DF20F-2830SCFA
DF20F-2830SCFA
    HRS(广濑)
    特性:1mm的接触间距允许可靠的焊接和电缆端接。1mm的配合触点滑动确保有效的电气连接。重新设计的金属配件减小了板载插座的整体长度,并允许多个连接器首尾相连安装。直插式引脚排针配有一个5.4mm X ...
DF20F-2830SCFA 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 1 mm Pitch Double Rows Low Profile Board-to-Cable Connectors DF20 series Cable 5.4 Socket DF20A**DS-1C DF20F(G)**DP-1V(56) PCB DF20A**DS-1C Socket Cable 6.2 DF20F **DP-1H(59) Pin Header 5.5 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.8 Pin Header PCB ■Features Narrower external width and length 1. Contact Pitch 1 mm contact pitch allows reliable solder and cable termination. 2. Reliable electrical connection wipe Effective electrical connection is assured with a 1mm wipe of mating contacts. 3. Narrower external width and length Redesigned metal fittings decreased the overall length of the board- mount receptacle and permit end-to-end mounting of several connectors. 4. Automatic equipment board placement Straight type pin headers are supplied with a 5.4 mm X 4.6mm flat platform to allow vacuum pick-up and placement on the board. Metal fitting 5. Product variations (1) Available with 10, 20, 30, 40, and 50 contacts. (2) Pin headers are available in two types: with or without board positioning bosses. (3) Depending on specific application pin headers can be ordered in straight or right angle types. ■Applications DF20F-****SCFA Contact Notebook PC, small office automation equipment, small consumer devices, portable devices. Any application requiring low profile reliable board-to-cable connection with a AWG #28, AWG#30, AWG#32 conductors. DF20A-**DS-1C Socket DF20F(G)-**DP-1V B266 1 Pin Header 1mm Pitch, Double Rows The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirosemm website RoHSDouble search at www.hirose-connectors.com, or contact your Hirose sales representative. DF20 Series●1 Pitch Rows Low Profile Board-to-Cable Connectors ■Product Specifications AWG#28 : 1A Operating temperature range -35°C to 85°C (Note 1,2) Storage temperature range -10°C to 60°C (Note 2) AWG#30 : 0.9A AWG#32 : 0.7A Storage humidity range -40% to 70% Rated voltage Operating humidity range -40% to 80% 100V AC Rated current Rating Item Specifications Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.Insulation resistance Conditions Measured at 100V DC 500Mø min. 2.Withstanding voltage No flashover or insulation breakdown Conduction of 300V AC applied for 1 minute 3.Contact resistance Measure at 100mA. 30Mø max. 4.Insertion-Extraction force 0.2 N Min., 2 N Max. 4.(per contact) Measured with a steel pin of 0.2 ±0.005 thickness 5.Vibration No electrical discontinuity of 1μs min. Frequency of 10 to 55 Hz, single amplitude of 0.75 mm, in 3 directions for 2hours 6.Humidity Contact resistance of 30mø max., insulation resistance of 100Mø min. Temperature of 40±2ç, humidity of 90% to 95%, left standing for 96 hours 7.Temperature cycle Contact resistance of 30mø max,insulation resistance of 500Mø min. (-55ç:30min / 5ç to 35ç: 2 to 3min / 85ç:30min / 5ç to 35ç:2 to 3min ) for 5 cycles 8.Mechanical operation Contact resistance of 30mø max. 50 cycles 9.Resistance to Soldering heat Reflow: At the recommended temperature profile, manual solder: Soldering iron temperature of 300°C for 3 seconds No deformation of the insulator parts that will affect performance Note1: Includes temperature rise caused by current flow. Note2: The term “storage” refers to products stored for long periods of time prior to mounting and use. Note2: Operating temperature range and Humidity range covers non-conducting conditions of installed connectors in storage, Note2: shipment or transportation. Note3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials Item Part Material Finish Remarks Socket Insulator Polyamide Color : Beige UL94V-0 Contact Phosphor bronze Gold plating ---------- Insulator Polyamide Color : Beige UL94V-0 Contact Phosphor bronze Gold plating ---------- Socket contact Pin header V type: Solder plating H type: Tin-Copper plating (Pb free) Brass Metal Fitting ■Ordering Information ●Connectors DF20 # - * DS - 1 C 1 2 3 4 1 Series name : DF20 2 Boss Type ■Pin header ■F: Without boss ■G: With boss ■Crimp