Xadow - LED 5x7
The Xadow LED 5x7 consists of a 5x7 monochrome LED matrix and a LED controller.
You can sending command to the LED controller through I2C interface (address 0x21)
to display numbers, letters or even pixel images. This could come handy sometime in
your project.
Features
LED Matrix
Plug-and-play if connected with RePhone Kit Create
Open source and modular design
Slim and small
Built-in 11 PIN Xadow Connectors for full flexible connection with other Xadow Modules
Stackable, chain-able and sew-able with other Xadow Modules
Specification
Item
Value
Microcontroller STM32F030F4
Core
ARM® 32‐bit Cortex® ‐M0 CPU
Power Supply
3.3 ~ 6 V (via breakout pins)
Flash
16 KB
SRAM
4 KB
Clock Speed
48 MHz
Interfaces
Interface with Xadow GSM+BLE through I2C (7‐bit address 0x21)
Dimension
25.37mm × 20.30mm / 1” × 0.8”
Hardware Overview
Use it with RePhone Kit Create
Display characters:
Without any programming, you can connect it to the Core Module (Xadow GSM+BLE) of
your 'RePhone Kit Create' to display numbers and letters using the 'Actuator Control'.
Set 'If This Then That' :
You can also set conditions in the 'If This Then That' to trigger the Xadow LED 5x7 to
display specific characters or pixel images.
Rephone Community
We’ve been looking for a better place where our backers (RePhone Users) can sit
together, warmly and comfortably, have conversations about RePhone, discuss
technical problems, share ideas/projects, and give feedback on the modules’
development in the future. And then here we go, the RePhone Community.
Now join us in the RePhone Community! Together we seek answers, make interesting
stuff, care about each other, and share our experiences.
http://wiki.seeedstudio.com/Xadow_LED_5x7/ 9‐10‐18
很抱歉,暂时无法提供与“104040004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4+79.053664+10.27672
