SLM21867
600V High and Low Side Driver
PRODUCT SUMMARY
VOFFSET
IO+/VOUT
ton/off (typ.)
FEATURES
600 V max.
4A/4A
7 V - 20 V
170ns / 170ns
GENERAL DESCRIPTION
The SLM21867 is a high voltage, high speed power
MOSFET and IGBT drivers with independent highand low-side referenced output channels.
Proprietary HVIC and latch immune CMOS
technologies enable ruggedized monolithic
construction. The logic input is compatible with
standard CMOS or LSTTL output, down to 3.3 V
logic. The output drivers feature a high pulse current
buffer stage designed for minimum driver cross
conduction. Propagation delays are matched to
simplify use in high frequency applications. The
floating channel can be used to drive an N-channel
power MOSFET or IGBT in the high-side
configuration which operates up to 600 V.
Floating channel designed for bootstrap
operation
Fully operational to +600 V
Low VCC operation
Tolerant to negative transient voltage, dV/dt
immune
Gate drive supply range from 7 V to 20 V
Undervoltage lockout for both channels
3.3 V, and 5 V logic compatible
CMOS Schmitt-triggered inputs with pull-down
Matched propagation delay for both channels
Outputs in phase with inputs
RoHS compliant
SOIC-8 package
TYPICAL APPLICATION CIRCUIT
up to 600V
VCC
VB
HIN
VCC
HIN
HO
LIN
LIN
VS
COM
LO
to
load
SLM21867
(Refer to Lead Assignments for correct configuration). This diagram shows electrical connections only. Please
refer to our Application Notes and Design Tips for proper circuit board layout.
Typical Application Circuit
Sillumin Semiconductor Co., Ltd. – www.sillumin.com
Rev0.2, January 2020
1
SLM21867
PIN CONFIGURATION
Package
Pin Configuration (Top View)
SOIC-8
1
VCC
VB
8
2
HIN
HO
7
3
LIN
VS
6
4
COM
LO
5
PIN DESCRIPTION
No.
Pin
Description
1
VCC
Low-side and logic fixed supply
2
HIN
Logic input for high-side gate driver output (HO), in phase
3
LIN
Logic input for low-side gate driver output (LO), in phase
4
COM
Low-side return
5
LO
Low-side gate drive output
6
VS
High-side floating supply return
7
HO
High-side gate drive output
8
VB
ORDERING INFORMATION
Industrial Range: -40°C to +125°C
Order Part No.
Package
QTY
SLM21867CA-DG
SLM21867CA-TG
SOIC8, Pb-Free
SOIC8, Pb-Free
2500/Reel
100/Tube
2
SLM21867
FUNCTIONAL BLOCK DIAGRAM
VB
VBS
UVLO
HIN
VSS/COM
LEVEL
SHIFT
Pulse
Filter
PULSE
GENERATOR
R
R
Q
HO
S
VS
VCC
UVLO
LO
LIN
VSS/COM
LEVEL
SHIFT
DELAY
COM
SLM21867
3
SLM21867
ABSOLUTE MAXIMUM RATINGS
Symbol
Definition
VB
High-side floating absolute voltage
Min.
-0.3
Max.
625
VS
High-side floating supply offset voltage
VB - 25
VB + 0.3
VHO
High-side floating output voltage
VS - 0.3
VB + 0.3
VCC
Low-side and logic fixed supply voltage
-0.3
25
VLO
Low-side output voltage
-0.3
VCC + 0.3
VIN
Logic input voltage (HIN & LIN )
Allowable offset supply voltage transient
-0.3
VCC + 0.3
50
PDIP-8
1.0
SOIC-8
0.625
PDIP-8
125
SOIC-8
200
dVS/dt
PD
Package power dissipation @ TA ≤ +25°C
RthJA
Thermal resistance, junction to ambient
TJ
Junction temperature
150
TS
Storage temperature
-55
150
TL
Lead temperature (soldering, 10 seconds)
300
Units
V
V/ns
W
°C/W
°C
Note:
Absolute maximum ratings indicate sustained limits beyond which damage to the device may occur. All voltage parameters are absolute
voltages referenced to COM. The thermal resistance and power dissipation ratings are measured under board mounted and still air conditions.
