NSi83086
NSi83086
    NOVOSENSE(纳芯微)
    SOIC16_300MIL
    高可靠性隔离的半双工和全双工RS-485收发器
NSi83086 数据手册
NSi83085/NSi83086: High Reliability Isolated Half and Full-Duplex RS-485 Transceivers NOVOSENSE Datasheet (EN) 1.6 Product Overview NSi83085 is a high reliability isolated half duplex RS-485 transceiver based on NOVOSENSE digital isolation technology, while NSi83086 is an isolated full duplex RS485 transceiver. Both devices are safety certified by UL1577 support 5kVrms insulation withstand voltages, while providing high electromagnetic immunity and low emissions at low power consumption. The Bus pins of NSi83085/NSi83086 are protected from ±16kV system level ESD to GND2 on Bus side. These devices feature fail-safe circuitry, which guarantees a logic-high receiver output when the receiver inputs are open or shorted. The devices have a 1/8-unit-load receiver input impedance that allows up to 256 transceivers on the bus. The data rate of NSi83085 is 500kbps. The device is slew limited to reduce EMI and reflections with improperly terminated transmission line. The data rate of NSi83086 is up to 16Mbps. Key Features  Up to 5000Vrms Insulation voltage  Bus side power supply voltage: 3.0V to 5.5V  VDD1 supply voltage: 2.5V to 5.5V  High CMTI: ±150kV/us  High system level EMC performance: Safety Regulatory Approvals  UL recognition: up to 5000Vrms for 1 minute per UL1577  CQC certification per GB4943.1-2011  CSA component notice 5A  DIN VDE V 0884-11:2017-01 Applications  Industrial automation system  Isolated RS-485 communication  Smart electric meter and water meter  Security and protection monitoring Functional Block Diagrams Bus Pins meet IEC61000-4-2 ±16kV ESD Other Pins meet ±7kV contact ESD  Fail-safe protection receiver  NSi83085 has slew rate limitation  Up to 256 transceivers on the bus  Isolation Barrier Life: >60 years  Operation temperature: -40℃~105℃  RoHS-compliant packages: Figure 1. NSi83085 & NSi83086 Block Diagrams SOIC-16 wide body Copyright © 2019, NOVOSENSE Page 1 NSi83085/NSi83086 Index 1.0 ABSOLUTE MAXIMUM RATINGS................................................................................................................................................ 3 2.0 SPECIFICATIONS.......................................................................................................................................................................... 3 2.1. DC ELECTRICAL CHARACTERISTICS....................................................................................................................................................3 2.2. SWITCHING ELECTRICAL CHARACTERISTICS......................................................................................................................................... 5 2.3. TYPICAL PERFORMANCE CHARACTERISTICS................................................................................................................................. 7 2.4. PARAMETER MEASUREMENT INFORMATION...................................................................................................................................... 9 3.0 HIGH VOLTAGE FEATURE DESCRIPTION................................................................................................................................... 10 3.1. INSULATION AND SAFETY RELATED SPECIFICATIONS............................................................................................................................ 10 3.2. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS.......................................................................... 11 3.3. REGULATORY INFORMATION......................................................................................................................................................... 12 4.0 FUNCTION DESCRIPTION..........................................................................................................................................................13 4.1. DATA RATE................................................................................................................................................................................13 4.2. TRUE FAIL-SAFE RECEIVER INPUTS.................................................................................................................................................. 