104020001
104020001
    SEEED(矽递科技)
    Development Kit
    Grove‐可变颜色LED
104020001 数据手册
    Grove ‐ Variable Color LED SKU 104020001 This product will EOL soon, please consider the Grove ‐ Variable Color LED V1.1 as alternative choice. Thank you! This product consists of one 8mm RGB LED. It operates at 5V DC. When SIG pin is logic LOW, the RGB LED will show. Perfect for use on Seeeduino digital outputs, or also can be controlled using pulse‐width modulation. And uses three adjustable resistor to change the color of the RGB LED. For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface ‐ Getting Started and Introduction to Grove before your using of the product. Technical details Dimensions 130mm x90mm x19mm Weight G.W 7g Battery Exclude Part List Grove ‐ Variable Color 1 LED Grove Cable 1       https://www.seeedstudio.com/Grove‐Variable‐Color‐LED‐p‐852.html/6‐18‐19
104020001 价格&库存
很抱歉,暂时无法提供与“104020001”相匹配的价格&库存,您可以联系我们找货