RECOMMENDED OPERATIONG CONDITIONS
Symbol
Definition
VB
Min.
VS + 10
Max.
VS + 20
VS
Note 1
600
VHO
VS
VB
VCC
10
VLO
VCC
VIN
Logic input voltage (HIN & LIN)
COM
VCC
TA
Ambient temperature
- 40
125
Units
V
°C
Note:
The input/output logic timing diagram is shown in Fig. 1. For proper operation the device should be used within the recommended conditions.
The VS offset rating is tested with all supplies biased at a 15 V differential.
4
SLM21867
DYNAMIC ELECTRICAL CHARACTERISTICS
VBIAS (VCC, VBS, VDD) = 15 V, CL = 1000 pF and TA = 25°C unless otherwise specified.
Symbol
Parameter
Condition
Min.
Typ.
Max.
ton
Turn-on propagation delay
VS = 0 V
170
250
toff
Turn-off propagation delay
VS = 600 V
170
250
tr
Turn-on rise time
22
38
tf
Turn-off fall time
18
30
Delay matching, HS & LS turn-on/off
35
MT
Unit
Ns
STATIC ELECTRICAL CHARACTERISTICS
VBIAS (VCC, VBS, VDD) = 15 V and TA = 25°C unless otherwise specified. The VIN, VTH, and IIN parameters are
referenced to COM and are applicable to all three logic input leads: HIN and LIN. The VO and IO parameters are
referenced to COM and are applicable to the respective output leads: HO or LO.
Symbol
Parameter
Condition
Min.
Typ.
Max.
2.5
0.8
1.4
0.02
0.15
50
400
200
290
400
VIH
Logic “1” input voltage
VIL
Logic “0” input voltage
VOH
High level output voltage, VBIAS - VO
VOL
Low level output voltage, VO
ILK
Offset supply leakage current
IQBS
Quiescent VBS supply current
IQCC
Quiescent VCC supply current
IIN+
Logic “1” input bias current
HIN=LIN = 5V
60
70
IIN-
Logic “0” input bias current
HIN=LIN= 0V
5
6.25
6.85
VCC = 7 V to 20V
IO = 20 mA
VB = VS = 600 V
VIN = 0 V or 5 V
VBSUV+
VBS supply undervoltage positive going
threshold
5.65
VBSUV-
VBS supply undervoltage negative going
threshold
5.15
5.75
6.35
VCCUV+
VCC supply undervoltage positive going
threshold
5.65
6.25
6.85
VCCUV-
VCC supply undervoltage negative going
threshold
5.15
5.75
3.0
4.0
IO+
IO-
Output high short circuit pulsed current
Output low short circuit pulsed current
Unit
V
µA
V
V
VO = 0 V
VIN = Logic “1”
PW ≤ 10 µs
VO = 15 V
VIN = Logic “0”
PW ≤ 10 µs
6.35
A
3.0
4.0
5
SLM21867
Switching and Timing Relationships
The relationships between the input and output signals of the SLM21867 are illustrated below
in Figures 1, 2. From these figures, we can see the definitions of several timing parameters
(i.e., tON, tOFF, tR, and tF) associated with this device.
6
SLM21867
PACKAGE CASE OUTLINES
PART MARKING INFORMATION
Part Number
Pin1 Identifier
Internal Trace Code
Data Code
7
SLM21867
Revision History
Note: page numbers for previous revisions may differ from page numbers in current version
Page or Item
Subjects (major changes since previous revision)
Whole document
Draft datasheet released
Page 2
Page 7
Change order information
Add part marking information
Rev 0.1 datasheet, 2019-9-1
Rev 0.2 datasheet, 2020-1-14
8
很抱歉,暂时无法提供与“SLM21867CA-DG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.88160
- 10+3.89880
- 30+3.40200
- 100+2.91600
- 500+2.78640
- 1000+2.63520
