1N5820 THRU 1N5822
SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 40 Volts
Forward Current - 3.0 Amperes
DO-201AD
FEATURES
Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Guardring for overvoltage protection
Low power loss,high erriciency
High current capability,low forward voltage drop
High surge capability
For use in low voltage,high frequency inverters,
free wheeling,and polarity protection applications
High temperature soldering guaranteed:
260 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.0 (25.4)
MIN.
0.220(5.6)
0.197(5.0)
DIA.
0.375 (9.50)
0.285(7.20)
1.0 (25.4)
MIN.
MECHANICAL DATA
0.052 (1.3)
0.048 (1.2)
DIA.
Dimensions in inches and (millimeters)
Case: JEDEC DO-201AD molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.04 ounce, 1.10 grams
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for current capacitive load derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TL=95 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
SYMBOLS
1N5820
1N5821
1N5822
UNITS
VRRM
VRMS
VDC
21
30
40
28
40
VOLTS
VOLTS
VOLTS
I(AV)
3.0
Amps
IFSM
80.0
Amps
VF
0.475
0.500
0.525
Volts
IR
0.5
40.0
mA
CJ
RθJA
TJ,TSTG
300.0
40.0
-65 to +125
pF
C/W
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
168
STAR SEA
RATINGS AND CHARACTERISTIC CURVES 1N5820 THRU 1N5822
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD
CURRENT,AMPERES
4
3
RESISTIVE OR
INDUCTIVE LOAD
0.375” (9.5mm)
LEAD LENGTH
2
1
60
80
100
120
140
LEAD TEMPERATURE, C
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
80
70
60
50
40
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
TJ=TJmax
1
10
100
NUMBER OF CYCLES AT 60 Hz
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
10
TJ=125 C
TJ=25 C
1
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.1
0.01
0.4
0.6
0.8
1.0
1.2
1.4
100
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
400
TJ=25 C
f=1.0MHz
Vsig=50mVp-p
100
1.0
10
40
60
80
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
10
0.1
PERCENT OF PEAK REVERSE VOLTAGE,%
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
JUNCTION CAPACITANCE, pF
TJ=100 C
10
0.1
1
10
100
100
REVERSE VOLTAGE,VOLTS
t,PULSE DURATION,sec.
169
STAR SEA
很抱歉,暂时无法提供与“1N5822”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.63112
- 50+0.49893
- 150+0.43278
- 1250+0.38325
- 2500+0.34356
- 5000+0.32366
- 国内价格
- 10+1.30130
- 100+0.77620
- 500+0.54340
- 1250+0.38810
- 2500+0.36870
- 12500+0.34150
