 22.500 30.000 74.250 32,72 1920 1080 Prog 2750 830 1125 45 27.000 24.000 74.250 33,73 1920 1080 Prog 2640 720 1125 45 28.125 25.000 74.250 34,74 1920 1080 Prog 2200 280 1125 45 33.750 30.000 74.250 79 1680 720 Prog 3300 1620 750 30 18.000 24.000 59.400 80 1680 720 Prog 3168 1488 750 30 18.750 25.000 59.400 81 1680 720 Prog 2640 960 750 30 22.500 30.000 59.400 86 2560 1080 Prog 3750 1190 1100 20 26.400 24.000 99.000 87 2560 1080 Prog 3200 640 1125 45 28.125 25.000 90.000 88 2560 1080 Prog 3520 960 1125 45 33.750 30.000 118.800 93,103 3840 2160 Prog 5500 1660 2250 90 54.000 24.000 297.000 94,104 3840 2160 Prog 5280 1440 2250 90 56.250 25.000 297.000 95,105 3840 2160 Prog 4400 560 2250 90 67.500 30.000 297.000 98 4096 2160 Prog 5500 1404 2250 90 54.000 24.000 297.000 99 4096 2160 Prog 5280 1184 2250 90 56.250 25.000 297.000 100 4096 2160 Prog 4400 304 2250 90 67.500 30.000 297.000 17,18 720 576 Prog 864 144 625 49 31.250 50.000 27.000 19,68 1280 720 Prog 1980 700 750 30 37.500 50.000 74.250 20 1920 1080 Int 2640 720 1125 22.51 28.125 50.000 74.250 21,22 1440 576 Int 1728 288 625 24.51 15.625 50.000 27.000 23,24 1440 288 Prog 1728 288 312 24 15.625 50.080 27.000 23,24 1440 288 Prog 1728 288 313 25 15.625 49.920 27.000 23,24 1440 288 Prog 1728 288 314 26 15.625 49.761 27.000 TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 10 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. 2880 576 Int 3456 576 625 24.51 15.625 50.000 54.000 27,28 2880 288 Prog 3456 576 312 24 15.625 50.080 54.000 27,28 2880 288 Prog 3456 576 313 25 15.625 49.920 54.000 27,28 2880 288 Prog 3456 576 314 26 15.625 49.761 54.000 29,30 1440 576 Prog 1728 288 625 49 31.250 50.000 54.000 31,75 1920 1080 Prog 2640 720 1125 45 56.250 50.000 148.500 37,38 2880 576 Prog 3456 576 625 49 31.250 50.000 108.000 39 1920 1080 Int 2304 384 1250 85 31.250 50.000 72.000 82 1680 720 Prog 2200 520 750 30 37.500 50.000 82.500 89 2560 1080 Prog 3300 740 1125 45 56.250 50.000 185.625 96,106 3840 2160 Prog 5280 1440 2250 90 112.500 50.000 594.000 101 4096 2160 Prog 5280 1184 2250 90 112.500 50.000 594.000 1 640 480 Prog 800 160 525 45 31.469 59.9403 25.175 Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y 25,26 60Hz 2,3 720 480 Prog 858 138 525 45 31.469 59.9403 27.000 4,69 1280 720 Prog 1650 370 750 30 45.000 60.0003 74.250 5 1920 1080 Int 2200 280 1125 22.51 33.750 60.0003 74.250 6,7 1440 480 Int 1716 276 525 22.51 15.734 59.9403 27.000 8,9 1440 240 Prog 1716 276 262 22 15.734 60.0543 27.000 8,9 1440 240 Prog 1716 276 263 23 15.734 59.8263 27.000 10,11 2880 480 Int 3432 552 525 22.51 15.734 59.9403 54.000 12,13 2880 240 Prog 3432 552 262 22 15.734 60.0543 54.000 12,13 2880 240 Prog 3432 552 263 23 15.734 59.8263 54.000 14,15 1440 480 Prog 1716 276 525 45 31.469 59.9403 54.000 16,76 1920 1080 Prog 2200 280 1125 45 67.500 60.0003 148.500 35,36 2880 480 Prog 3432 552 525 45 31.469 59.9403 108.000 83 1680 720 Prog 2200 520 750 30 45.000 60.0003 99.000 90 2560 1080 Prog 3000 440 1100 20 66.000 60.0003 198.000 97,107 3840 2160 Prog 4400 560 2250 90 135.000 60.0003 594.000 102 4096 2160 Prog 4400 304 2250 90 135.000 60.0003 594.000 (CEC-861-F, March 2013) Table 3. 4K x 2K video formats Pa HDMI_VIC 0x01 Description Pixel Freq (MHz) 4K x 2K 297.000 29.97, 30Hz 296.703 Hactive Hblank 3840 560 Vfreq (Hz) Vactive Vblank 30.000 2160 90 29.970 0x02 4K x 2K 25Hz 297.000 3840 1440 25.000 2160 90 0x03 4K x 2K 297.000 3840 1660 24.000 2160 90 23.98, 24Hz 296.703 4K x 2K 24Hz 297.000 2160 90 0x04 23.976 4096 1404 24.000 (SMPTE) (HDMI Specification Version 1.4b, October 11, 2011) TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 11 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. Table 4. DisplayPort to HDMI 3D video formats