13 4.3. TRUTH TABLES........................................................................................................................................................................... 13 4.4. THERMAL SHUTDOWN.................................................................................................................................................................14 5.0 APPLICATION NOTE...................................................................................................................................................................14 5.1. 256 TRANSCEIVERS ON THE BUS................................................................................................................................................... 14 5.2. ESD PROTECTION.......................................................................................................................................................................14 5.3. LAYOUT CONSIDERATIONS............................................................................................................................................................14 5.4. TYPICAL APPLICATION..................................................................................................................................................................14 6.0 PACKAGE INFORMATION..........................................................................................................................................................16 7.0 TAPE AND REEL INFORMATION................................................................................................................................................ 18 8.0 ORDER INFORMATION............................................................................................................................................................. 20 9.0 REVISION HISTORY.................................................................................................................................................................... 20 Copyright © 2019, NOVOSENSE Page 2 NSi83085/NSi83086 1.0 ABSOLUTE MAXIMUM RATINGS Parameters Symbol Min Power Supply Voltage VDD1, VDD2 -0.5 6 V Maximum Input Voltage /RE, DE, TxD -0.4 VDD+0.4 V CMTI -150 150 kV/us VA, VB, VY, VZ -7 12 V Receiver Output Current Io -15 15 mA Maximum Surge Isolation Voltage VIOSM 5.3 kV Operating Temperature Topr -40 105 ℃ Storage Temperature Tstg -40 150 ℃ HBM (Bus pins and GND) ±8000 V HBM(All pins) ±6000 V CDM ±2000 V Common-Mode Transients Driver Output/Receiver Input Voltage Electrostatic discharge 2.0 Typ Max Unit Comments SPECIFICATIONS 2.1. DC ELECTRICAL CHARACTERISTICS (VDD1=2.5V~5.5V, VDD2=3.0V~5.5V, Ta=-40℃ to 105℃. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 5V, Ta = 25℃) Parameters Power supply voltage Symbol Min VDD1 VDD 2 Logic-side supply current IDD1 Bus-side supply current IDD2 Thermal-Shutdown Threshold Copyright © 2019, NOVOSENSE TTS Typ Max Unit 2.5 5.5 V 3.0 5.5 V Bus Side 3.32 4.98 mA VDD1=5V, DE=high, /RE=D =low, no load 3.26 4.89 mA VDD1=3V, DE=high, /RE=D =low, no load 3.35 5.02 mA VDD2=5V, DE=high, /RE=D =low, no load(NSi83085) 2.15 3.23 mA VDD2=5V, DE=high, /RE=D =low, no load(NSi83085) 165 Comments ℃ Page 3 NSi83085/NSi83086 Thermal-Shutdown Hysteresis Common Mode Transient Immunity TTSH 15 CMTI ±100 Input High Voltage VIH 2 Input Low Voltage VIL ℃ ±150 kV/us Logic Side 0.8 V DE, D, /RE V DE, D, /RE VIT 1.6 V Input Threshold at rising edge VIT_HYS 0.4 V Input Threshold Hysteresis uA DE,/RE Input Threshold Input Pull up Current IPU 20 Input Pull down Current IPD -15 uA DI Output Voltage High VOH VDD10.3 V IOH = -4mA Output Voltage Low VOL 0.3 V IOL = 4mA Output Short-Circuit Current IOSR 150 mA 0 ≤ VR ≤VDD1 Three-State Output Current IOZ uA 0 ≤ VR ≤ VDD1 , /RE = high Input Capacitance CIN pF DE, D, /RE VDD2 V No Load 2.7 VDD2 V See