KAN0741-0601M1
KAN0741-0601M1
    GANGYUAN(港源)
    SMD8_7.3X7.3MM
    KAN0741-0601M1
KAN0741-0601M1 数据手册
APPROVAL SPECIFICATIONS Title. TACT SWITCH Product Model. KAN0741-0601M1 Customer’s Part NO. Customer’s Model: Customer’s Approval Requested. Please return this copy as a certification of your approval. Checked by: Date: Approved by: Date: APPROVE REVIEW Jack Wu 孙斌 Shenzhen Gangyuan Microkey Technology Co.,ltd POLT 张杰 GANGYUAN CUSTOMER CUSTOMER’S P/N APPROVAL SPECIFICATIONS GYE’S P/N KAN0741-0601M1 PRODUCT REVISION TACT SWITCH A 1、 概述 GENERAL 1.2 适用范围 APPLICATION 此规格书适用于机械式轻触开关的相关要求 This specification is applied to the requirements for TACTILE SWITCH (MECHANICAL CONTACT) 1.3 工作温度范围 Operating Temperature Range -20℃~70℃(在标准大气压、标准湿度条件下) -20℃~70℃(Normal humidity, normal air pressure) 1.4 贮藏温度范围 Storage Temperature Range -30℃~80℃(在标准大气压、标准湿度条件下) -30℃~80℃(Normal humidity, normal air pressure) 1.5 测试条件 Test Conditions 在没有其它特定的条件下,应该在以下的条件下进行测试和测量: Unless otherwise specified, tests and measurement shall be made in the following standard conditions: 常温…………………………………5℃~35℃ Normal temperature………………5℃~35℃ 标准湿度……………………………相对湿度 25%~85% Normal humidity…………………relative humidity 25%~85% 标准大气压…………………………86KPa~106Kpa Normal air pressure…………………86Kpa~106Kpa 在制造过程中,测试和测量应该在以下的条件下进行: If any doubt arise from the judgment, tests shall be conducted at the following conditions: 温度…………………………………20℃±2℃ Temperature………………………20℃±2℃ 相对湿度……………………………65%±5% Relative humidity………………65%±5% 环境气压…………………………86KPa~106Kpa Air pressure…………………………86KPa~106Kpa Page 1 of 9 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER 2、 CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A 详细说明 Detailed specification 2.1 外观:应无影响、降低产品性能的缺陷; Appearance: There should be no defects that affect the serviceability of product. 2.2 结构尺寸和安装尺寸:应符合装配图要求; Style and dimension: shall conform to the assemble drawings. 2.3 操作形式:按钮式:中间方向和边上四个方向(如成品图所示). Push Button: Center and 4-directional (as assembly drawing). 2.4 开关结构:单回路单输出(具体的触点结构在装配图中已绘出); Contact arrangement: 1 pole, 1 throw (Details of contact arrangement are given in the assembly drawings.) 2.5 开关工作额定值:DC 12V,50mA(有效值) Ratings: 12V DC, 50mA (effective value) 3.电气性能: ELECTRICAL SPECIFICATION 项 目 试 验 条 件 ITEM TEST CONDITIONS 要求 REQUIREMENTS 在以 5V 10mA 的直流电源或不低于 1KHz 的交流电源 的电路中,以一个等于 2 倍按力的静负荷施加于手柄中心 1 2 接触电阻 Contact Resistance 常态 Normal 100mΩ max Applying a static load of 2 times operating force to 气候及寿命试验后 the center of the stem, measurements shall be made by after weather and life 5V DC 10mA or more than 1KHZ AC small-current proof: 200mΩ max contact resistance meter. 绝缘电阻 在端子之间施加 DC 500V /1min 的条件下,测量端子 之间底座、盖板的电阻值 Insulation Measurement shall be made following application of Resistance 100V DC potential, across terminals, and across terminals and cover, for one minute. 介质耐压 3 Dielectric voltage proof 在端子之间施加 250V AC(50HZ 或 60HZ)/1min 250V AC (50HZ or 60HZ) shall be applied across terminals, for one minute. 常态 Normal 100MΩ min 气候及寿命试验后 after weather and life proof: 10MΩ min 无击穿、无飞弧 There should be no breakdown and flashover Page 2 of 9 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A 项目 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 按照正常使用时的力度轻按手柄中心(每秒 3~4 次), 在导通和断开过程中测试开关抖动 Lightly striking the center of the stem at a rate encountered in normal use (3 to 4 times per second), and bounce shall be tested at “ON” and “OFF” 开关 Switch 4 触点抖动 Bounce 5V DC 10KΩ “导通” “ ON” 示波器 Oscillograph ON-3msec.max OFF-8msec.max “ 断开” “OFF” 4.