DB207S(60MIL)
DB207S(60MIL)
    BAOCHENG(宝乘)
    DBS
    DB207S(60MIL)
DB207S(60MIL) 数据手册
DB201S thru DB207S 2.0 A Single-Phase Glass Passivated Bridge Rectifiers Rectifier Reverse Voltage 50 to 1000V DB-S _ Features This series is UL listed under the Recognized Component Index, file number E142814 The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 Surge overload ratings to 50 amperes Ideal for printed circuit board application High temperature soldering guaranteed 260 C /5 seconds at 5 lbs (2.3kg) tension + ~ ~ 6.35 + 0.15 7.65 + 0.25 8.15 + 0.2 2.35 + 0.15 Mechanical Data 0.20 + 0.05 0.15 + 0.05 1.28 + 0.15 1.01 + 0.13 Case: Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: Marked on body Mounting Position: Any Weight: 0.33 grams (approx) 5.1 + 0.1 10.4 Max. Dimensions in millimeters ( 1mm =0.0394" ) Maximum Ratings & Thermal Characteristics Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz. For Capacitive load derate current by 20%. DB DB DB DB DB DB Parameter Symbol 201S 202S 203S 204S 205S 206S DB 207S unit 1000 V Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 Maximum RMS bridge input voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum DC blocking voltage Maximum average forward rectified output current at TA=40 C IF(AV) 2.0 A Peak forward surge current single sine-wave superimposed on rated load (JEDEC Method) IFSM 50 A I t 6.35 A sec ReJA 58 Rating for fusing ( t
DB207S(60MIL) 价格&库存
很抱歉,暂时无法提供与“DB207S(60MIL)”相匹配的价格&库存,您可以联系我们找货
