PA0805-R-470RL
PA0805-R-470RL
    YAGEO(国巨)
    贴片电阻 0805
PA0805-R-470RL 数据手册
DATA SHEET HIGH CURRENT ZERO OHM JUMPER PA series sizes 0100/ 0201/ 0402/ 0603/ 0805/ 1206/ 2010 Product specification– January 27, 2021 V.1 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SERIES PA 2 11 0100 to 2010 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes PA0100~2010 series jumper with metal alloy layer. Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. APPLICATIONS  Consumer goods  Computer  Telecom / Datacom  Industrial / Power supply  Alternative Energy  Car electronics GLOBAL PART NUMBER PA XXXX X X X XX 0R L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0100 / 0201 / 0402 / 0603 / 0805 / 1206 / 2010 (2) TOLERANCE - (3) PACKAGING TYPE FEATURES  PA Jumper resistors are designed to be used as a zero ohm jumper  AEC-Q200 qualified  Halogen-free Epoxy  RoHS compliant  Reduce environmentally hazardous wastes  High component and equipment reliability  Non-forbidden materials used in products/production  High current capability  Moisture sensitivity level: MSL 1 R = Paper taping reel (PA0100~1206) K = Embossed taping reel (PA2010) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - (5) TAPING REEL 07 = 7 inch dia. Reel 7W = 7 inch dia. Reel, (0402 only) 47 = 7 inch dia. Reel, (0805 only) (6) RESISTANCE VALUE 0R = 0 Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance code rule 0R (0 Ω) ORDERING EXAMPLE Example The ordering code for a PA0603 chip 0R = 0 Ω resistor, value 0 Ω, supplied in 7-inch tape reel with 5Kpcs quantify is: PA0603-R-070RL. NOTE 1. All our RChip products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead-Free Process" www.yageo.com Jan. 27, 2021 V1 Product specification Chip Resistor Surface Mount SERIES PA 3 11 0100 to 2010 MARKING PA0201 No Marking Fig. 1 Value = 0 Ω PA0100 / 0402 / 0603 / 0805 / 1206 / 2010 Fig. 2 Value = 0 Ω No Marking CONSTRUCTION The advanced resistive material is adopted to get the low resistance and is covered with a protective coat. Finally, the three external terminations (Cu / Ni / matte Tin) are added, as shown in Fig. 3. Outlines L W H I1 I1 Fig. 3 Chip resistor outlines www.yageo.com Jan. 27, 2021 V1 Product specification Chip Resistor Surface Mount SERIES PA 4 11 0100 to 2010 DIMENSION Table 1 For outlines, please refer to Fig. 3 TYPE L (mm) W (mm) H (mm) I1 (mm) PA0100 0.40± 0.03 0.20± 0.03 Max. 0.15 0.10± 0.03 PA0201 0.60± 0.03 0.31± 0.04 Max. 0.35 0.15± 0.06 PA0402 1.00± 0.10 0.55± 0.10 Max. 0.35 0.25± 0.10 PA0603 1.60± 0.20 0.8+0.10/-0.20 0.45± 0.15 0.38± 0.12 PA0805 2.00± 0.15 1.20± 0.15 Max. 0.40 0.35± 0.25 PA1206 3.05± 0.20 1.52± 0.20 0.50± 0.20 0.70± 0.20 PA2010 5.08± 0.20 2.54± 0.20 0.40± 0.15 0.70± 0.20 Note: 1. For relevant physical dimensions, please refer to construction outlines. 2. Please contact with sales offices, distributors and representatives in your region before ordering. ELECTRICAL CHARACTERISTICS Table 2 Resistance Value, Jumper Criteria Fig. 4 Max. (mΩ) Rated Current (A) Chip resistor outlines Rated Power (W) PA0100 PA0201
PA0805-R-470RL
物料型号:YAGEO PA系列,包含0100至2010尺寸的贴片电阻。
器件简介:PA系列跳线电阻设计用作零欧姆跳线,通过AEC-Q200认证,无卤素环氧树脂,符合RoHS标准。
引脚分配:文档中未明确提及引脚分配,但通常零欧姆跳线为单端引脚。
参数特性: - 电阻值:0Ω。 - 公差:文档中未明确指出,但通常为1%或5%。 - 额定电流和功率:不同尺寸的电阻有不同的额定电流和功率,如PA0100为8A和1/8W,PA2010为100A和2W。 - 工作温度范围:不同尺寸的电阻有不同的工作温度范围,如PA0100至PA0402为-55°C至+125°C,PA0603/PA0805为-55°C至+155°C,PA1206/PA2010为-55°C至+170°C。
功能详解:文档中未提供详细的功能描述,但零欧姆跳线通常用于电路中实现短路或连接。
应用信息:适用于消费类电子产品、计算机、电信/数据通信、工业/电源、替代能源和汽车电子。
封装信息:提供多种尺寸封装,如0100、0201、0402、0603、0805、1206和2010,且符合RoHS标准。
订购信息:全球零件编号由系列、尺寸、公差、包装类型、温度系数、胶带卷和电阻值确定。
PA0805-R-470RL 价格&库存
很抱歉,暂时无法提供与“PA0805-R-470RL”相匹配的价格&库存,您可以联系我们找货
PA0805-R-470RL
库存:5000
PA0805-R-470RL
  • 1+2.73170
  • 100+1.91210
  • 1000+1.28920
  • 2500+0.87020
  • 5000+0.61990
库存:50530