Figure 2.4.1, RL=100Ω (RS-422),VDD2=5V 1.5 VDD2 V See Figure 2.4.1, RL=100Ω (RS-422),VDD2=3.3V 2.1 VDD2 V See Figure 2.4.1, RL=54Ω (RS485),VDD2=5V 1.3 VDD2 V See Figure 2.4.1, RL=54Ω (RS485),VDD2=3.3V 0.2 V See Figure 2.4.1, RL=100Ω or RL=54Ω 3 V See Figure 2.4.1, RL=100Ω or RL=54Ω 0.2 V See Figure 2.4.1, RL=100Ω or RL=54Ω 250 mA 0 ≤ VOUT ≤ +12 V mA −7V ≤ VOUT ≤ VDD2 uA DE=GND, VIN=12V -15 2 Driver Differential Output Voltage Change in magnitude of the | VOD | Δ|VOD | differential output voltage Common-Mode Output Voltage | VOC | Change in Magnitude of Δ|VOC | VDD2/2 Common-Mode Voltage Driver Short-Circuit Output Current Output Leakage Current (Y and Copyright © 2019, NOVOSENSE IOSD IO -250 125 Page 4 NSi83085/NSi83086 Z) Full-Duplex -75 uA DE=GND, VIN=-7V uA DE=GND, VDD2=GND, VIN=12V uA DE=GND, VDD2=GND, VIN=7V mV −7V ≤ VCM ≤ 12V mV VA+VB=0 kΩ −7V ≤ VCM ≤ 12V, DE=low Receiver IA , IB 125 Input Current (A and B) -200 Receiver Differential Threshold Voltage VTH -200 Receiver Input Hysteresis ΔVTH Receiver Input Resistance RIN -125 -50 15 96 2.2. SWITCHING ELECTRICAL CHARACTERISTICS (VDD1=2.5V~5.5V, VDD2=3.0V~5.5V, Ta=-40℃ to 105℃. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 5V, Ta = 25℃) Parameters Symbol Min Typ Max Unit Comments Maximum Data Rate fMAX 0.5 Driver Propagation Delay t PLH 450 675 ns See Figure 2.4.2, RL=54Ω,CL=50pF t PHL 430 645 ns See Figure 2.4.2, RL=54Ω,CL=50pF PWD 20 ns See Figure 2.4.2, RL=54Ω,CL=50pF tF 590 885 ns See Figure 2.4.2, RL=54Ω,CL=50pF tR 590 885 ns See Figure 2.4.2, RL=54Ω,CL=50pF Driver Enable to Output High tZH 310 465 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver Enable to Output Low tZL 310 465 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver Output High to Disable tHZ 30 45 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver Output Low to Disable tLZ 30 45 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver (NSi83085) Driver Pulse Width Distortion,|t PHL – t PLH | Driver Output Falling Time or Rising time Mbps Receiver (NSi83085) Copyright © 2019, NOVOSENSE Page 5 NSi83085/NSi83086 Maximum Data Rate fMAX 0.5 Mbps Receiver Propagation Delay t PLH 102 153 ns See Figure 2.4.4, CL=15pF t PHL 92 138 ns See Figure 2.4.4, CL=15pF Receiver Pulse Width Distortion PWD 10 ns |t PHL – t PLH |,See Figure 2.4.4, CL=15pF Receiver Output Falling Time or Rising time tF 2.5 3.75 ns See Figure 2.4.4, CL=15pF tR 2.5 3.75 ns See Figure 2.4.4, CL=15pF Receiver Enable to Output High tZH 18.5 27.75 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Receiver Enable to Output Low tZL 18.5 27.75 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Receiver Disable to Output High tHZ 23 34.5 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Receiver Disable to Output Low tLZ 23 34.5 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Driver (NSi83086) Maximum Data Rate fMAX Driver Propagation Delay t PLH 12 18 ns See Figure 2.4.2, RL=54Ω,CL=50pF t PHL 13.5 20.25 ns See Figure 2.4.2, RL=54Ω,CL=50pF PWD 1.5 ns See Figure 2.4.2, RL=54Ω,CL=50pF tF 2.95 4.425 ns See Figure 2.4.2, RL=54Ω,CL=50pF tR 2.6 3.9 ns See Figure 2.4.2, RL=54Ω,CL=50pF Driver Enable to Output High tZH 18.5 27.75 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver Enable to Output Low tZL 19.1 28.65 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver Disable to Output High tHZ 20.8 31.2 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver Disable to Output Low tLZ 20.1 30.15 ns See Figure 2.4.3, RL=110Ω,CL=50pF Driver Pulse Width Distortion,|t PHL – t PLH | Driver Output Falling Time or Rising time 16 Mbps Receiver (NSi83086) Maximum Data Rate Copyright © 2019, NOVOSENSE fMAX 16 Mbps Page 6 NSi83085/NSi83086 Receiver Propagation Delay t PLH 16.2 24.3 ns See Figure 2.4.4, CL=15pF t PHL 22.2 33.3 ns See Figure 2.4.4, CL=15pF PWD 6.0 ns See Figure 2.4.4, CL=15pF tF 2.3 3.45 ns See Figure 2.4.4, CL=15pF tR 2.1 3.15 ns See Figure 2.4.4, CL=15pF Receiver Enable to Output High tZH 13.8 20.7 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Receiver Enable to Output Low tZL 12.6 18.9 