TPESD12BS3
2 -L ine Bi -directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
250W peak pulse power(8/20µs)
Protects two bi-directional lines
Ultra low leakage:nA level
Operating voltage:12V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
7”
IC
Cellular Handsets and Accessories
Notebooks and Handhelds
Portable Instrumentation
Set Top Box
Industrial Controls
BL
3000
Reel Size
TE
CH
PU
TPESD12BS3
Qty per Reel
Applications
Ordering Information
Part Number
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J STD 020
Dimensions and Pin Configuration
Circuit and Pin Schematic
1
1
WWW.TPsemi.COM
TPESD12BS3
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
250
W
Peak Pulse Power(8/20µs)
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Electrical Characteristics (TA=25°C unless otherwise specified)
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
PU
VRWM
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
f
VC VBR VRWM
IT
IR
IR
IT
VRWM VBR VC V
Parasitic Capacitance
Reverse Voltage
TE
VR
I
IPP
CH
IT
CESD
BL
Parameter
Symbol
IPP
Small Signal Frequency
Parameter
Breakdown Voltage
Symbol
Bi-Directional TVS
Min
Typ
VRWM
VBR
Max
Unit
12
V
V
13.3
0.5
µA
Test Condition
IT = 1mA
VRWM = 12V
IR
0.01
Clamping Voltage
VC
15
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
24
V
IPP = 10A (8 x 20µs pulse)
Peak Pulse Current
IPP
10
A
tP=8/20µs
Junction Capacitance
CJ
24
pF
VR=0, f=1MHz, Pin 1 to Pin 3 or
Pin 2 to Pin 3
2
WWW.TPsemi.COM
TPESD12BS3
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
Time (ns)
30ns
60ns
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
tr = 0.7~1ns
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
3
WWW.TPsemi.COM
TPESD12BS3
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E1
GAUGE
PLANE
SEATING
PLANE
E
C
c
L
L1
1
IC
DETAIL A
2
bxN
A2
A
C A B
3X
aaa C
BL
bbb
e
SIDE VIEW
SEATING PLANE
C
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.18
0.08
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
SEE DETAIL A
TE
CH
PU
A1
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
C
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
C
E
E1
G
X
Y
Z
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
E
E1
4
WWW.TPsemi.COM
很抱歉,暂时无法提供与“TPESD12BS3”相匹配的价格&库存,您可以联系我们找货
