20449-001E-03
20449-001E-03
    I-PEX(第一精工)
    RF-CONN_2X2MM_SM
    射频和同轴连接器
20449-001E-03 数据手册
MHF® 4 Low-profile design (mated height = 1.2 mm max.), ideal for use in limited spaces Maximum Mating height (mm) Outside dimension of receptacle(mm) Applicable wire gauge Frequency DC~3GHz 3GHz~6GHz VSWR 6GHz~9GHz (L=100mm) 9GHz~12GHz 12GHz~15GHz Service temp. (Celsius) Characteristic impedance Rated voltage Contact resistance Withstand voltage Insulation resistance Small form factor with big performance through 6 GHz Solderless micro-coax termination technology "i-Fit®" provides consistent performance MHF® 4 Plug available micro-coax O.D. (AWG) : 0.81 mm (36) 1.2 2.0 x 2.0 O.D. 0.81 mm / AWG 36 DC~6 GHz 1.3 max. 1.5 max. -40 degree ~ +90 degree 50ohm AC60V 20m ohm max. AC200V/min 500M ohm min./DC100V Small form factor with big performance through 6 GHz VSWR L=100 mm (Harness) dB 2 Insertion Loss L=100 mm (Harness) 0 MHF 4 φ0.81 -0.5 1.8 -1 1.6 -1.5 1.4 -2 1.2 MHF 4 φ0.81 -2.5 1 -3 0 1 2 3 GHz 4 5 6 0 1 2 3 GHz 4 5 6 Solderless micro-coax termination technology "i-Fit®" provides consistent performance Center Conductor Contact Dielectric Core Center Conductor Outer Conductor Jacket crimping MHF® 4 Plug available micro-coax O.D. (AWG) : 0.81 mm (36) Coax O.D. (Center Conductor AWG) 2.00 mm (26) 1.80 mm (30) 1.37 mm (30) 1.32 mm (32) 1.13 mm (32) 0.95 mm (33) 0.81 mm (33) 0.81 mm (36) 0.64 mm (36) 0.48 mm (38) FPC Receptacle Mating Height 1.2 mm max. ○ ○ MHF 4 receptacle , MHF 4L receptacle Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 Component Parts Detail MHF® 4 plug Au Rev.6 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 plug Au Rev.6 MHF® 4 plug Au Rev.6 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 plug Ni top Rev.2 MHF® 4 plug Ni top Rev.2 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 plug Ni top Rev.2 Accessories for MHF® 4 plug Rev.2 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 Receptacle Rev.15 MHF® 4 Receptacle Rev.15 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 Receptacle Rev.15 MHF® 4 Receptacle Rev.15 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4 Receptacle Rev.15 MHF® 4L Receptacle Rev.8 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4L Receptacle Rev.8 MHF® 4L Receptacle Rev.8 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 MHF® 4L Receptacle Rev.8 Accessories for MHF® 4 Receptacle Rev.15 Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0 Copyright © I-PEX Inc. 2020. All rights reserved. I-PEX, MHF, CABLINE, NOVASTACK, EVAFLEX, MINIFLEX, ISH, IARPB, IASLP, ESTORQ, i-Fit and ISFIT are registered trademarks of I-PEX Inc. Please note that the contents in the catalog might be changed without prior notification. I-PEX Inc. assumes no responsibility for any inaccuracies or obligation to update Information on these documents. Please be sure to read and understand the latest "Precautions for Use" and "Instruction Manual" before you use our products. We shall not be responsible for any defects, damages or troubles in case you use our products without following the precautions for use. Please feel free to contact our sales representatives when you use our products for any applications that require very high reliability and safety, or that relate to human life (ex. nuclear power control, aerospace, transportation, medical equipment, safety equipment etc.). Contact your sales representative for more detailed information. [ i-pex.com ] 202101R0
20449-001E-03 价格&库存
很抱歉,暂时无法提供与“20449-001E-03”相匹配的价格&库存,您可以联系我们找货
