Grove - Differential Amplifier v1.2
This Grove is designed for precise differential-input amplification. Input the differential
signals of your sensor to this module through the male pins, then your Arduino will get a
precisely amplified output from the Grove interface. The gain scale factor is selectable.
You can get a 35 times or 1085 times amplification via a switch on the board.
Features
High amplifying precision
Selectable scale factor
Can be conveniently read by Arduino
Tip
More details about Grove modules please refer to Grove System
Applications
Data acquisition
Battery operated systems
Pressure and temperature bridge amplifiers
General purpose instrumentation
Specifications
Item
Min
Typical
Max
Unit
Operating Voltage
2.7
5.0
5.5
VDC
Input Voltage
0.1
(Vcc‐0.8)/Gain
mV
Output Voltage
Vcc‐0.80
mV
Gain
Select 35
35
Select 1085
1085
Platforms Supported
Arduino
Raspberry Pi
BeagleBone
Wio
LinkIt ONE
Caution
The platforms mentioned above as supported is/are an indication of the module's
software or theoritical compatibility. We only provide software library or code examples
for Arduino platform in most cases. It is not possible to provide software library / demo
code for all possible MCU platforms. Hence, users have to write their own software
library.
Usage
1. Sensor Choosing
The amplifier can turn signals in mA scale up to A scale. Before using it, make sure the
output range of your sensor is in mA scale. For example, Weight Sensor is one of them.
2. Connector Reforming
To pair the weight sensor up with the male pins on the amplifier, female connectors
need to be soldered on its wires.
3. Hardware Hookup
Connect the weight sensor to the amplifier as the picture depicts below.
4. Measurement
Copy and paste the demo code below to Arduino IDE and upload it.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
void setup()
Serial.begin(9600);
Serial.println("start");
void loop()
int i;
int value;
float V,Vo;
float Sum=0;
for(i=0;i
很抱歉,暂时无法提供与“103020016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+144.843851+18.72096
