VLP-02V-1
VLP-02V-1
    JST
    P=6.2mm
    胶壳 间距P=6.20mm 2Pin(1x2)
VLP-02V-1 数据手册
VL CONNECTOR (HIGH CURRENT TYPE) 6.2mm pitch/Disconnectable Crimp style connectors (Combined use for both wire-to-board and wire-to-wire connections) Specifications ––––––––––––––––––– • Current rating: 23 A AC, DC (Refer to the following table.) • Voltage rating: 600 V AC, DC • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 7 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 2,000 VAC/minute • Applicable wire: AWG #20 to #12 • Applicable PC board thickness: 1.6 mm Note: Do not branch in parallel current which exceeds the rated current (e.g. more than 22 A in the case of 3 circuits with AWG #12). If branched in parallel, current imbalance or other problems may develop. If it is absolutely necessary to branch such a large current in parallel, design the circuits without causing any imbalance and provide an extra margin for each circuit. Note: The current rating differs depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit: A This VL connector is 6.2 mm pitch wire-towire and wire-to-board connector, designed for large current. The connector suitable for the large electric current has been realized by using highly-conducting material, so that the connection of large current circuit enables. • Housing lances • Retainer • Suited for large current • Compatible for both wire-to-wire and wire-toboard connections No. of circuits #12 #14 Wire size (AWG) #16 #18 #20 2 23 18 15 11 9 3 22 17 14 10 8 4 21 16 13 9 8 * The current rating mentioned above is applied only in the combination of contact and header for high current. When either is a normal product, please be careful because the current rating of the normal product is applied. * In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * Contact JST for details. * RoHS2 compliance Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R9351103 PC board layout and Assembly layout Outer-housing lock φ2.1 ±0.05 3.6 min 6.2 ±0.05 (21.7) (29.2) A±0.1 6.2 ±0.05 3.4 min (15.6) (29.2) ±0.05 6.84 min φ2.1 3.6 min ±0.05 A ±0.1 8.28 Note: 1. The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 VL CONNECTOR (HIGH CURRENT TYPE) Contact Applicable wire AWG # mm2 Model No. Q’ty/ reel 0.5∼2.0 20∼14 1.9∼3.4 2,000 3.5 12 4.1 2,000 4.1 SVSF-61T-P2.0 SVSF-81T-P2.0 Insulation O.D. (mm) Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance 16.7 3.6 2 1.7 MK/SVF/M-81-20 APLMK SVF/M81-20 MKS-L SVSF-81T-S2.0 − − − AP-K2N Crimp applicator with dies MK/SVF/M-61-20 APLMK SVF/M61-20 MKS-L SVSF-61T-S2.0 3.1 Applicator Dies Crimping machine Crimp applicator Contact − − − Note: Contact JST for fully automatic crimping applicator. Housing 15 3 4 8.4 5.2 1 5.2 15.4 L JST 3 1 2 1 5.2 4 L JST 1 3 2 L JST 8.4 25.8 8.4 19.6 L JST 15 2 13 13 13 13 11 11 11 11 5.2 2 6.2 6.2 6.2 6.2 Outer-housing lock No. of circuits 2 3 4 4 (Single-row) Model No. VLP-02V-1 VLP-03V-1 VLP-04V-1 VLP-04VN-1 Material PA 66, UL94V-0, natural (white) RoHS2 compliance 2 Q’ty/bag 500 500 500 500 VL CONNECTOR (HIGH CURRENT TYPE) Retainer 11.4 17.6 No. of circuits Model No. Q’ty/bag 2, 4 VLS-02V VLP-03V VLP-08V 1,000 3 9.4 9.4 4 (Single-row) 1,000 1,000 Material Glass-filled PA 66, UL94V-0, natural (ivory) 5.9 5.9 RoHS2 compliance 5.9 9.4 23.8 Header 11.2 18 15 B 8.2 3.6 3.6 16.4 16.4 B 1.8 1.6 1.8 1.6 4.84 6.2 8.28 6.2 2 A A 11.2 8.2 16.4 B No. of circuits Model No. B02P-VL-1 B03P-VL-1 B04P-VL-1 B04P-VL-VN-1 2 3.6 3 1.54 6.2 A 4 4 (Single-row) 1.33 5 Q’ty/box 100 100 100 100 Material and Finish 2 Post: Copper-alloy, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) RoHS2 compliance 3 VL CONNECTOR (HIGH CURRENT TYPE) Contact position location numbers Outer-housing lock 1 L JST 1 2 4 3 L JST 2 2 1 4 3 3 2 L JST 1 Model number identification Contact Housing Form: S --- Strip form, B --- Loose piece Series name Shape: F --- Socket contact Applicable wire: 61 --- AWG #20 to #14 81 --- AWG #12 Series name Surface finish: T --- Tin-plated (Reflow treatment) No. of circuits: 2, 3, 4 Material: S --- Copper alloy Flammability: V --- UL94V-0 Terminal size Shape: 1 --- Outer lock Header 4 Part name: Plug Retainer Assembly style: B --- Top entry type Series name No. of circuits: 2, 3, 4 Part name: Retainer Series name No. of circuits: 2, 3, 8 1: 1 --- High-current product Flammability: V --- UL94V-0 L JST
VLP-02V-1 价格&库存
很抱歉,暂时无法提供与“VLP-02V-1”相匹配的价格&库存,您可以联系我们找货
VLP-02V-1
    库存:2000
    VLP-02V-1
      • 500+0.62700
      库存:13000
      VLP-02V-1
        • 1+1.06401
        • 30+1.02601
        • 100+0.98801
        • 500+0.91200
        • 1000+0.87400
        • 2000+0.85120
        VLP-02V-1
          库存:8
