JW5033S
JW5033S
    JOULWATT(杰华特)
    TSOT-23-6
    JW5033S是一款电流模式单片降压电压转换器,工作输入范围为3.7V至18V,可提供2A连续输出电流,具有两个集成的N-通道MOSFET。轻载时,调节器以低频率运行,以保持高效率和低输出纹波。该器件...
JW5033S 数据手册
JW5033S 18V/2A Sync. Step-Down Converter Parameters Subject to Change Without Notice DESCRIPTION FEATURES The JW ®5033S is a current mode monolithic buck voltage converter. Operating with an input range of 3.7V-18V, the JW5033S delivers 2A of continuous output current with two integrated N-Channel MOSFETs. At light loads, regulators operate in low frequency to maintain high efficiency and low output ripple. The JW5033S guarantees robustness with short circuit protection, thermal protection, current run-away protection, and input under voltage lockout. The JW5033S is available in a 6-pin TSOT23-6 and SOT563 package, which provides a compact solution with minimal external components.  Company’s Logo is Protected, “JW” and “JOULWATT” are Registered Trademarks of JoulWatt technology Inc.         3.7V to 18V operating input range 2A output current Up to 95% efficiency High efficiency at light load 800kHz Switching frequency Input under voltage lockout Start-up current run-away protection Over current protection and Hiccup Thermal protection Available in TSOT23-6 and SOT563 package APPLICATIONS      Distributed Power Systems Networking Systems FPGA, DSP, ASIC Power Supplies Green Electronics/ Appliances Notebook Computers TYPICAL APPLICATION JW5033S Rev.0.88 JoulWatt® Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 1 JW5033S JoulWatt ORDER INFORMATION DEVICE 1) PACKAGE 2) TOP MARKING JWHSX JW5033STSOTB#TRPBF TSOT23-6 YWLLL JW5033SSOTI#TRPBF SOT563 : JWFX YWLL Notes PIN CONFIGURATION ABSOLUTE MAXIMUM RATING1) VIN Pin =.............................................................................................................................. -0.3V to 20V EN Pin =............................................................................................................................... -0.3V to 20V SW........................................................................................... -0.3V(-4.5V for 10ns) to 20V(22V for 10ns) BST Pin ................................................................................................................... SW-0.3V to SW+5.5V All other Pins ............................................................................................................................ -0.3V to 6V Junction Temp. 2) 3) ............................................................................................................................150ºC Lead Temperature .............................................................................................................................260ºC ESD Susceptibility (Human Body Model) ............................................................................................. 2kV RECOMMENDED OPERATING CONDITIONS Input Voltage VIN .................................................................................................................... 3.7V to 18V Output Voltage Vout ............................................................................................................0.8V to VIN-3V JW5033S Rev.0.88 JoulWatt® Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 2 JW5033S JoulWatt THERMAL PERFORMANCE4) Package Absolute Max Storage Temp. Recommended Operating Junction Temp. Range Recommended Max Case Temp. TC (ºC) Abs. Max Junction Temp. Tj (ºC) Recommended Max Power Loss PD@25ºC (W) TSOT23-6 SOT563 -65ºC to 150ºC -40ºC to 125ºC 119 150 0.9 Package RθJC (ºC/W ) RθJA (ºC/W ) RθJB (ºC/W ) ψJT (ºC/W ) ψJB (ºC/W ) TSOT23-6 55 110 14.7 1.2 14.7 SOT563 60 130 17.6 1.5 17.4 : Note 1) 2) 3) 4) Exceeding these ratings may damage the device. The JW5033S guarantees robust performance from -40°C to 150°C junction temperature. The junction temperature range specification is assured by design, characterization and correlation with statistical process controls. The JW5033S includes thermal protection that is intended to protect the device in overload conditions. Thermal protection is active when junction temperature exceeds the maximum operating junction temperature. Continuous operation over the specified absolute maximum operating junction temperature may damage the device. Measured on JESD51-7, 4-layer PCB JW5033S Rev.0.88 JoulWatt® Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 3 JW5033S JoulWatt ELECTRICAL CHARACTERISTICS VIN=12V, TA=25 ℃,Unless otherwise stated. Item Symbol VIN Under Voltage Lock-out Threshold VIN Under voltage Lockout Hysteresis 5) VIN_MIN Conditions VIN rising Min. Typ. Max. Unit 3.2 3.4 3.7 V VIN_MIN_HYST 300 mV Shutdown Supply Current ISD VEN=0V 0.1 1 µA Supply Current IQ VEN=5V, VFB=1.2V 120 150 µA VFB 3.7V
JW5033S 价格&库存
很抱歉,暂时无法提供与“JW5033S”相匹配的价格&库存,您可以联系我们找货
