SUHR-04V-S-B
SUHR-04V-S-B
    JST
    P=0.8mm
    1X4P 0.8MM
SUHR-04V-S-B 数据手册
SUH CONNECTOR Emboss Emboss Tape Tape 0.8mm 0.8mm pitch/Disconnectable pitch/Disconnectable Crimp Crimp style style connectors connectors ● Headers are for common use with SUR connector. ● Current rating 1.0 A ● Miniaturization SUH CONNECTOR Specifications This SUH connector is developed for crimping type SUR connector that has been designed for 0.8 mm pitch wire-to-board insulation displacement connector. This connector adopted the first crimping method in a minimum 0.8 mm pitch of the wire-toboard type connector. Housing lance method provides the good workability and a constriction contact method provides the excellent contact reliability. ® • Current rating: 1.0 A AC, DC (AWG #28) • Voltage rating: 30 V AC, DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 50 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 200 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #28 Insulation O.D./ 0.5 to 0.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards ® ® Recognized E60389 Certified LR20812 ® PC board layout and Assembly layout Top entry type Side entry type 1.65 ±0.1 0.8 ±0.05 0.3 0.5 ±0.05 0.8 ±0.05 1 ±0.1 2.7 1.7 ±0.1 Connector outline 0.7 ±0.1 SUHコネクタ表1 2.2 1.2 ±0.1 0.35 ±0.1 1.1 ±0.1 0.5 ±0.05 2.75 4.15 1.7 ±0.1 4.1 1.75 Connector outline 1.65 1.2 2.3 ±0.1 ±0.1 ±0.1 0.7 ® 1.95 Note: 1 . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.03 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. Contact Model No. 2.52 SSUH-003T-P0.15 1.45 0.39 0.7 Applicable wire AWG# Insulation O.D. (mm) mm2 0.032 to 0.08 32 to 28 0.5 to 0.6 Q'ty/ reel 45,000 Material and Finish 0.75 Phosphor bronze, tin-plated (reflow treatment) 0.83 RoHS compliance Contact Crimping machine Crimp applicator SSUH-003T-P0.15 AP-K2N MKS-L-10-4 - Applicator Dies - Note: Contact JST for fully automatic crimping applicator. 1 Crimp applicator with dies MK/SSUH-003-015 APLMK SSUH003-015 - SUH CONNECTOR Housing No. of circuits With protrusions 1.65 1.4 C A 1.7 3.1 0.8 Circuit No.1 1.25 0.8 B Without protrusions A Model No. Without protrusions 2 With protrusions SUHR-02V-S-B 3 SUHR-03V-S-B 4 SUHR-04V-S-B 5 SUHR-02V-S Dimensions (mm) Q'ty/ box C B A 2.4 0.8 2,000 4.4 SUH CONNECTOR SUHR-03V-S 3.2 1.6 5.2 2,000 SUHR-04V-S 4.0 2.4 6.0 2,000 SUHR-05V-S-B SUHR-05V-S 4.8 3.2 6.8 2,000 6 SUHR-06V-S-B SUHR-06V-S 5.6 4.0 7.6 2,000 8 SUHR-08V-S-B - 7.2 5.6 9.2 2,000 10 SUHR-10V-S-B SUHR-10V-S 8.8 7.2 10.8 1,000 12 SUHR-12V-S-B SUHR-12V-S 10.4 8.8 12.4 1,000 14 SUHR-14V-S-B SUHR-14V-S 12.0 10.4 14.0 1,000 16 SUHR-16V-S-B SUHR-16V-S 13.6 12.0 15.6 1,000 17 SUHR-17V-S-B - 14.4 12.8 16.4 1,000 20 SUHR-20V-S-B SUHR-20V-S 16.8 15.2 18.8 1,000 Material 1.65 LCP, UL94V-0, natural Circuit No.1 1.7 3.1 RoHS compliance 0.8 1.25 B Header No. of circuits Top entry type B 2.7 2 0.6 A 1 Side entry type B A 0.8 1 0.2 3 BM03B-SURS-TF SM03B-SURS-TF 1.6 4.6 2,500 3,500 4 BM04B-SURS-TF SM04B-SURS-TF 2.4 5.4 2,500 3,500 5 BM05B-SURS-TF SM05B-SURS-TF 3.2 6.2 2,500 3,500 6 BM06B-SURS-TF SM06B-SURS-TF 4.0 7.0 2,500 3,500 8 BM08B-SURS-TF SM08B-SURS-TF 5.6 8.6 2,500 3,500 10 BM10B-SURS-TF SM10B-SURS-TF 7.2 10.2 2,500 3,500 12 BM12B-SURS-TF SM12B-SURS-TF 8.8 11.8 2,500 3,500 14 BM14B-SURS-TF SM14B-SURS-TF 10.4 13.4 2,500 3,500 16 BM16B-SURS-TF SM16B-SURS-TF 12.0 15.0 2,500 3,500 17 BM17B-SURS-TF SM17B-SURS-TF 12.8 15.8 2,500 3,500 20 BM20B-SURS-TF SM20B-SURS-TF 15.2 18.2 2,500 3,500 Material and Finish 2.7 Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 1.75 Circuit No.1 2 Model No. Dimensions (mm) Q'ty/reel Side entry type Top entry type A B Top type Side type 0.8 3.8 2,500 3,500 BM02B-SURS-TF SM02B-SURS-TF RoHS compliance This product displays (LF)(SN) on a label. Note: These products listed above are supplied on embossed-tape. 1 0.45 2 SUH CONNECTOR Model number allocation Contact Housing S SUH - 003 T - P 0.15 Form: S…Strip form Series name Series name Part name: Socket Applicable wire range: 003…AWG #32 to #28 No. of circuits: 2 to 6, 8, 10, 12, 14, 16, 17, 20 Surface finish: T…Tin-plated (reflow treatment) Flammability: V…UL94V-0 Material: P…Phosphor bronze Color: Natural Terminal size Shape: B…With protrusion, None…Without protrusion Header SM 02 B - SUR S - TF Shape of assembled product: BM…SMT top entry type SM…SMT side entry type No. of circuits: 2 to 6, 8, 10, 12, 14, 16, 17, 20 Part name: Header Series name Color: S…Natural Packaging style: TF…Embossed-taping 3 SUH R - 02 V - S - B
SUHR-04V-S-B 价格&库存
很抱歉,暂时无法提供与“SUHR-04V-S-B”相匹配的价格&库存,您可以联系我们找货
SUHR-04V-S-B
    库存:38000