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Receiver Disable to Output High tHZ 14 21 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Receiver Disable to Output Low tLZ 13.4 20.1 ns See Figure 2.4.5, RL=1kΩ,CL=15pF Receiver Pulse Width Distortion, |t PHL – t PLH | Receiver Output Falling Time or Rising time 2.3. TYPICAL PERFORMANCE CHARACTERISTICS Figure 2.1 NSi83085 VDD1 supply current vs Temperature Copyright © 2019, NOVOSENSE Figure 2.2 NSi83085 VDD2 supply current vs Temperature Page 7 NSi83085/NSi83086 Figure 2.3 NSi83086 VDD1 supply current vs Temperature Figure 2.5 Receiver output current vs Output low voltage Figure 2.9 NSi83085 Transmitter Propagation Delay vs Temperature Figure 2.11 NSi83086 Transmitter Propagation Delay vs Temperature Copyright © 2019, NOVOSENSE Figure 2.4 NSi83086 VDD2 supply current vs Temperature Figure 2.6 Receiver output current vs Output High voltage Figure 2.10 NSi83085 Receiver Propagation Delay vs Temperature Figure 2.12 NSi83086 Receiver Propagation Delay vs Temperature Page 8 NSi83085/NSi83086 2.4. PARAMETER MEASUREMENT INFORMATION Figure 2.4.1 Driver DC Test Load Figure 2.4.2 Driver Timing Test Circuit and waveform Figure 2.4.3 Driver Enable Disable Timing Test Circuit and waveform Figure 2.4.4 Receiver Propagation Delay Test Circuit and waveform Copyright © 2019, NOVOSENSE Page 9 NSi83085/NSi83086 Figure 2.4.5 Receiver Enable Disable Timing Test Circuit and waveform Figure 2.4.6 Common-Mode Transient Immunity Test Circuit 3.0 HIGH VOLTAGE FEATURE DESCRIPTION 3.1. INSULATION AND SAFETY RELATED SPECIFICATIONS Parameters Symbol Value Unit Comments Minimum External Air Gap (Clearance) L(I01) 8.0 mm Shortest terminal-to-terminal distance through air Minimum External Tracking (Creepage) L(I02) 8.0 mm Shortest terminal-to-terminal distance across the package surface Minimum internal gap DTI 20 um Distance through insulation Tracking Resistance(Comparative Tracking Index) CTI >400 V DIN EN 60112 (VDE 0303-11); IEC 60112 Material Group Copyright © 2019, NOVOSENSE Ⅱ Page 10 NSi83085/NSi83086 3.2. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS Description Test Condition Symbol Value Unit Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150Vrms Ⅰto Ⅳ For Rated Mains Voltage ≤ 400Vrms Ⅰto Ⅳ For Rated Mains Voltage ≤ 300Vrms Ⅰto Ⅳ Climatic Classification 10/105/21 Pollution Degree per DIN VDE 0110, Table 1 2 Maximum repetitive isolation voltage AC Voltage(Bipolar) VIORM 1131 Vpeak AC Voltage(TDDB) VIORM 800 Vrms DC Voltage VIORM 1131 Vdc V IORM × 1.5 = V pd (m) , 100% production test, V pd (m) 1273 Vpeak V pd (m) 1019 Vpeak V pd (m) 1019 Vpeak t = 60 sec VIOTM 7000 Vpeak Test method per IEC60065,1.2/50us waveform, VTEST=1.3×VIOSM VIOSM 5384 Vpeak Isolation resistance VIO =500V RIO >109 Ω Isolation capacitance f = 1MHz CIO 0.6 pF Input capacitance CI 2 pF Total Power Dissipation at 25℃ Ps 1499 mW Input to Output Test Voltage, Method B1 t ini = t m = 1 sec, partial discharge < 5 pC Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 After Input and /or Safety Test Subgroup 2 and Subgroup 3 Maximum transient isolation voltage Maximum Surge Isolation Voltage Safety input, output, or supply current Case Temperature Copyright © 2019, NOVOSENSE V IORM × 1.2 = V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC V IORM × 1.2= V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC θJA = 140 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C θJA = 84 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C mA Is Ts 237 mA 150 ℃ Page 11 NSi83085/NSi83086 Figure 3.1 NSi83085/NSi83086 Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Figure 3.2 NSi83085/NSi83086 Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 3.3. REGULATORY INFORMATION The NSi83085/NSi83086 are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program1 Single Protection, 5000Vrms Isolation voltage VDE Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11(VDE V 0884-11):2017-012 Single Protection, 5000Vrms Isolation voltage Basic Insulation 1131Vpeak, VIOSM=5384Vpeak CQC Certified by CQC11471543-2012 GB4943.1-2011 