mapping and list DisplayPort 3D Video Formats HDMI 3D Video Formats Stacked Frame Framing packing Frame Sequential Framing packing Pixel Interleaved (Line interleave only) Line alternative Side-by-Side (Full mode) Side-by-Side (Full) VIC Description Hactive Hblank Vactive Vact_space Vblank Pixel freq (MHz) V freq (Hz) Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y 3D Structure 0000 32 Frame Packing 1080p, 1920 830 1080 45 45 148.35/148.50 23.976/24.000 1280 370 720 30 30 148.35/148.50 59.940/60.000 23.98/24Hz 4 720p, 59.94/60Hz 0010 19 720p, 50Hz 1280 700 720 30 30 148.50 50.000 16 1080p 1920 280 1080 n.a. 45 297.00 60.000 31 1080p 1920 720 1080 n.a. 45 297.00 50.000 1920 280 1080 n.a. 45 297.00 60.000 1920 720 1080 n.a. 45 297.00 50.000 Line alternative 60Hz 50Hz 0011 16 Side-by-Side(Full) 1080p 60Hz 31 1080p 50Hz (HDMI Specification Version 1.4b, October 11, 2011) Note: All the supported 3D video formats in the mapping table can support all the timing data rates less than 3.0Gbps, Pa the timing list table only shows some examples. TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 12 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. POWER ON HARDWARE CONFIGURATION The configuration mechanism is through configuration pin as shown in Table 5. Table 5. Power On Configuration Configuration Signal I2C_ADDR Purpose Control I2C address selection Definition ‘0’: 10h – 2Fh (default) Pa Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y ‘1’: 90h – 9Fh, D0h – DFh TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 13 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. VDD12_ON DRX0N DRX0P DP_HPD DRX1N DRX1P VDDRX12 DRX2P VDDRX12 DRX2N DRX3P VDD33 HDMID2P HDMID2N HDMI_HPD HDMID1P VDDTX12 HDMID1N HDMID0P VDDTX12 HDMID0N HDMICKP HDMICKN Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y DRX3N PIN ASSIGNMENT & DESCRIPTION Pa Figure3. PS176 PIN Assignment TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 14 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. Table 6. PS176 Pin Descriptions Pin# Pin Name I/O Type I/O Dir Description DRX0P ANALOG I DP Main Link: DP_Lane0_p 39 41 DRX0N DRX1P ANALOG ANALOG I I DP Main Link: DP_Lane0_n DP Main Link: DP_Lane1_p 42 DRX1N ANALOG I DP Main Link: DP_Lane1_n 44 DRX2P ANALOG I DP Main Link: DP_Lane2_p 45 DRX2N ANALOG I DP Main Link: DP_Lane2_n 47 48 DRX3P DRX3N ANALOG ANALOG I I DP Main Link: DP_Lane3_p DP Main Link: DP_Lane3_n 34 AUXP ANALOG I/O DP AUX_p 33 AUXN ANALOG I/O DP AUX_n 40 DP_HPD ANALOG O DP RX Hot Plug Detect 14 HDMICKP ANALOG O HDMI Tx clock channel positive 13 HDMICKN ANALOG O HDMI Tx clock channel negative 17 16 20 19 HDMID0P HDMID0N HDMID1P HDMID1N ANALOG ANALOG ANALOG ANALOG O O O O HDMI Tx data channel 0 positive HDMI Tx data channel 0 negative HDMI Tx data channel 1 positive HDMI Tx data channel 1 negative 23 HDMID2P ANALOG O HDMI Tx data channel 2 positive 22 7 HDMID2N DDC_SCL ANALOG Schmitt, OD O I/O HDMI Tx data channel 2 negative HDMI DDC CLK 8 DDC_SDA Schmitt, OD I/O HDMI DDC DATA 21 HDMI_HPD LVTTL I 9 HDMI_CEC ANALOG I/O 36 REXT ANALOG I Connection to external resistor. 35 RESETB Schmitt I Reset; ACTIVE LOW 4 PDB Schmitt I Power down; ACTIVE LOW 2 37 TESTMODEB VDD12_ON Schmitt DIG I O Test mode control, NC for normal operation Signal to active 1.2V power supply; Active High Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y 38 HDMI Hot Plug Detect HDMI CEC (Optional) Internal pull-up at 27kΩ 29 CSCL Schmitt, OD I/O Control I2C slave clock for debugging use 28 CSDA Schmitt, OD I/O Control I2C slave data for debugging use XTLI ANALOG I Crystal oscillator clock input; 25 XTLO ANALOG O Crystal oscillator clock output; Pa 26 I2C slave address selection Internal pull-down at ~80kΩ General