TPM2030-3
N-Channel Mosfet
www.sot23.com.tw
Product Summary
Application
RDS(on)=Typ 200mΩ@VGS= 4.5V
RDS(on)=Typ 250mΩ@VGS= 2.5V
Lead free product is acquired
Surface mount package
N-channel switch with low RDS(on)
Operated at low logic level gate drive
ESD protection
Load/Power switch
Interfacing, logic switching
Battery management for ultra protable
electronics
Package and Pin Configuration
Circuit diagram
SOT723
Absolute Maximum Ratings (TA=25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
V
Gate-Source Voltage
VGS
±8
V
Continuous Drain Current @25℃ (note 1)
ID
0.95
A
Pulsed Drain Current @25℃ (tp=10 µs)
IDM
1.5
A
Diode Continuous Forward Current
IS
0.5
A
Power Dissipation @25℃ (note 1)
PD
150
mW
RθJA
820
℃/W
TJ
150
TSTG
-55 ~ +150
Thermal Resistance from Junction to Ambient (note 1)
Maximum Junction Temperature
Storage Temperature
WWW.TECHPUBLIC.COM.TW
TPM2030-3
N-Channel Mosfet
www.sot23.com.tw
Electrical Characteristics ( TA = 25°C unless otherwise noted )
Parameter
Symbol Test Condition
Min Typ
Max Unit
Static Characteristics
Drain-source Breakdown Voltage V(BR)DS
VGS = 0V, ID = 250μA
Drain-to-Source Leakage Current
IDS
VDS = 16V,VGS = 0V
1
µA
Gate-Body Leakage Current
IGS
VGS = ±8V, VDS = 0V
±10
µA
Gate Threshold Voltage (note 2)
VGS(th)
VDS =VGS, ID = 250μA
0.65
1
V
VGS = 4.5V, ID = 0.55A
200
350
mΩ
VGS = 2.5V, ID = 0.50A
250
420
mΩ
VGS = 1.8V, ID = 0.35A
310
480
mΩ
VSD
IS= 0.35A, VGS = 0V
0.9
1.5
V
Total Gate Charge
Qg
VDS = 10V
1.15
nC
Gate-Source Charge
Qgs
ID = 0.55A
0.15
nC
Gate-Drain Charge
Qgd
VGS = 4.5V
0.23
nC
Input capacitance
Ciss
VDS = 10V
50
pF
Output capacitance
Coss
VGS =0V
13
pF
Reverse transfer capacitance
Crss
f =100KHz
8
pF
Turn-on delay time (note 3)
td(on)
VGS= 4.5V
22
nS
Turn-on rise time (note 3)
tr
VDS= 10V
80
nS
Turn-off delay time (note3)
td(off)
ID = 0.55A
700
nS
Turn-off fall time (note 3)
tf
RGEN=6Ω
380
nS
Static Drain-Source On-Resistance
RDS(on)
(note 2)
Body-diode forward voltage
V
Dynamic Characteristics (note 4)
2
TPM2030-3
N-Channel Mosfet
www.sot23.com.tw
Package Outline Drawing
BL
IC
SOT7 23 -
TE
CH
PU
Symbol
Suggested Land Pattern
A
A1
b
b1
c
D
E
E1
e
θ
3
DIMENSIONS
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
0.43
0.50
0.017
0.020
0.00
0.05
0.000
0.002
0.17
0.27
0.007
0.011
0.27
0.37
0.011
0.015
0.08
0.15
0.003
0.006
1.15
1.25
0.045
0.049
1.15
1.25
0.045
0.049
0.75
0.85
0.03
0.033
0.8 typ
0.031 typ
7o REF
7o REF
很抱歉,暂时无法提供与“TPM2030-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.26413
- 800+0.18107
- 3200+0.16335
- 8000+0.13484
- 国内价格
- 20+0.28815
- 200+0.22994
- 600+0.19754
- 2000+0.17820
- 8000+0.14710
- 16000+0.13803