机械性能: MECHANICAL SPECIFICATION 按规定的操作方法给操作柄施加压力 Push by recommended operating condition. PUSH 1 中间方向 center: 360±90 gf 边上四个方向 4-directional: 230±50gf 按力 Operating Force CENTER 4-DIRECTIONAL Page3 of 9 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A 项目 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 开关发生转换后,操作元件末端与初始位置之间的距离。 Distance from the end of operating component to the start position when switch is being transformed . PUSH 2 3 最大行程 Full Travel 回弹力 Return Force 4 停止强度 Stop Strength 5 操作件强度 Operating Part Strength 6 可焊性 Solderability PUSH 开关垂直于操作方向放置,在开关驱动件顶端中心下降至全行程 后,测量顶端向自由位置转换的力度。 The sample switch is installed such that the direction of switch operation is vertical and upon depressing the stem in its center to the whole travel distance, the force of the stem to return to its free position shall be measured. 中心正按 Center push: 0.15±0.10 mm 四边侧按 4-dir leaning: 0.25±0.10 mm 中间方向 center: 1.0 N.Min 边上四个方向 4-directional:0.8 N.Min 开关垂直于操作方向放置,从操作方向向驱动件施加 30N 的静负 荷持续 1min。 Placing the switch such that the direction of switch operation is vertical, and then a static load of 30N shall be applied in the direction of stem operation for a period of 1 min. 无机械和电气损坏 There shall be no sign of damage mechanically and electrically. 置开关于正常安装位置,在操作件中心施加与操作件动作相同 方向的 1 kgf 静负荷,时间为 60 S。 Put the switch in the normal gearing position, Bring 1 kgf pressure which direction is similar to the actuator operates direction in the tip of the actuator center, time is 60S. 无机械和电气损坏 There shall be no sign of damage mechanically and electrically. 在以下设定条件下进行测量: Measurements shall be made following the test set forth below: (1) 焊接温度:245±5℃ Solder temperature : 245±5℃ (2) 浸入时间:2s±0.5s Immersion time: 2s±0.5s 对于其它步骤参考《GB 5095.6—86》试验 12a The other steps please refer to《GB 5095.6-86》TEST 12a 除边缘外涂层应均匀覆盖 90%以上 Except for the edge, the coating should cover a minimum 90% Page 4 of 9 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A 项目 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 低温测试 Resistance to low temperature 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:-30±2℃ Temperature : -30±2℃ (2) 时间:96h Time: 96h 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 高温测试 Heat resistance 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试:Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:80±2℃ temperature:80±2℃ (2) 时间:96h time: 96h 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 5、极限电气性能: ENVIRONMENTAL SPECIFICATION 1 2 根据下面的测试要求进行 5 次循环的温度周期性测试, 实验后 样品应放在常温及标准湿度的环境中 1 小时后做性能测试。测 试期间样品应保持干燥. After 5 cycles of following conditions, the sample shall be allowed to stand under normal temperature and humidity conditions for 1 h. and measurements shall be made. During the test water drops shall be removed. 1cycle 3 温度周期性测试 Change of temperature Temperature Time -10±2℃ 2(hour) -10~65℃ 1 65±2℃ 2 65~-10℃ 1 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 Page 5 of 9 GANGYUAN CUSTOMER 4 5 6 CUSTOMER’S P/N APPROVAL SPECIFICATIONS GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A 项目 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 湿温测试 Moisture resistance 硫化试验 Sulfuration resistance 盐雾试验 Salt Mist 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试:Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:60±2℃ temperature: 60±2℃ (2) 相对湿度:90%~95% relative humidity:90% to 95% (3) 时间:96h time: 96h 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试:Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) H2S 气体浓度:3ppm±1ppm H2S gas concentration: 3ppm±1ppm (2) 时间:72h Time: 72h (3) 温度:40±2℃(90~95%RH) temperature: 40±2℃(90~95%RH) 在以下设定条件下进行测量: The switch shall be checked after following test: (1)温度:35℃±2℃ temperature: 35℃±2℃ (2)盐溶液浓度:5±1%(质量百分比) salt solution : 5±1%(solids by mass) (3)时间:8h±1h Time: 8h±1 hour 实验后的盐沉积物后水冲掉 After test, salt deposit shall be removed by running water. 