102010008
102010008
    SEEED(矽递科技)
    DEVB_AVR
    AVR MCU 8-位 评估板 - 嵌入式
102010008 数据手册
    Seeeduino Lite Seeeduino Lite is a microcontroller based on ATmega32U4. Just like Arduino Leonardo, it saves a secondary processor needed for USB to serial communication. And this allows Seeeduino Lite appear to computer as a USB device, like keyboard and mouse. Derived from Leonardo, we also merged custom details of Seeeduino series into Seeeduino Lite, like selectable operating voltage, onboard Grove connectors and so on. It has 20 digital I/Os (7 of which can output PWM),a micro USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a ACto-DC adapter to get started. Specifications  Microcontroller: ATmega32u4  Operating Voltage: 5V  Input Voltage (recommended): 7-12V  Input Voltage (limits): 6-20V  Digital I/O Pins: 20  PWM Channels: 7  Analog Input Channels: 12  DC Current per I/O Pin: 40 mA  DC Current for 3.3V Pin: 50 mA  Flash Memory: 32 KB (ATmega32u4) of which 4 KB used by bootloader  SRAM: 2.5 KB (ATmega32u4)  EEPROM: 1 KB (ATmega32u4)  Clock Speed: 16 MHz Interface U1: 78M05 IC, Three-terminal positive voltage regulator. U3: LD1117 IC, a Low Drop Voltage Regulator able to provide up to 800mA of Output Current. U5: Atmega32U4 IC, 8-bit AVR Microcontroller with 32K Bytes of ISP Flash and USB Controller. Driver Installation Note If this is your first time using Arduino, we highly recommend you to refer to Getting Started with Arduino Download the driver files from here https://github.com/SeeedStudio/Signed_USB_Serial_Driver. Connect Seeeduino Lite to your computer via a micro-USB wire. Wait for the new found hardware prompt.If the installer does not launch automatically, Navigate to the Windows Device Manager and find the Seeeduino Lite listing. Right click and choose Update driver. When asked to install automatically or from a specific location, select "Browse my computer for driver software". Choose "Search for the best driver in these locations", and check the box "incude this location in the search". Click the Browse button and navigate to drive you have downloaded. Select the drivers folder an click OK. Replace two file in the path of Arduino. Open up Arduino1.0.1/hardware/arduino/cores/arduino directory, replace the file:USBCore.cpp with the new USBCore.cpp.And replace file:boards.txt with the new boards.txt in the path:Arduino-1.0.1/hardware/arduino. Now, you can program and use the seeeduino lite as you use other Arduino boards. Tech Support Please submit any technical issue into our forum or drop mail to techsupport@seeed.cc.                                                          http://wiki.seeedstudio.com/Seeeduino_Lite/2‐6‐19
102010008
物料型号:Seeeduino Lite
器件简介:Seeeduino Lite类似于Arduino Leonardo,它省去了USB到串行通信所需的次级处理器,允许Seeeduino Lite作为USB设备(如键盘和鼠标)出现在计算机上。它具有20个数字I/O引脚(其中7个可以输出PWM)、一个Micro USB连接、一个电源插座、一个ICSP头和一个复位按钮。
引脚分配:文档中提到了数字连接器和模拟连接器的引脚分配,但没有提供详细的引脚分配图。
参数特性: - 微控制器:ATmega32U4 - 工作电压:5V - 推荐输入电压:7-12V - 输入电压限制:6-20V - 数字I/O引脚:20 - PWM通道:7 - 模拟输入通道:12 - 每个I/O引脚的直流电流:40 mA - 3.3V引脚的直流电流:50 mA - 闪存存储:32 KB(ATmega32U4),其中4 KB由引导程序使用 - SRAM:2.5 KB(ATmega32U4) - EEPROM:1 KB(ATmega32U4) - 时钟速度:16 MHz
功能详解:文档中提到了Seeeduino Lite的主要特性和功能,包括其USB通信能力、可编程性以及与Arduino的兼容性。
应用信息:文档没有提供具体的应用案例,但提到了Seeeduino Lite可以用于各种电子项目。
封装信息:文档中没有提供封装信息
102010008 价格&库存
很抱歉,暂时无法提供与“102010008”相匹配的价格&库存,您可以联系我们找货