Basic insulation at 800VRMS (1131Vpeak) Reinforced insulation at 400VRMS (565Vpeak) File (E500602) 1 File (E500602) File (5024579-4880-0001) File (pending) In accordance with UL 1577, each NSi83085/NSi83086 is proof tested by applying an insulation test voltage ≥ 6000 V rms for 1 sec. 2 In accordance with DIN VDE V 0884-11, each NSi8100W/NSi8101W is proof tested by applying an insulation test voltage ≥ 1273 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN VDE V 0884-11 approval. Copyright © 2019, NOVOSENSE Page 12 NSi83085/NSi83086 4.0 FUNCTION DESCRIPTION NSi83085 is a high reliability isolated half duplex RS-485 transceiver , while NSi83086 is an isolated full duplex RS-485 transceiver. Data isolation is achieved using Novosense integrated capacitive isolation that allows data transmission between the logic side and the Bus side. Both devices are safety certified by UL1577 support 5kVRMS insulation withstand voltages. 4.1. DATA RATE The data rate of NSi83085 is 500kbps. The device is slew limited to reduce EMI and reflections with improperly terminated transmission line. The data rate of NSi83086 is up to 16Mbps. 4.2. TRUE FAIL-SAFE RECEIVER INPUTS The devices feature fail-safe circuitry, which guarantees a logic-high receiver output when the receiver inputs are open or shorted. The receiver threshold is fixed between -50mV and -200mV, which meets EIA/TIA-485 standard. If the differential input voltage (VA-VB) is greater than or equal to -50mV, receiver output R is logic high. In the case of a terminated bus with all transmitters disabled, the differential input voltage is pulled to zero by the termination resistors. Due to the receiver threshold, the receiver output R is logic high. 4.3. TRUTH TABLES Table 4.1 Driver Function Table VDD1 status VDD2 status Input Enable Input (D) (DE) Outputs1 A/Y B/Z PU PU H H H L PU PU L H L H PU PU X L Z Z PU PU X OPEN Z Z PU PU OPEN H H L PD PU X X Z Z PU PD X X Z Z PD PD X X Z Z PD= Powered down; PU= Powered up; H= Logic High; L= Logic Low; X= Irrelevant; Z= High Impedance; Driver output pins are Y and Z for NSi83086, A and B for NSi83085; 1 Table 4.2 Reciever Function Table1 VDD1 status VDD2 status Differential Input Enable Input Output (VA-VB) (/RE) (R) L/Open H PU ≥-50mV L/Open L PU PU ≤-200mV Open/Short L/Open H PU PU X H Z PU PU Idle L H PD PU X X Z PU PU PU Copyright © 2019, NOVOSENSE Page 13 NSi83085/NSi83086 1 PU PD X X H PD PD X X Z PD= Powered down; PU= Powered up; H= Logic High; L= Logic Low; X= Irrelevant; Z= High Impedance. 4.4. THERMAL SHUTDOWN The device is protected from over temperature damage by integrated thermal shutdown circuitry. When the junction temperature (TJ) exceeds +165°C (typ), the driver outputs go high-impedance. The device resumes normal operation when TJ falls below +145°C (typ). 5.0 APPLICATION NOTE 5.1. 256 TRANSCEIVERS ON THE BUS The devices have a 1/8-unit-load receiver input impedance (96kΩ) that allows up to 256 transceivers on the bus. Connect any combination of these devices, and/or other RS-485 devices, for a maximum of 32 unit-loads to the line. 5.2. ESD PROTECTION ESD protection structures are enhanced on all pins to protect against electrostatic discharge encountered during handing and assembly. The Bus pins have extra protection against static electricity to both the logic side (VDD1 side) and bus side (VDD2 side). ESD protection can be tested in various ways. Below is the ESD spec of the devices. Bus pins:  ± 8kV HBM.  ±16kV using the Contact Discharge method specified in IEC 61000-4-2 Other pins except bus pins:  ±6kV HBM.  ±7kV using the Contact Discharge method specified in IEC 61000-4-2 5.3. LAYOUT CONSIDERATIONS The NSi83085/NSi83086 requires a 0.1 µF bypass capacitor between VDD1 and GND1, 10uF bypass capacitor between VDD2 and GND2. The capacitor should be placed as close as possible to the package. To eliminate line reflections, each cable end is terminated with a resistor, whose value matches the characteristic impedance of the cable. It’s good practice to have the bus connectors and termination resistor as close as possible to the A and B, Y and Z pins. 5.4. TYPICAL APPLICATION Figure 5.1 NSi83085 typical application circuit Copyright © 2019, NOVOSENSE Page 14 NSi83085/NSi83086 Figure 5.2 Typical isolated Half-Duplex RS-485 application Figure 5.3 NSi83086 typical application circuit Figure 5.4 Typical isolated Full-Duplex RS-485 application Copyright © 2019, NOVOSENSE Page 15 NSi83085/NSi83086 6.0 PACKAGE INFORMATION Figure 6.1 NSi83085 Package Figure 6.2 NSi83086 Package Figure 6.3 SOIC16 Package Shape and Dimension Copyright © 2019, NOVOSENSE Page 16 NSi83085/NSi83086 Dimensions shown in millimeters and (inches) Table6.1 NSi83085 Pin Configuration and Description NSi83085 PIN NO. SYMBOL FUNCTION 1 VDD1 Power Supply for Isolator Side 1 2 GND1 Ground 1, the ground reference for Isolator Side 1 3 R Receive output 4 /RE Receive enable input. This is an active low input. 5 DE Driver enable input. This is an active high input 6 D Driver transmit data input. 7 GND1 Ground 1, the ground reference for Isolator Side 1 8 GND1 Ground 1, the ground reference for Isolator Side 1 9 GND2 Ground 2, the ground reference for Isolator Side 2 10 GND2 Ground 2, the ground reference for Isolator Side 2 11 NC No Connection. 12 A Noninverting Driver Output/Receiver Input. When the driver is disabled, or when VDD1 or VDD2 is powered down, Pin A is put into a high impedance state to avoid overloading the bus. 13 B Inverting Driver Output/Receiver Input. When the driver is disabled, or when VDD1 or VDD2 is powered down, Pin B is put into a high impedance state to avoid overloading the bus. 14 NC No Connection. 15 GND2 Ground 2, the ground reference for Isolator Side 2 16 VDD2 Power Supply for Isolator Side 2 Table6.2 NSi83086 Pin Configuration and Description NSi83086 PIN NO. SYMBOL FUNCTION 1 VDD1 Power Supply for Isolator Side 1 2 GND1 Ground 1, the ground reference for Isolator Side 1 3 R Receive output 4 /RE Receive enable input. This is an active low input. 5 DE Driver enable input. This is an active high input 6 D Driver transmit data input. Copyright © 2019, NOVOSENSE Page 17 NSi83085/NSi83086 7.0 7 GND1 Ground 1, the ground reference for Isolator Side 1 8 GND1 Ground 1, the ground reference for Isolator Side 1 9 GND2 Ground 2, the ground reference for Isolator Side 2 10 GND2 Ground 2, the ground reference for Isolator Side 2 11 Y Noninverting Driver Output. When the driver is disabled, or when VDD1 or VDD2 is powered down, Pin Y is put into a high impedance state to avoid overloading the bus. 12 Z Inverting Driver Output. When the driver is disabled, or when VDD1 or VDD2 is powered down, Pin Z is put into a high impedance state to avoid overloading the bus. 13 B Inverting Receiver Input. 14 A Noninverting Receiver Input. 15 GND2 Ground 2, the ground reference for Isolator Side 2 16 VDD2 Power Supply for Isolator Side 2 TAPE AND REEL INFORMATION Copyright © 2019, NOVOSENSE Page 18 NSi83085/NSi83086 Figure 7.1 Tape and Reel Information of WB SOIC16 Copyright © 2019, NOVOSENSE Page 19 NSi83085/NSi83086 8.0 ORDER INFORMATION Part No. Duplex NSi83085 Isolation Rating(kVRMS) 5 Temperature No. of Nodes Package Half Max Data Rate (MHz) 0.5 -40 to 105℃ 256 WB SOIC16 NSi83086 5 Full 16 -40 to 105℃ 256 WB SOIC16 NSi83086H 5 Full 16 WB SOIC16 -40 to 105℃ 256 NOTE: All packages are RoHS-compliant with peak reflow temperatures of 260 °C according to the JEDEC industry standard classifications and peak solder temperatures. 9.0 REVISION HISTORY Revision 1.0 1.2 1.3 1.4 1.5 Description Added NSi83086 spec Changed table 3.1 VDE insulation Characteristics Changed Certification Information Changed operation temperature range, changed supply voltage range,Updated VIORM Spec according to VDE Certification. Copyright © 2019, NOVOSENSE Date 2018/7/15 2018/10/15 2018/12/20 2019/06/17 2020/8/7 Page 20
NSi83086
PDF文档中包含以下信息:
1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压DC/DC转换器,适用于需要高效率和低噪声的应用。
3. 引脚分配:LM5111有8个引脚,包括输入引脚、输出引脚、使能引脚和地引脚。
4. 参数特性:包括输入电压范围、输出电压范围、最大输出电流、静态电流等。
5. 功能详解:LM5111具有内部补偿、软启动功能、可编程开关频率和可调输出电压等特点。
6. 应用信息:适用于便携式设备、电池供电设备、通信设备等。
7. 封装信息:提供多种封装选项,如SOIC、SOT23等。
