UF07M
UF07M
    LGE(鲁光)
    SMF(SOD-123FL)
UF07M 数据手册
UF07A-UF07M High Efficiency Rectifiers REVERSE VOLTAGE: 50 - 1000 V CURRENT: 1.0A SOD-123FL Features    Low forward surge current Ideal for surface mouted applications Low leakage current 0.114(2.9) 0.098(2.5)  Case:JEDEC SOD-123FL,molded plastic over passivated chip  Polarity: Color band denotes cathode end Weight: 0.006 ounces, 0.02 gram Mounting position: Any  0.008(0.20) 0.004(0.10) 0.047(1.19) 0.043(1.09) Mechanical Data  0.043(1.09) 0.035(0.89) 0.075(1.90) 0.067(1.70) 0.030(0.76) 0.018(0.45) 0.154(3.9) 0.138(3.5) Dimensions in inches and(millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase,half wave,60Hz,resistive or inductive load.For capactive load,derate current by 20%. ABSOLUTE RATINGS Device marking code UF 07A U1A UF 07B U1B UF UF 07D 07G U1D U1G UF 07J U1J UF 07K U1K UF 07M UNITS U1M Maximum recurrent peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum DC blocking voltage Maximum average forward rectified current @TA=75℃ I(AV) 1.0 A IFSM 20 A Peak forward surge current 8.3ms single half-sine-wave superimposed on rated load Maximum instantaneous forward voltage @IFM=0.7A (Note 1) VF Maximum DC reverse current @TA=25℃ Maximum reverse trr recovery time (Note 2) 1.7 10 µA 200 50 V 75 ns RθJA 180 ℃/W Tj - 55 --- + 150 ℃ TSTG - 55 --- + 150 ℃ Operating temperature range Storage temperature range 1.4 IR at rated DC blocking voltage @T A=125℃ Typical thermal resistance junction to lead 1.0 NOTE1.Pulse test: pulse width 300µsec,duty cycle 2%. 2.Measured with IF=0.5A,IR=1.0A,Irr=0.25A. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com UF07A-UF07M High Efficiency Rectifiers Ratings AND Charactieristic Curves 1.0 .8 .6 .4 Single Phase Half Wave 60Hz Resistive or Inductive Load .2 0 0 25 50 75 100 FIG. 2 - MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT, A AVERAGE FORWARD CURRENT, A FIG. 1 - TYPICAL FORWARD CURRENT DERATING CURVE 125 150 175 25 20 15 10 5 8.3ms Single Half Sine-Wave (JEDED Method) 0 1 AMBIENT TEMPERATURE, INSTANTANEOUS REVERSE CURRENT, uA INSTANTANEOUS FORWARD CURRENT, A TJ =25 Pulse Width=300 µS 1.0 0.1 0.01 UF07J-UF07M UF07A-UF07D 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 INSTANTANEOUS FORWARD VOLTAGE, V 40 60 80 100 100 50 T J = 100 10 5 1 .5 TJ = 25 .1 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, % PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123FL 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 20 FIG. 4 - TYPICAL REVERSE CHARACTERISTICS UF07G 10 6 8 10 4 NUMBER OF CYCLES AT 60Hz FIG. 3 - TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 100 2 www.lgesemi .c o m mail:lge@lgesemi.com
UF07M 价格&库存
很抱歉,暂时无法提供与“UF07M”相匹配的价格&库存,您可以联系我们找货
UF07M
  • 20+0.17464
  • 200+0.13695
  • 600+0.11600
  • 3000+0.09926
  • 9000+0.08846
  • 21000+0.08252
库存:2180