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 接触电阻:≤200mΩ Contact resistance: ≤200mΩ 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 金属件上没有腐蚀斑点 No remarkable corrosion shall be recognized in metal part. Page 6 of 9 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N 6、极限机械性能: ENDURANCE SPECIFICATION 项目 ITEM 1 2 GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A 试 验 条 件 要求 TEST CONDITIONS REQUIREMENTS 工作寿命 Operation life 根据下面的测试要求进行测试: Measurement shall be made following the test set forth below: 1, DC 12V,50mA 带负载 DC 12V, 50 mA resistive load 2, 按动速率:60 次/分钟 Rate of operation: 6 0 times/Min 3, 按力:按力的 1.5 倍 4, Operating Force: Operating Force1.5 倍 5, 寿命:100000 次 Llife: 10,0000 cycles 振动 Vibration 根据以下给定条件进行测试: Measurement shall be made following the test set forth below: (1) 振动频率范围:10~55~10Hz Vibration frequency range: 10 to 55 to 10Hz 项目 3,4.1,4.2,4.3 (2) 振幅(峰-峰):1.5mm Amplitude: 1.5mm Item 3,4.1,4.2,4.3 (3) 振动方向:包括手柄行程方向在内的三个相互垂直的方向 Direction of vibration:Three mutually perpendicular direction including the direction of stem travel (4) 测试时间:每次 2hours . Duration: Each 2hours. 接 触 电 阻 ≤200mΩContact resistance≤200mΩ 按 力 : 初 值 的 ±30% Operating Force: initial value±30% 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 开关应在实验后测量 Switch shall be measured after following test. 1.安装方法:正常安装 Mounting method: Normal mounting method 3 Shock 2.加速 490 m/s2(50G) Acceleration:490 m/s2 (50 G) 3.持续时间:11 ms Duration:11 ms 4.测试方向:6 个方向 Test direction: 6 directions 项目 3,4.1,4.2,4.3 Item 3,4.1,4.2,4.3 5.冲击次数:每个方向 3 次(18 次计) Number of shocks: 3 times per direction ( 18 times in total) 7.焊接条件: SOLDERING CONDITIONS: 7.1 手工焊接 Hand soldering 请按以下条件进行焊接: Please practice according to below conditions: (1) 焊锡温度:≤350℃ Soldering temperature: (2) 连续焊接时间:≤3 s Continuous soldering time: 3 s Max. 350℃ Max. Page 7 of 9 GANGYUAN CUSTOMER CUSTOMER’S P/N APPROVAL SPECIFICATIONS GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A 回流焊 7.2 Conditions for reflow 焊接说明: 1、开关浸焊后,注意不要用溶剂清洗。 After switches were soldered,please be careful not to clean switches with solvent. 1.1 在使用烙铁的情况下,焊锡温度应在 350℃以下、3 秒以内。 In the case of using solding iron, solding conditions shall be 350℃ max and 3 sec.max. 1.2 浸焊后,注意不要在顶部施加负荷。 Right after switches were soidered;please be careful not to load to on the knobs of switches. 2、设计中应注意的事项( Design instructions) 2.1 印刷基板的安装孔尺寸参见产品图。 Follow recommended P.W.B. piercing plan in outside drawing page. 3、注意点(Note): 3.1 注意不要施加超负荷的压力或晃动开关。 Please be cautions not to give excessive static load or shock to swiches. 3.2 开关浸焊后,印刷基板注意不要叠放。 Please be careful not to pile up P.W.B.after switches were soldered. 3.3 保管时尤其应注意避开高湿高温和有腐蚀性气体的环境。如需要长时间保存,请不要 打开包装箱。 Preservation under high temperature and high high humidity or corrosive gas should be avoided Especially . When you need to preserve for a long period ,do not open the carton. Page 8 of 9 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION KAN0741-0601M1 TACT SWITCH A General tolerance:±0.2mm NO. NAME MATERIAL QTY. FINISHING 1 STEM 1 LCP 1 Black 2 STEM 2 LCP 1 Black 3 COVER Ni/C7521 1 4 CASE LCP 1 Black 5 MEMBRANE KAPTON 1 Yellow 6 CONTACT Ag/SUS 6 Ag 7 TERMINAL Brass 6 Ag Page 9 of 9
KAN0741-0601M1 价格&库存
很抱歉,暂时无法提供与“KAN0741-0601M1”相匹配的价格&库存,您可以联系我们找货
KAN0741-0601M1
    • 1+3.70440
    • 10+2.70216
    • 30+2.12544
    • 100+1.84896
    • 500+1.65024
    • 800+1.57248
    库存:514