socket: A 3 Number of contacts: 10, 20, 30, 40, 50 ●Contacts 5 6 4 Connector type DS: Double-row socket DP: Double-row pin header 5 Contact pitch: 1 mm 6 Type of housing, header 7 C: Crimp housing V: Straight SMT header H: Right angle SMT header DF20 F - 2830 SCF A 1 1 F 2 Applicable wire size 2830: AWG #28 to 30 3032: AWG #30 to 32 2 3 4 3 Contact & packaging type SCF: Socket contact reel 4 Plating type A: Gold plating (* *) 5 5 Packaging Specifications Blank: 1 reel = 10,000 pieces 41: 1 reel = 20,000 pieces B267 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, will be discontinued soon. Please checkBoard-to-Cable the products status onConnectors the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF20 Series●1 mm PitchorDouble Rows Low Profile ■Double Row Socket A B P=1 Contact No. 2 Contact No. 1 Contact No. * Contact No. * 5 4.28 Shown with terminated and installed contacts Contact No. 1 mark Part Number CL No. Number of Contacts A B DF20A-10DS-1C 686-0020-3 10 17.2 14.0 DF20A-20DS-1C 686-0021-6 20 12.2 19.0 DF20A-30DS-1C 686-0022-9 30 17.2 14.0 DF20A-40DS-1C 686-0023-1 40 22.2 19.0 DF20A-50DS-1C 686-0024-4 50 27.2 24.0 Unit: mm [Specifications number]-*, (**) RoHS (59): Gold plating, embossed tape packaging YES Note: Sales quantities are by the package unit (containing 100 pieces). Please order by package unit. ■Socket Crimp Contacts Product No. DF20F-2830SCFA(**) DF20F-3032SCFA(**) DF20F-36SCFA(**) CL No. 686-0042-6-** 686-0043-9-** 686-0051-7-** Type of contacts Quantity Plating type RoHS Reel contacts See specifications number column Gold plating YES [Specifications number] -*, (**) (04): 10,000 pieces / reel (44): 20,000 pieces / reel 1.45 0.7 ●Applicable Wire (Tin plated solid soft conductor) Jacket diameter AWG #28 (7/0.127 mm) AWG #30 (7/0.1 mm) 0.5mm to 0.6 mm 2 AWG #32 (7/0.08 mm) 0.9 Applicable Wire Size (Stranded wire conductor) 3.3 ●Recommended wire ●UL1571 ●Strip length ●1.2 to 1.9 mm 0.5 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.1 5th contact marking Note: When using other than the recommended wire, contact your nearest Hirose representative. ●Applicable Crimping Tools Type CL No. Product No. Applicator 901-4572-6 AP105-DF20-2830S Press 901-0005-4 CM-105 Note 1: Hirose Electric will not be responsible for any problems caused by use of tools other than specified. Note 2: The manual crimping tool can be also used for cutting-off individual contacts from the reel. Note 3: Customers that already have DF13 Series Hirose’s press units and applicators will be able to use them for DF20 Series crimp terminations by replacing of only crimper and anvil. Note4: The crimping tool for the DF20F-3032SCFA can also be used with the DF20F-2830SCFA. B268 ■Replacement Parts List for Applicator Type Product No. CL No. Insulation crimper AP105-DF20-2830S(61) 901-4572-6-61 Wire crimper AP105-DF20-2830S(62) 901-4572-6-62 Insulation anvil and wire anvil AP105-DF20-2830S(63) 901-4572-6-63 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirosemm website RoHSDouble search at www.hirose-connectors.com, or contact your Hirose sales representative. DF20 Series●1 Pitch Rows Low Profile Board-to-Cable Connectors ■ Double Row Straight Pin header B A Contact No.3 P=1 Contact No.1 Contact No. **-1 Indication of number of contacts Contact No. ** 6.4 0.2 0.7 4.6 5.4 Ø0.5 1.9 D C A 0.2 BPCB Footprints A ±0.05 P=1±0.03 0.9±0.05 Contact No. 1 marking 0.85±0.1 1.9±0.05 7.2 ±0.1 4±0.1 1.8 ±0.1 0.5±0.05 0.6±0.05 .1 +0 0 .7 Ø0 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.2 D±0.05 Note 1:Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Note 2: Required only for pin headers supplied with the positioning boss. Unit: mm Part Number CL No. No. of contacts A B C D DF20F -10DP-1V(56) CL686-0032-2-56 10 14.0 17.3 16.6 ---- DF20F -20DP-1V(56) CL686-0033-5-56 20 19.0 12.3 11.6 ---- DF20F -30DP-1V(56) CL686-0034-8-56 30 14.0 17.3 16.6 ---- DF20F -40DP-1V(56) CL686-0035-0-56 40 19.0 22.3 21.6 ---- DF20F -50DP-1V(56) CL686-0036-3-56 50 24.0 27.3 26.6 ---- DF20G-10DP-1V(56) CL686-0037-6-56 10 14.0 17.3 16.6 15.7 DF20G-20DP-1V(56) CL686-0038-9-56 20 19.0 12.3 11.6 10.7 DF20G-30DP-1V(56) CL686-0039-1-56 