Purpose I/O Internal pull-up at ~80kΩ General Purpose I/O Internal pull-up at ~80kΩ General Purpose I/O Internal pull-up at ~80kΩ General Purpose I/O Internal pull-down at ~80kΩ 3 I2C_ADDR LVTTL I/O 5 GPIO1 LVTTL I/O 27 GPIO2 LVTTL I/O 10 GPIO3 LVTTL I/O 12 GPIO4 LVTTL I/O 31 AUXDCN ANALOG I DP source detection 32 AUXDCP ANALOG I DP source detection TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 15 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. VDD33 VDD33 VDDRX12 VDDRX12 VDDA12 VDD12 VDD12 PWR PWR PWR PWR PWR PWR PWR 3.3V VDD Power Supply 3.3V VDD Power Supply 1.2V VDD for DP receiver 1.2V VDD for DP receiver 1.2V VDD for analog 1.2V VDD for digital logic 1.2V VDD for digital logic 15 VDDTX12 PWR 1.2V VDD for HDMI transmitter 18 VDDTX12 EPAD PWR 1.2V VDD for HDMI transmitter Ground Pa Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y 1 24 43 46 11 6 30 TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 16 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. ABSOLUTE MAXIMUM RATINGS Parameters Comments Min Typ Max Unit Supply Voltage Range: -0.5 4 V VDDRX12, VDDA12, VDD12, VDDTX12 -0.5 1.45 V Normal I/O Voltage Range -0.5 4 V Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y VDD33 TJ Junction temperature TS Storage temperature ESD -40 125 °C 150 °C Human Body Model V Machine Model V Charged Device Model V ESD Standard: Human Body Mode: JESD22-A114-D Machine Mode: JESD22-A115-A Charged Device Mode: JESD22-C101-A Pa Latch-up Standard: JESD78; I-Test: +/- 200 mA; V-Test: 1.5X of Vcc TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 17 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. NORMAL OPERATING CONDITIONS Parameter Min Typ Max Unit VDD33 3.0 3.3 3.6 V VDDRX12, VDDA12, VDD12, VDDTX12 1.14 1.2 1.26 V Supply Voltage: Operation Temperature: 0 70 °C Tc - Case Temperature 0 85 °C Pa Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y Ta - Ambient Temperature TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 18 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. POWER CONSUMPTIONS Parameter Conditions DP input 4lane/5.4Gbps, HDMI output 5.94Gbps Typ Max Unit Tested at VDD33 = 3.3V 1.2V Normal Supply Current, IDD Min 432.2 mA 18.5 mA 16.8 mA 16 mA 1.2V Normal Supply Current, IDD 0 uA 3.3V Normal Supply Current, IDD 70 uA 1.2V Normal Supply Current, IDD 0 uA 3.3V Normal Supply Current, IDD 30 uA 579.7 mW 73 mW 0.23 mW 0.1 mW VDDRX12 = 1.2V 3.3V Normal Supply Current, IDD VDDA12 =1.2V Standby when DPCD600h = 02h VDD12=1.2V 1.2V Normal Supply Current, IDD Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y VDDTX12=1.2V 3.3V Normal Supply Current, IDD Auto Power Down Power down when PDB pin is asserted DP input 4lane/5.4Gbps, HDMI output 5.94Gbps Power consumption Standby when DPCD600h = 02h Power consumption Auto Power Down Power consumption Power down when PDB pin is asserted Pa Power consumption TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 19 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. PACKAGE DISSIPATION RATINGS 48-pin QFN Still air, 4-layer PCB 28.5 C/W θJC - Junction to Case Thermal Resistance 12.1 C/W Maximum Power Dissipation Rating, Ta = 70 °C 1930 mW Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y θJA - Junction to Ambient Thermal Resistance I/O DC CHARACTERISTICS Parameter Test Conditions Min Typ Max Unit I2C pins: CSCL/CSDA VOH High-level output voltage External 1.5 kΩ pull-up to VOL Low-level output voltage VDD33, IOL = 8 mA VDD33 V 0.4 V Control input pin: RESETB, PDB VIH Input High-level voltage VIL Input Low-level voltage 0.7VDD33 V 0.25VDD33 V Status I/O pins: GPIOx (x= 1~4) High-level output voltage VOL Low-level output voltage 0.8VDD33 V 0.15VDD33 V Pa VOH TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 20 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. I/O AC CHARACTERISTICS Parameter Test Conditions Min Typ2 Max Unit +10 ms +10 ms +10 ms 6 ns 6 ns 1.0 ms Supply ramp up time: (both supplies ramp at the same starting point) t3.3 3.3V supply ramp up time 10% to 90% of the 3.3V supply voltage 10% to 90% of the 1.2V 1.2V supply ramp up time Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y t1.2 supply voltage dt VDD33 and VDD12 power ramp up separation Time difference between -10 the mid points of VDD33 and VDD12 Status output pins: GPIOx (x=1~4) tr Output rise time tf Output fall time CL = 10 pF Hot plug detection pin: DP_HPD 0.5 Pa IRQ HPD pulse width (driven by sink device) TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 21 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y POWER UP AND RESET TIMING SEQUENCE Figure 4. Power Up and Reset Timing Sequence Pa Note: The de-assertion of the RESETB shall follow by the timing sequence as given in the above diagram. TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 22 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. DISPLAYPORT™ AUX CHANNEL CHARACTERISTICS Symbol and Parameter UI: Test Conditions Unit Interval for AUX channel VAUX-DIFF-p-p: AUX differential peak-to-peak voltage at TP1 Min Typ Max Unit 0.4 0.5 0.6 µs 400 900 mV 320 1360 mV 20 mA 200 nF When AUX CH is driving the bus Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y VAUX-DIFF-p-p: AUX differential peak-to-peak voltage at TP2 When AUX CH is receiving the bus AUX channel short circuit current CAUX: AUX AC coupling capacitor 75 Pa IAUX-SHORT: TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 23 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. DISPLAYPORT™ MAIN LINK RECEIVER CHARACTERISTICS Symbol and Parameter Test Conditions Min Spread spectrum clock, down-spreading by SOURCE Modulation Frequency VRX-DIFFp-p: Differential peak-to-peak input voltage at package pins Typ Max 0.5 Unit % 30 33 kHz 100 1360 mV 9 dB GND V Fo ra r V de IA Co In nf te ide rn n al tia U l: se O nl y Maximum adaptive RX equalization level at 1.35GHz VRX_DC_CM: RX input DC common mode voltage RRX-DIFF: Differential termination resistance 80 100 120 Ω RRX-SE: Single-ended termination resistance 40 50 60 Ω IRX_SHORT: Rx short circuit current limit 20 mA 50 ps 150 ps 300 ps LRX_SKEW_INTRA_PAIR: Intra-pair skew at Rx package pins (HBR2) RX intra-pair skew tolerance at HBR2 LRX_SKEW_INTRA_PAIR: Intra-pair skew at Rx package pins (HBR) RX intra-pair skew tolerance at HBR LRX_SKEW_INTRA_PAIR: Intra-pair skew at Rx package pins (RBR) RX intra-pair skew tolerance at RBR Receiver Jitter Tolerance for High Bit Rate 2 (HBR2) Total jitter tolerance at 2MHz 1026 mUI Total jitter tolerance at 10MHz 636 mUI Total jitter tolerance at 20MHz 624 mUI Total jitter tolerance at 100MHz 620 mUI Total jitter tolerance at 2MHz 1227 mUI Total jitter tolerance at 10MHz 548 mUI Total jitter tolerance at 20MHz 505 mUI Total jitter tolerance at 100MHz 491 mUI Total jitter tolerance at 2MHz 1648 mUI Total jitter tolerance at 10MHz 778 mUI Total jitter tolerance at 20MHz 747 mUI Pa Receiver Jitter Tolerance for High Bit Rate (HBR) Receiver Jitter Tolerance for Reduced Bit Rate (RBR) Note: Jitter Tolerance Testing follows VESA DisplayPort™ PHY Compliance Testing Specification, Version 1.2b. TEL: 408-329-5540 FAX: 408-329-5541 Email: Sales@paradetech.com For Customer Internal Use Only 24 PS176 DisplayPortTM-to-HDMI 2.0 Protocol Converter Parade Technologies Inc. HDMI TRANSMITTER CHARACTERISTICS Symbol and Parameter Test Conditions Min Typ Max Unit AVcc = 3.3V, RT = 50 Ω 800 1000 1200 mV AVcc+10 mV 1.65GHz
PS176 价格&库存
很抱歉,暂时无法提供与“PS176”相匹配的价格&库存,您可以联系我们找货
