KLJ-7525-3627
KLJ-7525-3627
    KELIKING(凯丽金)
    SMD
    KLJ-7525-3627
KLJ-7525-3627 数据手册
DESCRIPTION :SMD BUZZER PART :KLJ-7525-3627 NO. USER’S PART NO. : DATE :2012.05.09 CUSTOMER APPROVED : Approved By 明 华 Checked By 黄英姿 Made By 姚力波 常 州 市 凯 丽 金 电 子 有 限 公 司 CHANGZHOU KAILIJIN ELECTRONICS CO.,LTD 地址:常州市天宁区恒生科技园 1-1301 网址:www.kailijin.cn 邮箱:866@kailijin.cn 电话:0519-88671999-801 手机:13656128000 KLJ-7525-3627 DATE:2012.05.09 1﹒Electrical Characteristics Oscillation Frequency (Hz) Operating Voltage (Vp-p) Rated Voltage (Vp-p) VER .:0 2731 2.5 ~4.5 3.6 Current Consumption (mA/max.) 90 at Rated Voltage Sound Pressure Level (dB/min.) 85 at 10cm at Rated Voltage Coil Resistance (Ω) 16 ± 3 Operating Temperature (℃) -20 ~ +60 Storage Temperature (℃) -30 ~ +80 Environmental protection rule PS:Vp-p=1/2duty , square wave 2﹒Typical Frequency Response Curve ROHS 3﹒Dimensions and Material 3-1 Shape 3-2 Material Housing LCP plastic resin (Color : Black) Leading Pin Tin Plated Brass Weight (Gram) 0.6 4﹒Recommend Driving Circuit The base current Ib should high enough so that it saturates the collector current of the transistor with the CB load. 5. TESTING METHOD .Standard Measurement conditions Temperature:25±2℃ Humidity:45-60% .Acoustic Characteristics The oscillation frequency, current consumption and sound pressure are measured by the measuring instruments shown below. 10cm FUNCTION GENERATOR AMPERE METER SOUNDER MICROPHONE In the measuring test, buzzers is placed as follows: SAMPLE MICROPHONE 1OCM dB METER 6. RELIABILITY ITEMS Coldness withstanding Hotness withstanding Humidity withstanding METHOD OF TEST AND MEASUREMENTS After 98 hours of being exposed to -30℃ environment, should be returned to normal environment for 2 hours, then re-proceed to test. After 98 hours of being exposed to +80℃ environment, should be returned to normal environment for 2 hours, then re-proceed to test. After 98 hours of being exposed to 40℃ 95%RH environment in actual operation, should be returned to normal environment for 2 hours, then re-proceed to test. PERFORMANCE No abnormality shall exist No abnormality shall exist No abnormality shall exist Durability Testing after 1,000 hours actual continuous operation. (at standard measurement conditions) No abnormality shall exist Drop withstanding A natural drop from 75cm high down to the ground. No abnormality shall exist Vibration withstanding Vibration of 2,000 cycles per minute, 2mm amplitude, applied in X, Y and Z directions for 30 minutes each. No abnormality shall exist 7.Soldering Condition (1)Recommendable reflow soldering condition is as follows (Reflow soldering is twice) Note:It is requested that reflow soldering should be executed after heat of product goes down to normal. Heat resistant line (Used when heat resistant reliablity test is performed) (2)Manual soldering Manual soldering temperature 350 C within 10 sec. 8. PACKAGE METHOD CARRIER REEL 1K PCS BUZZER INNER BOX 1 ROLL CARRIER REEL CARTON BOX 10 INNER BOX 10K PCS BUZZER Unit:mm
KLJ-7525-3627
1. 物料型号:KLJ-7525-3627 2. 器件简介:常州市凯丽金电子有限公司生产的SMD BUZZER,产品规格书的批准日期为2012年5月9日。 3. 引脚分配:文档中未明确提供引脚分配信息,但提到了“+POLARITY”和“-POLARITY”,可能表示正负极性引脚。 4. 参数特性: - 振荡频率:2731 Hz - 工作电压:2.5 ~ 4.5 Vp-p - 额定电压:3.6 Vp-p - 最大电流消耗:90 mA(在额定电压下) - 声压级:85 dB(在10厘米处,额定电压下) - 线圈电阻:16±3 欧姆 - 工作温度:-20~+60°C - 存储温度:-30~+80°C - 环保规则:符合ROHS标准 5. 功能详解:文档中提供了典型频率响应曲线图,但没有详细描述功能。 6. 应用信息:文档中未明确提供应用信息。 7. 封装信息: - 外形尺寸:文档中提供了尺寸图,但未列出具体尺寸数值。 - 材料:外壳为黑色LCP塑料树脂,引脚为镀锡黄铜。 - 重量:0.6克。
KLJ-7525-3627 价格&库存
很抱歉,暂时无法提供与“KLJ-7525-3627”相匹配的价格&库存,您可以联系我们找货
