TPE32C12L01
1-Line Low Capacitance Bi-directional TVS Diode
WWW.SOT23.COM.TW
Features
Package:SOD-323
Ultra low leakage: nA level
UL Flammability Classification Rating 94V-0
Ultra
low leakage: nA leel
www.kxw-esd.com
Low clamping voltage
Protects one power line or data line
Complies with following standards:
www.kxw-esd.com
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
TPE32C12L01
www.kxw-esd.com
www.kxw-esd.com
Moisture Sensitivity: Level 3 per J-STD-020
IC
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
BL
Ordering Information
Part Number
www.kxw-esd.com
Case Material: “Green” Molding Compound.
Notebooks and Handhelds
Portable Instrumentation
Peripherals
PU
Ultra low capacitance: 1.0 pF typical
Qty per Reel
Reel Size
3000
7”
CH
Low operating :12V
TE
Mechanical Characteristics
Dimensions and Pin Configuration
w .kxw-esd.com
TPE32C12L01
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
www.kxw-esd.com
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
www.kxw-esd.com
www.kxw-esd.com
www.kxw-esd.com
Storage Temperature Range
Unit
±30
VESD
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Operating Temperature Range
Value
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
PU
VRWM
BL
Symbol
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
VR
f
IT
IR
VRWM VBR VC V
IR
IT
Parasitic Capacitance
Reverse Voltage
TE
CESD
VC VBR VRWM
CH
IT
I
IPP
IPP
Small Signal Frequency
Parameter
www.kxw-esd.com
Breakdown Voltage
Bi-Directional TVS
Symbol
Test Condition
VRWM
www.kxw-esd.com
VBR
IT = 1mA
Min
Typ
Max Unit
12
V
V
13.3
IR
VRWM = 12V
0.2
µA
www.kxw-esd.com
Clamping Voltagewww.kxw-esd.com
VC
IPP = 1A (8 x 20µs pulse)
19
V
VC
IPP = 7A (8 x 20us pulse)
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
1
Clamping Voltage
pF
TPE32C12L01
WWW.SOT23.COM.TW
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
t - Time ( s)
Power Derating Curve
110
100
CH
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
Fig3.
50
75
100
125
Ambient Temperature –TA (ºC)
150
w w.kxw-esd.com
IC
80
90%
tr = 0.7~1ns
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
30ns
60ns
Time (ns)
TPE32C12L01
WWW.SOT23.COM.TW
Outline Drawing - SOD-323
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
IC
SYM
TE
CH
PU
BL
w w.kxw-esd.com
Land Pattern - SOD-323
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
很抱歉,暂时无法提供与“TPE32C12L01”相匹配的价格&库存,您可以联系我们找货