30 14.0 17.3 16.6 15.7 DF20G-40DP-1V(56) CL686-0040-0-56 40 19.0 22.3 21.6 20.7 DF20G-50DP-1V(56) CL686-0041-3-56 50 24.0 27.3 26.6 25.7 Note1: Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) Note2: Vacuum pick-up cap are included with embossed tape packaged connectors. Remarks RoHS Without boss YES With boss [Specifications number]-*, (**) (56): Gold plating, embossed tape packaging B269 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, will be discontinued soon. Please checkBoard-to-Cable the products status onConnectors the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF20 Series●1 mm PitchorDouble Rows Low Profile ■Double Row Right angle Pin header Contact No.1 Contact No.**-1 Contact No.3 Contact No.1 marking Contact No.** Contact No.2 5 ** 5.5 Indication of number of contacts A P= 1 0.2 6.2 A 0.2 C +0.1 0 1.4 2.45 +0.1 0 3.8 ±0.05 1.4 +0.1 0 BPCB Footprints 2.75 ±0.05 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B 0.6 ±0.05 P= 1 ±0.03 A ±0.05 0.75 ±0.1 C ±0.1 Note : Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Unit: mm Part Number CL No. No. of contacts A B C DF20F -10DP-1H(59) 686-0027-2(59) 10 24.0 27.5 26.2 DF20F -20DP-1H(59) 686-0028-5(59) 20 29.0 12.5 11.2 DF20F -30DP-1H(59) 686-0029-8(59) 30 14.0 17.5 16.2 DF20F -40DP-1H(59) 686-0030-7(59) 40 19.0 22.5 21.2 Note:Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) B270 Remarks RoHS Without boss YES [Specifications number]-*, (**) (59): Gold plating, embossed tape packaging The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirosemm website RoHSDouble search at www.hirose-connectors.com, or contact your Hirose sales representative. DF20 Series●1 Pitch Rows Low Profile Board-to-Cable Connectors BEmbossed Carrier Tape Dimensions ●Straight pin header Ø1 12 ±0.1 +0 0 .1 A ±0.3 B ±0.1 0.2±0.05 R0. 7 5 1.7 +0.15 0 1.5 (0.4) +0.1 0 Unreeling direction (7.9) 4±0.1 1.75 ±0.1 ●Right angle pin header 2±0.1 12±0.1 0.2±0.05 A ±0.3 R0 .75 1.7 +0.15 0 B ±0.1 C ±0.1 .1 +0 0 .5 Ø1 (0.4) 1.5 +0.1 0 (7.4) Unreeling direction ●Reel dimensions C D 16 -------- 17.5 16.4 DF20F(G)-20DP-1V(56) 20 24 -------- 11.5 24.4 DF20F(G)-30DP-1V(56) 30 32 28.4 14.2 32.4 DF20F(G)-40DP-1V(56) 40 44 40.4 20.2 44.4 DF20F(G)-50DP-1V(56) 50 44 40.4 20.2 44.4 DF20F - 10DP-1H(59) 10 16 -------- 17.5 16.4 DF20F - 20DP-1H(59) 20 24 -------- 11.5 24.4 DF20F - 30DP-1H(59) 30 32 28.4 14.2 32.4 DF20F - 40DP-1H(59) 40 44 40.4 20.2 44.4 2 ±0.5 Product name label Ø1.5 mm diameter feed hole depth Ø21 ± 0.8 Ø380 ±2 B 10 (Ø80) A DF20F(G)-10DP-1V(56) .2 No. of Contacts ±0 Part Number 2 ±0.5 D +2 0 Ø1 3 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C ±0.1 .5 1.75 ±0.1 2 ±0.1 4 ±0.1 B271 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, will be discontinued soon. Please checkBoard-to-Cable the products status onConnectors the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF20 Series●1 mm PitchorDouble Rows Low Profile BUsage recommendation 1. Recommended Soldering DF20F–*DP–1H(59) Temperature Profile for IR Reflow. 10(s) max Temperature 250 240 220 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 200 B272 Powered by TCPDF (www.tcpdf.org) 150 60 to 120(s) 60(s) max 100 60 120 180 240 300 Time(S) Note 1: Up to 2 cycles of reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature indicates the board surface temperature at the points of contacts with the connector terminals. 2. Recommended Manual Soldering Conditions Soldering temperature: 290°C ±10°C, Soldering time: within 3 sec. 3. Recommended Solder Screen Thickness 0.15mm 4. Board Warping Maximum of 0.03 mm at the connector center section, with both ends of the connector as reference points. 5. Cleaning Conditions Refer to "Nylon Connector Use Handbook." 6. Wiring Termination Conditions Refer to "Nylon Connector Use Handbook." Crimp contacts should be handled with care as not to cause any deformation or damage affecting the performance or termination. 7. Mating / un-mating precautions Excessive twisting and pulling on wires during mating/un-mating should be avoided as it may cause damage to connectors.
DF20F-2830SCFA 价格&库存
很抱歉,暂时无法提供与“DF20F-2830SCFA”相匹配的价格&库存,您可以联系我们找货
